[U-Boot] [PATCH 01/07] db410c: configs: increase gunzip buffer size for the kernel
From: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org
the kernel fails to boot when it goes over the limit.
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- include/configs/dragonboard410c.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index d2447b2..3c5bb8a 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -23,7 +23,7 @@ #define CONFIG_SYS_TEXT_BASE 0x80080000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fff0) #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x80000) -#define CONFIG_SYS_BOOTM_LEN 0x1000000 /* 16MB max kernel size */ +#define CONFIG_SYS_BOOTM_LEN SZ_64M
/* UART */
The firmware that runs before u-boot modifies u-boot's device tree adding the local-mac-address and local-bd-address properties for the compatibles "qcom,wcnss-bt" and "qcom,wcnss-wlan".
This commit reads that firmware, retrieves the properties and fixups the device tree that is passed to the kernel before booting.
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- arch/arm/dts/dragonboard410c.dts | 10 +++++ board/qualcomm/dragonboard410c/Makefile | 1 + board/qualcomm/dragonboard410c/dragonboard410c.c | 49 +++++++++++++++++++++--- board/qualcomm/dragonboard410c/lowlevel_init.S | 28 ++++++++++++++ configs/dragonboard410c_defconfig | 3 ++ 5 files changed, 85 insertions(+), 6 deletions(-) create mode 100644 board/qualcomm/dragonboard410c/lowlevel_init.S
diff --git a/arch/arm/dts/dragonboard410c.dts b/arch/arm/dts/dragonboard410c.dts index 7746622..25aeac4 100644 --- a/arch/arm/dts/dragonboard410c.dts +++ b/arch/arm/dts/dragonboard410c.dts @@ -86,6 +86,16 @@ clock-frequency = <200000000>; };
+ wcnss { + bt { + compatible="qcom,wcnss-bt"; + }; + + wifi { + compatible="qcom,wcnss-wlan"; + }; + }; + spmi@200f000 { compatible = "qcom,spmi-pmic-arb"; reg = <0x200f800 0x200 0x2400000 0x400000 0x2c00000 0x400000>; diff --git a/board/qualcomm/dragonboard410c/Makefile b/board/qualcomm/dragonboard410c/Makefile index cd67808..5082383 100644 --- a/board/qualcomm/dragonboard410c/Makefile +++ b/board/qualcomm/dragonboard410c/Makefile @@ -5,4 +5,5 @@ #
obj-y := dragonboard410c.o +obj-y += lowlevel_init.o extra-y += head.o diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 848e278..99fc91b 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -10,9 +10,16 @@ #include <dm.h> #include <usb.h> #include <asm/gpio.h> +#include <fdt_support.h>
DECLARE_GLOBAL_DATA_PTR;
+/* pointer to the device tree ammended by the firmware */ +extern const void *fw_dtb; + +static char wlan_mac[ARP_HLEN]; +static char bt_mac[ARP_HLEN]; + int dram_init(void) { gd->ram_size = PHYS_SDRAM_1_SIZE; @@ -27,7 +34,6 @@ int dram_init_banksize(void) return 0; }
- int board_prepare_usb(enum usb_init_type type) { static struct udevice *pmic_gpio; @@ -96,11 +102,6 @@ int board_prepare_usb(enum usb_init_type type) return 0; }
-int board_init(void) -{ - return 0; -} - /* Check for vol- button - if pressed - stop autoboot */ int misc_init_r(void) { @@ -134,3 +135,39 @@ int misc_init_r(void)
return 0; } + +int board_init(void) +{ + int offset, len; + const char *mac; + + /* take a copy of the firmware information (the user could unknownly + overwrite that DDR via tftp or other means) */ + + offset = fdt_node_offset_by_compatible(fw_dtb, -1, "qcom,wcnss-wlan"); + if (offset >= 0) { + mac = fdt_getprop(fw_dtb, offset, "local-mac-address", &len); + if (mac) + memcpy(wlan_mac, mac, ARP_HLEN); + } + + offset = fdt_node_offset_by_compatible(fw_dtb, -1, "qcom,wcnss-bt"); + if (offset >= 0) { + mac = fdt_getprop(fw_dtb, offset, "local-bd-address", &len); + if (mac) + memcpy(bt_mac, mac, ARP_HLEN); + } + + return 0; +} + +int ft_board_setup(void *blob, bd_t *bd) +{ + do_fixup_by_compat(blob, "qcom,wcnss-wlan", "local-mac-address", + wlan_mac, ARP_HLEN, 1); + + do_fixup_by_compat(blob, "qcom,wcnss-bt", "local-bd-address", + bt_mac, ARP_HLEN, 1); + + return 0; +} diff --git a/board/qualcomm/dragonboard410c/lowlevel_init.S b/board/qualcomm/dragonboard410c/lowlevel_init.S new file mode 100644 index 0000000..15b2d0c --- /dev/null +++ b/board/qualcomm/dragonboard410c/lowlevel_init.S @@ -0,0 +1,28 @@ +/* + * (C) Copyright 2016 + * Cédric Schieli cschieli@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> + +.align 8 +.global fw_dtb +fw_dtb: + .dword 0x0 + +/* + * Routine: save_boot_params (called after reset from start.S) + * Description: save ATAG/FDT address provided by the firmware at boot time + */ + +.global save_boot_params +save_boot_params: + + /* The firmware provided ATAG/FDT address can be found in r2/x0 */ + adr x8, fw_dtb + str x0, [x8] + + /* Returns */ + b save_boot_params_ret diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index b71bff7..cfe9be9 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -44,3 +44,6 @@ CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_OF_BOARD_SETUP=y
this should be the norm for armv8 platforms.
