[U-Boot] [PATCH v2 1/1] arm64: mvebu: defconfig: enable CONFIG_CMD_NVME
An NVME drive may be installed on the MACCHIATObin board using the PCIe slot or on the Clearfog Pro using mini a PCI-e slot. With the configuration change it becomes usable.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- configs/clearfog_gt_8k_defconfig | 2 ++ configs/mvebu_db_armada8k_defconfig | 2 ++ configs/mvebu_mcbin-88f8040_defconfig | 2 ++ 3 files changed, 6 insertions(+)
diff --git a/configs/clearfog_gt_8k_defconfig b/configs/clearfog_gt_8k_defconfig index 8f766c176be..5f538d6163f 100644 --- a/configs/clearfog_gt_8k_defconfig +++ b/configs/clearfog_gt_8k_defconfig @@ -41,6 +41,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_MISC=y CONFIG_DM_MMC=y +CONFIG_CMD_NVME=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_XENON=y CONFIG_SPI_FLASH=y @@ -50,6 +51,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y +CONFIG_NVME=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_PCIE_DW_MVEBU=y diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig index bb29d2574d2..7b4e7152683 100644 --- a/configs/mvebu_db_armada8k_defconfig +++ b/configs/mvebu_db_armada8k_defconfig @@ -20,6 +20,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NVME=y CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y @@ -47,6 +48,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_MVPP2=y +CONFIG_NVME=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_PCIE_DW_MVEBU=y diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig index 9df4c51c6f1..882169be2ce 100644 --- a/configs/mvebu_mcbin-88f8040_defconfig +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -20,6 +20,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_NVME=y CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y @@ -51,6 +52,7 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_MVPP2=y +CONFIG_NVME=y CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_PCIE_DW_MVEBU=y
Please add a revision history next time (not necessary to resend).
Thanks, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
Stefan Roese
