[U-Boot] [PATCH v2 0/7] Update for inka4x0 plus some new features
This patchset contains updates for the ink4x0 platform. Namely it adds hardware diagnostic funtions and an RTC driver.
For a nice integration by using private command tables, do_help is extended to support this scenario also.
To successfully convert all the pointer access to accessor macros, a bunch of new defines is also needed for the 5200 cpu.
Changes from v1:
Addresses comments from ML. Specifically: - Moved ns16650 defines to proper include file. - Used structures from this header file to access UARTs - this nicely eliminates serial_{in,out}. - Convert inka_diag.c pointer accesses to accessor macros. - Move variable declarations to start of functions.
A diff of the "before" and "after" branches will be posted seperately for easier inspection.
Detlev Zundel (7): command.c: Expose the core of do_help as _do_help to the rest of u-boot. mpc5xxx: Add structure definition for several more register blocks. drivers/twserial: Add protocol driver for "three wire serial" interface. rtc: add support for 4543 RTC (manufactured by e.g. EPSON) inka4x0: Add hardware diagnosis functions for inka4x0 inka4x0: Add hardware diagnosis and RTC in configuration. inka4x0: Use proper accessor macros for memory mapped registers.
Makefile | 3 +- board/inka4x0/Makefile | 4 +- board/inka4x0/inka4x0.c | 171 +++++++++----- board/inka4x0/inkadiag.c | 514 +++++++++++++++++++++++++++++++++++++++++++ common/command.c | 20 +- drivers/rtc/Makefile | 1 + drivers/rtc/rtc4543.c | 118 ++++++++++ drivers/twserial/Makefile | 46 ++++ drivers/twserial/soft_tws.c | 110 +++++++++ include/command.h | 4 +- include/configs/inka4x0.h | 91 +++++++- include/mpc5xxx.h | 124 +++++++++++ include/ns16550.h | 11 + include/rtc.h | 4 + include/tws.h | 47 ++++ 15 files changed, 1190 insertions(+), 78 deletions(-) create mode 100644 board/inka4x0/inkadiag.c create mode 100644 drivers/rtc/rtc4543.c create mode 100644 drivers/twserial/Makefile create mode 100644 drivers/twserial/soft_tws.c create mode 100644 include/tws.h
Other commands implementing subcommands can reuse this code nicely.
Signed-off-by: Detlev Zundel dzu@denx.de Signed-off-by: Andreas Pfefferle ap@denx.de --- common/command.c | 20 +++++++++++++------- include/command.h | 4 +++- 2 files changed, 16 insertions(+), 8 deletions(-)
diff --git a/common/command.c b/common/command.c index 3b9ccc9..c9a3f5b 100644 --- a/common/command.c +++ b/common/command.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2003 + * (C) Copyright 2000-2009 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -233,20 +233,19 @@ U_BOOT_CMD( * Use puts() instead of printf() to avoid printf buffer overflow * for long help messages */ -int do_help (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) + +int _do_help (cmd_tbl_t *cmd_start, int cmd_items, cmd_tbl_t * cmdtp, int + flag, int argc, char *argv[]) { int i; int rcode = 0;
if (argc == 1) { /*show list of commands */ - - int cmd_items = &__u_boot_cmd_end - - &__u_boot_cmd_start; /* pointer arith! */ cmd_tbl_t *cmd_array[cmd_items]; int i, j, swaps;
/* Make array of commands from .uboot_cmd section */ - cmdtp = &__u_boot_cmd_start; + cmdtp = cmd_start; for (i = 0; i < cmd_items; i++) { cmd_array[i] = cmdtp++; } @@ -286,7 +285,7 @@ int do_help (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) * command help (long version) */ for (i = 1; i < argc; ++i) { - if ((cmdtp = find_cmd (argv[i])) != NULL) { + if ((cmdtp = find_cmd_tbl (argv[i], cmd_start, cmd_items )) != NULL) { #ifdef CONFIG_SYS_LONGHELP /* found - print (long) help info */ puts (cmdtp->name); @@ -313,6 +312,13 @@ int do_help (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) return rcode; }
+int do_help (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{ + return _do_help(&__u_boot_cmd_start, + &__u_boot_cmd_end - &__u_boot_cmd_start, + cmdtp, flag, argc, argv); +} +
U_BOOT_CMD( help, CONFIG_SYS_MAXARGS, 1, do_help, diff --git a/include/command.h b/include/command.h index d7321af..bd47853 100644 --- a/include/command.h +++ b/include/command.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000 + * (C) Copyright 2000-2009 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -66,6 +66,8 @@ extern cmd_tbl_t __u_boot_cmd_end;
/* common/command.c */ +int _do_help (cmd_tbl_t *cmd_start, int cmd_items, cmd_tbl_t * cmdtp, int + flag, int argc, char *argv[]); cmd_tbl_t *find_cmd(const char *cmd); cmd_tbl_t *find_cmd_tbl (const char *cmd, cmd_tbl_t *table, int table_len);
Signed-off-by: Detlev Zundel dzu@denx.de --- include/mpc5xxx.h | 124 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 124 insertions(+), 0 deletions(-)
diff --git a/include/mpc5xxx.h b/include/mpc5xxx.h index 6138d45..463d5ae 100644 --- a/include/mpc5xxx.h +++ b/include/mpc5xxx.h @@ -30,6 +30,8 @@ #ifndef __ASMPPC_MPC5XXX_H #define __ASMPPC_MPC5XXX_H
+#include <asm/types.h> + /* Processor name */ #if defined(CONFIG_MPC5200) #define CPU_ID_STR "MPC5200" @@ -217,6 +219,12 @@ #define MPC5XXX_GPIO_SIMPLE_PSC1_1 0x00000002UL #define MPC5XXX_GPIO_SIMPLE_PSC1_0 0x00000001UL
+#define MPC5XXX_GPIO_SINT_ETH_16 0x80 +#define MPC5XXX_GPIO_SINT_ETH_15 0x40 +#define MPC5XXX_GPIO_SINT_ETH_14 0x20 +#define MPC5XXX_GPIO_SINT_ETH_13 0x10 +#define MPC5XXX_GPIO_SINT_USB1_9 0x08 +#define MPC5XXX_GPIO_SINT_PSC3_8 0x04 #define MPC5XXX_GPIO_SINT_PSC3_5 0x02 #define MPC5XXX_GPIO_SINT_PSC3_4 0x01
@@ -454,6 +462,99 @@ IORDY protocol */
#ifndef __ASSEMBLY__ +/* Memory map registers */ +struct mpc5xxx_mmap_ctl { + volatile u32 mbar; + volatile u32 cs0_start; /* 0x0004 */ + volatile u32 cs0_stop; + volatile u32 cs1_start; /* 0x000c */ + volatile u32 cs1_stop; + volatile u32 cs2_start; /* 0x0014 */ + volatile u32 cs2_stop; + volatile u32 cs3_start; /* 0x001c */ + volatile u32 cs3_stop; + volatile u32 cs4_start; /* 0x0024 */ + volatile u32 cs4_stop; + volatile u32 cs5_start; /* 0x002c */ + volatile u32 cs5_stop; +#if defined(CONFIG_MGT5100) + volatile u32 sdram_start; /* 0x0034 */ + volatile u32 sdram_stop; /* 0x0038 */ + volatile u32 pci1_start; /* 0x003c */ + volatile u32 pci1_stop; /* 0x0040 */ + volatile u32 pci2_start; /* 0x0044 */ + volatile u32 pci2_stop; /* 0x0048 */ +#elif defined(CONFIG_MPC5200) + volatile u32 sdram0; /* 0x0034 */ + volatile u32 sdram1; /* 0x0038 */ + volatile u32 dummy1[4]; /* 0x003c */ +#endif + volatile u32 boot_start; /* 0x004c */ + volatile u32 boot_stop; +#if defined(CONFIG_MGT5100) + volatile u32 addecr; /* 0x0054 */ +#elif defined(CONFIG_MPC5200) + volatile u32 ipbi_ws_ctrl; /* 0x0054 */ +#endif +#if defined(CONFIG_MPC5200) + volatile u32 