[PATCH v2 1/2] tools: dtoc: Allow passing optional input directories
An optional list of input directories can be passed to EnsureCompiled() which allows to pass a list of directories where input files can be searched.
Signed-off-by: Paul HENRYS paul.henrys_ext@softathome.com --- Changes for v2: - Use 'None' instead of a list as a default argument for EnsureCompiled()
tools/dtoc/fdt_util.py | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/tools/dtoc/fdt_util.py b/tools/dtoc/fdt_util.py index f1f70568cf..d5ecc4207d 100644 --- a/tools/dtoc/fdt_util.py +++ b/tools/dtoc/fdt_util.py @@ -55,7 +55,7 @@ def fdt_cells_to_cpu(val, cells): out = out << 32 | fdt32_to_cpu(val[1]) return out
-def EnsureCompiled(fname, tmpdir=None, capture_stderr=False): +def EnsureCompiled(fname, tmpdir=None, capture_stderr=False, indir=None): """Compile an fdt .dts source file into a .dtb binary blob if needed.
Args: @@ -63,6 +63,7 @@ def EnsureCompiled(fname, tmpdir=None, capture_stderr=False): left alone tmpdir: Temporary directory for output files, or None to use the tools-module output directory + indir: List of directories where input files can be found
Returns: Filename of resulting .dtb file @@ -79,6 +80,8 @@ def EnsureCompiled(fname, tmpdir=None, capture_stderr=False): dtb_output = tools.get_output_filename('source.dtb')
search_paths = [os.path.join(os.getcwd(), 'include')] + if indir is not None: + search_paths += indir root, _ = os.path.splitext(fname) cc, args = tools.get_target_compile_tool('cc') args += ['-E', '-P', '-x', 'assembler-with-cpp', '-D__ASSEMBLY__']
Input directories can be passed to binman using the '-I' option and those input directories are now also passed to 'dtc' when run by binman.
Signed-off-by: Paul HENRYS paul.henrys_ext@softathome.com --- Changes for v2: - No change
tools/binman/control.py | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/tools/binman/control.py b/tools/binman/control.py index 542c2b4564..e73c598298 100644 --- a/tools/binman/control.py +++ b/tools/binman/control.py @@ -526,7 +526,7 @@ def _RemoveTemplates(parent): if node.name.startswith('template'): node.Delete()
-def PrepareImagesAndDtbs(dtb_fname, select_images, update_fdt, use_expanded): +def PrepareImagesAndDtbs(dtb_fname, select_images, update_fdt, use_expanded, indir): """Prepare the images to be processed and select the device tree
This function: @@ -543,6 +543,7 @@ def PrepareImagesAndDtbs(dtb_fname, select_images, update_fdt, use_expanded): use_expanded: True to use expanded versions of entries, if available. So if 'u-boot' is called for, we use 'u-boot-expanded' instead. This is needed if update_fdt is True (although tests may disable it) + indir: List of directories where input files can be found
Returns: OrderedDict of images: @@ -558,7 +559,9 @@ def PrepareImagesAndDtbs(dtb_fname, select_images, update_fdt, use_expanded): # Get the device tree ready by compiling it and copying the compiled # output into a file in our output directly. Then scan it for use # in binman. - dtb_fname = fdt_util.EnsureCompiled(dtb_fname) + if indir is None: + indir = [] + dtb_fname = fdt_util.EnsureCompiled(dtb_fname, indir=indir) fname = tools.get_output_filename('u-boot.dtb.out') tools.write_file(fname, tools.read_file(dtb_fname)) dtb = fdt.FdtScan(fname) @@ -846,7 +849,7 @@ def Binman(args): state.SetThreads(args.threads)
images = PrepareImagesAndDtbs(dtb_fname, args.image, - args.update_fdt, use_expanded) + args.update_fdt, use_expanded, args.indir)
if args.test_section_timeout: # Set the first image to timeout, used in testThreadTimeout()
On Mon, 25 Nov 2024 at 10:51, Paul HENRYS paul.henrys_ext@softathome.com wrote:
Changes for v2:
- No change
indirs would be a better name, but the comment makes it clear enough
This function:
- if indir is None:
indir = []
- dtb_fname = fdt_util.EnsureCompiled(dtb_fname, indir=indir) fname = tools.get_output_filename('u-boot.dtb.out') tools.write_file(fname, tools.read_file(dtb_fname)) dtb = fdt.FdtScan(fname)
args.update_fdt, use_expanded, args.indir) if args.test_section_timeout: # Set the first image to timeout, used in testThreadTimeout()
-- 2.43.0
Changes for v2:
Args:
- if indir is not None:
root, _ = os.path.splitext(fname) cc, args = tools.get_target_compile_tool('cc') args += ['-E', '-P', '-x', 'assembler-with-cpp', '-D__ASSEMBLY__']search_paths += indir
-- 2.43.0
Paul HENRYS
