[PATCH] Series-to: Fred Bloggs <f.blogs@napier.co.nz> Series-cc: Sean O'Brien <seobrien@chromium.org> HID: input: Restore missing cursor for digitizer devices
A previously committed patch to remove cursors for HID Digitizer-Pen devices also removed the cursors for some tablets which have incorrect HID descriptors. These devices should enumerate with Usage ID "Digitizer" instead of Usage ID "Pen".
Patch which introduced the issue: commit 8473a93d1ba5 ("HID: input: Set INPUT_PROP_-property for HID_UP_DIGITIZERS")
Changes- Add HID quirk HID_QUIRK_DEVICE_IS_DIGITIZER Quirk will force INPUT_PROP_POINTER for HID Digitizers Apply quirk to Huion tablets Apply quirk to UGEE/XP-Pen tablets based on device ID
Signed-off-by: Torsha Banerjee torsha@google.com ---
drivers/hid/hid-input.c | 3 ++- drivers/hid/hid-quirks.c | 9 +++++++++ include/linux/hid.h | 2 ++ 3 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/drivers/hid/hid-input.c b/drivers/hid/hid-input.c index 7fc967964dd8..f0c67baddc8d 100644 --- a/drivers/hid/hid-input.c +++ b/drivers/hid/hid-input.c @@ -927,7 +927,8 @@ static void hidinput_configure_usage(struct hid_input *hidinput, struct hid_fiel break;
case HID_UP_DIGITIZER: - if ((field->application & 0xff) == 0x01) /* Digitizer */ + if (((field->application & 0xff) == 0x01) || + (device->quirks & HID_QUIRK_DEVICE_IS_DIGITIZER)) /* Digitizer */ __set_bit(INPUT_PROP_POINTER, input->propbit); else if ((field->application & 0xff) == 0x02) /* Pen */ __set_bit(INPUT_PROP_DIRECT, input->propbit); diff --git a/drivers/hid/hid-quirks.c b/drivers/hid/hid-quirks.c index 66e64350f138..094fe4c4f3b3 100644 --- a/drivers/hid/hid-quirks.c +++ b/drivers/hid/hid-quirks.c @@ -102,6 +102,8 @@ static const struct hid_device_id hid_quirks[] = { { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_PIXART_OEM_USB_OPTICAL_MOUSE_0941), HID_QUIRK_ALWAYS_POLL }, { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_PIXART_OEM_USB_OPTICAL_MOUSE_0641), HID_QUIRK_ALWAYS_POLL }, { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_PIXART_OEM_USB_OPTICAL_MOUSE_1f4a), HID_QUIRK_ALWAYS_POLL }, + { HID_USB_DEVICE(USB_VENDOR_ID_HUION, USB_DEVICE_ID_HUION_HS64), HID_QUIRK_DEVICE_IS_DIGITIZER }, + { HID_USB_DEVICE(USB_VENDOR_ID_HUION, USB_DEVICE_ID_HUION_TABLET), HID_QUIRK_DEVICE_IS_DIGITIZER }, { HID_USB_DEVICE(USB_VENDOR_ID_IDEACOM, USB_DEVICE_ID_IDEACOM_IDC6680), HID_QUIRK_MULTI_INPUT }, { HID_USB_DEVICE(USB_VENDOR_ID_INNOMEDIA, USB_DEVICE_ID_INNEX_GENESIS_ATARI), HID_QUIRK_MULTI_INPUT }, { HID_USB_DEVICE(USB_VENDOR_ID_KYE, USB_DEVICE_ID_KYE_EASYPEN_M610X), HID_QUIRK_MULTI_INPUT }, @@ -1298,6 +1300,13 @@ unsigned long hid_lookup_quirk(const struct hid_device *hdev) quirks = hid_gets_squirk(hdev); mutex_unlock(&dquirks_lock);
+ /* + * UGEE/XP-Pen HID Pen devices which have 0x0-0x9 as the low nibble + * of the device ID are actually digitizers, not HID Pen devices + */ + if (hdev->vendor == USB_VENDOR_ID_UGEE && (hdev->product & 0x0F) <= 0x09) + quirks |= HID_QUIRK_DEVICE_IS_DIGITIZER; + return quirks; } EXPORT_SYMBOL_GPL(hid_lookup_quirk); diff --git a/include/linux/hid.h b/include/linux/hid.h index 1ea8c7a3570b..c9cc81e85a33 100644 --- a/include/linux/hid.h +++ b/include/linux/hid.h @@ -352,8 +352,10 @@ struct hid_item { /* BIT(9) reserved for backward compatibility, was NO_INIT_INPUT_REPORTS */ #define HID_QUIRK_ALWAYS_POLL BIT(10) #define HID_QUIRK_INPUT_PER_APP BIT(11) + #define HID_QUIRK_X_INVERT BIT(12) #define HID_QUIRK_Y_INVERT BIT(13) +#define HID_QUIRK_DEVICE_IS_DIGITIZER BIT(14) #define HID_QUIRK_SKIP_OUTPUT_REPORTS BIT(16) #define HID_QUIRK_SKIP_OUTPUT_REPORT_ID BIT(17) #define HID_QUIRK_NO_OUTPUT_REPORTS_ON_INTR_EP BIT(18)
