Re: [U-Boot] u-boot-2008.10 nand boot not working for SMDK6400
hi Guennadi thanks for ur immediate reply... i had flash u-boot-nand.bin into nand, after reseting nothing is coming in console but 4 LEDs(D11-D14) are glowing.i'm using SMDK6400 rev0.1 Thanks & Regards Alagan.S
--- On Fri, 5/12/08, Guennadi Liakhovetski g.liakhovetski@gmx.de wrote: From: Guennadi Liakhovetski g.liakhovetski@gmx.de Subject: Re: u-boot-2008.10 nand boot not working for SMDK6400 To: "Alagan S" contact_ssa82@yahoo.in Date: Friday, 5 December, 2008, 8:07 AM
Hi Alagan,
On Fri, 5 Dec 2008, Alagan S wrote:
hi Guennadi,
           i am working on smdk6400
board.i've downloaded
u-boot-2008.10.i've compiled successfully and loaded u-boot.bin image into nand flash(say F2) using working u-boot-1.1.6(say F1). step i followed....
Please, write to the u-boot mailing list with any u-boot questions. If you feel that one specific person can help better than the others you can add him or her to CC, but you _have_ to have the mailing list among recepients. Also if you reply to this mail, please, write to the list, otherwise, I do not think I will be able to reply to you.
1.booting board with nand-boot using F1 nand flash (u-boot-1.1.6) 2.removed F1 from nand socket 3.placed F2(fresh nand) in nand socket 4.downloaded u-boot.bin in memory(tftp c0008000 u-boot.bin) using tftp 5.erased F2 (nand erase 0 40000) 6.has written u-boot.bin into F2 (nand write c0008000 0 40000) 7.then reset the board with F2
but board is not booting. nand boot support is there?? what is u-boot-nand.bin??i was trying to write into F2 but i has given
error??
u-boot-nand.bin _IS_ the image you need. It is this image that you have to flash to NAND.
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D. Freelance Open-Source Software Developer
Add more friends to your messenger and enjoy! Go to http://messenger.yahoo.com/invite/
Hi Alagan,
I didn't test 2008.10 release on smdk6400, last version I tried was from approximately end of September, which is not much older than 2008.10. Which toolchain and which configuration have you used? You haven't modified the sources, have you?
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Alagan S
