[PATCH 1/1] snd: enable building max98357a driver with ACPIGEN=n
sandbox_defconfig builds the max98357a driver. It should be possible to build the sandbox without ACPI support.
ACPI support in the max98357a driver is only needed when creating an ACPI table. Fix building with ACPIGEN=n.
Fixes: 54bcca29737f ("sound: Add an ACPI driver for Maxim MAX98357ac") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/sound/max98357a.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/sound/max98357a.c b/drivers/sound/max98357a.c index a2088f0301..bdf6dc236e 100644 --- a/drivers/sound/max98357a.c +++ b/drivers/sound/max98357a.c @@ -38,6 +38,7 @@ static int max98357a_of_to_plat(struct udevice *dev) return 0; }
+__maybe_unused static int max98357a_acpi_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) { @@ -137,10 +138,12 @@ static int max98357a_acpi_setup_nhlt(const struct udevice *dev, #endif
struct acpi_ops max98357a_acpi_ops = { +#ifdef CONFIG_ACPIGEN .fill_ssdt = max98357a_acpi_fill_ssdt, #ifdef CONFIG_X86 .setup_nhlt = max98357a_acpi_setup_nhlt, #endif +#endif };
static const struct audio_codec_ops max98357a_ops = { -- 2.36.1
