[U-Boot] [PATCH v3 0/3] Make usb device-tree fixup independent of USB controller
Makes usb device-tree fixup independent of Controller type. This enables the usage of device-tree fixup as a common framework for EHCI and XHCI controllers
Sriram Dash (3): board:freescale:common: Move device-tree fixup framework to common file board:freescale:usb: Remove code duplication for fdt_usb_get_node_type board:freescale:usb: Add device-tree fixup support for xhci controller
board/freescale/common/Makefile | 3 + board/freescale/common/usb.c | 194 +++++++++++++++++++++++++++++++++++++++ drivers/usb/host/ehci-fsl.c | 195 ---------------------------------------- include/fdt_support.h | 4 +- 4 files changed, 199 insertions(+), 197 deletions(-) create mode 100644 board/freescale/common/usb.c
Move usb device-tree fixup framework from ehci-fsl.c to common place so that it can be used by other drivers as well (xhci-fsl.c).
Signed-off-by: Ramneek Mehresh ramneek.mehresh@nxp.com Signed-off-by: Sriram Dash sriram.dash@nxp.com --- board/freescale/common/Makefile | 2 + .../ehci-fsl.c => board/freescale/common/usb.c | 160 +---------------- drivers/usb/host/ehci-fsl.c | 195 --------------------- 3 files changed, 3 insertions(+), 354 deletions(-) copy drivers/usb/host/ehci-fsl.c => board/freescale/common/usb.c (53%)
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index be114ce..62de45c 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -13,6 +13,8 @@ MINIMAL=y endif endif
+obj-$(CONFIG_USB_EHCI_FSL) += usb.o + ifdef MINIMAL # necessary to create built-in.o obj- := __dummy__.o diff --git a/drivers/usb/host/ehci-fsl.c b/board/freescale/common/usb.c similarity index 53% copy from drivers/usb/host/ehci-fsl.c copy to board/freescale/common/usb.c index 97b7f14..85cb1bf 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/board/freescale/common/usb.c @@ -1,9 +1,5 @@ /* - * (C) Copyright 2009, 2011 Freescale Semiconductor, Inc. - * - * (C) Copyright 2008, Excito Elektronik i Sk=E5ne AB - * - * Author: Tor Krill tor@excito.com + * (C) Copyright 2016 Freescale Semiconductor, Inc. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -17,164 +13,11 @@ #include <fsl_usb.h> #include <fdt_support.h>
-#include "ehci.h"
#ifndef CONFIG_USB_MAX_CONTROLLER_COUNT #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #endif
-static void set_txfifothresh(struct usb_ehci *, u32); - -/* Check USB PHY clock valid */ -static int usb_phy_clk_valid(struct usb_ehci *ehci) -{ - if (!((in_be32(&ehci->control) & PHY_CLK_VALID) || - in_be32(&ehci->prictrl))) { - printf("USB PHY clock invalid!\n"); - return 0; - } else { - return 1; - } -} - -/* - * Create the appropriate control structures to manage - * a new EHCI host controller. - * - * Excerpts from linux ehci fsl driver. - */ -int ehci_hcd_init(int index, enum usb_init_type init, - struct ehci_hccr **hccr, struct ehci_hcor **hcor) -{ - struct usb_ehci *ehci = NULL; - const char *phy_type = NULL; - size_t len; - char current_usb_controller[5]; -#ifdef CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY - char usb_phy[5]; - - usb_phy[0] = '\0'; -#endif - if (has_erratum_a007075()) { - /* - * A 5ms delay is needed after applying soft-reset to the - * controller to let external ULPI phy come out of reset. - * This delay needs to be added before re-initializing - * the controller after soft-resetting completes - */ - mdelay(5); - } - memset(current_usb_controller, '\0', 5); - snprintf(current_usb_controller, 4, "usb%d", index+1); - - switch (index) { - case 0: - ehci = (struct usb_ehci *)CONFIG_SYS_FSL_USB1_ADDR; - break; - case 1: - ehci = (struct usb_ehci *)CONFIG_SYS_FSL_USB2_ADDR; - break; - default: - printf("ERROR: wrong controller index!!\n"); - return -EINVAL; - }; - - *hccr = (struct ehci_hccr *)((uint32_t)&ehci->caplength); - *hcor = (struct ehci_hcor *)((uint32_t) *hccr + - HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); - - /* Set to Host mode */ - setbits_le32(&ehci->usbmode, CM_HOST); - - out_be32(&ehci->snoop1, SNOOP_SIZE_2GB); - out_be32(&ehci->snoop2, 0x80000000 | SNOOP_SIZE_2GB); - - /* Init phy */ - if (hwconfig_sub(current_usb_controller, "phy_type")) - phy_type = hwconfig_subarg(current_usb_controller, - "phy_type", &len); - else - phy_type = getenv("usb_phy_type"); - - if (!phy_type) { -#ifdef CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY - /* if none specified assume internal UTMI */ - strcpy(usb_phy, "utmi"); - phy_type = usb_phy; -#else - printf("WARNING: USB phy type not defined !!