cs6_start; /* 0x0058 */ + volatile u32 cs6_stop; + volatile u32 cs7_start; /* 0x0060 */ + volatile u32 cs7_stop; +#endif +}; + +/* Clock distribution module */ +struct mpc5xxx_cdm { + volatile u32 jtagid; /* 0x0000 */ + volatile u32 porcfg; + volatile u32 brdcrmb; /* 0x0008 */ + volatile u32 cfg; + volatile u32 fourtyeight_fdc;/* 0x0010 */ + volatile u32 clock_enable; + volatile u32 system_osc; /* 0x0018 */ + volatile u32 ccscr; + volatile u32 sreset; /* 0x0020 */ + volatile u32 pll_status; + volatile u32 psc1_mccr; /* 0x0028 */ + volatile u32 psc2_mccr; + volatile u32 psc3_mccr; /* 0x0030 */ + volatile u32 psc6_mccr; +}; + +/* SDRAM controller */ +struct mpc5xxx_sdram { + volatile u32 mode; + volatile u32 ctrl; + volatile u32 config1; + volatile u32 config2; +#if defined(CONFIG_MGT5100) + volatile u32 xlbsel; + volatile u32 dummy[31]; +#else + volatile u32 dummy[32]; +#endif + volatile u32 sdelay; +}; + +struct mpc5xxx_lpb { + volatile u32 cs0_cfg; + volatile u32 cs1_cfg; + volatile u32 cs2_cfg; + volatile u32 cs3_cfg; + volatile u32 cs4_cfg; + volatile u32 cs5_cfg; + volatile u32 cs_ctrl; + volatile u32 cs_status; +#if defined(CONFIG_MPC5200) + volatile u32 cs6_cfg; + volatile u32 cs7_cfg; + volatile u32 cs_burst; + volatile u32 cs_deadcycle; +#endif +}; + + struct mpc5xxx_psc { volatile u8 mode; /* PSC + 0x00 */ volatile u8 reserved0[3]; @@ -596,6 +697,29 @@ struct mpc5xxx_gpio { volatile u8 reserved10; /* GPIO + 0x3f */ };
+struct mpc5xxx_wu_gpio { + volatile u8 enable; /* WU_GPIO + 0x00 */ + volatile u8 reserved1[3]; /* WU_GPIO + 0x01 */ + volatile u8 ode; /* WU_GPIO + 0x04 */ + volatile u8 reserved2[3]; /* WU_GPIO + 0x05 */ + volatile u8 ddr; /* WU_GPIO + 0x08 */ + volatile u8 reserved3[3]; /* WU_GPIO + 0x09 */ + volatile u8 dvo; /* WU_GPIO + 0x0c */ + volatile u8 reserved4[3]; /* WU_GPIO + 0x0d */ + volatile u8 inten; /* WU_GPIO + 0x10 */ + volatile u8 reserved5[3]; /* WU_GPIO + 0x11 */ + volatile u8 iinten; /* WU_GPIO + 0x14 */ + volatile u8 reserved6[3]; /* WU_GPIO + 0x15 */ + volatile u16 itype; /* WU_GPIO + 0x18 */ + volatile u8 reserved7[2]; /* WU_GPIO + 0x1a */ + volatile u8 master_enable; /* WU_GPIO + 0x1c */ + volatile u8 reserved8[3]; /* WU_GPIO + 0x1d */ + volatile u8 ival; /* WU_GPIO + 0x20 */ + volatile u8 reserved9[3]; /* WU_GPIO + 0x21 */ + volatile u8 status; /* WU_GPIO + 0x24 */ + volatile u8 reserved10[3]; /* WU_GPIO + 0x25 */ +}; + struct mpc5xxx_sdma { volatile u32 taskBar; /* SDMA + 0x00 */ volatile u32 currentPointer; /* SDMA + 0x04 */
This pretty unintelligent interface is used on some RTC chips.
Signed-off-by: Detlev Zundel dzu@denx.de --- Makefile | 3 +- drivers/twserial/Makefile | 46 ++++++++++++++++++ drivers/twserial/soft_tws.c | 110 +++++++++++++++++++++++++++++++++++++++++++ include/tws.h | 47 ++++++++++++++++++ 4 files changed, 205 insertions(+), 1 deletions(-) create mode 100644 drivers/twserial/Makefile create mode 100644 drivers/twserial/soft_tws.c create mode 100644 include/tws.h
diff --git a/Makefile b/Makefile index 63b9909..7c37845 100644 --- a/Makefile +++ b/Makefile @@ -1,5 +1,5 @@ # -# (C) Copyright 2000-2008 +# (C) Copyright 2000-2009 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # See file CREDITS for list of people who contributed to this @@ -262,6 +262,7 @@ TAG_SUBDIRS += cpu/mpc8xxx endif LIBS += drivers/rtc/librtc.a LIBS += drivers/serial/libserial.a +LIBS += drivers/twserial/libtws.a LIBS += drivers/usb/libusb.a LIBS += drivers/video/libvideo.a LIBS += common/libcommon.a diff --git a/drivers/twserial/Makefile b/drivers/twserial/Makefile new file mode 100644 index 0000000..0b059f3 --- /dev/null +++ b/drivers/twserial/Makefile @@ -0,0 +1,46 @@ +# +# (C) Copyright 2009 +# Detlev Zundel, DENX Software Engineering, dzu@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libtws.a + +COBJS-$(CONFIG_SOFT_TWS) += soft_tws.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/drivers/twserial/soft_tws.c b/drivers/twserial/soft_tws.c new file mode 100644 index 0000000..f63fc3f --- /dev/null +++ b/drivers/twserial/soft_tws.c @@ -0,0 +1,110 @@ +/* + * (C) Copyright 2009 + * Detlev Zundel, DENX Software Engineering, dzu@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#define TWS_IMPLEMENTATION +#include <common.h> + +/*=====================================================================*/ +/* Public Functions */ +/*=====================================================================*/ + +/*----------------------------------------------------------------------- + * Read bits + */ +int tws_read(uchar *buffer, int len) +{ + int rem = len; + uchar accu, shift; + + debug("tws_read: buffer %p len %d\n", buffer, len); + + /* Configure the data pin for input */ + tws_data_config_output(0); + + /* Disable WR, i.e. setup a read */ + tws_wr(0); + udelay(1); + + /* Rise CE */ + tws_ce(1); + udelay(1); + + for (; rem > 0; ) { + for (shift = 0, accu = 0; + (rem > 0) && (shift < 8); + rem--, shift++) { + tws_clk(1); + udelay(10); + accu |= (tws_data_read() << shift); /* LSB first */ + tws_clk(0); + udelay(10); + } + *buffer++ = accu; + } + + /* Lower CE */ + tws_ce(0); + + return len - rem; +} + + +/*----------------------------------------------------------------------- + * Write bits + */ +int tws_write(uchar *buffer, int len) +{ + int rem = len; + uchar accu, shift; + debug("tws_write: buffer %p len %d\n", buffer, len); + + /* Configure the data pin for output */ + tws_data_config_output(1); + + /* Enable WR, i.e. setup a write */ + tws_wr(1); + udelay(1); + + /* Rise CE */ + tws_ce(1); + udelay(1); + + for (; rem > 0; ) { + for (shift = 0, accu = *buffer++; + (rem > 0) && (shift < 8); + rem--, shift++) { + tws_data(accu & 0x01); /* LSB first */ + tws_clk(1); + udelay(10); + tws_clk(0); + udelay(10); + accu >>= 1; + } + } + + /* Lower CE */ + tws_ce(0); + + return len - rem; +} diff --git a/include/tws.h b/include/tws.h new file mode 100644 index 0000000..bfa8d58 --- /dev/null +++ b/include/tws.h @@ -0,0 +1,47 @@ +/* + * (C) Copyright 2009 + * Detlev Zundel, DENX Software Engineering, dzu@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#ifndef _TWS_H_ +#define _TWS_H_ + +#ifndef TWS_SOFT_DECLARATIONS +# if defined(CONFIG_MPC5xxx) +# define TWS_SOFT_DECLARATIONS \ + volatile ioport_t *iop = ioport_addr((immap_t *)CONFIG_SYS_IMMR, I2C_PORT); +# else +# define TWS_SOFT_DECLARATIONS +# endif +#endif + +/* + * Read/Write interface: + * buffer: Where to read/write the data + * len: How many bits to read/write + * + * Returns: 0 on success, not 0 on failure + */ +int tws_read(uchar *buffer, int len); +int tws_write(uchar *buffer, int len); + +#endif /* _TWS_H_ */
