[PATCH] usb: ehci-mx6: Add i.MX95 support
i.MX95 uses the same USB IP as i.MX8MM. It can then reuse the ehci-mx6 driver.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Alice Guo alice.guo@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Mathieu Othacehe othacehe@gnu.org Cc: Mattijs Korpershoek mkorpershoek@baylibre.com Cc: Peng Fan peng.fan@nxp.com Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- drivers/usb/host/Kconfig | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 24786a2bc91..a656265890e 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -217,14 +217,14 @@ config USB_EHCI_MX6 Enables support for the on-chip EHCI controller on i.MX6 SoCs.
config USB_EHCI_MX7 - bool "Support for i.MX7 on-chip EHCI USB controller" - depends on ARCH_MX7 || IMX8M || IMX93 + bool "Support for i.MX7/i.MX8M/i.MX9 on-chip EHCI USB controller" + depends on ARCH_MX7 || IMX8M || IMX93 || IMX95 select EHCI_HCD_INIT_AFTER_RESET if ARCH_MX7 - select PHY if IMX8M || IMX93 - select NOP_PHY if IMX8M || IMX93 + select PHY if IMX8M || IMX93 || IMX95 + select NOP_PHY if IMX8M || IMX93 || IMX95 default y ---help--- - Enables support for the on-chip EHCI controller on i.MX7 SoCs. + Enables support for the on-chip EHCI controller on i.MX7/i.MX8M/i.MX9 SoCs.
config USB_EHCI_MXS bool "Support for i.MX23/i.MX28 EHCI USB controller"
s/ehci-mx6/ehci-mx7
Reviewed-by: Fabio Estevam festevam@gmail.com
s/ehci-mx6/ehci-mx7
The driver is still called ehci-mx6.c , the Kconfig symbol contains MX7 in it, but we still use the ehci-mx6.c driver .
You are right, I am sorry for the confusion.
Fabio Estevam
