[U-Boot] [PATCH] Add support for initializing MMC
Firmware loader would encounter problem if the MMC is accessed before initializing it. This patch would adding the support of initializing MMC before the MMC is accessed by firmware loader.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- drivers/misc/fs_loader.c | 31 +++++++++++++++++++++++++++++++ 1 files changed, 31 insertions(+), 0 deletions(-)
diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index 57a14a3..744fa46 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -12,6 +12,7 @@ #include <linux/string.h> #include <mapmem.h> #include <malloc.h> +#include <mmc.h> #include <spl.h>
DECLARE_GLOBAL_DATA_PTR; @@ -252,6 +253,36 @@ static int fs_loader_ofdata_to_platdata(struct udevice *dev)
static int fs_loader_probe(struct udevice *dev) { +#ifdef CONFIG_MMC + int ret; + struct device_platdata *plat = dev->platdata; + + ret = mmc_initialize(NULL); + if (ret) { + debug("MMC: could not initialize mmc. error: %d\n", ret); + + return ret; + } + + if (plat->phandlepart.phandle) { + ofnode node = ofnode_get_by_phandle(plat->phandlepart.phandle); + + struct udevice *mmc_dev = NULL; + + ret = device_get_global_by_ofnode(node, &mmc_dev); + if (!ret) { + struct mmc *mmc = mmc_get_mmc_dev(mmc_dev); + + ret = mmc_init(mmc); + if (ret) { + debug("MMC: mmc init failed with error: %d\n", + ret); + + return ret; + } + } + } +#endif return 0; };
Any comment for this patch?
diff --git a/drivers/misc/fs_loader.c b/drivers/misc/fs_loader.c index 57a14a3..744fa46 100644 --- a/drivers/misc/fs_loader.c +++ b/drivers/misc/fs_loader.c @@ -12,6 +12,7 @@ #include <linux/string.h> #include <mapmem.h> #include <malloc.h> +#include <mmc.h> #include <spl.h> DECLARE_GLOBAL_DATA_PTR; @@ -252,6 +253,36 @@ static int fs_loader_ofdata_to_platdata(struct udevice *dev) static int fs_loader_probe(struct udevice *dev) { +#ifdef CONFIG_MMC
- int ret;
- struct device_platdata *plat = dev->platdata;
- ret = mmc_initialize(NULL);
- if (ret) {
ret);
return ret;
- if (plat->phandlepart.phandle) {
if (!ret) {
if (ret) {
error: %d\n",
ret);
return ret;
On Fri, 21 Dec 2018 at 01:25, Chee, Tien Fong tien.fong.chee@intel.com wrote:
This should not be needed with CONFIG_DM_MMC enabled as it should be enough to probe the mmc device. Is that right?
int ret;
if (ret) {
ret);
return ret;
if (!ret) {
if (ret) {
error: %d\n",
ret);
return ret;
On Fri, 2018-12-21 at 10:16 -0700, Simon Glass wrote:
On Fri, 21 Dec 2018 at 01:25, Chee, Tien Fong <tien.fong.chee@intel.c om> wrote:
No, CONFIG_DM_MMC is required, otherwise compiler would tell you error. This whole mechanism is always developed in DM context. What's your concern? You want me to add CONFIG_DM_MMC or replace with CONFIG_MMC? or You want to improve the document?
+ return ret; + }
Hi Tien,
On Fri, 21 Dec 2018 at 10:50, Chee, Tien Fong tien.fong.chee@intel.com wrote:
Well, mmc_blk_probe() calls mmc_init() on the device. So instead of the code you have, would it be possible to probe the blk device? You can use device_find_first_child() for that. Perhaps write a function in blk.h which probes the first block device for a parent?
On Sat, 2018-12-22 at 13:51 -0700, Simon Glass wrote:
Hi Tien,
On Fri, 21 Dec 2018 at 10:50, Chee, Tien Fong <tien.fong.chee@intel.c om> wrote:
On Fri, 21 Dec 2018 at 01:25, Chee, Tien Fong <tien.fong.chee@int el.c om> wrote:
Yeah, sure. Let me find out more info.
Chee, Tien Fong