Signed-off-by: Detlev Zundel dzu@denx.de Signed-off-by: Andreas Pfefferle ap@denx.de --- drivers/rtc/Makefile | 1 + drivers/rtc/rtc4543.c | 118 +++++++++++++++++++++++++++++++++++++++++++++++++ include/rtc.h | 4 ++ 3 files changed, 123 insertions(+), 0 deletions(-) create mode 100644 drivers/rtc/rtc4543.c
diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index 94bc518..6adece2 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -55,6 +55,7 @@ COBJS-$(CONFIG_RTC_MPC8xx) += mpc8xx.o COBJS-$(CONFIG_RTC_PCF8563) += pcf8563.o COBJS-$(CONFIG_RTC_PL031) += pl031.o COBJS-$(CONFIG_RTC_RS5C372A) += rs5c372.o +COBJS-$(CONFIG_RTC_RTC4543) += rtc4543.o COBJS-$(CONFIG_RTC_RX8025) += rx8025.o COBJS-$(CONFIG_RTC_S3C24X0) += s3c24x0_rtc.o COBJS-$(CONFIG_RTC_X1205) += x1205.o diff --git a/drivers/rtc/rtc4543.c b/drivers/rtc/rtc4543.c new file mode 100644 index 0000000..242d9bc --- /dev/null +++ b/drivers/rtc/rtc4543.c @@ -0,0 +1,118 @@ +/* + * (C) Copyright 2008, 2009 + * Andreas Pfefferle, DENX Software Engineering, ap@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/io.h> +#include <common.h> +#include <command.h> +#include <config.h> +#include <bcd.h> +#include <rtc.h> +#include <tws.h> + +#if defined(CONFIG_CMD_DATE) + +/* + * Note: The acrobatics below is due to the hideously ingenius idea of + * the chip designers. As the chip does not allow register + * addressing, all values need to be read and written in one go. Sure + * enough, the 'wday' field (0-6) is transferred using the economic + * number of 4 bits right in the middle of the packet..... + */ + +int rtc_get(struct rtc_time *tm) +{ + int rel = 0; + uchar buffer[7]; + + memset(buffer, 0, 7); + + /* Read 52 bits into our buffer */ + tws_read(buffer, 52); + + tm->tm_sec = BCD2BIN( buffer[0] & 0x7F); + tm->tm_min = BCD2BIN( buffer[1] & 0x7F); + tm->tm_hour = BCD2BIN( buffer[2] & 0x3F); + tm->tm_wday = BCD2BIN( buffer[3] & 0x07); + tm->tm_mday = BCD2BIN((buffer[3] & 0xF0) >> 4 | (buffer[4] & 0x0F) << 4); + tm->tm_mon = BCD2BIN((buffer[4] & 0x30) >> 4 | (buffer[5] & 0x0F) << 4); + tm->tm_year = BCD2BIN((buffer[5] & 0xF0) >> 4 | (buffer[6] & 0x0F) << 4) + 2000; + tm->tm_yday = 0; + tm->tm_isdst = 0; + + if (tm->tm_sec & 0x80) { + puts("### Warning: RTC Low Voltage - date/time not reliable\n"); + rel = -1; + } + + debug("Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tm->tm_year, tm->tm_mon, tm->tm_mday, tm->tm_wday, + tm->tm_hour, tm->tm_min, tm->tm_sec); + + return rel; +} + +int rtc_set(struct rtc_time *tm) +{ + uchar buffer[7]; + uchar tmp; + + debug("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tm->tm_year, tm->tm_mon, tm->tm_mday, tm->tm_wday, + tm->tm_hour, tm->tm_min, tm->tm_sec); + + memset(buffer, 0, 7); + buffer[0] = BIN2BCD(tm->tm_sec); + buffer[1] = BIN2BCD(tm->tm_min); + buffer[2] = BIN2BCD(tm->tm_hour); + buffer[3] = BIN2BCD(tm->tm_wday); + tmp = BIN2BCD(tm->tm_mday); + buffer[3] |= (tmp & 0x0F) << 4; + buffer[4] = (tmp & 0xF0) >> 4; + tmp = BIN2BCD(tm->tm_mon); + buffer[4] |= (tmp & 0x0F) << 4; + buffer[5] = (tmp & 0xF0) >> 4; + tmp = BIN2BCD(tm->tm_year % 100); + buffer[5] |= (tmp & 0x0F) << 4; + buffer[6] = (tmp & 0xF0) >> 4; + + /* Write the resulting 52 bits to device */ + tws_write(buffer, 52); + + return 0; +} + +void rtc_reset(void) +{ + struct rtc_time tmp; + + tmp.tm_sec = 0; + tmp.tm_min = 0; + tmp.tm_hour = 0; + tmp.tm_wday = 4; + tmp.tm_mday = 1; + tmp.tm_mon = 1; + tmp.tm_year = 2000; + rtc_set(&tmp); +} + +#endif diff --git a/include/rtc.h b/include/rtc.h index 785fbe3..019c2eb 100644 --- a/include/rtc.h +++ b/include/rtc.h @@ -61,4 +61,8 @@ void to_tm (int, struct rtc_time *); unsigned long mktime (unsigned int, unsigned int, unsigned int, unsigned int, unsigned int, unsigned int);
+uchar rtc_read(uchar reg) __attribute__((weak)); +void rtc_write(uchar reg, uchar val) __attribute__((weak)); + + #endif /* _RTC_H_ */
This patch adds advanced diagnosis functions for the inka4x0 board.
Signed-off-by: Andreas Pfefferle ap@denx.de Signed-off-by: Detlev Zundel dzu@denx.de --- board/inka4x0/Makefile | 4 +- board/inka4x0/inka4x0.c | 20 ++- board/inka4x0/inkadiag.c | 514 +++++++++++++++++++++++++++++++++++++++++++++ include/configs/inka4x0.h | 1 + include/ns16550.h | 11 + 5 files changed, 546 insertions(+), 4 deletions(-) create mode 100644 board/inka4x0/inkadiag.c
diff --git a/board/inka4x0/Makefile b/board/inka4x0/Makefile index 442e2d0..82aa950 100644 --- a/board/inka4x0/Makefile +++ b/board/inka4x0/Makefile @@ -1,5 +1,5 @@ # -# (C) Copyright 2003-2006 +# (C) Copyright 2003-2009 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # See file CREDITS for list of people who contributed to this @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS := $(BOARD).o +COBJS := $(BOARD).o inkadiag.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/inka4x0/inka4x0.c b/board/inka4x0/inka4x0.c index 507196b..bb5c25d 100644 --- a/board/inka4x0/inka4x0.c +++ b/board/inka4x0/inka4x0.c @@ -1,6 +1,9 @@ /* - * (C) Copyright 2003-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * (C) Copyright 2008-2009 + * Andreas Pfefferle, DENX Software Engineering, ap@denx.de. + * + * (C) Copyright 2009 + * Detlev Zundel, DENX Software Engineering, dzu@denx.de. * * (C) Copyright 2004 * Mark Jonas, Freescale Semiconductor, mark.jonas@motorola.com. @@ -8,6 +11,9 @@ * (C) Copyright 2004 * Martin Krause, TQ-Systems GmbH, martin.krause@tqs.de * + * (C) Copyright 2003-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * * See file CREDITS for list of people who contributed to this * project. * @@ -171,6 +177,16 @@ void flash_preinit(void) *(vu_long *)MPC5XXX_BOOTCS_CFG &= ~0x1; /* clear RO */ }
