[PATCH 1/1] ata: sata_rescan must scan for block devices
A system may have multiple SATA controller. Removing the controller with the lowest sequence number before probing all SATA controllers makes no sense.
In sata_rescan we remove all block devices which are children of SATA controllers. We also have to remove the bootdev devices as they will be created when scanning for block devices.
After probing all SATA controllers we must scan for block devices otherwise we end up without any SATA block device.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- drivers/ata/sata.c | 46 ++++++++++++++++++++++++---------------------- 1 file changed, 24 insertions(+), 22 deletions(-)
diff --git a/drivers/ata/sata.c b/drivers/ata/sata.c index 84437d3d346..2139ae9903e 100644 --- a/drivers/ata/sata.c +++ b/drivers/ata/sata.c @@ -49,38 +49,40 @@ int sata_scan(struct udevice *dev)
int sata_rescan(bool verbose) { + struct uclass *uc; + struct udevice *dev; /* SATA controller */ int ret; - struct udevice *dev;
if (verbose) - printf("Removing devices on SATA bus...\n"); - - blk_unbind_all(UCLASS_AHCI); - - ret = uclass_find_first_device(UCLASS_AHCI, &dev); - if (ret || !dev) { - printf("Cannot find SATA device (err=%d)\n", ret); - return -ENOENT; - } - - ret = device_remove(dev, DM_REMOVE_NORMAL); - if (ret) { - printf("Cannot remove SATA device '%s' (err=%d)\n", dev->name, ret); - return -ENOSYS; + printf("scanning bus for devices...\n"); + + ret = uclass_get(UCLASS_AHCI, &uc); + if (ret) + return ret; + + /* Remove all children of SATA devices (blk and bootdev) */ + uclass_foreach_dev(dev, uc) { + log_debug("unbind %s\n", dev->name); + ret = device_chld_remove(dev, NULL, DM_REMOVE_NORMAL); + if (!ret) + ret = device_chld_unbind(dev, NULL); + if (ret) { + if (verbose) + printf("unable to unbind devices (%dE)\n", ret); + return log_msg_ret("unb", ret); + } }
if (verbose) printf("Rescanning SATA bus for devices...\n");
- ret = uclass_probe_all(UCLASS_AHCI); - - if (ret == -ENODEV) { - if (verbose) - printf("No SATA block device found\n"); - return 0; + uclass_foreach_dev(dev, uc) { + ret = sata_scan(dev); + if (ret) + return ret; }
- return ret; + return 0; }
static unsigned long sata_bread(struct udevice *dev, lbaint_t start,
