[U-Boot] [PATCH 2/4] EHCI: fix off-by-one error in ehci_submit_root()
USB devices on the 2nd port are not detected and I get the following message:
The request port(1) is not configured
That's with default CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS value of 2. 'req->index' is 1-based, so the comparison in ehci_submit_root() can't be correct.
Signed-off-by: Sergei Shtylyov sshtylyov@mvista.com
--- drivers/usb/host/ehci-hcd.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
Index: u-boot/drivers/usb/host/ehci-hcd.c =================================================================== --- u-boot.orig/drivers/usb/host/ehci-hcd.c +++ u-boot/drivers/usb/host/ehci-hcd.c @@ -536,7 +536,7 @@ ehci_submit_root(struct usb_device *dev, uint32_t reg; uint32_t *status_reg;
- if (le16_to_cpu(req->index) >= CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS) { + if (le16_to_cpu(req->index) > CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS) { printf("The request port(%d) is not configured\n", le16_to_cpu(req->index) - 1); return -1;
2010/2/27 Sergei Shtylyov sshtylyov@ru.mvista.com:
Applied to u-boot-usb Thanks!
Remy
- if (le16_to_cpu(req->index) > CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS) {
printf("The request port(%d) is not configured\n", le16_to_cpu(req->index) - 1); return -1; _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Remy Bohmer
Sergei Shtylyov