+int misc_init_r (void) { + extern int inkadiag_init_r (void); + + /* + * The command table used for the subcommands of inkadiag + * needs to be relocated manually. + */ + return inkadiag_init_r(); +} + int misc_init_f (void) { char tmp[10]; diff --git a/board/inka4x0/inkadiag.c b/board/inka4x0/inkadiag.c new file mode 100644 index 0000000..06c9807 --- /dev/null +++ b/board/inka4x0/inkadiag.c @@ -0,0 +1,514 @@ +/* + * (C) Copyright 2008, 2009 Andreas Pfefferle, + * DENX Software Engineering, ap@denx.de. + * (C) Copyright 2009 Detlev Zundel, + * DENX Software Engineering, dzu@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/io.h> +#include <common.h> +#include <config.h> +#include <mpc5xxx.h> +#include <pci.h> + +#include <command.h> + +/* This is needed for the includes in ns16550.h */ +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#include <ns16550.h> + +#define GPIO_BASE ((u_char *)CONFIG_SYS_CS3_START) + +#define DIGIN_TOUCHSCR_MASK 0x00003000 /* Inputs 12-13 */ +#define DIGIN_KEYB_MASK 0x00010000 /* Input 16 */ + +#define DIGIN_DRAWER_SW1 0x00400000 /* Input 22 */ +#define DIGIN_DRAWER_SW2 0x00800000 /* Input 23 */ + +#define DIGIO_LED0 0x00000001 /* Output 0 */ +#define DIGIO_LED1 0x00000002 /* Output 1 */ +#define DIGIO_LED2 0x00000004 /* Output 2 */ +#define DIGIO_LED3 0x00000008 /* Output 3 */ +#define DIGIO_LED4 0x00000010 /* Output 4 */ +#define DIGIO_LED5 0x00000020 /* Output 5 */ + +#define DIGIO_DRAWER1 0x00000100 /* Output 8 */ +#define DIGIO_DRAWER2 0x00000200 /* Output 9 */ + +#define SERIAL_PORT_BASE ((u_char *)CONFIG_SYS_CS2_START) + +#define PSC_OP1_RTS 0x01 +#define PSC_OP0_RTS 0x01 + +/* + * Table with supported baudrates (defined in inka4x0.h) + */ +static const unsigned long baudrate_table[] = CONFIG_SYS_BAUDRATE_TABLE; +#define N_BAUDRATES (sizeof(baudrate_table) / sizeof(baudrate_table[0])) + +static unsigned int inka_digin_get_input(void) +{ + return in_8(GPIO_BASE + 0) << 0 | in_8(GPIO_BASE + 1) << 8 | + in_8(GPIO_BASE + 2) << 16 | in_8(GPIO_BASE + 3) << 24; +} + +#define LED_HIGH(NUM) \ + do { \ + setbits_be32((unsigned *)MPC5XXX_GPT##NUM##_ENABLE, 0x10); \ + } while (0) + +#define LED_LOW(NUM) \ + do { \ + clrbits_be32((unsigned *)MPC5XXX_GPT##NUM##_ENABLE, 0x10); \ + } while (0) + +#define CHECK_LED(NUM) \ + do { \ + if (state & (1 << NUM)) { \ + LED_HIGH(NUM); \ + } else { \ + LED_LOW(NUM); \ + } \ + } while (0) + +static void inka_digio_set_output(unsigned int state, int which) +{ + volatile struct mpc5xxx_gpio *gpio = (struct mpc5xxx_gpio *)MPC5XXX_GPIO; + + if (which == 0) { + /* other */ + CHECK_LED(0); + CHECK_LED(1); + CHECK_LED(2); + CHECK_LED(3); + CHECK_LED(4); + CHECK_LED(5); + } else { + if (which == 1) { + /* drawer1 */ + if (state) { + clrbits_be32(&gpio->simple_dvo, 0x1000); + udelay(1); + setbits_be32(&gpio->simple_dvo, 0x1000); + } else { + setbits_be32(&gpio->simple_dvo, 0x1000); + udelay(1); + clrbits_be32(&gpio->simple_dvo, 0x1000); + } + } + if (which == 2) { + /* drawer 2 */ + if (state) { + clrbits_be32(&gpio->simple_dvo, 0x2000); + udelay(1); + setbits_be32(&gpio->simple_dvo, 0x2000); + } else { + setbits_be32(&gpio->simple_dvo, 0x2000); + udelay(1); + clrbits_be32(&gpio->simple_dvo, 0x2000); + } + } + } + udelay(1); +} + +static int do_inkadiag_io(cmd_tbl_t *cmdtp, int flag, int argc, + char *argv[]) { + unsigned int state, val; + + switch (argc) { + case 3: + /* Write a value */ + val = simple_strtol(argv[2], NULL, 16); + + if (strcmp(argv[1], "drawer1") == 0) { + inka_digio_set_output(val, 1); + } else if (strcmp(argv[1], "drawer2") == 0) { + inka_digio_set_output(val, 2); + } else if (strcmp(argv[1], "other") == 0) + inka_digio_set_output(val, 0); + else { + printf("Invalid argument: %s\n", argv[1]); + return -1; + } + /* fall through */ + case 2: + /* Read a value */ + state = inka_digin_get_input(); + + if (strcmp(argv[1], "drawer1") == 0) { + val = (state & DIGIN_DRAWER_SW1) >> (ffs(DIGIN_DRAWER_SW1) - 1); + } else if (strcmp(argv[1], "drawer2") == 0) { + val = (state & DIGIN_DRAWER_SW2) >> (ffs(DIGIN_DRAWER_SW2) - 1); + } else if (strcmp(argv[1], "other") == 0) { + val = ((state & DIGIN_KEYB_MASK) >> (ffs(DIGIN_KEYB_MASK) - 1)) + | (state & DIGIN_TOUCHSCR_MASK) >> (ffs(DIGIN_TOUCHSCR_MASK) - 2); + } else { + printf("Invalid argument: %s\n", argv[1]); + return -1; + } + printf("exit code: 0x%X\n", val); + return 0; + default: + cmd_usage(cmdtp); + break; + } + + return -1; +} + +DECLARE_GLOBAL_DATA_PTR; + +static int ser_init(volatile struct mpc5xxx_psc *psc, int baudrate) +{ + unsigned long baseclk; + int div; + + /* reset PSC */ + out_8(&psc->command, PSC_SEL_MODE_REG_1); + + /* select clock sources */ + + out_be16(&psc->psc_clock_select, 0); + baseclk = (gd->ipb_clk + 16) / 32; + + /* switch to UART mode */ + out_be32(&psc->sicr, 0); + + /* configure parity, bit length and so on */ + + out_8(&psc->mode, PSC_MODE_8_BITS | PSC_MODE_PARNONE); + out_8(&psc->mode, PSC_MODE_ONE_STOP); + + /* set up UART divisor */ + div = (baseclk + (baudrate / 2)) / baudrate; + out_8(&psc->ctur, (div >> 8) & 0xff); + out_8(&psc->ctlr, div & 0xff); + + /* disable all interrupts */ + out_be16(&psc->psc_imr, 0); + + /* reset and enable Rx/Tx */ + out_8(&psc->command, PSC_RST_RX); + out_8(&psc->command, PSC_RST_TX); + out_8(&psc->command, PSC_RX_ENABLE | PSC_TX_ENABLE); + + return 0; +} + +static void ser_putc(volatile struct mpc5xxx_psc *psc, const char c) +{ + /* Wait 1 second for last character to go. */ + int i = 0; + + while (!(psc->psc_status & PSC_SR_TXEMP) && (i++ < 1000000/10)) + udelay(10); + psc->psc_buffer_8 = c; + +} + +static int ser_getc(volatile struct mpc5xxx_psc *psc) +{ + /* Wait for a character to arrive. */ + int i = 0; + + while (!(in_be16(&psc->psc_status) & PSC_SR_RXRDY) && (i++ < 1000000/10)) + udelay(10); + + return in_8(&psc->psc_buffer_8); +} + +static int do_inkadiag_serial(cmd_tbl_t *cmdtp, int flag, int argc, + char *argv[]) { + volatile struct NS16550 *uart; + volatile struct mpc5xxx_psc *psc; + unsigned int num, mode; + int combrd, baudrate, i, j, len; + int address; + + if (argc < 5) { + cmd_usage(cmdtp); + return 1; + } + + argc--; + argv++; + + num = simple_strtol(argv[0], NULL, 0); + if (num < 0 || num > 11) { + printf("invalid argument for num: %d\n", num); + return -1; + } + + mode = simple_strtol(argv[1], NULL, 0); + + combrd = 0; + baudrate = simple_strtoul(argv[2], NULL, 10); + for (i=0; i<N_BAUDRATES; ++i) { + if (baudrate == baudrate_table[i]) + break; + } + if (i == N_BAUDRATES) { + printf("## Baudrate %d bps not supported\n", + baudrate); + return 1; + } + combrd = 115200 / baudrate; + + uart = (struct NS16550 *)(SERIAL_PORT_BASE + (num << 3)); + + printf("Testing uart %d.