[PATCH 0/8] Support 64-bit U-Boot for Slim Bootloader
This patchset will build 64-bit U-Boot as a Slim Bootloader payload and introduce a new X86_RUN_64BIT_ONLY to build pure 64-bit U-Boot binary without SPL. In addition, this supports 64-bit kernel booting from 64-bit U-Boot.
Aiden Park (8): x86: Add a new X86_RUN_64BIT_ONLY to Kconfig x86: start64: Add a hook at 64-bit entry x86: start64: Support HOB in 64-bit U-Boot x86: slimbootloader: Support 64-bit operation configs: slimbootloader: Add x86_64 slimbootloader config x86: Fix 64-bit compile warning x86: enable 64-bit kernel boot from 64-bit U-Boot doc: slimbootloader: Update 64-bit build instruction
arch/x86/Kconfig | 8 ++++++ arch/x86/cpu/slimbootloader/Makefile | 9 ++++-- arch/x86/cpu/slimbootloader/entry64.S | 14 ++++++++++ arch/x86/cpu/slimbootloader/slimbootloader.c | 17 ++++++++++-- arch/x86/cpu/start64.S | 10 +++++++ arch/x86/cpu/x86_64/Makefile | 2 +- arch/x86/cpu/x86_64/call64.S | 21 ++++++++++++++ arch/x86/cpu/x86_64/cpu.c | 10 +++++++ arch/x86/include/asm/bootparam.h | 10 ++++++- arch/x86/include/asm/zimage.h | 2 +- arch/x86/lib/bootm.c | 10 +++++-- arch/x86/lib/zimage.c | 24 ++++++++++------ cmd/x86/hob.c | 8 +++--- configs/slimbootloader-x86_64_defconfig | 24 ++++++++++++++++ doc/board/intel/slimbootloader.rst | 29 ++++++++++++++++++++ 15 files changed, 176 insertions(+), 22 deletions(-) create mode 100644 arch/x86/cpu/slimbootloader/entry64.S create mode 100644 arch/x86/cpu/x86_64/call64.S create mode 100644 configs/slimbootloader-x86_64_defconfig
This will build U-Boot as a pure 64-bit binary with no SPL. It can be used with a pre-stage boot firmware which has already done 16-bit, 32-bit and 64-bit init.
Signed-off-by: Aiden Park aiden.park@intel.com --- arch/x86/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index c8eae24c07..89add17e69 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -40,6 +40,14 @@ config X86_RUN_64BIT runs through the 16-bit and 32-bit init, then switches to 64-bit mode and jumps to U-Boot proper.
+config X86_RUN_64BIT_ONLY + bool "64-bit only" + select X86_64 + help + Build U-Boot as a pure 64-bit binary with no 32-bit SPL. This can + be used with a pre-stage boot firmware which has already done + 16-bit, 32-bit and 64-bit init. + endchoice
config X86_64
Hi Aiden,
Perhaps X86_RUN_64BIT_NO_SPL? Bin might hav a better idea.
bool "64-bit only"
select X86_64
help
endchoice
config X86_64
2.20.1
Hi Simon,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Sunday, April 26, 2020 1:16 PM To: Park, Aiden aiden.park@intel.com Cc: Bin Meng bmeng.cn@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 1/8] x86: Add a new X86_RUN_64BIT_ONLY to Kconfig
Hi Aiden,
I considered X64_RUN_64BIT_NO_SPL, X64_RUN_64BIT_PURE and X64_RUN_64BIT_NATIVE. Hi Bin, can you recommend better naming?
bool "64-bit only"
select X86_64
help
endchoice
config X86_64
2.20.1
Best Regards, Aiden
Hi Aiden,
On Wed, Apr 29, 2020 at 1:44 PM Park, Aiden aiden.park@intel.com wrote:
Hi Simon,
Hi Aiden,
Cannot figure out a better name :) Let's use it.
Regards, Bin
Hi Bin,
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: Thursday, April 30, 2020 2:14 AM To: Park, Aiden aiden.park@intel.com Cc: Simon Glass sjg@chromium.org; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 1/8] x86: Add a new X86_RUN_64BIT_ONLY to Kconfig
Hi Aiden,
Hi Simon,
Hi Aiden,
Thanks Bin. Let me use X86_RUN_64BIT_ONLY for now.
Hi Simon, is this naming okay for you?
