[RFT PATCH] riscv: andes_plic: Fix riscv_get_ipi() mask
Current logic in riscv_get_ipi() for Andes PLICSW does not look good to me. The mask to test IPI pending bits for a hart should be left shifted by (8 * gd->arch.boot_hart), just the same as what is done in riscv_send_ipi().
Signed-off-by: Bin Meng bmeng.cn@gmail.com
--- It looks there is no datasheet released from Andes that describes how PLICSW works, and its register fields. I can only get an understanding from current U-Boot and OpenSBI PLICSW driver.
This requires testing on Andes hardware, which I don't have access to.
arch/riscv/lib/andes_plic.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/lib/andes_plic.c b/arch/riscv/lib/andes_plic.c index 221a5fe324..5e113ee8c9 100644 --- a/arch/riscv/lib/andes_plic.c +++ b/arch/riscv/lib/andes_plic.c @@ -105,9 +105,11 @@ int riscv_clear_ipi(int hart)
int riscv_get_ipi(int hart, int *pending) { + unsigned int ipi = (SEND_IPI_TO_HART(hart) << (8 * gd->arch.boot_hart)); + *pending = readl((void __iomem *)PENDING_REG(gd->arch.plic, gd->arch.boot_hart)); - *pending = !!(*pending & SEND_IPI_TO_HART(hart)); + *pending = !!(*pending & ipi);
return 0; }
Ping?
Bin Meng