Hi Torsha,
Thank you for the patch! Yet something to improve:
[auto build test ERROR on v6.3-rc4] [also build test ERROR on linus/master next-20230328] [cannot apply to hid/for-next] [If your patch is applied to the wrong git tree, kindly drop us a note. And when submitting patch, we suggest to use '--base' as documented in https://git-scm.com/docs/git-format-patch#_base_tree_information]
url: https://github.com/intel-lab-lkp/linux/commits/Torsha-Banerjee/Series-to-Fre... patch link: https://lore.kernel.org/r/20230328161119.1.I40a8881b83b0e440ed5368d98b42a2d9... patch subject: [PATCH] Series-to: Fred Bloggs f.blogs@napier.co.nz Series-cc: Sean O'Brien seobrien@chromium.org HID: input: Restore missing cursor for digitizer devices config: riscv-allmodconfig (https://download.01.org/0day-ci/archive/20230329/202303290538.GxYGQ37a-lkp@i...) compiler: riscv64-linux-gcc (GCC) 12.1.0 reproduce (this is a W=1 build): wget https://raw.githubusercontent.com/intel/lkp-tests/master/sbin/make.cross -O ~/bin/make.cross chmod +x ~/bin/make.cross # https://github.com/intel-lab-lkp/linux/commit/15e6cca84ddc6ef20ce0e540e439b1... git remote add linux-review https://github.com/intel-lab-lkp/linux git fetch --no-tags linux-review Torsha-Banerjee/Series-to-Fred-Bloggs-f-blogs-napier-co-nz-Series-cc-Sean-O-Brien-seobrien-chromium-org-HID-input-Restore-missing-cursor/20230329-001305 git checkout 15e6cca84ddc6ef20ce0e540e439b1e976006f0b # save the config file mkdir build_dir && cp config build_dir/.config COMPILER_INSTALL_PATH=$HOME/0day COMPILER=gcc-12.1.0 make.cross W=1 O=build_dir ARCH=riscv olddefconfig COMPILER_INSTALL_PATH=$HOME/0day COMPILER=gcc-12.1.0 make.cross W=1 O=build_dir ARCH=riscv SHELL=/bin/bash drivers/
If you fix the issue, kindly add following tag where applicable | Reported-by: kernel test robot lkp@intel.com | Link: https://lore.kernel.org/oe-kbuild-all/202303290538.GxYGQ37a-lkp@intel.com/
All errors (new ones prefixed by >>):
In file included from drivers/hid/hid-quirks.c:15:
drivers/hid/hid-quirks.c:105:47: error: 'USB_DEVICE_ID_HUION_HS64' undeclared here (not in a function); did you mean 'USB_DEVICE_ID_HUION_TABLET'?
105 | { HID_USB_DEVICE(USB_VENDOR_ID_HUION, USB_DEVICE_ID_HUION_HS64), HID_QUIRK_DEVICE_IS_DIGITIZER }, | ^~~~~~~~~~~~~~~~~~~~~~~~ include/linux/hid.h:716:54: note: in definition of macro 'HID_USB_DEVICE' 716 | .bus = BUS_USB, .vendor = (ven), .product = (prod) | ^~~~
vim +105 drivers/hid/hid-quirks.c