Regards, Bin
Best Regards, Aiden
Hi Aiden,
On Fri, 1 May 2020 at 12:36, Park, Aiden aiden.park@intel.com wrote:
Hi Bin,
Hi Aiden,
Hi Simon,
Hi Aiden,
Yes that's fine thanks.
This will allow a board or cpu to do its specific initialization at 64-bit entry if U-Boot is a pure 64-bit binary.
Signed-off-by: Aiden Park aiden.park@intel.com --- arch/x86/cpu/start64.S | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/x86/cpu/start64.S b/arch/x86/cpu/start64.S index 7be834788b..b8ac5aab57 100644 --- a/arch/x86/cpu/start64.S +++ b/arch/x86/cpu/start64.S @@ -13,6 +13,11 @@ .globl _start .type _start, @function _start: +#if defined(CONFIG_X86_RUN_64BIT_ONLY) + jmp init_64bit_entry +.globl init_64bit_entry_ret +init_64bit_entry_ret: +#endif /* Set up memory using the existing stack */ mov %rsp, %rdi call board_init_f_alloc_reserve
Hi Aiden,
Would it be safe to do this always? Is that a standard register to have the HOB pointer be in? If so, we could always store it. We could also make sure that U-Boot passes it on too.
Note that U-Boot has a struct arch_spl_handoff which is how it passes the HOB through.
-- 2.20.1
Hi Simon,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Sunday, April 26, 2020 1:16 PM To: Park, Aiden aiden.park@intel.com Cc: Bin Meng bmeng.cn@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 2/8] x86: start64: Add a hook at 64-bit entry
Hi Aiden,
Would it be safe to do this always? Is that a standard register to have the HOB pointer be in? If so, we could always store it. We could also make sure that U- Boot passes it on too.
Unfortunately, it's not. This is to cover pre-stage firmware's calling convention. The calling convention of 64-bit Slim Bootloader is that HOB address is in rcx.
Thanks for your information. Let me try to leverage arch_spl_handoff to pass HOB.
-- 2.20.1
Best Regards, Aiden
This will allow 64-bit U-Boot to use HOB.
diff --git a/arch/x86/cpu/start64.S b/arch/x86/cpu/start64.S index b8ac5aab57..7faf4f6f13 100644 --- a/arch/x86/cpu/start64.S +++ b/arch/x86/cpu/start64.S @@ -25,6 +25,11 @@ init_64bit_entry_ret:
call board_init_f_init_reserve
+#if defined(CONFIG_X86_RUN_64BIT_ONLY) && defined(CONFIG_USE_HOB) + mov %r10, %rdi + call set_hob_list +#endif + xor %rdi, %rdi call board_init_f call board_init_f_r
Hi Aiden,
mov %r10, %rdi
call set_hob_list
Similar question - would it be safe to always do this?
-- 2.20.1
Hi Simon,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Sunday, April 26, 2020 1:16 PM To: Park, Aiden aiden.park@intel.com Cc: Bin Meng bmeng.cn@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 3/8] x86: start64: Support HOB in 64-bit U-Boot
Hi Aiden,
mov %r10, %rdi
call set_hob_list
You are right. The r10 is a scratch register. The r12-r15 would be correct choice. Instead of this, let me try to leverage arch_spl_handoff.
-- 2.20.1
Best Regards, Aiden
This supports 64-bit U-Boot as a Slim Bootloader payload.
