[U-Boot] Fwd: Parallel build is broken
---------- Forwarded message --------- From: Andy Shevchenko andy.shevchenko@gmail.com Date: Tue, Sep 4, 2018 at 3:40 PM Subject: Parallel build is broken To: Tom Rini trini@konsulko.com Cc: Bin Meng bmeng.cn@gmail.com, Simon Glass sjg@chromium.org
U-Boot can't be build with make -j16.
Second pass passes fine.
Didn't investigate myself and probably will not have time (near to vacation time for me). So, please, fix it before release.
sh: echo: I/O error make[1]: *** [scripts/Makefile.build:278: common/malloc_simple.o] Error 1 make[1]: *** Waiting for unfinished jobs.... CC drivers/serial/ns16550.o CC drivers/spi/spi.o CC cmd/mmc.o CC drivers/watchdog/tangier_wdt.o CC drivers/serial/serial_intel_mid.o CC cmd/net.o CC drivers/usb/common/common.o CC arch/x86/lib/acpi.o LD drivers/timer/built-in.o CC arch/x86/lib/acpi_table.o CC drivers/video/console_normal.o make: *** [Makefile:1377: common] Error 2 make: *** Waiting for unfinished jobs....
-- With Best Regards, Andy Shevchenko
What build target (and O= or not?) is this with? Thanks!
make clean && make edison_defconfig && make -j16
gcc (Debian 8.2.0-4) 8.2.0 Copyright (C) 2018 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-- Tom
On Tue, Sep 4, 2018 at 5:50 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
So, first time it's being built, consequent runs usually failed.
On Tue, Sep 4, 2018 at 5:54 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
More information: - when consequential run is being executed no code had been changed - the object files where it fails is totally arbitrary - I used ccache, though I disabled for now completely (through modifying PATH) and problem still exists - Linux kernel rebuilds on that very same machine fine (like touch include/linux/perf_event.h; make -j64 in a loop)
It's total mystery to me. It was rebuilding just fine yesterday, I updated today from GH and even older (v2018.09-rc2) fails.
On Tue, Sep 4, 2018 at 6:03 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
Switching to gcc-7 does *not* cure.
More information:
On Tue, Sep 4, 2018 at 3:54 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
I've seen this problem - building inside a VMware VM. I've always found that logging out and back in appears to fix it, so possibly something related to the session... I've similarly failed to figure out what the problem is as it comes and goes.
I am no expert, but I/O error to me indicates a hardware problem on the build machine and not necessarily a software issue.
adam
-- Alex Kiernan _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Not exactly. AFAIR it's a message mapped to EIO errno. The scenario can be like that (hypothetically), make runs compiler, but instead of compiler ccache is being called and, in case it's somehow broken, it might try to access to wrong block on the block device which returns EIO on some (read()?) system call.
I doubt that is the issue. While EIO can be returned in response to a hardware failure, it would be very random and most likely affect something - the linker, a compiler - that process a lot of files or data, not an echo command.
This is likely on track to the real problem. What happened is something echo did returned EIO as an errno. That failing syscall was probably a write(3), since echo doesn't do a whole lot else! And why can write(3) return EIO, besides a hardware error?
EIO The process is a member of a background process group attempting to write to its controlling terminal, TOSTOP is set, the calling thread is not blocking SIGTTOU, the process is not ignoring SIGTTOU, and the process group of the process is orphaned. This error may also be returned under implementation-defined conditions.
I think there's a $(shell echo something &) or something like that somewhere.
> ---------- Forwarded message --------- > From: Andy Shevchenko andy.shevchenko@gmail.com > Date: Tue, Sep 4, 2018 at 3:40 PM > Subject: Parallel build is broken > To: Tom Rini trini@konsulko.com > Cc: Bin Meng bmeng.cn@gmail.com, Simon Glass sjg@chromium.org > > > U-Boot can't be build with make -j16. > > Second pass passes fine. > > Didn't investigate myself and probably will not have time (near to > vacation time for me). > So, please, fix it before release. > > sh: echo: I/O error > make[1]: *** [scripts/Makefile.build:278: common/malloc_simple.o] Error 1
I observe similar issue when I build QEMU except that its makefiles use 'printf' instead of 'echo' in the 'quiet-command' macro. But I observe the same issue even when building with V=1, i.e. when 'printf' is not used. In that case the error comes from the make itself. I tested a range of make versions from 3.81 to 4.2.1 and see the issue with all of them.