\n\n", num); + + if ((num >= 0) && (num <= 7)) { + if (mode & 1) { + /* turn on 'loopback' mode */ + out_8(&uart->mcr, MCR_LOOP); + } else { + /* + * establish the UART's operational parameters + * set DLAB=1, so rbr accesses DLL + */ + out_8(&uart->lcr, LCR_DLAB); + /* set baudrate */ + out_8(&uart->rbr, combrd); + /* set data-format: 8-N-1 */ + out_8(&uart->lcr, LCR_WLS_8); + } + + if (mode & 2) { + /* set request to send */ + out_8(&uart->mcr, MCR_RTS); + udelay(10); + /* check clear to send */ + if ((in_8(&uart->msr) & MSR_CTS) == 0x00) + return -1; + } + if (mode & 4) { + /* set data terminal ready */ + out_8(&uart->mcr, MCR_DTR); + udelay(10); + /* check data set ready and carrier detect */ + if ((in_8(&uart->msr) & (MSR_DSR | MSR_DCD)) + != (MSR_DSR | MSR_DCD)) + return -1; + } + + /* write each message-character, read it back, and display it */ + for (i = 0, len = strlen(argv[3]); i < len; ++i) { + j = 0; + while ((in_8(&uart->lsr) & LSR_THRE) == 0x00) { + if (j++ > CONFIG_SYS_HZ) + break; + udelay(10); + } + out_8(&uart->rbr, argv[3][i]); + j = 0; + while ((in_8(&uart->lsr) & LSR_DR) == 0x00) { + if (j++ > CONFIG_SYS_HZ) + break; + udelay(10); + } + printf("%c", in_8(&uart->rbr)); + } + printf("\n\n"); + out_8(&uart->mcr, 0x00); + } else { + address = 0; + + switch (num) { + case 8: + address = MPC5XXX_PSC6; + break; + case 9: + address = MPC5XXX_PSC3; + break; + case 10: + address = MPC5XXX_PSC2; + break; + case 11: + address = MPC5XXX_PSC1; + break; + } + psc = (struct mpc5xxx_psc *)address; + ser_init(psc, simple_strtol(argv[2], NULL, 0)); + if (mode & 2) { + /* set request to send */ + out_8(&psc->op0, PSC_OP0_RTS); + udelay(10); + /* check clear to send */ + if ((in_8(&psc->ip) & PSC_IPCR_CTS) == 0) + return -1; + } + len = strlen(argv[3]); + for (i = 0; i < len; ++i) { + ser_putc(psc, argv[3][i]); + printf("%c", ser_getc(psc)); + } + printf("\n\n"); + } + return 0; +} + +#define BUZZER_GPT (MPC5XXX_GPT + 0x60) /* GPT6 */ +static void buzzer_turn_on(unsigned int freq) +{ + volatile struct mpc5xxx_gpt *gpt = (struct mpc5xxx_gpt *)(BUZZER_GPT); + + const u32 prescale = gd->ipb_clk / freq / 128; + const u32 count = 128; + const u32 width = 64; + + gpt->cir = (prescale << 16) | count; + gpt->pwmcr = width << 16; + gpt->emsr = 3; /* Timer enabled for PWM */ +} + +static void buzzer_turn_off(void) +{ + volatile struct mpc5xxx_gpt *gpt = (struct mpc5xxx_gpt *)(BUZZER_GPT); + + gpt->emsr = 0; +} + +static int do_inkadiag_buzzer(cmd_tbl_t *cmdtp, int flag, int argc, + char *argv[]) { + + unsigned int period, freq; + int prev, i; + + if (argc != 3) { + cmd_usage(cmdtp); + return 1; + } + + argc--; + argv++; + + period = simple_strtol(argv[0], NULL, 0); + if (!period) + printf("Zero period is senseless\n"); + argc--; + argv++; + + freq = simple_strtol(argv[0], NULL, 0); + /* avoid zero prescale in buzzer_turn_on() */ + if (freq > gd->ipb_clk / 128) { + printf("%dHz exceeds maximum (%ldHz)\n", freq, + gd->ipb_clk / 128); + } else if (!freq) + printf("Zero frequency is senseless\n"); + else + buzzer_turn_on(freq); + + clear_ctrlc(); + prev = disable_ctrlc(0); + + printf("Buzzing for %d ms. Type ^C to abort!\n\n", period); + + i = 0; + while (!ctrlc() && (i++ < CONFIG_SYS_HZ)) + udelay(period); + + clear_ctrlc(); + disable_ctrlc(prev); + + buzzer_turn_off(); + + return 0; +} + +static int do_inkadiag_help(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); + +cmd_tbl_t cmd_inkadiag_sub[] = { + U_BOOT_CMD_MKENT(io, 1, 1, do_inkadiag_io, "read digital input", + "<drawer1|drawer2|other> [value] - get or set specified signal\n"), + U_BOOT_CMD_MKENT(serial, 4, 1, do_inkadiag_serial, "test serial port", + "<num> <mode> <baudrate> <msg> - test uart num [0..11] in mode\n" + "and baudrate with msg\n"), + U_BOOT_CMD_MKENT(buzzer, 2, 1, do_inkadiag_buzzer, "activate buzzer", + "<period> <freq> - turn buzzer on for period ms with freq hz\n"), + U_BOOT_CMD_MKENT(help, 4, 1, do_inkadiag_help, "get help", + "[command] - get help for command\n"), +}; + +static int do_inkadiag_help(cmd_tbl_t *cmdtp, int flag, + int argc, char *argv[]) { + extern int _do_help (cmd_tbl_t *cmd_start, int cmd_items, + cmd_tbl_t *cmdtp, int flag, + int argc, char *argv[]); + /* do_help prints command name - we prepend inkadiag to our subcommands! */ +#ifdef CONFIG_SYS_LONGHELP + puts ("inkadiag "); +#endif + return _do_help(&cmd_inkadiag_sub[0], + ARRAY_SIZE(cmd_inkadiag_sub), cmdtp, flag, argc, argv); +} + +static int do_inkadiag(cmd_tbl_t *cmdtp, int flag, int argc, + char *argv[]) { + cmd_tbl_t *c; + + c = find_cmd_tbl(argv[1], &cmd_inkadiag_sub[0], ARRAY_SIZE(cmd_inkadiag_sub)); + + if (c) { + argc--; + argv++; + return c->cmd(c, flag, argc, argv); + } else { + /* Unrecognized command */ + cmd_usage(cmdtp); + return 1; + } +} + +U_BOOT_CMD(inkadiag, 6, 1, do_inkadiag, + "inkadiag - inka diagnosis\n", + "[inkadiag what ...]\n" + " - perform a diagnosis on inka hardware\n" + "'inkadiag' performs hardware tests.\n\n"); + +/* Relocate the command table function pointers when running in RAM */ +int inkadiag_init_r (void) { + cmd_tbl_t *cmdtp; + + for (cmdtp = &cmd_inkadiag_sub[0]; cmdtp != + &cmd_inkadiag_sub[ARRAY_SIZE(cmd_inkadiag_sub)]; cmdtp++) { + ulong addr; + + addr = (ulong) (cmdtp->cmd) + gd->reloc_off; + cmdtp->cmd = (int (*)(struct cmd_tbl_s *, int, int, char *[]))addr; + + addr = (ulong)(cmdtp->name) + gd->reloc_off; + cmdtp->name = (char *)addr; + + if (cmdtp->usage) { + addr = (ulong)(cmdtp->usage) + gd->reloc_off; + cmdtp->usage = (char *)addr; + } +#ifdef CONFIG_SYS_LONGHELP + if (cmdtp->help) { + addr = (ulong)(cmdtp->help) + gd->reloc_off; + cmdtp->help = (char *)addr; + } +#endif + } + return 0; +} diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index e42fa6d..b80796d 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -39,6 +39,7 @@ #define BOOTFLAG_WARM 0x02 /* Software reboot */
#define CONFIG_MISC_INIT_F 1 /* Use misc_init_f() */ +#define CONFIG_MISC_INIT_R 1 /* Use misc_init_r() */
#define CONFIG_HIGH_BATS 1 /* High BATs supported */
diff --git a/include/ns16550.h b/include/ns16550.h index e6ade61..edfbc53 100644 --- a/include/ns16550.h +++ b/include/ns16550.h @@ -123,6 +123,7 @@ typedef volatile struct NS16550 *NS16550_t; #define MCR_RTS 0x02 #define MCR_DMA_EN 0x04 #define MCR_TX_DFR 0x08 +#define MCR_LOOP 0x10 /* Enable loopback test mode */
#define LCR_WLS_MSK 0x03 /* character length select mask */ #define LCR_WLS_5 0x00 /* 5 bit character length */ @@ -135,6 +136,7 @@ typedef volatile struct NS16550 *NS16550_t; #define LCR_STKP 0x20 /* Stick Parity */ #define LCR_SBRK 0x40 /* Set Break */ #define LCR_BKSE 0x80 /* Bank select enable */ +#define LCR_DLAB 0x80 /* Divisor latch access bit */
#define LSR_DR 0x01 /* Data ready */ #define LSR_OE 0x02 /* Overrun */ @@ -145,6 +147,15 @@ typedef volatile struct NS16550 *NS16550_t; #define LSR_TEMT 0x40 /* Xmitter empty */ #define LSR_ERR 0x80 /* Error */
+#define MSR_DCD 0x80 /* Data Carrier Detect */ +#define MSR_RI 0x40 /* Ring Indicator */ +#define MSR_DSR 0x20 /* Data Set Ready */ +#define MSR_CTS 0x10 /* Clear to Send */ +#define MSR_DDCD 0x08 /* Delta DCD */ +#define MSR_TERI 0x04 /* Trailing edge ring indicator */ +#define MSR_DDSR 0x02 /* Delta DSR */ +#define MSR_DCTS 0x01 /* Delta CTS */ + #ifdef CONFIG_OMAP1510 #define OSC_12M_SEL 0x01 /* selects 6.5 * current clk div */ #endif
This patch adds the board specific communication routines needed by the external 4543 RTC.
