[U-Boot] [PATCH 0/4] arm: mxs: mxs_set_gpmiclk
While trying to implement an mxs_set_gpmiclk() I stumbled on a few minor things.
Rasmus Villemoes (4): arm: mxs: fix register definitions for clkctrl_gpmi and clkctrl_sspX arm: mxs: fix comments in arch_cpu_init to match the code arm: mxs: be more careful when enabling gpmi_clk arm: mxs: implement mxs_set_gpmiclk
arch/arm/cpu/arm926ejs/mxs/clock.c | 41 +++++++++++++++++++ arch/arm/cpu/arm926ejs/mxs/mxs.c | 9 ++-- arch/arm/include/asm/arch-mxs/clock.h | 1 + .../include/asm/arch-mxs/regs-clkctrl-mx23.h | 6 ++- .../include/asm/arch-mxs/regs-clkctrl-mx28.h | 15 ++++--- 5 files changed, 62 insertions(+), 10 deletions(-)
I tried clearing a bit by writing to hw_clkctrl_gpmi_clr, then busy-waiting for it to actually clear. My board hung. The data sheet agrees, these registers do not have _set, _clr, _tog, so fix up the definitions. git grep -E 'clkctrl_(gpmi|ssp[0-9])_' says that nobody uses those non-existing ops registers.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- arch/arm/include/asm/arch-mxs/regs-clkctrl-mx23.h | 6 ++++-- arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h | 15 ++++++++++----- 2 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx23.h b/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx23.h index 6e9ffeb6d5..50fdc9cd03 100644 --- a/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx23.h +++ b/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx23.h @@ -24,8 +24,10 @@ struct mxs_clkctrl_regs { mxs_reg_32(hw_clkctrl_xbus) /* 0x40 */ mxs_reg_32(hw_clkctrl_xtal) /* 0x50 */ mxs_reg_32(hw_clkctrl_pix) /* 0x60 */ - mxs_reg_32(hw_clkctrl_ssp0) /* 0x70 */ - mxs_reg_32(hw_clkctrl_gpmi) /* 0x80 */ + uint32_t hw_clkctrl_ssp0; /* 0x70 */ + uint32_t reserved_ssp0[3]; /* 0x74-0x7c */ + uint32_t hw_clkctrl_gpmi; /* 0x80 */ + uint32_t reserved_gpmi[3]; /* 0x84-0x8c */ mxs_reg_32(hw_clkctrl_spdif) /* 0x90 */ mxs_reg_32(hw_clkctrl_emi) /* 0xa0 */
diff --git a/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h b/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h index 01e0a7a053..caef9e4b1f 100644 --- a/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h +++ b/arch/arm/include/asm/arch-mxs/regs-clkctrl-mx28.h @@ -27,11 +27,16 @@ struct mxs_clkctrl_regs { mxs_reg_32(hw_clkctrl_hbus) /* 0x60 */ mxs_reg_32(hw_clkctrl_xbus) /* 0x70 */ mxs_reg_32(hw_clkctrl_xtal) /* 0x80 */ - mxs_reg_32(hw_clkctrl_ssp0) /* 0x90 */ - mxs_reg_32(hw_clkctrl_ssp1) /* 0xa0 */ - mxs_reg_32(hw_clkctrl_ssp2) /* 0xb0 */ - mxs_reg_32(hw_clkctrl_ssp3) /* 0xc0 */ - mxs_reg_32(hw_clkctrl_gpmi) /* 0xd0 */ + uint32_t hw_clkctrl_ssp0; /* 0x90 */ + uint32_t reserved_ssp0[3]; /* 0x94-0x9c */ + uint32_t hw_clkctrl_ssp1; /* 0xa0 */ + uint32_t reserved_ssp1[3]; /* 0xa4-0xac */ + uint32_t hw_clkctrl_ssp2; /* 0xb0 */ + uint32_t reserved_ssp2[3]; /* 0xb4-0xbc */ + uint32_t hw_clkctrl_ssp3; /* 0xc0 */ + uint32_t reserved_ssp3[3]; /* 0xc4-0xcc */ + uint32_t hw_clkctrl_gpmi; /* 0xd0 */ + uint32_t reserved_gpmi[3]; /* 0xd4-0xdc */ mxs_reg_32(hw_clkctrl_spdif) /* 0xe0 */ mxs_reg_32(hw_clkctrl_emi) /* 0xf0 */ mxs_reg_32(hw_clkctrl_saif0) /* 0x100 */