When it happens under strace it looks like this (make V=0):
8341 write(1, " CC arch/AArch64/AArch64Di"..., 45) = -1 EAGAIN (Resource temporarily unavailable)
or this (make V=1):
31716 write(1, "c++ -I/usr/include/pixman-1 -W"..., 1024) = 1024 31716 write(1, "tcg-op-gvec.o tcg/tcg-common.o t"..., 10240) = 7936 31716 write(1, "ut-keymap.o ../ui/input-legacy.o"..., 2304) = -1 EAGAIN (Resource temporarily unavailable) 31716 write(1, "\n", 1) = 1
I suspect that it's a kernel issue, as I started to notice it after the system upgrade from Debian 8 to Debian 9.
I assume this is on Debian/unstable? I can't directly replicate this on my 24core (Debian/stretch) or 16core(Ubuntu/xenial) machines. I'll setup a chroot soon, but since you've said -j64 is fine there too I suspect you have more cores than I. This may be something you have to bisect for us if I can't replicate it myself. Can you confirm how many cores you have? I might be able to spin something up in Google compute. Thanks!
testing
$ sed -n -e '/cpu cores/ { p; q }' /proc/cpuinfo cpu cores : 22
OTOH, I tried on my desktop (where is unstable) and everything works fine with the same (-j16) command line on any gcc I tried. $ sed -n -e '/cpu cores/ { p; q }' /proc/cpuinfo cpu cores : 4
On Tue, Sep 4, 2018 at 6:47 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
testing
Did few runs (~6) on this machine with -j4, no failures so far. Reruning same with -j16 brings failure on ~2-3 iteration.
It seems the scope can be narrowed to: - many cores build system, and - Debian testing/unstable toolchain, and/or - U-Boot build system
testing
I'm pretty sure it's a dependency problem somewhere. Since this was working reliably for you recently (right?) and I can't reproduce it and you can, if you can run a git bisect to figure out what commit is breaking things, that would be very helpful. Thanks!
testing
Now after my vacation. So, I guess it's not so critical for release as I thought at the beginning.
On Tue, Sep 4, 2018 at 5:00 PM Tom Rini trini@konsulko.com wrote: > On Tue, Sep 04, 2018 at 03:42:05PM +0300, Andy Shevchenko wrote:
testing
I'd love to fix it, but I can't replicate it.
Hi Andy,
On Tue, Sep 04, 2018 at 05:50:33PM +0300, Andy Shevchenko wrote: > On Tue, Sep 4, 2018 at 5:00 PM Tom Rini trini@konsulko.com wrote: > > On Tue, Sep 04, 2018 at 03:42:05PM +0300, Andy Shevchenko wrote:
> make clean && make edison_defconfig && make -j16 > > gcc (Debian 8.2.0-4) 8.2.0 > Copyright (C) 2018 Free Software Foundation, Inc. > This is free software; see the source for copying conditions. There is NO > warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
testing
I can't reproduce this on my machine too, on Ubuntu 16.04 with either native gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.10), or the kernel.org gcc (gcc version 7.3.0 (GCC)), using below commands:
$ make clean && make edison_defconfig && make -j64
Regards, Bin
On Tue, 2018-09-04 at 17:43 -0400, Tom Rini wrote:
CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.
On Tue, Sep 04, 2018 at 05:50:33PM +0300, Andy Shevchenko wrote: > On Tue, Sep 4, 2018 at 5:00 PM Tom Rini trini@konsulko.com wrote: > > On Tue, Sep 04, 2018 at 03:42:05PM +0300, Andy Shevchenko wrote: > make clean && make edison_defconfig && make -j16 > > gcc (Debian 8.2.0-4) 8.2.0 > Copyright (C) 2018 Free Software Foundation, Inc. > This is free software; see the source for copying conditions. There is NO > warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
testing
There was a patch recently to make 4.2.1 to fix some parallel build issue. No idea if that fix applies to your case though.
Jocke
participants (8)
Adam Ford
Alex Kiernan
Andy Shevchenko
Bin Meng
Joakim Tjernlund
Max Filippov
Trent Piepho