Signed-off-by: Aiden Park aiden.park@intel.com --- arch/x86/cpu/slimbootloader/Makefile | 9 +++++++-- arch/x86/cpu/slimbootloader/entry64.S | 14 ++++++++++++++ arch/x86/cpu/slimbootloader/slimbootloader.c | 17 +++++++++++++++-- 3 files changed, 36 insertions(+), 4 deletions(-) create mode 100644 arch/x86/cpu/slimbootloader/entry64.S
diff --git a/arch/x86/cpu/slimbootloader/Makefile b/arch/x86/cpu/slimbootloader/Makefile index aac9fa3db8..79fa699501 100644 --- a/arch/x86/cpu/slimbootloader/Makefile +++ b/arch/x86/cpu/slimbootloader/Makefile @@ -1,5 +1,10 @@ # SPDX-License-Identifier: GPL-2.0+ # -# Copyright (C) 2019 Intel Corporation <www.intel.com> +# Copyright (C) 2019-2020 Intel Corporation <www.intel.com>
-obj-y += car.o slimbootloader.o sdram.o serial.o +ifeq ($(CONFIG_X86_64),y) +obj-y += entry64.o +else +obj-y += car.o +endif +obj-y += slimbootloader.o sdram.o serial.o diff --git a/arch/x86/cpu/slimbootloader/entry64.S b/arch/x86/cpu/slimbootloader/entry64.S new file mode 100644 index 0000000000..5e101e18a9 --- /dev/null +++ b/arch/x86/cpu/slimbootloader/entry64.S @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Intel Corporation <www.intel.com> + */ + +#include <generated/asm-offsets.h> + +.section .text + +.globl init_64bit_entry +init_64bit_entry: + /* Save hob pointer parameter */ + mov %rcx, %r10 + jmp init_64bit_entry_ret diff --git a/arch/x86/cpu/slimbootloader/slimbootloader.c b/arch/x86/cpu/slimbootloader/slimbootloader.c index 21dcfb2142..7857e4cd8b 100644 --- a/arch/x86/cpu/slimbootloader/slimbootloader.c +++ b/arch/x86/cpu/slimbootloader/slimbootloader.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2019 Intel Corporation <www.intel.com> + * Copyright (C) 2019-2020 Intel Corporation <www.intel.com> */
#include <common.h> @@ -43,11 +43,23 @@ static void tsc_init(void)
int arch_cpu_init(void) { + int ret = 0; + tsc_init();
- return x86_cpu_init_f(); +#if !CONFIG_IS_ENABLED(X86_64) + ret = x86_cpu_init_f(); +#endif + return ret; }
+#if CONFIG_IS_ENABLED(X86_64) +int set_hob_list(void *hob_list) +{ + gd->arch.hob_list = hob_list; + return 0; +} +#else int checkcpu(void) { return 0; @@ -57,3 +69,4 @@ int print_cpuinfo(void) { return default_print_cpuinfo(); } +#endif
Hi Aiden,
- Copyright (C) 2020 Intel Corporation <www.intel.com>
+.section .text
mov %rcx, %r10
- Copyright (C) 2019 Intel Corporation <www.intel.com>
- Copyright (C) 2019-2020 Intel Corporation <www.intel.com>
int ret = 0;
tsc_init();
Can you use if() instead of #if ?
return ret;
It should be safe to define both of these functions so I don't think you need the #ifdef
2.20.1
Hi Simon,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Sunday, April 26, 2020 1:16 PM To: Park, Aiden aiden.park@intel.com Cc: Bin Meng bmeng.cn@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 4/8] x86: slimbootloader: Support 64-bit operation
Hi Aiden,
- Copyright (C) 2020 Intel Corporation <www.intel.com> */
+.section .text
mov %rcx, %r10
int ret = 0;
tsc_init();
I will do it.
return ret;
These are defined in arch/x86/cpu/x86_64/cpu.c already. Is it okay to make them weak reference or can I keep this as it is?
2.20.1
Best Regards, Aiden
Hi Aiden,
On Wed, 29 Apr 2020 at 00:01, Park, Aiden aiden.park@intel.com wrote:
Hi Simon,
Hi Aiden,
+.section .text
mov %rcx, %r10
int ret = 0;
tsc_init();
I will do it.
return ret;
Oh I see. I am not a fan of weak functions so perhaps we should keep them as is.
2.20.1
Hi Simon,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Wednesday, April 29, 2020 11:04 AM To: Park, Aiden aiden.park@intel.com Cc: Bin Meng bmeng.cn@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 4/8] x86: slimbootloader: Support 64-bit operation
Hi Aiden,
Hi Simon,
Hi Aiden,
+.section .text
mov %rcx, %r10
int ret = 0;
tsc_init();
I will do it.
return ret;
I agree with you about the weak functions. Let me keep this as is. Thanks.
2.20.1
Best Regards, Aiden
Add slimbootloader-x86_64_defconfig for 64-bit slimbootloader board.