Signed-off-by: Detlev Zundel dzu@denx.de Signed-off-by: Andreas Pfefferle ap@denx.de --- board/inka4x0/inka4x0.c | 20 ++++++++++ include/configs/inka4x0.h | 90 ++++++++++++++++++++++++++++++++++++++++++-- 2 files changed, 105 insertions(+), 5 deletions(-)
diff --git a/board/inka4x0/inka4x0.c b/board/inka4x0/inka4x0.c index bb5c25d..a8bc3b3 100644 --- a/board/inka4x0/inka4x0.c +++ b/board/inka4x0/inka4x0.c @@ -33,6 +33,7 @@ * MA 02111-1307 USA */
+#include <asm/io.h> #include <common.h> #include <mpc5xxx.h> #include <pci.h> @@ -189,6 +190,8 @@ int misc_init_r (void) {
int misc_init_f (void) { + struct mpc5xxx_gpio *gpio = (struct mpc5xxx_gpio *)MPC5XXX_GPIO; + struct mpc5xxx_wu_gpio *wu_gpio = (struct mpc5xxx_wu_gpio *)MPC5XXX_WU_GPIO; char tmp[10]; int i, br;
@@ -236,6 +239,23 @@ int misc_init_f (void) *(vu_long *) MPC5XXX_WU_GPIO_ENABLE |= GPIO_PSC3_9; *(vu_long *) MPC5XXX_WU_GPIO_DIR |= GPIO_PSC3_9; *(vu_long *) MPC5XXX_WU_GPIO_DATA_O |= GPIO_PSC3_9; + + /* + * Configure three wire serial interface to RTC (PSC1_4, + * PSC2_4, PSC3_4, PSC3_5) + */ + setbits_8(&wu_gpio->enable, MPC5XXX_GPIO_WKUP_PSC1_4 | + MPC5XXX_GPIO_WKUP_PSC2_4); + setbits_8(&wu_gpio->ddr, MPC5XXX_GPIO_WKUP_PSC1_4 | + MPC5XXX_GPIO_WKUP_PSC2_4); + clrbits_8(&wu_gpio->dvo, MPC5XXX_GPIO_WKUP_PSC1_4); + clrbits_8(&gpio->sint_inten, MPC5XXX_GPIO_SINT_PSC3_4 | + MPC5XXX_GPIO_SINT_PSC3_5); + setbits_8(&gpio->sint_gpioe, MPC5XXX_GPIO_SINT_PSC3_4 | + MPC5XXX_GPIO_SINT_PSC3_5); + setbits_8(&gpio->sint_ddr, MPC5XXX_GPIO_SINT_PSC3_5); + clrbits_8(&gpio->sint_dvo, MPC5XXX_GPIO_SINT_PSC3_5); + return 0; }
diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index b80796d..5f06b09 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -1,4 +1,7 @@ /* + * (C) Copyright 2009 + * Detlev Zundel, DENX Software Engineering, dzu@denx.de. + * * (C) Copyright 2003-2005 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * @@ -90,16 +93,17 @@ */ #include <config_cmd_default.h>
+#define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_IDE #define CONFIG_CMD_NFS #define CONFIG_CMD_PCI +#define CONFIG_CMD_PING #define CONFIG_CMD_SNTP #define CONFIG_CMD_USB
- #define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */
#if (TEXT_BASE == 0xFFE00000) /* Boot low */ @@ -240,15 +244,91 @@ * 01 -> CAN1 on I2C1, CAN2 on Tmr0/1 do not use on TQM5200 with onboard * EEPROM * use PSC1 as UART: Bits 28-31 (mask: 0x00000007): 0100 - * use PSC6_1 and PSC6_3 as GPIO: Bits 9:11 (mask: 0x07000000): - * 011 -> PSC6 could not be used as UART or CODEC. IrDA still possible. + * use PSC2 as UART: Bits 24-27 (mask: 0x00000070): 0100 + * use PSC3 as UART: Bits 20-23 (mask: 0x00000700): 0100 + * use PSC6 as UART: Bits 9-11 (mask: 0x00700000): 0101 */ -#define CONFIG_SYS_GPS_PORT_CONFIG 0x01001004 +#define CONFIG_SYS_GPS_PORT_CONFIG 0x01501444
/* * RTC configuration */ -#define CONFIG_RTC_MPC5200 1 /* use internal MPC5200 RTC */ +#define CONFIG_RTC_RTC4543 1 /* use external RTC */ + +/* + * Software (bit-bang) three wire serial configuration + * + * Note that we need the ifdefs because otherwise compilation of + * mkimage.c fails. + */ +#define CONFIG_SOFT_TWS 1 + +#ifdef TWS_IMPLEMENTATION +#include <mpc5xxx.h> +#include <asm/io.h> + +#define TWS_CE MPC5XXX_GPIO_WKUP_PSC1_4 /* GPIO_WKUP_0 */ +#define TWS_WR MPC5XXX_GPIO_WKUP_PSC2_4 /* GPIO_WKUP_1 */ +#define TWS_DATA MPC5XXX_GPIO_SINT_PSC3_4 /* GPIO_SINT_0 */ +#define TWS_CLK MPC5XXX_GPIO_SINT_PSC3_5 /* GPIO_SINT_1 */ + +static inline void tws_ce(unsigned bit) +{ + struct mpc5xxx_wu_gpio *wu_gpio = + (struct mpc5xxx_wu_gpio *)MPC5XXX_WU_GPIO; + if (bit) + setbits_8(&wu_gpio->dvo, TWS_CE); + else + clrbits_8(&wu_gpio->dvo, TWS_CE); +} + +static inline void tws_wr(unsigned bit) +{ + struct mpc5xxx_wu_gpio *wu_gpio = + (struct mpc5xxx_wu_gpio *)MPC5XXX_WU_GPIO; + if (bit) + setbits_8(&wu_gpio->dvo, TWS_WR); + else + clrbits_8(&wu_gpio->dvo, TWS_WR); +} + +static inline void tws_clk(unsigned bit) +{ + struct mpc5xxx_gpio *gpio = + (struct mpc5xxx_gpio *)MPC5XXX_GPIO; + if (bit) + setbits_8(&gpio->sint_dvo, TWS_CLK); + else + clrbits_8(&gpio->sint_dvo, TWS_CLK); +} + +static inline void tws_data(unsigned bit) +{ + struct mpc5xxx_gpio *gpio = + (struct mpc5xxx_gpio *)MPC5XXX_GPIO; + if (bit) + setbits_8(&gpio->sint_dvo, TWS_DATA); + else + clrbits_8(&gpio->sint_dvo, TWS_DATA); +} + +static inline unsigned tws_data_read(void) +{ + struct mpc5xxx_gpio *gpio = + (struct mpc5xxx_gpio *)MPC5XXX_GPIO; + return !!(in_8(&gpio->sint_ival) & TWS_DATA); +} + +static inline void tws_data_config_output(unsigned output) +{ + struct mpc5xxx_gpio *gpio = + (struct mpc5xxx_gpio *)MPC5XXX_GPIO; + if (output) + setbits_8(&gpio->sint_ddr, TWS_DATA); + else + clrbits_8(&gpio->sint_ddr, TWS_DATA); +} +#endif /* TWS_IMPLEMENTATION */
/* * Miscellaneous configurable options
Signed-off-by: Detlev Zundel dzu@denx.de --- board/inka4x0/inka4x0.c | 139 +++++++++++++++++++++++++---------------------- 1 files changed, 75 insertions(+), 64 deletions(-)
diff --git a/board/inka4x0/inka4x0.c b/board/inka4x0/inka4x0.c index a8bc3b3..7428b92 100644 --- a/board/inka4x0/inka4x0.c +++ b/board/inka4x0/inka4x0.c @@ -55,41 +55,35 @@ #ifndef CONFIG_SYS_RAMBOOT static void sdram_start (int hi_addr) { + volatile struct mpc5xxx_sdram *sdram = + (struct mpc5xxx_sdram *)MPC5XXX_SDRAM; long hi_addr_bit = hi_addr ? 0x01000000 : 0;
/* unlock mode register */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000000 | hi_addr_bit; - __asm__ volatile ("sync"); + out_be32(&sdram->ctrl, SDRAM_CONTROL | 0x80000000 | hi_addr_bit);
/* precharge all banks */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000002 | hi_addr_bit; - __asm__ volatile ("sync"); + out_be32(&sdram->ctrl, SDRAM_CONTROL | 0x80000002 | hi_addr_bit);
#if SDRAM_DDR /* set mode register: extended mode */ - *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_EMODE; - __asm__ volatile ("sync"); + out_be32(&sdram->mode, SDRAM_EMODE);
/* set mode register: reset DLL */ - *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_MODE | 0x04000000; - __asm__ volatile ("sync"); + out_be32(&sdram->mode, SDRAM_MODE | 0x04000000); #endif
/* auto refresh */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | 0x80000004 | hi_addr_bit; - __asm__ volatile ("sync"); + out_be32(&sdram->ctrl, SDRAM_CONTROL | 0x80000004 | hi_addr_bit);
/* set mode register */ - *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_MODE; - __asm__ volatile ("sync"); + out_be32(&sdram->mode, SDRAM_MODE);
