[U-Boot] Pull request: nand flash
Sorry for the lateness, but here are some MTD/UBI bugfixes. They've been acked by Stefan Roese.
The following changes since commit b770e88a6c2548727f0d57a3e9e8bb0830f977b5:
Fix number base handling of "load" command (2013-10-07 15:54:18 -0400)
git://git.denx.de/u-boot-nand-flash.git master
for you to fetch changes up to cc734f5ab26134e5e8d57c34edc257c89ac5b1d2:
cmd_ubi: add write.part command, to write a volume in multiple parts (2013-10-09 12:52:22 -0500)
---------------------------------------------------------------- Paul Burton (4): mtd: driver _read() returns max_bitflips; mtd_read() returns -EUCLEAN cmd_mtdparts: use 64 bits for flash size, partition size & offset cmd_ubi: use int64_t volume size for 'ubi create' cmd_ubi: add write.part command, to write a volume in multiple parts
common/cmd_mtdparts.c | 54 ++++++++++++++------------ common/cmd_ubi.c | 79 +++++++++++++++++++++++++++----------- doc/README.ubi | 3 ++ drivers/mtd/mtdcore.c | 14 ++++++- drivers/mtd/mtdpart.c | 12 +++--- drivers/mtd/nand/nand_base.c | 18 +++++++-- drivers/mtd/onenand/onenand_base.c | 3 +- include/jffs2/load_kernel.h | 6 +-- include/linux/mtd/nand.h | 3 ++ 9 files changed, 129 insertions(+), 63 deletions(-)
OK, problem: Author: Paul Burton paul.burton@imgtec.com Date: Wed Sep 4 15:16:57 2013 +0100
Causes a number of platform such as am3517_crane to fail to build with recent toolchains with errors such as: /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/arm-linux-gnueabihf-ld.bfd: error: /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.7.3/libgcc.a(bpabi.o) uses VFP register arguments, u-boot does not
Which we need to sort out, one way or another. Albert, any quick ideas?
Hi Tom,
Builds OK on my side, both nand-flash/master and a merge of nf/master and u-boot/master, with gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1)
Tom, can you specify which toolchain shows the issue?
Amicalement,
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 10/10/2013 04:12 AM, Albert ARIBAUD wrote:
Hi Tom,
Both ELDK 5.3 and Linaro 2013.03 (one TI has picked for some things) do the above. ELDK 5.2 is OK
- -- Tom
Hi Tom,
Hi Tom,
I'll test with ELDK5.3 in about an hour.
Amicalement,
On Thu, 10 Oct 2013 17:52:14 +0200, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Tom,
Hi Tom,
I've installed eldk-eglibc-i686-arm-toolchain-gmae-5.3.sh and can build am3517_crane on both nand-flash/master as well as on a merge of u-boot/master and nand-flash/master
Amicalement,
Hi Tom,
Hi Tom,
Here we go, armhf toolchains trigger this problem because, I suspect, we aren't enforcing a flag to say "no, really, no hfp here" or similar.
- -- Tom
Hi Tom,
Hi Tom,
> Sorry for the lateness, but here are some MTD/UBI bugfixes. They've > been acked by Stefan Roese. > > The following changes since commit b770e88a6c2548727f0d57a3e9e8bb0830f977b5: > > Fix number base handling of "load" command (2013-10-07 15:54:18 -0400) > > are available in the git repository at: > > git://git.denx.de/u-boot-nand-flash.git master > > for you to fetch changes up to cc734f5ab26134e5e8d57c34edc257c89ac5b1d2: > > cmd_ubi: add write.part command, to write a volume in multiple parts (2013-10-09 12:52:22 -0500) > > ---------------------------------------------------------------- > Paul Burton (4): > mtd: driver _read() returns max_bitflips; mtd_read() returns -EUCLEAN > cmd_mtdparts: use 64 bits for flash size, partition size & offset > cmd_ubi: use int64_t volume size for 'ubi create' > cmd_ubi: add write.part command, to write a volume in multiple parts
Any idea why this patchset triggers it? Does the 64-bit stuff cause something from libgcc to be used that previously wasn't? There is some open-coded 64-bit division, but it's by a power of two so GCC should convert it to a shift (and the ability to do 64-bit shifts was already required by print_size()).
-Scott
Hi Tom,
Hi Tom,
> On Wed, Oct 09, 2013 at 01:29:55PM -0500, Scott Wood wrote: > >> Sorry for the lateness, but here are some MTD/UBI bugfixes. They've >> been acked by Stefan Roese. >> >> The following changes since commit b770e88a6c2548727f0d57a3e9e8bb0830f977b5: >> >> Fix number base handling of "load" command (2013-10-07 15:54:18 -0400) >> >> are available in the git repository at: >> >> git://git.denx.de/u-boot-nand-flash.git master >> >> for you to fetch changes up to cc734f5ab26134e5e8d57c34edc257c89ac5b1d2: >> >> cmd_ubi: add write.part command, to write a volume in multiple parts (2013-10-09 12:52:22 -0500) >> >> ---------------------------------------------------------------- >> Paul Burton (4): >> mtd: driver _read() returns max_bitflips; mtd_read() returns -EUCLEAN >> cmd_mtdparts: use 64 bits for flash size, partition size & offset >> cmd_ubi: use int64_t volume size for 'ubi create' >> cmd_ubi: add write.part command, to write a volume in multiple parts > > OK, problem: > Author: Paul Burton paul.burton@imgtec.com > Date: Wed Sep 4 15:16:57 2013 +0100 > > cmd_mtdparts: use 64 bits for flash size, partition size & offset > > Causes a number of platform such as am3517_crane to fail to build with > recent toolchains with errors such as: > /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/arm-linux-gnueabihf-ld.bfd: > error: > /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.7.3/libgcc.a(bpabi.o) > uses VFP register arguments, u-boot does not > > Which we need to sort out, one way or another. Albert, any quick ideas?