Signed-off-by: Aiden Park aiden.park@intel.com --- configs/slimbootloader-x86_64_defconfig | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+) create mode 100644 configs/slimbootloader-x86_64_defconfig
diff --git a/configs/slimbootloader-x86_64_defconfig b/configs/slimbootloader-x86_64_defconfig new file mode 100644 index 0000000000..f046c30179 --- /dev/null +++ b/configs/slimbootloader-x86_64_defconfig @@ -0,0 +1,24 @@ +CONFIG_X86=y +CONFIG_X86_RUN_64BIT_ONLY=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_VENDOR_INTEL=y +CONFIG_TARGET_SLIMBOOTLOADER=y +# CONFIG_USE_CAR is not set +CONFIG_BOOTSTAGE=y +CONFIG_BOOTSTAGE_REPORT=y +CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_LAST_STAGE_INIT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_EFI_PARTITION=y +CONFIG_DEFAULT_DEVICE_TREE="slimbootloader" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +# CONFIG_PCI_PNP is not set +CONFIG_CONSOLE_SCROLL_LINES=5
Hi Aiden,
How about slimbootloader64?
We always know it is x86.
Hi Simon,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Sunday, April 26, 2020 1:32 PM To: Park, Aiden aiden.park@intel.com Cc: Bin Meng bmeng.cn@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 5/8] configs: slimbootloader: Add x86_64 slimbootloader config
Hi Aiden,
Thanks for your suggestion. I will rename it to slimbootloader64.
Best Regards, Aiden
On Mon, Apr 27, 2020 at 4:32 AM Simon Glass sjg@chromium.org wrote:
Hi Aiden,
Agreed with Simon,
Aiden, please also make sure the defconfig file is written with all options in the correct order. You can do it like this:
$ make slimbootloader64_defconfig $ make savedefconfig $ cp defconfig configs/slimbootloader64_defconfig
Regards, Bin
This is to fix pointer type cast warning in hob command.
Signed-off-by: Aiden Park aiden.park@intel.com --- cmd/x86/hob.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/cmd/x86/hob.c b/cmd/x86/hob.c index 3967a7ca5a..8c2c1ffc63 100644 --- a/cmd/x86/hob.c +++ b/cmd/x86/hob.c @@ -36,14 +36,14 @@ static int do_hob(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
hdr = gd->arch.hob_list;
- printf("HOB list address: 0x%08x\n\n", (unsigned int)hdr); + printf("HOB list address: 0x%p\n\n", hdr);
- printf("# | Address | Type | Len | "); + printf("# | Address | Type | Len | "); printf("%36s\n", "GUID"); - printf("---|----------|-----------|------|-"); + printf("---|------------------|-----------|------|-"); printf("------------------------------------\n"); while (!end_of_hob(hdr)) { - printf("%02x | %08x | ", i, (unsigned int)hdr); + printf("%02x | %p | ", i, hdr); type = hdr->type; if (type == HOB_TYPE_UNUSED) desc = "*Unused*";
Hi Aiden,
That 0x should not be there as hex is assumed in U-Boot.
Do we actually need a 64-bit pointer here, or will the HOB be below 4GB? I'm really not a fan of 16-character addresses in a user command.
-- 2.20.1
Hi Simon,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Sunday, April 26, 2020 12:46 PM To: Park, Aiden aiden.park@intel.com Cc: Bin Meng bmeng.cn@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 6/8] x86: Fix 64-bit compile warning
Hi Aiden,
Thanks. Let me remove the 0x prefix.
Currently, HOB is always below 4GB. This was just in case for 64-bit address space. Let me assume HOB < 4GB for now.