22 23 /* 24 * Alphabetically sorted by vendor then product. 25 */ 26 27 static const struct hid_device_id hid_quirks[] = { 28 { HID_USB_DEVICE(USB_VENDOR_ID_AASHIMA, USB_DEVICE_ID_AASHIMA_GAMEPAD), HID_QUIRK_BADPAD }, 29 { HID_USB_DEVICE(USB_VENDOR_ID_AASHIMA, USB_DEVICE_ID_AASHIMA_PREDATOR), HID_QUIRK_BADPAD }, 30 { HID_USB_DEVICE(USB_VENDOR_ID_AFATECH, USB_DEVICE_ID_AFATECH_AF9016), HID_QUIRK_FULLSPEED_INTERVAL }, 31 { HID_USB_DEVICE(USB_VENDOR_ID_AIREN, USB_DEVICE_ID_AIREN_SLIMPLUS), HID_QUIRK_NOGET }, 32 { HID_USB_DEVICE(USB_VENDOR_ID_AKAI_09E8, USB_DEVICE_ID_AKAI_09E8_MIDIMIX), HID_QUIRK_NO_INIT_REPORTS }, 33 { HID_USB_DEVICE(USB_VENDOR_ID_AKAI, USB_DEVICE_ID_AKAI_MPKMINI2), HID_QUIRK_NO_INIT_REPORTS }, 34 { HID_USB_DEVICE(USB_VENDOR_ID_ALPS, USB_DEVICE_ID_IBM_GAMEPAD), HID_QUIRK_BADPAD }, 35 { HID_USB_DEVICE(USB_VENDOR_ID_AMI, USB_DEVICE_ID_AMI_VIRT_KEYBOARD_AND_MOUSE), HID_QUIRK_ALWAYS_POLL }, 36 { HID_USB_DEVICE(USB_VENDOR_ID_ATEN, USB_DEVICE_ID_ATEN_2PORTKVM), HID_QUIRK_NOGET }, 37 { HID_USB_DEVICE(USB_VENDOR_ID_ATEN, USB_DEVICE_ID_ATEN_4PORTKVMC), HID_QUIRK_NOGET }, 38 { HID_USB_DEVICE(USB_VENDOR_ID_ATEN, USB_DEVICE_ID_ATEN_4PORTKVM), HID_QUIRK_NOGET }, 39 { HID_USB_DEVICE(USB_VENDOR_ID_ATEN, USB_DEVICE_ID_ATEN_CS124U), HID_QUIRK_NOGET }, 40 { HID_USB_DEVICE(USB_VENDOR_ID_ATEN, USB_DEVICE_ID_ATEN_CS1758), HID_QUIRK_NOGET }, 41 { HID_USB_DEVICE(USB_VENDOR_ID_ATEN, USB_DEVICE_ID_ATEN_CS682), HID_QUIRK_NOGET }, 42 { HID_USB_DEVICE(USB_VENDOR_ID_ATEN, USB_DEVICE_ID_ATEN_CS692), HID_QUIRK_NOGET }, 43 { HID_USB_DEVICE(USB_VENDOR_ID_ATEN, USB_DEVICE_ID_ATEN_UC100KM), HID_QUIRK_NOGET }, 44 { HID_USB_DEVICE(USB_VENDOR_ID_CHICONY, USB_DEVICE_ID_CHICONY_MULTI_TOUCH), HID_QUIRK_MULTI_INPUT }, 45 { HID_USB_DEVICE(USB_VENDOR_ID_CHICONY, USB_DEVICE_ID_CHICONY_PIXART_USB_OPTICAL_MOUSE), HID_QUIRK_ALWAYS_POLL }, 46 { HID_USB_DEVICE(USB_VENDOR_ID_CHICONY, USB_DEVICE_ID_CHICONY_PIXART_USB_OPTICAL_MOUSE2), HID_QUIRK_ALWAYS_POLL }, 47 { HID_USB_DEVICE(USB_VENDOR_ID_CHICONY, USB_DEVICE_ID_CHICONY_WIRELESS), HID_QUIRK_MULTI_INPUT }, 48 { HID_USB_DEVICE(USB_VENDOR_ID_CHIC, USB_DEVICE_ID_CHIC_GAMEPAD), HID_QUIRK_BADPAD }, 49 { HID_USB_DEVICE(USB_VENDOR_ID_CH, USB_DEVICE_ID_CH_3AXIS_5BUTTON_STICK), HID_QUIRK_NOGET }, 50 { HID_USB_DEVICE(USB_VENDOR_ID_CH, USB_DEVICE_ID_CH_AXIS_295), HID_QUIRK_NOGET }, 51 { HID_USB_DEVICE(USB_VENDOR_ID_CH, USB_DEVICE_ID_CH_COMBATSTICK), HID_QUIRK_NOGET }, 52 { HID_USB_DEVICE(USB_VENDOR_ID_CH, USB_DEVICE_ID_CH_FIGHTERSTICK), HID_QUIRK_NOGET }, 53 { HID_USB_DEVICE(USB_VENDOR_ID_CH, USB_DEVICE_ID_CH_FLIGHT_SIM_ECLIPSE_YOKE), HID_QUIRK_NOGET }, 54 { HID_USB_DEVICE(USB_VENDOR_ID_CH, USB_DEVICE_ID_CH_FLIGHT_SIM_YOKE), HID_QUIRK_NOGET }, 55 { HID_USB_DEVICE(USB_VENDOR_ID_CH, USB_DEVICE_ID_CH_PRO_PEDALS), HID_QUIRK_NOGET }, 56 { HID_USB_DEVICE(USB_VENDOR_ID_CH, USB_DEVICE_ID_CH_PRO_THROTTLE), HID_QUIRK_NOGET }, 57 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_K65RGB), HID_QUIRK_NO_INIT_REPORTS }, 58 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_K65RGB_RAPIDFIRE), HID_QUIRK_NO_INIT_REPORTS | HID_QUIRK_ALWAYS_POLL }, 59 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_K70RGB), HID_QUIRK_NO_INIT_REPORTS }, 60 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_K70RGB_RAPIDFIRE), HID_QUIRK_NO_INIT_REPORTS | HID_QUIRK_ALWAYS_POLL }, 61 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_K70R), HID_QUIRK_NO_INIT_REPORTS }, 62 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_K95RGB), HID_QUIRK_NO_INIT_REPORTS | HID_QUIRK_ALWAYS_POLL }, 63 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_M65RGB), HID_QUIRK_NO_INIT_REPORTS }, 64 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_GLAIVE_RGB), HID_QUIRK_NO_INIT_REPORTS | HID_QUIRK_ALWAYS_POLL }, 