The comment says to clear the bypass bit, but in fact it sets it, thus selecting ref_xtal. And the next line of code does not set the divider to 12, but to (the reset value of) 1.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- arch/arm/cpu/arm926ejs/mxs/mxs.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/mxs.c b/arch/arm/cpu/arm926ejs/mxs/mxs.c index 85c65dcb44..585c53baf6 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxs.c +++ b/arch/arm/cpu/arm926ejs/mxs/mxs.c @@ -98,11 +98,11 @@ int arch_cpu_init(void) /* * Enable NAND clock */ - /* Clear bypass bit */ + /* Set bypass bit */ writel(CLKCTRL_CLKSEQ_BYPASS_GPMI, &clkctrl_regs->hw_clkctrl_clkseq_set);
- /* Set GPMI clock to ref_gpmi / 12 */ + /* Set GPMI clock to ref_xtal / 1 */ clrsetbits_le32(&clkctrl_regs->hw_clkctrl_gpmi, CLKCTRL_GPMI_CLKGATE | CLKCTRL_GPMI_DIV_MASK, 1);
The data sheet says that the DIV field cannot change while the CLKGATE bit is set or modified. So do it a little more carefully, by first clearing the bit, waiting for that to appear, then setting the DIV field.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- arch/arm/cpu/arm926ejs/mxs/mxs.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/mxs.c b/arch/arm/cpu/arm926ejs/mxs/mxs.c index 585c53baf6..183aa40b6d 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxs.c +++ b/arch/arm/cpu/arm926ejs/mxs/mxs.c @@ -103,8 +103,11 @@ int arch_cpu_init(void) &clkctrl_regs->hw_clkctrl_clkseq_set);
/* Set GPMI clock to ref_xtal / 1 */ + clrbits_le32(&clkctrl_regs->hw_clkctrl_gpmi, CLKCTRL_GPMI_CLKGATE); + while (readl(&clkctrl_regs->hw_clkctrl_gpmi) & CLKCTRL_GPMI_CLKGATE) + ; clrsetbits_le32(&clkctrl_regs->hw_clkctrl_gpmi, - CLKCTRL_GPMI_CLKGATE | CLKCTRL_GPMI_DIV_MASK, 1); + CLKCTRL_GPMI_DIV_MASK, 1);
udelay(1000);
This allows a board file to set the gpmiclk to something other than the default 24 MHz based on ref_xtal.
I don't have an mx23-based board, but I believe there's a bug in the current mxs_get_gpmiclk: According to the data sheet, the gpmiclk can be derived from ref_io, not ref_cpu. Since other clocks are also derived from ref_io, it seems most sensible to require the board file to set that appropriately first, then derive the divider from its current setting.
For mx28 boards, OTOH, there's a separate ref_gpmi only used for clk_gpmi. For simplicity, if !xtal, simply enable that at its maximum frequency.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- arch/arm/cpu/arm926ejs/mxs/clock.c | 41 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-mxs/clock.h | 1 + 2 files changed, 42 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/mxs/clock.c b/arch/arm/cpu/arm926ejs/mxs/clock.c index 43d044d917..d247da56fe 100644 --- a/arch/arm/cpu/arm926ejs/mxs/clock.c +++ b/arch/arm/cpu/arm926ejs/mxs/clock.c @@ -138,6 +138,47 @@ static uint32_t mxs_get_gpmiclk(void) return (PLL_FREQ_MHZ * PLL_FREQ_COEF / frac) / div; }
