[U-Boot-Users] Query: Flash remapping
Folks,
While reading through the source code for the TQM860L board, I have found some comment cards (and related functional details) that are puzzling me. I can't find anything about this in the archive, so I am raising it here as a question.
From TQM860L.h: lines 323to 328 (u-boot-1.1.1 source)
/* used to re-map FLASH both when starting from SRAM or FLASH: * restrict access enough to keep SRAM working (if any) * but not too much to meddle with FLASH accesses */ #define CFG_REMAP_OR_AM 0x80000000 /* OR addr mask */ #define CFG_PRELIM_OR_AM 0xE0000000 /* OR addr mask */
I can see the above hash-defines being used in file
./cpu/mpc8xx/cpu_init.c
as follows (lines 176 to 178).
/* now restrict to preliminary range */ memctl->memc_br0 = CFG_BR0_PRELIM; memctl->memc_or0 = CFG_OR0_PRELIM;
where CFG_PRELIM_OR_AM is used in the definition of CFG_OR0_PRELIM, also in TQML860L.h (line 337).
I read Table 15.4 of the Motorola MPC860 Family Users Manual which explains the format of the OR registers. If I understand it correctly, the definition of CFG_PRELIM_OR_AM limits the size of the Flash address range by masking out bits 0,1 and 2.
Why are only three bits removed ?
Also, what puzzles me is the comment:
restrict access enough to keep SRAM working (if any) but not too much to meddle with FLASH accesses
Why do we have to restrict access to keep SRAM working ?
Any explanations would be appreciated.
Thanks,
Charles.
Dr Charles J Gillan The Institute of Electronics, Communications and Information Technology (ECIT), Queen's University Belfast, Titanic Quarter Queens Road, Queens Island, Belfast, BT3 9DT Northern Ireland, UK Tel: +44 (0) 2890 971847
In message 005101c4b5f1$0d3a8020$8a24758f@ee.qub.ac.uk you wrote:
While reading through the source code for the TQM860L board,=20 I have found some comment cards (and related functional details) that are puzzling me. I can't find anything about this in the archive, so I am raising it here as a question.
Actually this is described in the README, section "System Initialization". Please do what the name suggests - read the README.
Forget this here. There are no TQM8xxL modules with SRAM (the comment relates to an older module named TQM860 [the 'L' meaning 'low cost' originally], but I bet you'll never see a TQM860 in use any more.
Charles J Gillan