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- arch/arm/dts/dragonboard410c.dts | 5 --- board/qualcomm/dragonboard410c/dragonboard410c.c | 5 +++ configs/dragonboard410c_defconfig | 2 +- drivers/sysreset/Makefile | 2 -- drivers/sysreset/sysreset_snapdragon.c | 40 ------------------------ 5 files changed, 6 insertions(+), 48 deletions(-) delete mode 100644 drivers/sysreset/sysreset_snapdragon.c
diff --git a/arch/arm/dts/dragonboard410c.dts b/arch/arm/dts/dragonboard410c.dts index 25aeac4..b67e588 100644 --- a/arch/arm/dts/dragonboard410c.dts +++ b/arch/arm/dts/dragonboard410c.dts @@ -48,11 +48,6 @@ clock = <&clkc 4>; };
- restart@4ab000 { - compatible = "qcom,pshold"; - reg = <0x4ab000 0x4>; - }; - soc_gpios: pinctrl@1000000 { compatible = "qcom,apq8016-pinctrl"; reg = <0x1000000 0x300000>; diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 99fc91b..8ef4338 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -171,3 +171,8 @@ int ft_board_setup(void *blob, bd_t *bd)
return 0; } + +void reset_cpu(ulong addr) +{ + psci_system_reset(); +} diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index cfe9be9..de923ad 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -30,7 +30,6 @@ CONFIG_DM_PMIC=y CONFIG_PMIC_PM8916=y CONFIG_MSM_SERIAL=y CONFIG_SPMI_MSM=y -CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y @@ -47,3 +46,4 @@ CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_BOARD_SETUP=y +CONFIG_PSCI_RESET=y diff --git a/drivers/sysreset/Makefile b/drivers/sysreset/Makefile index 2e9598e..000c288 100644 --- a/drivers/sysreset/Makefile +++ b/drivers/sysreset/Makefile @@ -8,10 +8,8 @@ obj-$(CONFIG_SYSRESET) += sysreset-uclass.o obj-$(CONFIG_SYSRESET_PSCI) += sysreset_psci.o obj-$(CONFIG_SYSRESET_SYSCON) += sysreset_syscon.o obj-$(CONFIG_SYSRESET_WATCHDOG) += sysreset_watchdog.o - obj-$(CONFIG_ARCH_ROCKCHIP) += sysreset_rockchip.o obj-$(CONFIG_SANDBOX) += sysreset_sandbox.o -obj-$(CONFIG_ARCH_SNAPDRAGON) += sysreset_snapdragon.o obj-$(CONFIG_ARCH_STI) += sysreset_sti.o obj-$(CONFIG_TARGET_XTFPGA) += sysreset_xtfpga.o obj-$(CONFIG_ARCH_ASPEED) += sysreset_ast.o diff --git a/drivers/sysreset/sysreset_snapdragon.c b/drivers/sysreset/sysreset_snapdragon.c deleted file mode 100644 index 9869813..0000000 --- a/drivers/sysreset/sysreset_snapdragon.c +++ /dev/null @@ -1,40 +0,0 @@ -/* - * Qualcomm APQ8016 reset controller driver - * - * (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <dm.h> -#include <errno.h> -#include <sysreset.h> -#include <asm/io.h> - -DECLARE_GLOBAL_DATA_PTR; - -static int msm_sysreset_request(struct udevice *dev, enum sysreset_t type) -{ - phys_addr_t addr = devfdt_get_addr(dev); - if (!addr) - return -EINVAL; - writel(0, addr); - return -EINPROGRESS; -} - -static struct sysreset_ops msm_sysreset_ops = { - .request = msm_sysreset_request, -}; - -static const struct udevice_id msm_sysreset_ids[] = { - { .compatible = "qcom,pshold" }, - { } -}; - -U_BOOT_DRIVER(msm_reset) = { - .name = "msm_sysreset", - .id = UCLASS_SYSRESET, - .of_match = msm_sysreset_ids, - .ops = &msm_sysreset_ops, -};
Hi Jorge,
restart@4ab000 {
return 0; }
- psci_system_reset();
I think you don't need to implement this boilerplate reset_cpu() function if you just enable CONFIG_SYSRESET_PSCI. At least that works for qemu_arm.