+void mxs_set_gpmiclk(uint32_t freq, int xtal) +{ + struct mxs_clkctrl_regs *clkctrl_regs = + (struct mxs_clkctrl_regs *)MXS_CLKCTRL_BASE; + uint32_t clk, div; + + if (xtal) { + clk = XTAL_FREQ_KHZ; + } else { +#if defined(CONFIG_MX23) + clk = mxs_get_ioclk(MXC_IOCLK0); +#elif defined(CONFIG_MX28) + /* enable ref_gpmi at 480 MHz. */ + writeb(CLKCTRL_FRAC_CLKGATE, + &clkctrl_regs->hw_clkctrl_frac1_set[CLKCTRL_FRAC1_GPMI]); + writeb(CLKCTRL_FRAC_CLKGATE | PLL_FREQ_COEF, + &clkctrl_regs->hw_clkctrl_frac1[CLKCTRL_FRAC1_GPMI]); + writeb(CLKCTRL_FRAC_CLKGATE, + &clkctrl_regs->hw_clkctrl_frac1_clr[CLKCTRL_FRAC1_GPMI]); + clk = PLL_FREQ_KHZ; +#endif + } + if (freq > clk) + return; + div = clk / freq; + if (div > CLKCTRL_GPMI_DIV_MASK) + div = CLKCTRL_GPMI_DIV_MASK; + + clrbits_le32(&clkctrl_regs->hw_clkctrl_gpmi, CLKCTRL_GPMI_CLKGATE); + while (readl(&clkctrl_regs->hw_clkctrl_gpmi) & CLKCTRL_GPMI_CLKGATE) + ; + clrsetbits_le32(&clkctrl_regs->hw_clkctrl_gpmi, CLKCTRL_GPMI_DIV_MASK, div); + while (readl(&clkctrl_regs->hw_clkctrl_gpmi) & CLKCTRL_GPMI_BUSY) + ; + + if (xtal) + writel(CLKCTRL_CLKSEQ_BYPASS_GPMI, &clkctrl_regs->hw_clkctrl_clkseq_set); + else + writel(CLKCTRL_CLKSEQ_BYPASS_GPMI, &clkctrl_regs->hw_clkctrl_clkseq_clr); +} + /* * Set IO clock frequency, in kHz */ diff --git a/arch/arm/include/asm/arch-mxs/clock.h b/arch/arm/include/asm/arch-mxs/clock.h index ee56d10fec..0a6625eb90 100644 --- a/arch/arm/include/asm/arch-mxs/clock.h +++ b/arch/arm/include/asm/arch-mxs/clock.h @@ -44,6 +44,7 @@ uint32_t mxc_get_clock(enum mxc_clock clk);
void mxs_set_ioclk(enum mxs_ioclock io, uint32_t freq); void mxs_set_sspclk(enum mxs_sspclock ssp, uint32_t freq, int xtal); +void mxs_set_gpmiclk(uint32_t freq, int xtal); void mxs_set_ssp_busclock(unsigned int bus, uint32_t freq); void mxs_set_lcdclk(uint32_t __maybe_unused lcd_base, uint32_t freq);
ping
Hi Rasmus,
ping
You're right, patch was lost (..just because the list of patches for i.MX was very long and I have not seen..), I found the series again.
I applied the first 3 patches, they are improvements / clarifications. The fourth patch has no user, so I ask who is suing it. Nevertheless, patch 4/4 breaks some boards (I found at least "xfi3") because it is compiled even for not i.MX boards and then prototype is missing:
arm: + xfi3 +arch/arm/cpu/arm926ejs/mxs/clock.c: In function 'mxs_set_gpmiclk': +arch/arm/cpu/arm926ejs/mxs/clock.c:151:9: error: implicit declaration of function 'mxs_get_ioclk'; did you mean 'mxs_set_ioclk'? [-Werror=implicit-function-declaration] + clk = mxs_get_ioclk(MXC_IOCLK0); + ^~~~~~~~~~~~~ + mxs_set_ioclk +arch/arm/cpu/arm926ejs/mxs/clock.c: At top level: +arch/arm/cpu/arm926ejs/mxs/clock.c:218:17: error: conflicting types for 'mxs_get_ioclk' + static uint32_t mxs_get_ioclk(enum mxs_ioclock io) + ^~~~~~~~~~~~~ +arch/arm/cpu/arm926ejs/mxs/clock.c:151:9: note: previous implicit declaration of 'mxs_get_ioclk' was here +cc1: all warnings being treated as errors +make[3]: *** [arch/arm/cpu/arm926ejs/mxs/clock.o] Error 1 +make[2]: *** [arch/arm/cpu/arm926ejs/mxs] Error 2 +make[1]: *** [arch/arm/cpu/arm926ejs] Error 2 +make: *** [sub-make] Error 2
I have nothing against to merge this, too, but the issue above must be fixed - thanks !
Best regards, Stefano Babic
On 03/01/2020 13.42, Stefano Babic wrote:
Hi Rasmus,
ping
Thanks.
I had a user in the branch I was working on, from which I tried to carve out some upstreamable chunks. Unfortunately, the focus internally has now shifted away from that mx28 board, so I don't know if and when I'll be working on that again. But I'll try to remember to fix the break you report the next time around.
Thanks, Rasmus
Rasmus Villemoes
Rasmus Villemoes
Rasmus Villemoes
Stefano Babic
