[U-Boot] [PATCH 2/2] arm64: ls1046ardb: Add distro boot support
Tested on ls1046ardb with automatically boot Ubuntu from SD card or USB disk, if it fails to detect external storage disk, fall back to qspi boot.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- configs/ls1046ardb_qspi_defconfig | 1 + configs/ls1046ardb_sdcard_defconfig | 1 + include/configs/ls1046a_common.h | 42 +++++++++++++++++++++++++++++++------ include/configs/ls1046aqds.h | 1 + include/configs/ls1046ardb.h | 6 ++---- 5 files changed, 41 insertions(+), 10 deletions(-)
diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 0479c98..9ab17d4 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -35,3 +35,4 @@ CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 12eb524..e9aa023 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -39,3 +39,4 @@ CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_DISTRO_DEFAULTS=y diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index b66b8ac..b859727 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -201,20 +201,54 @@ #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128
+#include <config_distro_defaults.h> +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(USB, usb, 0) +#include <config_distro_bootcmd.h> +#endif + #ifndef SPL_NO_MISC /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ - "loadaddr=0x80100000\0" \ "ramdisk_addr=0x800000\0" \ "ramdisk_size=0x2000000\0" \ "fdt_high=0xffffffffffffffff\0" \ "initrd_high=0xffffffffffffffff\0" \ + "fdt_addr=0x64f00000\0" \ + "kernel_addr=0x65000000\0" \ + "scriptaddr=0x80000000\0" \ + "fdtheader_addr_r=0x80100000\0" \ + "kernelheader_addr_r=0x80200000\0" \ + "load_addr=0xa0000000\0" \ + "fdt_addr_r=0x90000000\0" \ + "ramdisk_addr_r=0xa0000000\0" \ "kernel_start=0x1000000\0" \ "kernel_load=0xa0000000\0" \ "kernel_size=0x2800000\0" \ "console=ttyS0,115200\0" \ - MTDPARTS_DEFAULT "\0" + MTDPARTS_DEFAULT "\0" \ + BOOTENV \ + "boot_scripts=ls1046ardb_boot.scr\0" \ + "scan_dev_for_boot_part=" \ + "part list ${devtype} ${devnum} devplist; " \ + "env exists devplist || setenv devplist 1; " \ + "for distro_bootpart in ${devplist}; do " \ + "if fstype ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "bootfstype; then " \ + "run scan_dev_for_boot; " \ + "fi; " \ + "done\0" \ + "installer=load mmc 0:2 $load_addr " \ + "/flex_installer_arm64.itb; " \ + "bootm $load_addr#ls1046ardb\0" \ + "qspi_bootcmd=echo Trying load from qspi..;" \ + "sf probe && sf read $load_addr " \ + "$kernel_start $kernel_size && bootm $load_addr#$board\0" +
#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ "earlycon=uart8250,mmio,0x21c0500 " \ @@ -228,10 +262,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ #define CONFIG_SYS_LONGHELP
-#ifndef SPL_NO_MISC -#define CONFIG_CMDLINE_EDITING 1 -#endif - #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_MAXARGS 64 /* max command args */
diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 645cd9c..1b66c94 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -466,6 +466,7 @@ unsigned long get_board_ddr_clk(void);
#define CONFIG_CMDLINE_TAG
+#undef CONFIG_BOOTCOMMAND #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_BOOTCOMMAND "sf probe && sf read $kernel_load " \ "e0000 f00000 && bootm $kernel_load" diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index fb04248..b29fbad 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -243,10 +243,8 @@ #endif
#ifndef SPL_NO_MISC -#define CONFIG_BOOTCOMMAND "sf probe 0:0;sf read $kernel_load" \ - "$kernel_start $kernel_size;" \ - "bootm $kernel_load" - +#undef CONFIG_BOOTCOMMAND +#define CONFIG_BOOTCOMMAND "run distro_bootcmd;run qspi_bootcmd" #define MTDPARTS_DEFAULT "mtdparts=1550000.quadspi:1m(rcw)," \ "15m(u-boot),48m(kernel.itb);" \ "7e800000.flash:16m(nand_uboot)," \
It would be greatly helpful if you document your steps in board README file. Don't you think?
York
Gong Qianyu
York Sun