Similar to CONFIG_OF_BOARD, but in this case the fdt is still built by u-boot build. This allows the board to patch the fdt, etc.
In the specific case of dragonboard 410c, we pass the u-boot generated fdt to the previous stage of bootloader (by embedding it in the u-boot.img that is loaded by lk/aboot), which patches the fdt and passes it back to u-boot.
Signed-off-by: Rob Clark robdclark@gmail.com --- include/fdtdec.h | 3 ++- lib/fdtdec.c | 35 +++++++++++++++++++++++------------ 2 files changed, 25 insertions(+), 13 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index 0fb3e07..4afb9ac 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -990,7 +990,8 @@ int fdtdec_setup(void);
/** * Board-specific FDT initialization. Returns the address to a device tree blob. - * Called when CONFIG_OF_BOARD is defined. + * Called when CONFIG_OF_BOARD is defined, or if CONFIG_OF_SEPARATE is defined + * and the board implements it. */ void *board_fdt_blob_setup(void);
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 30ec6b9..cc3dfd6 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1272,6 +1272,28 @@ static int uncompress_blob(const void *src, ulong sz_src, void **dstp) # endif #endif
+#if CONFIG_IS_ENABLED(OF_SEPARATE) +/* + * For CONFIG_OF_SEPARATE, the board may optionally implement this to + * provide and/or fixup the fdt. + */ +__weak void *board_fdt_blob_setup(void) +{ + void *fdt_blob = NULL; +#ifdef CONFIG_SPL_BUILD + /* FDT is at end of BSS unless it is in a different memory region */ + if (IS_ENABLED(CONFIG_SPL_SEPARATE_BSS)) + fdt_blob = (ulong *)&_image_binary_end; + else + fdt_blob = (ulong *)&__bss_end; +#else + /* FDT is at end of image */ + fdt_blob = (ulong *)&_end; +#endif + return fdt_blob; +} +#endif + int fdtdec_setup(void) { #if CONFIG_IS_ENABLED(OF_CONTROL) @@ -1285,18 +1307,7 @@ int fdtdec_setup(void) # else gd->fdt_blob = __dtb_dt_begin; # endif -# elif defined CONFIG_OF_SEPARATE -# ifdef CONFIG_SPL_BUILD - /* FDT is at end of BSS unless it is in a different memory region */ - if (IS_ENABLED(CONFIG_SPL_SEPARATE_BSS)) - gd->fdt_blob = (ulong *)&_image_binary_end; - else - gd->fdt_blob = (ulong *)&__bss_end; -# else - /* FDT is at end of image */ - gd->fdt_blob = (ulong *)&_end; -# endif -# elif defined(CONFIG_OF_BOARD) +# elif defined(CONFIG_OF_BOARD) || defined (CONFIG_OF_SEPARATE) /* Allow the board to override the fdt address. */ gd->fdt_blob = board_fdt_blob_setup(); # elif defined(CONFIG_OF_HOSTFILE)
We dont need to keep copies of the properties that we are going to fixup since we will be using the dtb provided by the firmware.
