[PATCH 1/1] efi_loader: correctly identify binary name
Only on the sandbox the default EFI binary name (e.g. BOOTX64.EFI) must match the host architecture.
In all other cases we must use the target architecture.
Use #elif where appropriate.
Reported-by: Vagrant Cascadian vagrant@reproducible-builds.org Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- include/efi_default_filename.h | 40 +++++++++++++++++++++------------- 1 file changed, 25 insertions(+), 15 deletions(-)
diff --git a/include/efi_default_filename.h b/include/efi_default_filename.h index 13b9de8754..fc46e386a6 100644 --- a/include/efi_default_filename.h +++ b/include/efi_default_filename.h @@ -14,32 +14,42 @@
#undef BOOTEFI_NAME
+#ifdef CONFIG_SANDBOX + #if HOST_ARCH == HOST_ARCH_X86_64 #define BOOTEFI_NAME "BOOTX64.EFI" -#endif - -#if HOST_ARCH == HOST_ARCH_X86 +#elif HOST_ARCH == HOST_ARCH_X86 #define BOOTEFI_NAME "BOOTIA32.EFI" -#endif - -#if HOST_ARCH == HOST_ARCH_AARCH64 +#elif HOST_ARCH == HOST_ARCH_AARCH64 #define BOOTEFI_NAME "BOOTAA64.EFI" -#endif - -#if HOST_ARCH == HOST_ARCH_ARM +#elif HOST_ARCH == HOST_ARCH_ARM #define BOOTEFI_NAME "BOOTARM.EFI" -#endif - -#if HOST_ARCH == HOST_ARCH_RISCV32 +#elif HOST_ARCH == HOST_ARCH_RISCV32 #define BOOTEFI_NAME "BOOTRISCV32.EFI" +#elif HOST_ARCH == HOST_ARCH_RISCV64 +#define BOOTEFI_NAME "BOOTRISCV64.EFI" +#else +#error Unsupported UEFI architecture #endif
-#if HOST_ARCH == HOST_ARCH_RISCV64 +#else + +#if defined(CONFIG_ARM64) +#define BOOTEFI_NAME "BOOTAA64.EFI" +#elif defined(CONFIG_ARM) +#define BOOTEFI_NAME "BOOTARM.EFI" +#elif defined(CONFIG_X86_64) +#define BOOTEFI_NAME "BOOTX64.EFI" +#elif defined(CONFIG_X86) +#define BOOTEFI_NAME "BOOTIA32.EFI" +#elif defined(CONFIG_ARCH_RV32I) +#define BOOTEFI_NAME "BOOTRISCV32.EFI" +#elif defined(CONFIG_ARCH_RV64I) #define BOOTEFI_NAME "BOOTRISCV64.EFI" +#else +#error Unsupported UEFI architecture #endif
-#ifndef BOOTEFI_NAME -#error Unsupported UEFI architecture #endif
#endif
So most of the new code, particularly else clause of "#ifdef CONFIG_SANDBOX", is the same as the *original* commit in my (or rather Kojima-san's) patch. Please retain the original copyright.
[1] https://lists.denx.de/pipermail/u-boot/2022-April/482711.html
-Takahiro Akashi
#undef BOOTEFI_NAME
#endif
2.36.1
AKASHI Takahiro