-- 2.20.1
Best Regards, Aiden
Signed-off-by: Aiden Park aiden.park@intel.com --- arch/x86/cpu/x86_64/Makefile | 2 +- arch/x86/cpu/x86_64/call64.S | 21 +++++++++++++++++++++ arch/x86/cpu/x86_64/cpu.c | 10 ++++++++++ arch/x86/include/asm/bootparam.h | 10 +++++++++- arch/x86/include/asm/zimage.h | 2 +- arch/x86/lib/bootm.c | 10 +++++++--- arch/x86/lib/zimage.c | 24 ++++++++++++++++-------- 7 files changed, 65 insertions(+), 14 deletions(-) create mode 100644 arch/x86/cpu/x86_64/call64.S
diff --git a/arch/x86/cpu/x86_64/Makefile b/arch/x86/cpu/x86_64/Makefile index 400f0ffe39..951e503a1f 100644 --- a/arch/x86/cpu/x86_64/Makefile +++ b/arch/x86/cpu/x86_64/Makefile @@ -3,4 +3,4 @@ # Written by Simon Glass sjg@chromium.org #
-obj-y += cpu.o interrupts.o setjmp.o +obj-y += cpu.o interrupts.o setjmp.o call64.o diff --git a/arch/x86/cpu/x86_64/call64.S b/arch/x86/cpu/x86_64/call64.S new file mode 100644 index 0000000000..e2cfe15080 --- /dev/null +++ b/arch/x86/cpu/x86_64/call64.S @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Intel Corporation <www.intel.com> + */ + +.code64 +.globl cpu_call64 +cpu_call64: + /* + * cpu_call64(ulong pgtable, ulong setup_base, ulong target) + * + * rdi - pgtable (unused - already in 64-bit with paging) + * rsi - setup_base + * rdx - target + * + */ + cli + mov %rdx, %rcx + mov %rsi, %rdx + call *%rcx + ret diff --git a/arch/x86/cpu/x86_64/cpu.c b/arch/x86/cpu/x86_64/cpu.c index 90925e46ea..0730c43f1c 100644 --- a/arch/x86/cpu/x86_64/cpu.c +++ b/arch/x86/cpu/x86_64/cpu.c @@ -7,6 +7,7 @@ #include <common.h> #include <cpu_func.h> #include <debug_uart.h> +#include <asm/cpu.h>
/* * Global declaration of gd. @@ -67,3 +68,12 @@ int x86_cpu_reinit_f(void) { return 0; } + +int cpu_jump_to_64bit(ulong setup_base, ulong load_address) +{ + ulong target = load_address + 0x200; + + cpu_call64(0, setup_base, target); + + return -EFAULT; +} diff --git a/arch/x86/include/asm/bootparam.h b/arch/x86/include/asm/bootparam.h index d961dddc9e..73c94a33ec 100644 --- a/arch/x86/include/asm/bootparam.h +++ b/arch/x86/include/asm/bootparam.h @@ -59,7 +59,15 @@ struct setup_header { __u32 initrd_addr_max; __u32 kernel_alignment; __u8 relocatable_kernel; - __u8 _pad2[3]; + __u8 min_alignment; + __u16 xloadflags; +#define XLF_KERNEL_64 BIT(0) +#define XLF_CAN_BE_LOADED_ABOVE_4G BIT(1) +#define XLF_EFI_HANDOVER_32 BIT(2) +#define XLF_EFI_HANDOVER_64 BIT(3) +#define XLF_EFI_KEXEC BIT(4) +#define XLF_5LEVEL BIT(5) +#define XLF_5LEVEL_ENABLED BIT(6) __u32 cmdline_size; __u32 hardware_subarch; __u64 hardware_subarch_data; diff --git a/arch/x86/include/asm/zimage.h b/arch/x86/include/asm/zimage.h index 80e128ccf3..cadeb04168 100644 --- a/arch/x86/include/asm/zimage.h +++ b/arch/x86/include/asm/zimage.h @@ -31,7 +31,7 @@ #define ZIMAGE_LOAD_ADDR 0x10000
struct boot_params *load_zimage(char *image, unsigned long kernel_size, - ulong *load_addressp); + ulong *load_addressp, bool *image_64bit); int setup_zimage(struct boot_params *setup_base, char *cmd_line, int auto_boot, unsigned long initrd_addr, unsigned long initrd_size); void setup_video(struct screen_info *screen_info); diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index 07d8f1f279..ebed9e4605 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -74,6 +74,7 @@ static int boot_prep_linux(bootm_headers_t *images) void *data = NULL; size_t len; int ret; + bool image_64bit;
#ifdef CONFIG_OF_LIBFDT if (images->ft_len) { @@ -116,7 +117,8 @@ static int boot_prep_linux(bootm_headers_t *images) ulong load_address; char *base_ptr;