Signed-off-by: Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org --- board/qualcomm/dragonboard410c/dragonboard410c.c | 71 ++++++++++++++---------- configs/dragonboard410c_defconfig | 1 + 2 files changed, 44 insertions(+), 28 deletions(-)
diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 8ef4338..236160a 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -15,14 +15,22 @@ DECLARE_GLOBAL_DATA_PTR;
/* pointer to the device tree ammended by the firmware */ -extern const void *fw_dtb; +extern void *fw_dtb;
-static char wlan_mac[ARP_HLEN]; -static char bt_mac[ARP_HLEN]; +void *board_fdt_blob_setup(void) +{ + if (fdt_magic(fw_dtb) != FDT_MAGIC) { + printf("Firmware provided invalid dtb!\n"); + return NULL; + } + + return fw_dtb; +}
int dram_init(void) { gd->ram_size = PHYS_SDRAM_1_SIZE; + return 0; }
@@ -138,36 +146,43 @@ int misc_init_r(void)
int board_init(void) { - int offset, len; - const char *mac; - - /* take a copy of the firmware information (the user could unknownly - overwrite that DDR via tftp or other means) */ - - offset = fdt_node_offset_by_compatible(fw_dtb, -1, "qcom,wcnss-wlan"); - if (offset >= 0) { - mac = fdt_getprop(fw_dtb, offset, "local-mac-address", &len); - if (mac) - memcpy(wlan_mac, mac, ARP_HLEN); - } - - offset = fdt_node_offset_by_compatible(fw_dtb, -1, "qcom,wcnss-bt"); - if (offset >= 0) { - mac = fdt_getprop(fw_dtb, offset, "local-bd-address", &len); - if (mac) - memcpy(bt_mac, mac, ARP_HLEN); - } - return 0; }
int ft_board_setup(void *blob, bd_t *bd) { - do_fixup_by_compat(blob, "qcom,wcnss-wlan", "local-mac-address", - wlan_mac, ARP_HLEN, 1); - - do_fixup_by_compat(blob, "qcom,wcnss-bt", "local-bd-address", - bt_mac, ARP_HLEN, 1); + int offset, len, i; + const char *mac; + struct { + const char *compatible; + const char *property; + } fix[] = { + [0] = { + /* update the kernel's dtb with wlan mac */ + .compatible = "qcom,wcnss-wlan", + .property = "local-mac-address", + }, + [1] = { + /* update the kernel's dtb with bt mac */ + .compatible = "qcom,wcnss-bt", + .property = "local-bd-address", + }, + }; + + for ( i = 0; i < sizeof(fix)/sizeof(fix[0]); i++) { + + offset = fdt_node_offset_by_compatible(gd->fdt_blob, -1, + fix[i].compatible); + if (offset < 0) + continue; + + mac = fdt_getprop(gd->fdt_blob, offset, fix[i].property, &len); + if (mac) + do_fixup_by_compat(blob, + fix[i].compatible, + fix[i].property, + mac, ARP_HLEN, 1); + }
return 0; } diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index de923ad..4389f52 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -47,3 +47,4 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_BOARD_SETUP=y CONFIG_PSCI_RESET=y +CONFIG_OF_SEPARATE=y
If lk lights up display and populates simple-framebuffer node, it will also setup a reserved-memory node (needed by simplefb on linux). But it isn't clever enough to cope when the reserved-memory node is not present.
Signed-off-by: Rob Clark robdclark@gmail.com --- arch/arm/dts/dragonboard410c.dts | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/dragonboard410c.dts b/arch/arm/dts/dragonboard410c.dts index b67e588..5ccfe7f 100644 --- a/arch/arm/dts/dragonboard410c.dts +++ b/arch/arm/dts/dragonboard410c.dts @@ -23,11 +23,16 @@ reg = <0 0x80000000 0 0x3da00000>; };
+ reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + }; + chosen { stdout-path = "/soc/serial@78b0000"; };
- soc { #address-cells = <0x1>; #size-cells = <0x1>;
Signed-off-by: Rob Clark robdclark@gmail.com --- include/configs/dragonboard410c.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index 3c5bb8a..530d667 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -92,7 +92,7 @@ REFLASH(dragonboard/u-boot.img, 8)\ "initrd_high=0xffffffffffffffff\0" \ "linux_image=Image\0" \ "kernel_addr_r=0x81000000\0"\ - "fdtfile=apq8016-sbc.dtb\0" \ + "fdtfile=qcom/apq8016-sbc.dtb\0" \ "fdt_addr_r=0x83000000\0"\ "ramdisk_addr_r=0x84000000\0"\ "scriptaddr=0x90000000\0"\
Jorge Ramirez-Ortiz
Tuomas Tynkkynen
