[U-Boot-Users] [PATCH] bootm/fdt: Only process the fdt if an fdt address was provided
Boards with CONFIG_OF_LIBFDT enabled are not able to boot old-style kernels using the board info structure (instead of passing a device tree) This change allows the old style booting to be used if the fdt argument was not passed to 'bootm'.
Signed-off-by: Grant Likely grant.likely@secretlab.ca ---
common/cmd_bootm.c | 36 +++++++++++++++++++----------------- 1 files changed, 19 insertions(+), 17 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index bcb927f..919188f 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -962,29 +962,31 @@ do_bootm_linux (cmd_tbl_t *cmdtp, int flag, * Add the chosen node if it doesn't exist, add the env and bd_t * if the user wants it (the logic is in the subroutines). */ - if (fdt_chosen(of_flat_tree, initrd_start, initrd_end, 0) < 0) { - puts ("ERROR: /chosen node create failed - " - "must RESET the board to recover.\n"); - do_reset (cmdtp, flag, argc, argv); - } + if (of_flat_tree) { + if (fdt_chosen(of_flat_tree, initrd_start, initrd_end, 0) < 0) { + puts ("ERROR: /chosen node create failed - " + "must RESET the board to recover.\n"); + do_reset (cmdtp, flag, argc, argv); + } #ifdef CONFIG_OF_HAS_UBOOT_ENV - if (fdt_env(of_flat_tree) < 0) { - puts ("ERROR: /u-boot-env node create failed - " - "must RESET the board to recover.\n"); - do_reset (cmdtp, flag, argc, argv); - } + if (fdt_env(of_flat_tree) < 0) { + puts ("ERROR: /u-boot-env node create failed - " + "must RESET the board to recover.\n"); + do_reset (cmdtp, flag, argc, argv); + } #endif #ifdef CONFIG_OF_HAS_BD_T - if (fdt_bd_t(of_flat_tree) < 0) { - puts ("ERROR: /bd_t node create failed - " - "must RESET the board to recover.\n"); - do_reset (cmdtp, flag, argc, argv); - } + if (fdt_bd_t(of_flat_tree) < 0) { + puts ("ERROR: /bd_t node create failed - " + "must RESET the board to recover.\n"); + do_reset (cmdtp, flag, argc, argv); + } #endif #ifdef CONFIG_OF_BOARD_SETUP - /* Call the board-specific fixup routine */ - ft_board_setup(of_flat_tree, gd->bd); + /* Call the board-specific fixup routine */ + ft_board_setup(of_flat_tree, gd->bd); #endif + } #endif /* CONFIG_OF_LIBFDT */ #if defined(CONFIG_OF_FLAT_TREE) #ifdef CFG_BOOTMAPSZ
On Thu, 30 Aug 2007 17:59:05 -0600 Grant Likely grant.likely@secretlab.ca wrote:
Thanks Grant,
Acked-by: Kim Phillips kim.phillips@freescale.com
Kim
Thanks Grant,
Who's tree should this getting pushed through? I'm getting ready to push the 5xxx libfdt fixup; shall I include it in my tree (even though it's not strictly a 5xxx change).
Cheers, g.
Thanks Grant,
Cheers, g.
U-boot-testing or, since it fixes an apparent bug, direct to the main repo would be my advice (through Wolfgang in either case).
Best regards, gvb
Grant Likely
Jerry Van Baren
Kim Phillips