- base_ptr = (char *)load_zimage(data, len, &load_address); + base_ptr = (char *)load_zimage(data, len, &load_address, + &image_64bit); if (!base_ptr) { puts("## Kernel loading failed ...\n"); goto error; @@ -124,6 +126,10 @@ static int boot_prep_linux(bootm_headers_t *images) images->os.load = load_address; cmd_line_dest = base_ptr + COMMAND_LINE_OFFSET; images->ep = (ulong)base_ptr; +#if CONFIG_IS_ENABLED(X86_64) + if (image_64bit) + images->os.arch = IH_ARCH_X86_64; +#endif } else if (images->ep) { cmd_line_dest = (void *)images->ep + COMMAND_LINE_OFFSET; } else { @@ -164,9 +170,7 @@ int boot_linux_kernel(ulong setup_base, ulong load_address, bool image_64bit) * TODO(sjg@chromium.org): Support booting both 32-bit and * 64-bit kernels from 64-bit U-Boot. */ -#if !CONFIG_IS_ENABLED(X86_64) return cpu_jump_to_64bit(setup_base, load_address); -#endif } else { /* * Set %ebx, %ebp, and %edi to 0, %esi to point to the diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index ffc09630b7..c84e2d39b2 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -129,7 +129,7 @@ static int setup_device_tree(struct setup_header *hdr, const void *fdt_blob) }
struct boot_params *load_zimage(char *image, unsigned long kernel_size, - ulong *load_addressp) + ulong *load_addressp, bool *image_64bit) { struct boot_params *setup_base; int setup_size; @@ -179,6 +179,9 @@ struct boot_params *load_zimage(char *image, unsigned long kernel_size, big_image = (bootproto >= 0x0200) && (hdr->loadflags & BIG_KERNEL_FLAG);
+ /* Determine 64-bit kernel */ + *image_64bit = (hdr->xloadflags & XLF_KERNEL_64) ? true : false; + /* Determine load address */ if (big_image) *load_addressp = BZIMAGE_LOAD_ADDR; @@ -313,12 +316,13 @@ void __setup_pcat_compatibility(void) int do_zboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { struct boot_params *base_ptr; - void *bzImage_addr = NULL; + void *bzimage_addr = NULL; ulong load_address; char *s; - ulong bzImage_size = 0; + ulong bzimage_size = 0; ulong initrd_addr = 0; ulong initrd_size = 0; + bool image_64bit;
disable_interrupts();
@@ -333,11 +337,11 @@ int do_zboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) }
if (s) - bzImage_addr = (void *)simple_strtoul(s, NULL, 16); + bzimage_addr = (void *)simple_strtoul(s, NULL, 16);
if (argc >= 3) { /* argv[2] holds the size of the bzImage */ - bzImage_size = simple_strtoul(argv[2], NULL, 16); + bzimage_size = simple_strtoul(argv[2], NULL, 16); }
if (argc >= 4) @@ -346,8 +350,13 @@ int do_zboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) initrd_size = simple_strtoul(argv[4], NULL, 16);
/* Lets look for */ - base_ptr = load_zimage(bzImage_addr, bzImage_size, &load_address); + base_ptr = load_zimage(bzimage_addr, bzimage_size, &load_address, + &image_64bit); +#if !CONFIG_IS_ENABLED(X86_64) + image_64bit = false; +#endif
+ /* we assume that the kernel is in place */ if (!base_ptr) { puts("## Kernel loading failed ...\n"); return -1; @@ -358,8 +367,7 @@ int do_zboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) return -1; }
- /* we assume that the kernel is in place */ - return boot_linux_kernel((ulong)base_ptr, load_address, false); + return boot_linux_kernel((ulong)base_ptr, load_address, image_64bit); }
U_BOOT_CMD(
Hi Aiden,
* rsi - setup_base
* rdx - target
cli
mov %rdx, %rcx
mov %rsi, %rdx
call *%rcx
ret
- Global declaration of gd.
return -EFAULT;
__u8 _pad2[3];
__u8 min_alignment;
__u16 xloadflags;
Please put a 'p' on the end, so image_64bitp, since it a return value.
bool image_64bit;
if (image_64bit)
if (CONFIG_IS_ENABLED(X86_64) && image_64bit)
if()
image_64bitp
Drop ()
In fact I suspect you can do:
*image_64bit = hdr->xloadflags & XLF_KERNEL_64)
Good change, but really should be in a separate patch.
bool image_64bit; disable_interrupts();
if (s)
bzimage_addr = (void *)simple_strtoul(s, NULL, 16); if (argc >= 3) { /* argv[2] holds the size of the bzImage */
bzimage_size = simple_strtoul(argv[2], NULL, 16); } if (argc >= 4)
/* Lets look for */
&image_64bit);
if()
But why not just set it always?
