[U-Boot] Flash not erased problem.
Hi, I am using u-Boot [2009.08-CanyonlandsOptimized_2.6.30_1.13-01] in canyonlands board to flash my ram file system (which I need to do often). I go in step to erase/tftp/copy the binary in my flash.
era 0xfc200000 0xfd5fffff tftp 0x200000 canyonlands/ramdisk.img cp.b ${fileaddr} 0xfc200000 ${filesize}
other than copy command everything works fine. The copy command bails out with error message "flash not erased". Size of ramdisk image is ~7MB. I have verified the sectors for erase operation done properly (i.e filled with 0xFFFFFFFF).
After giving 'n" number of shot copy works great. I suspect timing problem which degrades with age of flash memory. I have acquired a new board and i see the same problem.
Can some one help me out ?
Thank You Sanjoy Saha
::DISCLAIMER:: -----------------------------------------------------------------------------------------------------------------------
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only. It shall not attach any liability on the originator or HCL or its affiliates. Any views or opinions presented in this email are solely those of the author and may not necessarily reflect the opinions of HCL or its affiliates. Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have received this email in error please delete it and notify the sender immediately. Before opening any mail and attachments please check them for viruses and defect.
Hi Sanjoy,
Did you check upgrading to a newer U-Boot version? Take a look at this commit:
Author: Stefan Roese sr@denx.de 2009-10-29 18:37:45 Committer: Stefan Roese sr@denx.de 2009-11-09 13:30:19 Parent: 514bab6609acd1a2a19fdd75c2f6255178db7c96 (ppc4xx: Fix "chip_config" command for AMCC Arches) Child: 17a684449728ce4c9ce79fa9e7e75b86a5f9b41d (ppc4xx/Canyonlands added USB board callbacks) Branches: many (141) Follows: v2009.11-rc1 Precedes: v2009.11-rc2
ppc4xx: Canyonlands: Change EBC bus config to drive always (no high-z)
This patch fixes a problem only seen very occasionally on Canyonlands. The NOR flash interface (CFI driver) doesn't work reliably in all cases. Erasing and/or programming sometimes doesn't work. Sometimes with an error message, like "flash not erased" when trying to program an area that should have just been erased. And sometimes without any error messages. As mentioned above, this problem was only seen rarely and with some PLL configuration (CPU speed, EBC speed).
Now I spotted this problem a few times, when running my Canyonlands with the following setup (chip_config):
1000-nor - NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100
Changing the EBC configuration to not release the bus into high impedance state inbetween the transfers (ATC, DTC and CTC bits set to 1 in EBC0_CFG) seems to fix this problem. I haven't seen any failure anymore with this patch applied.
Signed-off-by: Stefan Roese sr@denx.de
So a newer U-Boot version should fix your issue.
Best regards, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