/* normal operation */ - *(vu_long *)MPC5XXX_SDRAM_CTRL = SDRAM_CONTROL | hi_addr_bit; - __asm__ volatile ("sync"); + out_be32(&sdram->ctrl, SDRAM_CONTROL | hi_addr_bit); } #endif
@@ -101,24 +95,27 @@ static void sdram_start (int hi_addr)
phys_size_t initdram (int board_type) { + volatile struct mpc5xxx_mmap_ctl *mm = + (struct mpc5xxx_mmap_ctl *) CONFIG_SYS_MBAR; + volatile struct mpc5xxx_cdm *cdm = + (struct mpc5xxx_cdm *) MPC5XXX_CDM; + volatile struct mpc5xxx_sdram *sdram = + (struct mpc5xxx_sdram *) MPC5XXX_SDRAM; ulong dramsize = 0; #ifndef CONFIG_SYS_RAMBOOT long test1, test2;
/* setup SDRAM chip selects */ - *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0x0000001c; /* 512MB at 0x0 */ - *(vu_long *)MPC5XXX_SDRAM_CS1CFG = 0x40000000; /* disabled */ - __asm__ volatile ("sync"); + out_be32(&mm->sdram0, 0x0000001c); /* 512MB at 0x0 */ + out_be32(&mm->sdram1, 0x40000000); /* disabled */
/* setup config registers */ - *(vu_long *)MPC5XXX_SDRAM_CONFIG1 = SDRAM_CONFIG1; - *(vu_long *)MPC5XXX_SDRAM_CONFIG2 = SDRAM_CONFIG2; - __asm__ volatile ("sync"); + out_be32(&sdram->config1, SDRAM_CONFIG1); + out_be32(&sdram->config2, SDRAM_CONFIG2);
#if SDRAM_DDR /* set tap delay */ - *(vu_long *)MPC5XXX_CDM_PORCFG = SDRAM_TAPDELAY; - __asm__ volatile ("sync"); + out_be32(&cdm->porcfg, SDRAM_TAPDELAY); #endif
/* find RAM size using SDRAM CS0 only */ @@ -140,17 +137,17 @@ phys_size_t initdram (int board_type)
/* set SDRAM CS0 size according to the amount of RAM found */ if (dramsize > 0) { - *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0x13 + - __builtin_ffs(dramsize >> 20) - 1; + out_be32(&mm->sdram0, 0x13 + + __builtin_ffs(dramsize >> 20) - 1); } else { - *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0; /* disabled */ + out_be32(&mm->sdram0, 0); /* disabled */ }
- *(vu_long *)MPC5XXX_SDRAM_CS1CFG = dramsize; /* disabled */ + out_be32(&mm->sdram1, dramsize); /* disabled */ #else /* CONFIG_SYS_RAMBOOT */
/* retrieve size of memory connected to SDRAM CS0 */ - dramsize = *(vu_long *)MPC5XXX_SDRAM_CS0CFG & 0xFF; + dramsize = in_be32(&mm->sdram0) & 0xFF; if (dramsize >= 0x13) { dramsize = (1 << (dramsize - 0x13)) << 20; } else { @@ -169,13 +166,15 @@ int checkboard (void)
void flash_preinit(void) { + volatile struct mpc5xxx_lpb *lpb = (struct mpc5xxx_lpb *)MPC5XXX_LPB; + /* * Now, when we are in RAM, enable flash write * access for detection process. - * Note that CS_BOOT cannot be cleared when + * Note that CS_BOOT (CS0) cannot be cleared when * executing in flash. */ - *(vu_long *)MPC5XXX_BOOTCS_CFG &= ~0x1; /* clear RO */ + clrbits_be32(&lpb->cs0_cfg, 0x1); /* clear RO */ }
int misc_init_r (void) { @@ -190,8 +189,11 @@ int misc_init_r (void) {
int misc_init_f (void) { - struct mpc5xxx_gpio *gpio = (struct mpc5xxx_gpio *)MPC5XXX_GPIO; - struct mpc5xxx_wu_gpio *wu_gpio = (struct mpc5xxx_wu_gpio *)MPC5XXX_WU_GPIO; + volatile struct mpc5xxx_gpio *gpio = + (struct mpc5xxx_gpio *) MPC5XXX_GPIO; + volatile struct mpc5xxx_wu_gpio *wu_gpio = + (struct mpc5xxx_wu_gpio *)MPC5XXX_WU_GPIO; + volatile struct mpc5xxx_gpt *gpt; char tmp[10]; int i, br;
@@ -205,40 +207,43 @@ int misc_init_f (void) /* Initialize GPIO output pins. */ /* Configure GPT as GPIO output (and set them as they control low-active LEDs */ - *(vu_long *)MPC5XXX_GPT0_ENABLE = - *(vu_long *)MPC5XXX_GPT1_ENABLE = - *(vu_long *)MPC5XXX_GPT2_ENABLE = - *(vu_long *)MPC5XXX_GPT3_ENABLE = - *(vu_long *)MPC5XXX_GPT4_ENABLE = - *(vu_long *)MPC5XXX_GPT5_ENABLE = 0x34; + for (i = 0; i <= 5; i++) { + gpt = (struct mpc5xxx_gpt *)(MPC5XXX_GPT + (i * 0x10)); + out_be32(&gpt->emsr, 0x34); + }
/* Configure GPT7 as PWM timer, 1kHz, no ints. */ - *(vu_long *)MPC5XXX_GPT7_ENABLE = 0;/* Disable */ - *(vu_long *)MPC5XXX_GPT7_COUNTER = 0x020000fe; - *(vu_long *)MPC5XXX_GPT7_PWMCFG = (br << 16); - *(vu_long *)MPC5XXX_GPT7_ENABLE = 0x3;/* Enable PWM mode and start */ + gpt = (struct mpc5xxx_gpt *)(MPC5XXX_GPT + (7 * 0x10)); + out_be32(&gpt->emsr, 0); /* Disable */ + out_be32(&gpt->cir, 0x020000fe); + out_be32(&gpt->pwmcr, (br << 16)); + out_be32(&gpt->emsr, 0x3); /* Enable PWM mode and start */
/* Configure PSC3_6,7 as GPIO output */ - *(vu_long *)MPC5XXX_GPIO_ENABLE |= 0x00003000; - *(vu_long *)MPC5XXX_GPIO_DIR |= 0x00003000; - - /* Configure PSC3_8 as GPIO output, no interrupt */ - *(vu_long *)MPC5XXX_GPIO_SI_ENABLE |= 0x04000000; - *(vu_long *)MPC5XXX_GPIO_SI_DIR |= 0x04000000; - *(vu_long *)MPC5XXX_GPIO_SI_IEN &= ~0x04000000; + setbits_be32(&gpio->simple_gpioe, MPC5XXX_GPIO_SIMPLE_PSC3_6 | + MPC5XXX_GPIO_SIMPLE_PSC3_7); + setbits_be32(&gpio->simple_ddr, MPC5XXX_GPIO_SIMPLE_PSC3_6 | + MPC5XXX_GPIO_SIMPLE_PSC3_7);
/* Configure PSC3_9 and GPIO_WKUP6,7 as GPIO output */ - *(vu_long *)MPC5XXX_WU_GPIO_ENABLE |= 0xc4000000; - *(vu_long *)MPC5XXX_WU_GPIO_DIR |= 0xc4000000; + setbits_8(&wu_gpio->enable, MPC5XXX_GPIO_WKUP_6 | + MPC5XXX_GPIO_WKUP_7 | + MPC5XXX_GPIO_WKUP_PSC3_9); + setbits_8(&wu_gpio->ddr, MPC5XXX_GPIO_WKUP_6 | + MPC5XXX_GPIO_WKUP_7 | + MPC5XXX_GPIO_WKUP_PSC3_9);
/* Set LR mirror bit because it is low-active */ - *(vu_long *) MPC5XXX_WU_GPIO_DATA_O |= GPIO_WKUP_7; - /* - * Reset Coral-P graphics controller - */ - *(vu_long *) MPC5XXX_WU_GPIO_ENABLE |= GPIO_PSC3_9; - *(vu_long *) MPC5XXX_WU_GPIO_DIR |= GPIO_PSC3_9; - *(vu_long *) MPC5XXX_WU_GPIO_DATA_O |= GPIO_PSC3_9; + setbits_8(&wu_gpio->dvo, MPC5XXX_GPIO_WKUP_7); + + /* Reset Coral-P graphics controller */ + setbits_8(&wu_gpio->dvo, MPC5XXX_GPIO_WKUP_PSC3_9); + + /* Enable display backlight */ + clrbits_8(&gpio->sint_inten, MPC5XXX_GPIO_SINT_PSC3_8); + setbits_8(&gpio->sint_gpioe, MPC5XXX_GPIO_SINT_PSC3_8); + setbits_8(&gpio->sint_ddr, MPC5XXX_GPIO_SINT_PSC3_8); + setbits_8(&gpio->sint_dvo, MPC5XXX_GPIO_SINT_PSC3_8);
/* * Configure three wire serial interface to RTC (PSC1_4, @@ -274,25 +279,31 @@ void pci_init_board(void)
void init_ide_reset (void) { + volatile struct mpc5xxx_wu_gpio *wu_gpio = + (struct mpc5xxx_wu_gpio *)MPC5XXX_WU_GPIO; + debug ("init_ide_reset\n");
/* Configure PSC1_4 as GPIO output for ATA reset */ - *(vu_long *) MPC5XXX_WU_GPIO_ENABLE |= GPIO_PSC1_4; - *(vu_long *) MPC5XXX_WU_GPIO_DIR |= GPIO_PSC1_4; + setbits_8(&wu_gpio->enable, MPC5XXX_GPIO_WKUP_PSC1_4); + setbits_8(&wu_gpio->ddr, MPC5XXX_GPIO_WKUP_PSC1_4); /* Deassert reset */ - *(vu_long *) MPC5XXX_WU_GPIO_DATA_O |= GPIO_PSC1_4; + setbits_8(&wu_gpio->dvo, MPC5XXX_GPIO_WKUP_PSC1_4); }