U_BOOT_CMD(
2.20.1
Hi Simon,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Sunday, April 26, 2020 1:16 PM To: Park, Aiden aiden.park@intel.com Cc: Bin Meng bmeng.cn@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 7/8] x86: enable 64-bit kernel boot from 64-bit U-Boot
Hi Aiden,
* rsi - setup_base
* rdx - target
cli
mov %rdx, %rcx
mov %rsi, %rdx
call *%rcx
ret
+int cpu_jump_to_64bit(ulong setup_base, ulong load_address) {
return -EFAULT;
__u8 _pad2[3];
__u8 min_alignment;
__u16 xloadflags;
- *image_64bit);
Thanks. I will do that.
auto_boot,
bool image_64bit;
*images)
if (image_64bit)
images->os.arch = IH_ARCH_X86_64; #endif } else if (images->ep) { cmd_line_dest = (void *)images->ep + COMMAND_LINE_OFFSET; } else {
if()
I will do that.
- *image_64bit)
image_64bitp
I will do that.
- false;
Drop ()
I will do that.
Let me make a separate patch for this.
char *const argv[])
} if (s)
char *const argv[])
initrd_size = simple_strtoul(argv[4], NULL, 16); /* Lets look for */
&image_64bit); #if
+!CONFIG_IS_ENABLED(X86_64)
if()
This was just to keep original boot flow in zboot to boot 32-bit kernel entry from 32-bit U-Boot. I also agree with you. 32-bit U-Boot is able to boot 64-bit kernel entry with 64-bit paging. Let me remove this.
char *const argv[])
return -1; }
- image_64bit);
U_BOOT_CMD(
2.20.1
Best Regards, Aiden
Add steps to build 64-bit Slim Bootloader and U-Boot.
Signed-off-by: Aiden Park aiden.park@intel.com --- doc/board/intel/slimbootloader.rst | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/doc/board/intel/slimbootloader.rst b/doc/board/intel/slimbootloader.rst index a8c41b1aa7..779ed78ef1 100644 --- a/doc/board/intel/slimbootloader.rst +++ b/doc/board/intel/slimbootloader.rst @@ -145,6 +145,35 @@ Also, the PayloadId needs to be set for APL board.
Use DediProg to flash IFWI. You should reach at U-Boot serial console.
+Build Instruction for 64-bit Slim Bootloader & U-Boot on QEMU target +-------------------------------------------------------------------- + +1. Build 64-bit U-Boot and obtain u-boot-dtb.bin:: + + $ make distclean + $ make slimbootloader-x86_64_defconfig + $ make all + +2. Copy u-boot-dtb.bin to Slim Bootloader:: + + $ mkdir -p <Slim Bootloader Dir>/PayloadPkg/PayloadBins/ + $ cp <U-Boot Dir>/u-boot-dtb.bin <Slim Bootloader Dir>/PayloadPkg/PayloadBins/u-boot-dtb.bin + +3. Update PayloadId with 'U-BT':: + + $ vi Platform/QemuBoardPkg/CfgData/CfgDataExt_Brd1.dlt + -GEN_CFG_DATA.PayloadId | 'AUTO' + +GEN_CFG_DATA.PayloadId | 'U-BT' + +4. Update payload text base:: + + $ vi Platform/QemuBoardPkg/BoardConfig.py + + self.PAYLOAD_LOAD_HIGH = 0 + + self.PAYLOAD_EXE_BASE = 0x00100000 + +5. Build QEMU target:: + + $ python BuildLoader.py build qemu -a x64 -p "OsLoader.efi:LLDR:Lz4;u-boot-dtb.bin:U-BT:Lzma"
Build Instruction to use ELF U-Boot -----------------------------------
Hi Aiden,
For the series:
Tested on qemu: Tested-by: Simon Glass sjg@chromium.org
One little thing that I noticed...your instructions show copying u-boot-dtb.bin into the slimbootloader directory. This is the same as u-boot.bin and I suggest you use that name instead. When I tried to, I got an error.
Regards, SImon
Hi Simon,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Sunday, April 26, 2020 1:16 PM To: Park, Aiden aiden.park@intel.com Cc: Bin Meng bmeng.cn@gmail.com; U-Boot Mailing List <u- boot@lists.denx.de> Subject: Re: [PATCH 0/8] Support 64-bit U-Boot for Slim Bootloader
Hi Aiden,
For the series:
Thanks for your testing. Let me update the instruction with u-boot.bin.
Best Regards, Aiden
Bin Meng
Park, Aiden