I'm not sure what parts of this math exactly cause things to go all nutty, but I suspect the answer is that we should be enforcing - -msomething or another than hf defaults to using (un)setting.
- -- Tom
Hi Tom,
Hi Tom,
On 10/10/2013 04:12 AM, Albert ARIBAUD wrote: > Hi Tom, > > On Wed, 9 Oct 2013 21:45:25 -0400, Tom Rini trini@ti.com wrote: > >> On Wed, Oct 09, 2013 at 01:29:55PM -0500, Scott Wood wrote: >> >>> Sorry for the lateness, but here are some MTD/UBI bugfixes. They've >>> been acked by Stefan Roese. >>> >>> The following changes since commit b770e88a6c2548727f0d57a3e9e8bb0830f977b5: >>> >>> Fix number base handling of "load" command (2013-10-07 15:54:18 -0400) >>> >>> are available in the git repository at: >>> >>> git://git.denx.de/u-boot-nand-flash.git master >>> >>> for you to fetch changes up to cc734f5ab26134e5e8d57c34edc257c89ac5b1d2: >>> >>> cmd_ubi: add write.part command, to write a volume in multiple parts (2013-10-09 12:52:22 -0500) >>> >>> ---------------------------------------------------------------- >>> Paul Burton (4): >>> mtd: driver _read() returns max_bitflips; mtd_read() returns -EUCLEAN >>> cmd_mtdparts: use 64 bits for flash size, partition size & offset >>> cmd_ubi: use int64_t volume size for 'ubi create' >>> cmd_ubi: add write.part command, to write a volume in multiple parts >> >> OK, problem: >> Author: Paul Burton paul.burton@imgtec.com >> Date: Wed Sep 4 15:16:57 2013 +0100 >> >> cmd_mtdparts: use 64 bits for flash size, partition size & offset >> >> Causes a number of platform such as am3517_crane to fail to build with >> recent toolchains with errors such as: >> /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/arm-linux-gnueabihf-ld.bfd: >> error: >> /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.7.3/libgcc.a(bpabi.o) >> uses VFP register arguments, u-boot does not >> >> Which we need to sort out, one way or another. Albert, any quick ideas? > > Builds OK on my side, both nand-flash/master and a merge of nf/master > and u-boot/master, with gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1) > > Tom, can you specify which toolchain shows the issue?
Ok, trying with the ARMhf toolchain.
Amicalement,
On Fri, 11 Oct 2013 09:11:52 +0200, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Tom,
Hi Tom,
> -----BEGIN PGP SIGNED MESSAGE----- > Hash: SHA1 > > On 10/10/2013 04:12 AM, Albert ARIBAUD wrote: >> Hi Tom, >> >> On Wed, 9 Oct 2013 21:45:25 -0400, Tom Rini trini@ti.com wrote: >> >>> On Wed, Oct 09, 2013 at 01:29:55PM -0500, Scott Wood wrote: >>> >>>> Sorry for the lateness, but here are some MTD/UBI bugfixes. They've >>>> been acked by Stefan Roese. >>>> >>>> The following changes since commit b770e88a6c2548727f0d57a3e9e8bb0830f977b5: >>>> >>>> Fix number base handling of "load" command (2013-10-07 15:54:18 -0400) >>>> >>>> are available in the git repository at: >>>> >>>> git://git.denx.de/u-boot-nand-flash.git master >>>> >>>> for you to fetch changes up to cc734f5ab26134e5e8d57c34edc257c89ac5b1d2: >>>> >>>> cmd_ubi: add write.part command, to write a volume in multiple parts (2013-10-09 12:52:22 -0500) >>>> >>>> ---------------------------------------------------------------- >>>> Paul Burton (4): >>>> mtd: driver _read() returns max_bitflips; mtd_read() returns -EUCLEAN >>>> cmd_mtdparts: use 64 bits for flash size, partition size & offset >>>> cmd_ubi: use int64_t volume size for 'ubi create' >>>> cmd_ubi: add write.part command, to write a volume in multiple parts >>> >>> OK, problem: >>> Author: Paul Burton paul.burton@imgtec.com >>> Date: Wed Sep 4 15:16:57 2013 +0100 >>> >>> cmd_mtdparts: use 64 bits for flash size, partition size & offset >>> >>> Causes a number of platform such as am3517_crane to fail to build with >>> recent toolchains with errors such as: >>> /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/arm-linux-gnueabihf-ld.bfd: >>> error: >>> /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.7-2013.03-20130313_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.7.3/libgcc.a(bpabi.o) >>> uses VFP register arguments, u-boot does not >>> >>> Which we need to sort out, one way or another. Albert, any quick ideas? >> >> Builds OK on my side, both nand-flash/master and a merge of nf/master >> and u-boot/master, with gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-1ubuntu1) >> >> Tom, can you specify which toolchain shows the issue? > > Both ELDK 5.3 and Linaro 2013.03 (one TI has picked for some things) do > the above. ELDK 5.2 is OK
Even using the gnueabihf ELDK 5.3 toolchain, I still can build am3517_crane with no problem.
Amicalement,
This fixed the problem I had with UBI using 4G NAND in mx28evk :-)
http://patchwork.ozlabs.org/patch/280283/
This is the missing fix to get 4G NAND working fine on it.
I have some environment changes pending but will send it later tomorrow (for next).
Albert ARIBAUD
Otavio Salvador
Scott Wood
