[U-Boot] Please pull u-boot-ti/master
The following changes since commit 6d66073614539d94dabff1f63ebd962840c44b81: Thomas Herzmann (1): arm/km: portl2 environment address update to P1B
git://git.denx.de/u-boot-ti.git master
Bastian Ruppert (4): Davinci: ea20: set console on UART0 Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console Davinci: ea20: add gpio for keeping power on in board_late_init Davinci: ea20: add gpios for LCD backlight control
Christian Riesch (1): arm, davinci: Add function lpsc_syncreset()
Heiko Schocher (13): arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD arm, arm926: fix missing symbols in NAND_SPL mode usb, davinci: add enable_vbus() weak function arm, usb, davinci: make USBPHY_CTL register configurable net, davinci_emac: make clock divider in MDIO control register configurable spl: add option for adding post memory test to the SPL framework arm, davinci: add support for new spl framework spl, nand: add 4bit HW ecc oob first nand_read_page function arm, davinci: add header files for dm365 arm, davinci: add lowlevel function for dm365 soc arm926ejs, davinci: add cpuinfo for dm365 arm926ejs, davinci: add missing spi defines for dm365 arm, davinci: add cam_enc_4xx support
Ilya Yanok (2): davinci_emac: compilation fix, phy is array now omap/spl: actually enable the console
Sanjeev Premi (7): omap3evm: Set environment variable 'ethaddr' omap3evm: Reorder related config options omap3evm: Prepare to split configuration omap3evm: move common config options to new file omap3evm: Add (quick) configuration for MMC/SD only omap3evm: Add (quick) configuration for NAND only omap3evm: fix errors caused by multiple definitions
Stefano Babic (8): Davinci: ea20: Add NAND support Davinci: ea20: Add early init to get early output from console Davinci: ea20: Add default U-Boot environment ARM: Davinci: added missing registers to hardware.h VIDEO: davinci: add framebuffer to da8xx Davinci: ea20: added video support Davinci: ea20: added I2C support Davinci: ea20: added PREBOOT to configuration
MAINTAINERS | 1 + Makefile | 8 +- README | 5 + arch/arm/cpu/arm926ejs/davinci/Makefile | 5 + arch/arm/cpu/arm926ejs/davinci/cpu.c | 27 +- arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c | 439 ++++++++++ arch/arm/cpu/arm926ejs/davinci/psc.c | 20 +- arch/arm/cpu/arm926ejs/davinci/spl.c | 63 ++ arch/arm/cpu/arm926ejs/start.S | 31 +- arch/arm/cpu/armv7/omap-common/spl.c | 2 + arch/arm/include/asm/arch-davinci/aintc_defs.h | 50 ++ arch/arm/include/asm/arch-davinci/da8xx-fb.h | 126 +++ arch/arm/include/asm/arch-davinci/dm365_lowlevel.h | 41 + arch/arm/include/asm/arch-davinci/hardware.h | 27 +- arch/arm/include/asm/arch-davinci/pll_defs.h | 84 ++ arch/arm/include/asm/arch-davinci/psc_defs.h | 86 ++ arch/arm/include/asm/arch-davinci/syscfg_defs.h | 66 ++ board/ait/cam_enc_4xx/Makefile | 46 ++ board/ait/cam_enc_4xx/cam_enc_4xx.c | 446 +++++++++++ board/ait/cam_enc_4xx/config.mk | 15 + board/ait/cam_enc_4xx/u-boot-spl.lds | 73 ++ board/ait/cam_enc_4xx/ublimage.cfg | 48 ++ board/davinci/common/misc.c | 2 +- board/davinci/ea20/ea20.c | 205 ++++- board/ti/evm/evm.c | 15 + boards.cfg | 3 + doc/README.SPL | 2 + doc/README.davinci.nand_spl | 141 ++++ drivers/mtd/nand/Makefile | 3 + drivers/mtd/nand/nand_spl_load.c | 56 ++ drivers/mtd/nand/nand_spl_simple.c | 43 +- drivers/net/davinci_emac.c | 11 +- drivers/usb/musb/davinci.c | 20 +- drivers/video/Makefile | 1 + drivers/video/da8xx-fb.c | 846 ++++++++++++++++++++ include/configs/cam_enc_4xx.h | 453 +++++++++++ include/configs/ea20.h | 126 +++- include/configs/omap3_evm.h | 331 ++------- include/configs/omap3_evm_common.h | 292 +++++++ include/configs/omap3_evm_quick_mmc.h | 91 +++ include/configs/omap3_evm_quick_nand.h | 79 ++ spl/Makefile | 1 + tools/ublimage.h | 2 +- 43 files changed, 4098 insertions(+), 334 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c create mode 100644 arch/arm/cpu/arm926ejs/davinci/spl.c create mode 100644 arch/arm/include/asm/arch-davinci/aintc_defs.h create mode 100644 arch/arm/include/asm/arch-davinci/da8xx-fb.h create mode 100644 arch/arm/include/asm/arch-davinci/dm365_lowlevel.h create mode 100644 arch/arm/include/asm/arch-davinci/pll_defs.h create mode 100644 arch/arm/include/asm/arch-davinci/psc_defs.h create mode 100644 arch/arm/include/asm/arch-davinci/syscfg_defs.h create mode 100644 board/ait/cam_enc_4xx/Makefile create mode 100644 board/ait/cam_enc_4xx/cam_enc_4xx.c create mode 100644 board/ait/cam_enc_4xx/config.mk create mode 100644 board/ait/cam_enc_4xx/u-boot-spl.lds create mode 100644 board/ait/cam_enc_4xx/ublimage.cfg create mode 100644 doc/README.davinci.nand_spl create mode 100644 drivers/mtd/nand/nand_spl_load.c create mode 100644 drivers/video/da8xx-fb.c create mode 100644 include/configs/cam_enc_4xx.h create mode 100644 include/configs/omap3_evm_common.h create mode 100644 include/configs/omap3_evm_quick_mmc.h create mode 100644 include/configs/omap3_evm_quick_nand.h
Hi Sandeep,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
s-paulraj@ti.com
