[PATCH 1/1] efi_loader: eliminate efi_set_(non)volatile_variable
Eliminate superfluous functions efi_set_volatile_variable() and efi_set_nonvolatile_variable().
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_variable.c | 141 +++++++++------------------------- 1 file changed, 37 insertions(+), 104 deletions(-)
diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index ceb6b17b00..b9c2e4ebf6 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -169,12 +169,12 @@ static const char *parse_attr(const char *str, u32 *attrp, u64 *timep) return str; }
-static efi_status_t efi_set_variable_internal(u16 *variable_name, - const efi_guid_t *vendor, - u32 attributes, - efi_uintn_t data_size, - const void *data, - bool ro_check); +static efi_status_t efi_set_variable_common(u16 *variable_name, + const efi_guid_t *vendor, + u32 attributes, + efi_uintn_t data_size, + const void *data, + bool ro_check);
/** * efi_set_secure_state - modify secure boot state variables @@ -196,35 +196,28 @@ static efi_status_t efi_set_secure_state(int sec_boot, int setup_mode, attributes = EFI_VARIABLE_BOOTSERVICE_ACCESS | EFI_VARIABLE_RUNTIME_ACCESS | READ_ONLY; - ret = efi_set_variable_internal(L"SecureBoot", - &efi_global_variable_guid, - attributes, - sizeof(sec_boot), &sec_boot, - false); + ret = efi_set_variable_common(L"SecureBoot", &efi_global_variable_guid, + attributes, sizeof(sec_boot), &sec_boot, + false); if (ret != EFI_SUCCESS) goto err;
- ret = efi_set_variable_internal(L"SetupMode", - &efi_global_variable_guid, - attributes, - sizeof(setup_mode), &setup_mode, - false); + ret = efi_set_variable_common(L"SetupMode", &efi_global_variable_guid, + attributes, sizeof(setup_mode), + &setup_mode, false); if (ret != EFI_SUCCESS) goto err;
- ret = efi_set_variable_internal(L"AuditMode", - &efi_global_variable_guid, - attributes, - sizeof(audit_mode), &audit_mode, - false); + ret = efi_set_variable_common(L"AuditMode", &efi_global_variable_guid, + attributes, sizeof(audit_mode), + &audit_mode, false); if (ret != EFI_SUCCESS) goto err;
- ret = efi_set_variable_internal(L"DeployedMode", - &efi_global_variable_guid, - attributes, - sizeof(deployed_mode), &deployed_mode, - false); + ret = efi_set_variable_common(L"DeployedMode", + &efi_global_variable_guid, attributes, + sizeof(deployed_mode), &deployed_mode, + false); err: return ret; } @@ -234,7 +227,7 @@ err: * @mode: new state * * Depending on @mode, secure boot related variables are updated. - * Those variables are *read-only* for users, efi_set_variable_internal() + * Those variables are *read-only* for users, efi_set_variable_common() * is called here. * * Return: EFI_SUCCESS on success, status code (negative) on error @@ -252,11 +245,10 @@ static efi_status_t efi_transfer_secure_state(enum efi_secure_mode mode)
efi_secure_boot = true; } else if (mode == EFI_MODE_AUDIT) { - ret = efi_set_variable_internal( - L"PK", &efi_global_variable_guid, - EFI_VARIABLE_BOOTSERVICE_ACCESS | - EFI_VARIABLE_RUNTIME_ACCESS, - 0, NULL, false); + ret = efi_set_variable_common(L"PK", &efi_global_variable_guid, + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + 0, NULL, false); if (ret != EFI_SUCCESS) goto err;
@@ -326,14 +318,13 @@ static efi_status_t efi_init_secure_state(void)