void ide_set_reset (int idereset) { + volatile struct mpc5xxx_wu_gpio *wu_gpio = + (struct mpc5xxx_wu_gpio *)MPC5XXX_WU_GPIO; + debug ("ide_reset(%d)\n", idereset);
if (idereset) { - *(vu_long *) MPC5XXX_WU_GPIO_DATA_O &= ~GPIO_PSC1_4; + clrbits_8(&wu_gpio->dvo, MPC5XXX_GPIO_WKUP_PSC1_4); /* Make a delay. MPC5200 spec says 25 usec min */ udelay(500000); } else { - *(vu_long *) MPC5XXX_WU_GPIO_DATA_O |= GPIO_PSC1_4; + setbits_8(&wu_gpio->dvo, MPC5XXX_GPIO_WKUP_PSC1_4); } } #endif
Hi Detlev,
some more small style issues, see comments below.
----------------------------------------------------------^ please, remove space here.
<snip>
- Note: The acrobatics below is due to the hideously ingenius idea of
- the chip designers. As the chip does not allow register
- addressing, all values need to be read and written in one go. Sure
-------------------------------------------------------------------^ please, remove space here.
<snip>
- int rel = 0;
- uchar buffer[7];
- memset(buffer, 0, 7);
- /* Read 52 bits into our buffer */
- tws_read(buffer, 52);
- tm->tm_sec = BCD2BIN( buffer[0] & 0x7F);
- tm->tm_min = BCD2BIN( buffer[1] & 0x7F);
- tm->tm_hour = BCD2BIN( buffer[2] & 0x3F);
- tm->tm_wday = BCD2BIN( buffer[3] & 0x07);
- tm->tm_mday = BCD2BIN((buffer[3] & 0xF0) >> 4 | (buffer[4] & 0x0F) << 4);
- tm->tm_mon = BCD2BIN((buffer[4] & 0x30) >> 4 | (buffer[5] & 0x0F) << 4);
- tm->tm_year = BCD2BIN((buffer[5] & 0xF0) >> 4 | (buffer[6] & 0x0F) << 4) + 2000;
these tree lines above are too long.
remove one blank line here, please.
Best regards, Anatolij
Dear Anatolij,
<snip> > +/* > + * Note: The acrobatics below is due to the hideously ingenius idea of > + * the chip designers. As the chip does not allow register -------------------------^ please, remove space here.
Nope. These are actually intentional. Good type setting systems add wider horizontal space after a full stop than between words. The double space after a full stop is the ASSCII representation of this.
It may be a matter of taste, and since many editors don't support this (at least not out of the box), so it is not a required style element, but in any case there is no reason to remove this.
Hi Anatolij,
Wow, you want me to change the default GPL boiler plate? You've got guts ;)
As said by Wolfgang, you may infer that I use Emacs as my preferred text editor, which knows about the double space. Citing from the info file:
The sentence commands assume that you follow the American typist's convention of putting two spaces at the end of a sentence; they consider a sentence to end wherever there is a `.', `?' or `!' followed by the end of a line or two spaces, with any number of `)', `]', `'', or `"' characters allowed in between. A sentence also begins or ends wherever a paragraph begins or ends. It is useful to follow this convention, because it makes a distinction between periods that end a sentence and periods that indicate abbreviations; that enables the Emacs sentence commands to distinguish, too. These commands do not stop for periods that indicate abbreviations.
So I really ask you to reconsider your critique.
- int rel = 0;
- uchar buffer[7];
Are you sure? You may notice that the spaces are intentional and *actually improve* the readability.
Oh well. I really checked CodingStyle in the Linux kernel and it has this to say:
The only exception to this is where exceeding 80 columns significantly increases readability and does not hide information.
So please reconsider your critique with this sentence in mind. What do you think?
Ok, I don't have a problem with that. I will not fix however, because I actually realize that this is another leftover of the previous implementation which did not use the tws protocol driver, so I remove the lines entirely.
Cheers Detlev
I checked some other files before suggesting to fix, and accidentally caught the files with one space character here. Now running
[ag@wker u-boot]$ fgrep -r "PURPOSE. See" * | wc -l 151 [ag@wker u-boot]$ fgrep -r "PURPOSE. See" * | wc -l 3530
shows, that these are outnumbered. So, forget it. Sorry for the noise.
Ok, your and Wolfgang's arguments show me, that being consistent with something is often brain-damaged. Sorry for the noise.
- int rel = 0;
- uchar buffer[7];
OK.
OK. Something like
tm->tm_mday = BCD2BIN((buffer[3] & 0xF0) >> 4 | (buffer[4] & 0x0F) << 4); tm->tm_mon = BCD2BIN((buffer[4] & 0x30) >> 4 | (buffer[5] & 0x0F) << 4); tm->tm_year = BCD2BIN((buffer[5] & 0xF0) >> 4 | (buffer[6] & 0x0F) << 4) + 2000;
isn't more readable than your version. Sorry for the noise, again.
[snip]
A foolish consistency is the hobgoblin of little minds.
-- Ralph Waldo Emerson
I change my mind periodically just because of that quote. :-D
[snip]
Best regards, gvb
Hi Jerry,
Thanks Jerry. I was about to write a few sentences but I am sure I could not have driven the point home any better ;)
I also found a new addition to my signature data base which contained only the cite below being almost but not entirely off-topic...
Cheers Detlev
[snip]
But hopefully you don't do so *consistently*. :-)
-Scott
Dear Detlev Zundel,
- volatile ioport_t *iop = ioport_addr((immap_t *)CONFIG_SYS_IMMR, I2C_PORT);
Indentation not by TAB.
Hi Wolfgang,
Dear Detlev Zundel,
Yes, intentionally so. Indenting by TAB exceeds the available line length. Judging by this single line I felt non-breaking the line was more important.
Can you please point me to the section in the CodingStyle regarding indentation for macros? I'd be much obliged.
Thanks Detlev
Hi Wolfgang,
The point is moot. Pondering over this piece of code it suddenly occured to me that the best solution is simply to remove it entirely ;)
This really is a leftover from an in-between broken implementation of the interface, so the removal in this case bears no consequences.
If no further feedback on the patch series arrive, I'll repost the whole stack tomorrow again.
Thanks again Detlev
Dear Detlev,
I applied some of the patches that were OK, so please make sure to rebase against master first.
Hi Detlev,
<snip>
- Write bits
- int rem = len;
- uchar accu, shift;
- debug("tws_write: buffer %p len %d\n", buffer, len);
please, add blank line here.
Hi Anatolij,
Hi Detlev,
<snip>
- Write bits
- int rem = len;
Fixed, thanks.
Cheers Detlev
Dear Detlev Zundel,
Applied, thanks.
Detlev Zundel dzu@denx.de writes:
As promised attached the diff "before" -> "after".
Cheers Detlev
participants (5)
Anatolij Gustschin
Detlev Zundel
Jerry Van Baren
Scott Wood