65 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_SCIMITAR_PRO_RGB), HID_QUIRK_NO_INIT_REPORTS | HID_QUIRK_ALWAYS_POLL }, 66 { HID_USB_DEVICE(USB_VENDOR_ID_CORSAIR, USB_DEVICE_ID_CORSAIR_STRAFE), HID_QUIRK_NO_INIT_REPORTS | HID_QUIRK_ALWAYS_POLL }, 67 { HID_USB_DEVICE(USB_VENDOR_ID_CREATIVELABS, USB_DEVICE_ID_CREATIVE_SB_OMNI_SURROUND_51), HID_QUIRK_NOGET }, 68 { HID_USB_DEVICE(USB_VENDOR_ID_DELL, USB_DEVICE_ID_DELL_PIXART_USB_OPTICAL_MOUSE), HID_QUIRK_ALWAYS_POLL }, 69 { HID_USB_DEVICE(USB_VENDOR_ID_DMI, USB_DEVICE_ID_DMI_ENC), HID_QUIRK_NOGET }, 70 { HID_USB_DEVICE(USB_VENDOR_ID_DRACAL_RAPHNET, USB_DEVICE_ID_RAPHNET_2NES2SNES), HID_QUIRK_MULTI_INPUT }, 71 { HID_USB_DEVICE(USB_VENDOR_ID_DRACAL_RAPHNET, USB_DEVICE_ID_RAPHNET_4NES4SNES), HID_QUIRK_MULTI_INPUT }, 72 { HID_USB_DEVICE(USB_VENDOR_ID_DRAGONRISE, USB_DEVICE_ID_REDRAGON_SEYMUR2), HID_QUIRK_INCREMENT_USAGE_ON_DUPLICATE }, 73 { HID_USB_DEVICE(USB_VENDOR_ID_DRAGONRISE, USB_DEVICE_ID_DRAGONRISE_DOLPHINBAR), HID_QUIRK_MULTI_INPUT }, 74 { HID_USB_DEVICE(USB_VENDOR_ID_DRAGONRISE, USB_DEVICE_ID_DRAGONRISE_GAMECUBE1), HID_QUIRK_MULTI_INPUT }, 75 { HID_USB_DEVICE(USB_VENDOR_ID_DRAGONRISE, USB_DEVICE_ID_DRAGONRISE_GAMECUBE3), HID_QUIRK_MULTI_INPUT }, 76 { HID_USB_DEVICE(USB_VENDOR_ID_DRAGONRISE, USB_DEVICE_ID_DRAGONRISE_PS3), HID_QUIRK_MULTI_INPUT }, 77 { HID_USB_DEVICE(USB_VENDOR_ID_DRAGONRISE, USB_DEVICE_ID_DRAGONRISE_WIIU), HID_QUIRK_MULTI_INPUT }, 78 { HID_USB_DEVICE(USB_VENDOR_ID_DWAV, USB_DEVICE_ID_EGALAX_TOUCHCONTROLLER), HID_QUIRK_MULTI_INPUT | HID_QUIRK_NOGET }, 79 { HID_USB_DEVICE(USB_VENDOR_ID_ELAN, HID_ANY_ID), HID_QUIRK_ALWAYS_POLL }, 80 { HID_USB_DEVICE(USB_VENDOR_ID_ELO, USB_DEVICE_ID_ELO_TS2700), HID_QUIRK_NOGET }, 81 { HID_USB_DEVICE(USB_VENDOR_ID_EMS, USB_DEVICE_ID_EMS_TRIO_LINKER_PLUS_II), HID_QUIRK_MULTI_INPUT }, 82 { HID_USB_DEVICE(USB_VENDOR_ID_ETURBOTOUCH, USB_DEVICE_ID_ETURBOTOUCH_2968), HID_QUIRK_MULTI_INPUT }, 83 { HID_USB_DEVICE(USB_VENDOR_ID_ETURBOTOUCH, USB_DEVICE_ID_ETURBOTOUCH), HID_QUIRK_MULTI_INPUT }, 84 { HID_USB_DEVICE(USB_VENDOR_ID_FORMOSA, USB_DEVICE_ID_FORMOSA_IR_RECEIVER), HID_QUIRK_NO_INIT_REPORTS }, 85 { HID_USB_DEVICE(USB_VENDOR_ID_FREESCALE, USB_DEVICE_ID_FREESCALE_MX28), HID_QUIRK_NOGET }, 86 { HID_USB_DEVICE(USB_VENDOR_ID_FUTABA, USB_DEVICE_ID_LED_DISPLAY), HID_QUIRK_NO_INIT_REPORTS }, 87 { HID_USB_DEVICE(USB_VENDOR_ID_GREENASIA, USB_DEVICE_ID_GREENASIA_DUAL_SAT_ADAPTOR), HID_QUIRK_MULTI_INPUT }, 88 { HID_USB_DEVICE(USB_VENDOR_ID_GREENASIA, USB_DEVICE_ID_GREENASIA_DUAL_USB_JOYPAD), HID_QUIRK_MULTI_INPUT }, 89 { HID_BLUETOOTH_DEVICE(USB_VENDOR_ID_GAMEVICE, USB_DEVICE_ID_GAMEVICE_GV186), 90 HID_QUIRK_INCREMENT_USAGE_ON_DUPLICATE }, 91 { HID_USB_DEVICE(USB_VENDOR_ID_GAMEVICE, USB_DEVICE_ID_GAMEVICE_KISHI), 92 HID_QUIRK_INCREMENT_USAGE_ON_DUPLICATE }, 93 { HID_USB_DEVICE(USB_VENDOR_ID_HAPP, USB_DEVICE_ID_UGCI_DRIVING), HID_QUIRK_BADPAD | HID_QUIRK_MULTI_INPUT }, 94 { HID_USB_DEVICE(USB_VENDOR_ID_HAPP, USB_DEVICE_ID_UGCI_FIGHTING), HID_QUIRK_BADPAD | HID_QUIRK_MULTI_INPUT }, 95 { HID_USB_DEVICE(USB_VENDOR_ID_HAPP, USB_DEVICE_ID_UGCI_FLYING), HID_QUIRK_BADPAD | HID_QUIRK_MULTI_INPUT }, 96 { HID_USB_DEVICE(USB_VENDOR_ID_HOLTEK_ALT, USB_DEVICE_ID_HOLTEK_ALT_KEYBOARD_A096), HID_QUIRK_NO_INIT_REPORTS }, 97 { HID_USB_DEVICE(USB_VENDOR_ID_HOLTEK_ALT, USB_DEVICE_ID_HOLTEK_ALT_KEYBOARD_A293), HID_QUIRK_ALWAYS_POLL }, 98 { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_LOGITECH_OEM_USB_OPTICAL_MOUSE_0A4A), HID_QUIRK_ALWAYS_POLL }, 99 { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_LOGITECH_OEM_USB_OPTICAL_MOUSE_0B4A), HID_QUIRK_ALWAYS_POLL }, 100 { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_PIXART_OEM_USB_OPTICAL_MOUSE), HID_QUIRK_ALWAYS_POLL }, 101 { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_PIXART_OEM_USB_OPTICAL_MOUSE_094A), HID_QUIRK_ALWAYS_POLL }, 102 { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_PIXART_OEM_USB_OPTICAL_MOUSE_0941), HID_QUIRK_ALWAYS_POLL }, 103 { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_PIXART_OEM_USB_OPTICAL_MOUSE_0641), HID_QUIRK_ALWAYS_POLL }, 104 { HID_USB_DEVICE(USB_VENDOR_ID_HP, USB_PRODUCT_ID_HP_PIXART_OEM_USB_OPTICAL_MOUSE_1f4a), HID_QUIRK_ALWAYS_POLL },
105 { HID_USB_DEVICE(USB_VENDOR_ID_HUION, USB_DEVICE_ID_HUION_HS64), HID_QUIRK_DEVICE_IS_DIGITIZER },
106 { HID_USB_DEVICE(USB_VENDOR_ID_HUION, USB_DEVICE_ID_HUION_TABLET), HID_QUIRK_DEVICE_IS_DIGITIZER }, 107 { HID_USB_DEVICE(USB_VENDOR_ID_IDEACOM, USB_DEVICE_ID_IDEACOM_IDC6680), HID_QUIRK_MULTI_INPUT }, 108 { HID_USB_DEVICE(USB_VENDOR_ID_INNOMEDIA, USB_DEVICE_ID_INNEX_GENESIS_ATARI), HID_QUIRK_MULTI_INPUT }, 109 { HID_USB_DEVICE(USB_VENDOR_ID_KYE, USB_DEVICE_ID_KYE_EASYPEN_M610X), HID_QUIRK_MULTI_INPUT }, 110 { HID_USB_DEVICE(USB_VENDOR_ID_KYE, USB_DEVICE_ID_KYE_MOUSEPEN_I608X), HID_QUIRK_MULTI_INPUT }, 111 { HID_USB_DEVICE(USB_VENDOR_ID_KYE, USB_DEVICE_ID_KYE_MOUSEPEN_I608X_V2), HID_QUIRK_MULTI_INPUT }, 112 { HID_USB_DEVICE(USB_VENDOR_ID_KYE, USB_DEVICE_ID_KYE_PENSKETCH_M912), HID_QUIRK_MULTI_INPUT }, 113 { HID_USB_DEVICE(USB_VENDOR_ID_KYE, USB_DEVICE_ID_KYE_EASYPEN_M406XE), HID_QUIRK_MULTI_INPUT }, 114 { HID_USB_DEVICE(USB_VENDOR_ID_KYE, USB_DEVICE_ID_PIXART_USB_OPTICAL_MOUSE_ID2), HID_QUIRK_ALWAYS_POLL }, 115 { HID_USB_DEVICE(USB_VENDOR_ID_LENOVO, USB_DEVICE_ID_LENOVO_OPTICAL_USB_MOUSE_600E), HID_QUIRK_ALWAYS_POLL }, 116 { HID_USB_DEVICE(USB_VENDOR_ID_LENOVO, USB_DEVICE_ID_LENOVO_PIXART_USB_MOUSE_608D), HID_QUIRK_ALWAYS_POLL }, 117 { HID_USB_DEVICE(USB_VENDOR_ID_LENOVO, USB_DEVICE_ID_LENOVO_PIXART_USB_MOUSE_6019), HID_QUIRK_ALWAYS_POLL }, 118 { HID_USB_DEVICE(USB_VENDOR_ID_LENOVO, USB_DEVICE_ID_LENOVO_PIXART_USB_MOUSE_602E), HID_QUIRK_ALWAYS_POLL }, 119 { HID_USB_DEVICE(USB_VENDOR_ID_LENOVO, USB_DEVICE_ID_LENOVO_PIXART_USB_MOUSE_6093), HID_QUIRK_ALWAYS_POLL }, 120 { HID_USB_DEVICE(USB_VENDOR_ID_LOGITECH, USB_DEVICE_ID_LOGITECH_C007), HID_QUIRK_ALWAYS_POLL }, 121 { HID_USB_DEVICE(USB_VENDOR_ID_LOGITECH, USB_DEVICE_ID_LOGITECH_C077), HID_QUIRK_ALWAYS_POLL }, 122 { HID_USB_DEVICE(USB_VENDOR_ID_LOGITECH, USB_DEVICE_ID_LOGITECH_KEYBOARD_G710_PLUS), HID_QUIRK_NOGET }, 123 { HID_USB_DEVICE(USB_VENDOR_ID_LOGITECH, USB_DEVICE_ID_LOGITECH_MOUSE_C01A), HID_QUIRK_ALWAYS_POLL }, 124 { HID_USB_DEVICE(USB_VENDOR_ID_LOGITECH, USB_DEVICE_ID_LOGITECH_MOUSE_C05A), HID_QUIRK_ALWAYS_POLL }, 125 { HID_USB_DEVICE(USB_VENDOR_ID_LOGITECH, USB_DEVICE_ID_LOGITECH_MOUSE_C06A), HID_QUIRK_ALWAYS_POLL }, 126 { HID_USB_DEVICE(USB_VENDOR_ID_MCS, USB_DEVICE_ID_MCS_GAMEPADBLOCK), HID_QUIRK_MULTI_INPUT }, 127 { HID_USB_DEVICE(USB_VENDOR_ID_MICROSOFT, USB_DEVICE_ID_MS_MOUSE_0783), HID_QUIRK_ALWAYS_POLL }, 128 { HID_USB_DEVICE(USB_VENDOR_ID_MICROSOFT, USB_DEVICE_ID_MS_PIXART_MOUSE), HID_QUIRK_ALWAYS_POLL }, 129 { HID_USB_DEVICE(USB_VENDOR_ID_MICROSOFT, USB_DEVICE_ID_MS_POWER_COVER), HID_QUIRK_NO_INIT_REPORTS }, 130 { HID_USB_DEVICE(USB_VENDOR_ID_MICROSOFT, USB_DEVICE_ID_MS_SURFACE3_COVER), HID_QUIRK_NO_INIT_REPORTS }, 131 { HID_USB_DEVICE(USB_VENDOR_ID_MICROSOFT, USB_DEVICE_ID_MS_SURFACE_PRO_2), HID_QUIRK_NO_INIT_REPORTS }, 132 { HID_USB_DEVICE(USB_VENDOR_ID_MICROSOFT, USB_DEVICE_ID_MS_TOUCH_COVER_2), HID_QUIRK_NO_INIT_REPORTS }, 133 { HID_USB_DEVICE(USB_VENDOR_ID_MICROSOFT, USB_DEVICE_ID_MS_TYPE_COVER_2), HID_QUIRK_NO_INIT_REPORTS }, 134 { HID_USB_DEVICE(USB_VENDOR_ID_MOJO, USB_DEVICE_ID_RETRO_ADAPTER), HID_QUIRK_MULTI_INPUT }, 135 { HID_USB_DEVICE(USB_VENDOR_ID_MSI, USB_DEVICE_ID_MSI_GT683R_LED_PANEL), HID_QUIRK_NO_INIT_REPORTS }, 136 { HID_USB_DEVICE(USB_VENDOR_ID_MULTIPLE_1781, USB_DEVICE_ID_RAPHNET_4NES4SNES_OLD), HID_QUIRK_MULTI_INPUT }, 137 { HID_USB_DEVICE(USB_VENDOR_ID_NATSU, USB_DEVICE_ID_NATSU_GAMEPAD), HID_QUIRK_BADPAD }, 138 { HID_USB_DEVICE(USB_VENDOR_ID_NEC, USB_DEVICE_ID_NEC_USB_GAME_PAD), HID_QUIRK_BADPAD }, 139 { HID_USB_DEVICE(USB_VENDOR_ID_NEXIO, USB_DEVICE_ID_NEXIO_MULTITOUCH_PTI0750), HID_QUIRK_NO_INIT_REPORTS }, 140 { HID_USB_DEVICE(USB_VENDOR_ID_NEXTWINDOW, USB_DEVICE_ID_NEXTWINDOW_TOUCHSCREEN), HID_QUIRK_MULTI_INPUT}, 141 { HID_USB_DEVICE(USB_VENDOR_ID_NOVATEK, USB_DEVICE_ID_NOVATEK_MOUSE), HID_QUIRK_NO_INIT_REPORTS }, 142 { HID_USB_DEVICE(USB_VENDOR_ID_NTRIG, USB_DEVICE_ID_NTRIG_DUOSENSE), HID_QUIRK_NO_INIT_REPORTS }, 143 { HID_USB_DEVICE(USB_VENDOR_ID_PANTHERLORD, USB_DEVICE_ID_PANTHERLORD_TWIN_USB_JOYSTICK), HID_QUIRK_MULTI_INPUT | HID_QUIRK_SKIP_OUTPUT_REPORTS }, 144 { HID_USB_DEVICE(USB_VENDOR_ID_PENMOUNT, USB_DEVICE_ID_PENMOUNT_1610), HID_QUIRK_NOGET }, 145 { HID_USB_DEVICE(USB_VENDOR_ID_PENMOUNT, USB_DEVICE_ID_PENMOUNT_1640), HID_QUIRK_NOGET }, 146 { HID_USB_DEVICE(USB_VENDOR_ID_PI_ENGINEERING, USB_DEVICE_ID_PI_ENGINEERING_VEC_USB_FOOTPEDAL), HID_QUIRK_HIDINPUT_FORCE }, 147 { HID_USB_DEVICE(USB_VENDOR_ID_PIXART, USB_DEVICE_ID_PIXART_OPTICAL_TOUCH_SCREEN1), HID_QUIRK_NO_INIT_REPORTS }, 148 { HID_USB_DEVICE(USB_VENDOR_ID_PIXART, USB_DEVICE_ID_PIXART_OPTICAL_TOUCH_SCREEN2), HID_QUIRK_NO_INIT_REPORTS }, 149 { HID_USB_DEVICE(USB_VENDOR_ID_PIXART, USB_DEVICE_ID_PIXART_OPTICAL_TOUCH_SCREEN), HID_QUIRK_NO_INIT_REPORTS }, 150 { HID_USB_DEVICE(USB_VENDOR_ID_PIXART, USB_DEVICE_ID_PIXART_USB_OPTICAL_MOUSE), HID_QUIRK_ALWAYS_POLL }, 151 { HID_USB_DEVICE(USB_VENDOR_ID_PRIMAX, USB_DEVICE_ID_PRIMAX_MOUSE_4D22), HID_QUIRK_ALWAYS_POLL }, 152 { HID_USB_DEVICE(USB_VENDOR_ID_PRIMAX, USB_DEVICE_ID_PRIMAX_MOUSE_4E2A), HID_QUIRK_ALWAYS_POLL }, 153 { HID_USB_DEVICE(USB_VENDOR_ID_PRIMAX, USB_DEVICE_ID_PRIMAX_PIXART_MOUSE_4D0F), HID_QUIRK_ALWAYS_POLL }, 154 { HID_USB_DEVICE(USB_VENDOR_ID_PRIMAX, USB_DEVICE_ID_PRIMAX_PIXART_MOUSE_4D65), HID_QUIRK_ALWAYS_POLL }, 155 { HID_USB_DEVICE(USB_VENDOR_ID_PRIMAX, USB_DEVICE_ID_PRIMAX_PIXART_MOUSE_4E22), HID_QUIRK_ALWAYS_POLL }, 156 { HID_USB_DEVICE(USB_VENDOR_ID_PRODIGE, USB_DEVICE_ID_PRODIGE_CORDLESS), HID_QUIRK_NOGET }, 157 { HID_USB_DEVICE(USB_VENDOR_ID_QUANTA, USB_DEVICE_ID_QUANTA_OPTICAL_TOUCH_3001), HID_QUIRK_NOGET }, 158 { HID_USB_DEVICE(USB_VENDOR_ID_QUANTA, USB_DEVICE_ID_QUANTA_OPTICAL_TOUCH_3003), HID_QUIRK_NOGET }, 159 { HID_USB_DEVICE(USB_VENDOR_ID_QUANTA, USB_DEVICE_ID_QUANTA_OPTICAL_TOUCH_3008), HID_QUIRK_NOGET }, 160 { HID_USB_DEVICE(USB_VENDOR_ID_REALTEK, USB_DEVICE_ID_REALTEK_READER), HID_QUIRK_NO_INIT_REPORTS }, 161 { HID_USB_DEVICE(USB_VENDOR_ID_RETROUSB, USB_DEVICE_ID_RETROUSB_SNES_RETROPAD), HID_QUIRK_INCREMENT_USAGE_ON_DUPLICATE }, 162 { HID_USB_DEVICE(USB_VENDOR_ID_RETROUSB, USB_DEVICE_ID_RETROUSB_SNES_RETROPORT), HID_QUIRK_INCREMENT_USAGE_ON_DUPLICATE }, 163 { HID_USB_DEVICE(USB_VENDOR_ID_SAITEK, USB_DEVICE_ID_SAITEK_RUMBLEPAD), HID_QUIRK_BADPAD }, 164 { HID_USB_DEVICE(USB_VENDOR_ID_SAITEK, USB_DEVICE_ID_SAITEK_X52), HID_QUIRK_INCREMENT_USAGE_ON_DUPLICATE }, 165 { HID_USB_DEVICE(USB_VENDOR_ID_SAITEK, USB_DEVICE_ID_SAITEK_X52_2), HID_QUIRK_INCREMENT_USAGE_ON_DUPLICATE }, 166 { HID_USB_DEVICE(USB_VENDOR_ID_SAITEK, USB_DEVICE_ID_SAITEK_X52_PRO), HID_QUIRK_INCREMENT_USAGE_ON_DUPLICATE }, 167 { HID_USB_DEVICE(USB_VENDOR_ID_SAITEK, USB_DEVICE_ID_SAITEK_X65), HID_QUIRK_INCREMENT_USAGE_ON_DUPLICATE }, 168 { HID_USB_DEVICE(USB_VENDOR_ID_SEMICO, USB_DEVICE_ID_SEMICO_USB_KEYKOARD2), HID_QUIRK_NO_INIT_REPORTS }, 169 { HID_USB_DEVICE(USB_VENDOR_ID_SEMICO, USB_DEVICE_ID_SEMICO_USB_KEYKOARD), HID_QUIRK_NO_INIT_REPORTS }, 170 { HID_USB_DEVICE(USB_VENDOR_ID_SENNHEISER, USB_DEVICE_ID_SENNHEISER_BTD500USB), HID_QUIRK_NOGET }, 171 { HID_USB_DEVICE(USB_VENDOR_ID_SIGMA_MICRO, USB_DEVICE_ID_SIGMA_MICRO_KEYBOARD), HID_QUIRK_NO_INIT_REPORTS }, 172 { HID_USB_DEVICE(USB_VENDOR_ID_SIGMATEL, USB_DEVICE_ID_SIGMATEL_STMP3780), HID_QUIRK_NOGET }, 173 { HID_USB_DEVICE(USB_VENDOR_ID_SIS_TOUCH, USB_DEVICE_ID_SIS1030_TOUCH), HID_QUIRK_NOGET }, 174 { HID_USB_DEVICE(USB_VENDOR_ID_SIS_TOUCH, USB_DEVICE_ID_SIS817_TOUCH), HID_QUIRK_NOGET }, 175 { HID_USB_DEVICE(USB_VENDOR_ID_SIS_TOUCH, USB_DEVICE_ID_SIS9200_TOUCH), HID_QUIRK_NOGET }, 176 { HID_USB_DEVICE(USB_VENDOR_ID_SIS_TOUCH, USB_DEVICE_ID_SIS_TS), HID_QUIRK_NO_INIT_REPORTS }, 177 { HID_USB_DEVICE(USB_VENDOR_ID_SUN, USB_DEVICE_ID_RARITAN_KVM_DONGLE), HID_QUIRK_NOGET }, 178 { HID_USB_DEVICE(USB_VENDOR_ID_SYMBOL, USB_DEVICE_ID_SYMBOL_SCANNER_1), HID_QUIRK_NOGET }, 179 { HID_USB_DEVICE(USB_VENDOR_ID_SYMBOL, USB_DEVICE_ID_SYMBOL_SCANNER_2), HID_QUIRK_NOGET }, 180 { HID_USB_DEVICE(USB_VENDOR_ID_SYNAPTICS, USB_DEVICE_ID_SYNAPTICS_HD), HID_QUIRK_NO_INIT_REPORTS }, 181 { HID_USB_DEVICE(USB_VENDOR_ID_SYNAPTICS, USB_DEVICE_ID_SYNAPTICS_LTS1), HID_QUIRK_NO_INIT_REPORTS }, 182 { HID_USB_DEVICE(USB_VENDOR_ID_SYNAPTICS, USB_DEVICE_ID_SYNAPTICS_LTS2), HID_QUIRK_NO_INIT_REPORTS }, 183 { HID_USB_DEVICE(USB_VENDOR_ID_SYNAPTICS, USB_DEVICE_ID_SYNAPTICS_QUAD_HD), HID_QUIRK_NO_INIT_REPORTS }, 184 { HID_USB_DEVICE(USB_VENDOR_ID_SYNAPTICS, USB_DEVICE_ID_SYNAPTICS_TP_V103), HID_QUIRK_NO_INIT_REPORTS }, 185 { HID_USB_DEVICE(USB_VENDOR_ID_SYNAPTICS, USB_DEVICE_ID_SYNAPTICS_DELL_K12A), HID_QUIRK_NO_INIT_REPORTS }, 186 { HID_USB_DEVICE(USB_VENDOR_ID_SYNAPTICS, USB_DEVICE_ID_SYNAPTICS_DELL_K15A), HID_QUIRK_NO_INIT_REPORTS }, 187 { HID_USB_DEVICE(USB_VENDOR_ID_TOPMAX, USB_DEVICE_ID_TOPMAX_COBRAPAD), HID_QUIRK_BADPAD }, 188 { HID_USB_DEVICE(USB_VENDOR_ID_TOUCHPACK, USB_DEVICE_ID_TOUCHPACK_RTS), HID_QUIRK_MULTI_INPUT }, 189 { HID_USB_DEVICE(USB_VENDOR_ID_TPV, USB_DEVICE_ID_TPV_OPTICAL_TOUCHSCREEN_8882), HID_QUIRK_NOGET }, 190 { HID_USB_DEVICE(USB_VENDOR_ID_TPV, USB_DEVICE_ID_TPV_OPTICAL_TOUCHSCREEN_8883), HID_QUIRK_NOGET }, 191 { HID_USB_DEVICE(USB_VENDOR_ID_TURBOX, USB_DEVICE_ID_TURBOX_KEYBOARD), HID_QUIRK_NOGET }, 192 { HID_USB_DEVICE(USB_VENDOR_ID_UCLOGIC, USB_DEVICE_ID_UCLOGIC_TABLET_KNA5), HID_QUIRK_MULTI_INPUT }, 193 { HID_USB_DEVICE(USB_VENDOR_ID_UCLOGIC, USB_DEVICE_ID_UCLOGIC_TABLET_TWA60), HID_QUIRK_MULTI_INPUT }, 194 { HID_USB_DEVICE(USB_VENDOR_ID_UGTIZER, USB_DEVICE_ID_UGTIZER_TABLET_WP5540), HID_QUIRK_MULTI_INPUT }, 195 { HID_USB_DEVICE(USB_VENDOR_ID_WALTOP, USB_DEVICE_ID_WALTOP_MEDIA_TABLET_10_6_INCH), HID_QUIRK_MULTI_INPUT }, 196 { HID_USB_DEVICE(USB_VENDOR_ID_WALTOP, USB_DEVICE_ID_WALTOP_MEDIA_TABLET_14_1_INCH), HID_QUIRK_MULTI_INPUT }, 197 { HID_USB_DEVICE(USB_VENDOR_ID_WALTOP, USB_DEVICE_ID_WALTOP_SIRIUS_BATTERY_FREE_TABLET), HID_QUIRK_MULTI_INPUT }, 198 { HID_USB_DEVICE(USB_VENDOR_ID_WISEGROUP_LTD2, USB_DEVICE_ID_SMARTJOY_DUAL_PLUS), HID_QUIRK_NOGET | HID_QUIRK_MULTI_INPUT }, 199 { HID_USB_DEVICE(USB_VENDOR_ID_WISEGROUP, USB_DEVICE_ID_QUAD_USB_JOYPAD), HID_QUIRK_NOGET | HID_QUIRK_MULTI_INPUT }, 200 { HID_USB_DEVICE(USB_VENDOR_ID_XIN_MO, USB_DEVICE_ID_XIN_MO_DUAL_ARCADE), HID_QUIRK_MULTI_INPUT }, 201 { HID_USB_DEVICE(USB_VENDOR_ID_LOGITECH, USB_DEVICE_ID_LOGITECH_GROUP_AUDIO), HID_QUIRK_NOGET }, 202 203 { 0 } 204 }; 205
Hi Torsha,
url: https://github.com/intel-lab-lkp/linux/commits/Torsha-Banerjee/Series-to-Fre... patch link: https://lore.kernel.org/r/20230328161119.1.I40a8881b83b0e440ed5368d98b42a2d9... patch subject: [PATCH] Series-to: Fred Bloggs f.blogs@napier.co.nz Series-cc: Sean O'Brien seobrien@chromium.org HID: input: Restore missing cursor for digitizer devices config: i386-randconfig-a012-20230327 (https://download.01.org/0day-ci/archive/20230329/202303290657.v6bveeLJ-lkp@i...) compiler: clang version 14.0.6 (https://github.com/llvm/llvm-project f28c006a5895fc0e329fe15fead81e37457cb1d1) reproduce (this is a W=1 build): wget https://raw.githubusercontent.com/intel/lkp-tests/master/sbin/make.cross -O ~/bin/make.cross chmod +x ~/bin/make.cross # https://github.com/intel-lab-lkp/linux/commit/15e6cca84ddc6ef20ce0e540e439b1... git remote add linux-review https://github.com/intel-lab-lkp/linux git fetch --no-tags linux-review Torsha-Banerjee/Series-to-Fred-Bloggs-f-blogs-napier-co-nz-Series-cc-Sean-O-Brien-seobrien-chromium-org-HID-input-Restore-missing-cursor/20230329-001305 git checkout 15e6cca84ddc6ef20ce0e540e439b1e976006f0b # save the config file mkdir build_dir && cp config build_dir/.config COMPILER_INSTALL_PATH=$HOME/0day COMPILER=clang make.cross W=1 O=build_dir ARCH=i386 olddefconfig COMPILER_INSTALL_PATH=$HOME/0day COMPILER=clang make.cross W=1 O=build_dir ARCH=i386 SHELL=/bin/bash drivers/
If you fix the issue, kindly add following tag where applicable | Reported-by: kernel test robot lkp@intel.com | Link: https://lore.kernel.org/oe-kbuild-all/202303290657.v6bveeLJ-lkp@intel.com/
drivers/hid/hid-quirks.c:105:40: error: use of undeclared identifier 'USB_DEVICE_ID_HUION_HS64'
{ HID_USB_DEVICE(USB_VENDOR_ID_HUION, USB_DEVICE_ID_HUION_HS64), HID_QUIRK_DEVICE_IS_DIGITIZER }, ^ 1 error generated.
vim +/USB_DEVICE_ID_HUION_HS64 +105 drivers/hid/hid-quirks.c
kernel test robot
Torsha Banerjee