ret = efi_transfer_secure_state(mode); if (ret == EFI_SUCCESS) - ret = efi_set_variable_internal(L"VendorKeys", - &efi_global_variable_guid, - EFI_VARIABLE_BOOTSERVICE_ACCESS - | EFI_VARIABLE_RUNTIME_ACCESS - | READ_ONLY, - sizeof(efi_vendor_keys), - &efi_vendor_keys, - false); + ret = efi_set_variable_common(L"VendorKeys", + &efi_global_variable_guid, + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS | + READ_ONLY, + sizeof(efi_vendor_keys), + &efi_vendor_keys, false);
err: return ret; @@ -872,14 +863,12 @@ efi_status_t EFIAPI efi_get_next_variable_name(efi_uintn_t *variable_name_size, return EFI_EXIT(ret); }
-static -efi_status_t EFIAPI efi_set_variable_common(u16 *variable_name, +static efi_status_t efi_set_variable_common(u16 *variable_name, const efi_guid_t *vendor, u32 attributes, efi_uintn_t data_size, const void *data, - bool ro_check, - bool is_non_volatile) + bool ro_check) { char *native_name = NULL, *old_data = NULL, *val = NULL, *s; efi_uintn_t old_size; @@ -906,14 +895,6 @@ efi_status_t EFIAPI efi_set_variable_common(u16 *variable_name, attr = 0; ret = EFI_CALL(efi_get_variable(variable_name, vendor, &attr, &old_size, NULL)); - if (ret == EFI_BUFFER_TOO_SMALL) { - if ((is_non_volatile && !(attr & EFI_VARIABLE_NON_VOLATILE)) || - (!is_non_volatile && (attr & EFI_VARIABLE_NON_VOLATILE))) { - ret = EFI_INVALID_PARAMETER; - goto err; - } - } - append = !!(attributes & EFI_VARIABLE_APPEND_WRITE); attributes &= ~(u32)EFI_VARIABLE_APPEND_WRITE; delete = !append && (!data_size || !attributes); @@ -1087,7 +1068,7 @@ out: /* update VendorKeys */ if (vendor_keys_modified & efi_vendor_keys) { efi_vendor_keys = 0; - ret = efi_set_variable_internal( + ret = efi_set_variable_common( L"VendorKeys", &efi_global_variable_guid, EFI_VARIABLE_BOOTSERVICE_ACCESS @@ -1109,54 +1090,6 @@ err: return ret; }
-static -efi_status_t EFIAPI efi_set_volatile_variable(u16 *variable_name, - const efi_guid_t *vendor, - u32 attributes, - efi_uintn_t data_size, - const void *data, - bool ro_check) -{ - return efi_set_variable_common(variable_name, vendor, attributes, - data_size, data, ro_check, false); -} - -efi_status_t EFIAPI efi_set_nonvolatile_variable(u16 *variable_name, - const efi_guid_t *vendor, - u32 attributes, - efi_uintn_t data_size, - const void *data, - bool ro_check) -{ - efi_status_t ret; - - ret = efi_set_variable_common(variable_name, vendor, attributes, - data_size, data, ro_check, true); - - return ret; -} - -static efi_status_t efi_set_variable_internal(u16 *variable_name, - const efi_guid_t *vendor, - u32 attributes, - efi_uintn_t data_size, - const void *data, - bool ro_check) -{ - efi_status_t ret; - - if (attributes & EFI_VARIABLE_NON_VOLATILE) - ret = efi_set_nonvolatile_variable(variable_name, vendor, - attributes, - data_size, data, ro_check); - else - ret = efi_set_volatile_variable(variable_name, vendor, - attributes, data_size, data, - ro_check); - - return ret; -} - /** * efi_set_variable() - set value of a UEFI variable * @@ -1182,9 +1115,9 @@ efi_status_t EFIAPI efi_set_variable(u16 *variable_name, /* READ_ONLY bit is not part of API */ attributes &= ~(u32)READ_ONLY;
- return EFI_EXIT(efi_set_variable_internal(variable_name, vendor, - attributes, data_size, data, - true)); + return EFI_EXIT(efi_set_variable_common(variable_name, vendor, + attributes, data_size, data, + true)); }
/** -- 2.26.2
