[U-Boot] [PATCH 10/13 v5] Makefile: Add Kconfig option CONFIG_SPL_IMAGE to select the SPL binary
This patch adds the CONFIG_SPL_IMAGE option to select the SPL image that shall be used to generate the combined SPL + U-Boot image. The default value is the current value "spl/u-boot-spl.bin".
This patch also sets CONFIG_SPL_IMAGE to "spl/boot.bin" for AT91 targets which use SPL NAND support (boot from NAND). For these build targets the combined image "u-boot-with-spl.bin" is now automatically generated and can be programmed into NAND as one single image (vs. SPL image and U-Boot as 2 separate images).
Signed-off-by: Stefan Roese sr@denx.de Cc: Heiko Schocher hs@denx.de Cc: Andreas Bießmann andreas@biessmann.org Cc: Eugen Hristev eugen.hristev@microchip.com --- v5: - Re-phrase Kconfig text to better describe the meaning of this Kconfig option
v3: - No change
v2: - No change
Kconfig | 11 +++++++++++ Makefile | 4 +++- 2 files changed, 14 insertions(+), 1 deletion(-)
diff --git a/Kconfig b/Kconfig index 305b265ed7..7a5491bd67 100644 --- a/Kconfig +++ b/Kconfig @@ -224,6 +224,16 @@ config BUILD_ROM which are not shipped in the U-Boot source tree. Please, see doc/README.x86 for details.
+config SPL_IMAGE + string "SPL image used in the combined SPL+U-Boot image" + default "spl/boot.bin" if ARCH_AT91 && SPL_NAND_SUPPORT + default "spl/u-boot-spl.bin" + help + Select the SPL build target that shall be generated by the SPL + build process (default spl/u-boot-spl.bin). This image will be + used to generate a combined image with SPL and main U-Boot + proper as one single image. + config BUILD_TARGET string "Build target special images" default "u-boot-with-spl.sfp" if TARGET_SOCFPGA_ARRIA10 @@ -232,6 +242,7 @@ config BUILD_TARGET default "u-boot-elf.srec" if RCAR_GEN3 default "u-boot.itb" if SPL_LOAD_FIT && ARCH_SUNXI default "u-boot.kwb" if KIRKWOOD + default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT help Some SoCs need special image types (e.g. U-Boot binary with a special header) as build targets. By defining diff --git a/Makefile b/Makefile index c1af9307b3..077bb6634e 100644 --- a/Makefile +++ b/Makefile @@ -1225,9 +1225,11 @@ else SPL_PAYLOAD := u-boot.bin endif
+SPL_IMAGE := $(CONFIG_SPL_IMAGE:"%"=%) + OBJCOPYFLAGS_u-boot-with-spl.bin = -I binary -O binary \ --pad-to=$(CONFIG_SPL_PAD_TO) -u-boot-with-spl.bin: spl/u-boot-spl.bin $(SPL_PAYLOAD) FORCE +u-boot-with-spl.bin: $(SPL_IMAGE) $(SPL_PAYLOAD) FORCE $(call if_changed,pad_cat)
ifeq ($(CONFIG_ARCH_LPC32XX)$(CONFIG_SPL),yy)
Applied this whole series to u-boot-atmel/next
Thanks !
Eugen.Hristev@microchip.com
Stefan Roese