\n"); - return -1; -#endif - } - - if (!strncmp(phy_type, "utmi", 4)) { -#if defined(CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY) - clrsetbits_be32(&ehci->control, CONTROL_REGISTER_W1C_MASK, - PHY_CLK_SEL_UTMI); - clrsetbits_be32(&ehci->control, CONTROL_REGISTER_W1C_MASK, - UTMI_PHY_EN); - udelay(1000); /* delay required for PHY Clk to appear */ -#endif - out_le32(&(*hcor)->or_portsc[0], PORT_PTS_UTMI); - clrsetbits_be32(&ehci->control, CONTROL_REGISTER_W1C_MASK, - USB_EN); - } else { - clrsetbits_be32(&ehci->control, CONTROL_REGISTER_W1C_MASK, - PHY_CLK_SEL_ULPI); - clrsetbits_be32(&ehci->control, UTMI_PHY_EN | - CONTROL_REGISTER_W1C_MASK, USB_EN); - udelay(1000); /* delay required for PHY Clk to appear */ - if (!usb_phy_clk_valid(ehci)) - return -EINVAL; - out_le32(&(*hcor)->or_portsc[0], PORT_PTS_ULPI); - } - - out_be32(&ehci->prictrl, 0x0000000c); - out_be32(&ehci->age_cnt_limit, 0x00000040); - out_be32(&ehci->sictrl, 0x00000001); - - in_le32(&ehci->usbmode); - - if (has_erratum_a007798()) - set_txfifothresh(ehci, TXFIFOTHRESH); - - if (has_erratum_a004477()) { - /* - * When reset is issued while any ULPI transaction is ongoing - * then it may result to corruption of ULPI Function Control - * Register which eventually causes phy clock to enter low - * power mode which stops the clock. Thus delay is required - * before reset to let ongoing ULPI transaction complete. - */ - udelay(1); - } - return 0; -} - -/* - * Destroy the appropriate control structures corresponding - * the the EHCI host controller. - */ -int ehci_hcd_stop(int index) -{ - return 0; -} - -/* - * Setting the value of TXFIFO_THRESH field in TXFILLTUNING register - * to counter DDR latencies in writing data into Tx buffer. - * This prevents Tx buffer from getting underrun - */ -static void set_txfifothresh(struct usb_ehci *ehci, u32 txfifo_thresh) -{ - u32 cmd; - cmd = ehci_readl(&ehci->txfilltuning); - cmd &= ~TXFIFO_THRESH_MASK; - cmd |= TXFIFO_THRESH(txfifo_thresh); - ehci_writel(&ehci->txfilltuning, cmd); -} - -#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, const char *phy_type, int start_offset) { @@ -367,4 +210,3 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) } } } -#endif diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index 97b7f14..ec6b8fe 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -173,198 +173,3 @@ static void set_txfifothresh(struct usb_ehci *ehci, u32 txfifo_thresh) cmd |= TXFIFO_THRESH(txfifo_thresh); ehci_writel(&ehci->txfilltuning, cmd); } - -#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) -static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, - const char *phy_type, int start_offset) -{ - const char *compat_dr = "fsl-usb2-dr"; - const char *compat_mph = "fsl-usb2-mph"; - const char *prop_mode = "dr_mode"; - const char *prop_type = "phy_type"; - const char *node_type = NULL; - int node_offset; - int err; - - node_offset = fdt_node_offset_by_compatible(blob, - start_offset, compat_mph); - if (node_offset < 0) { - node_offset = fdt_node_offset_by_compatible(blob, - start_offset, - compat_dr); - if (node_offset < 0) { - printf("WARNING: could not find compatible node: %s", - fdt_strerror(node_offset)); - return -1; - } - node_type = compat_dr; - } else { - node_type = compat_mph; - } - - if (mode) { - err = fdt_setprop(blob, node_offset, prop_mode, mode, - strlen(mode) + 1); - if (err < 0) - printf("WARNING: could not set %s for %s: %s.\n", - prop_mode, node_type, fdt_strerror(err)); - } - - if (phy_type) { - err = fdt_setprop(blob, node_offset, prop_type, phy_type, - strlen(phy_type) + 1); - if (err < 0) - printf("WARNING: could not set %s for %s: %s.\n", - prop_type, node_type, fdt_strerror(err)); - } - - return node_offset; -} - -static const char *fdt_usb_get_node_type(void *blob, int start_offset, - int *node_offset) -{ - const char *compat_dr = "fsl-usb2-dr"; - const char *compat_mph = "fsl-usb2-mph"; - const char *node_type = NULL; - - *node_offset = fdt_node_offset_by_compatible(blob, start_offset, - compat_mph); - if (*node_offset < 0) { - *node_offset = fdt_node_offset_by_compatible(blob, - start_offset, - compat_dr); - if (*node_offset < 0) { - printf("ERROR: could not find compatible node: %s\n", - fdt_strerror(*node_offset)); - } else { - node_type = compat_dr; - } - } else { - node_type = compat_mph; - } - - return node_type; -} - -static int fdt_fixup_usb_erratum(void *blob, const char *prop_erratum, - int start_offset) -{ - int node_offset, err; - const char *node_type = NULL; - - node_type = fdt_usb_get_node_type(blob, start_offset, &node_offset); - if (!node_type) - return -1; - - err = fdt_setprop(blob, node_offset, prop_erratum, NULL, 0); - if (err < 0) { - printf("ERROR: could not set %s for %s: %s.\n", - prop_erratum, node_type, fdt_strerror(err)); - } - - return node_offset; -} - -void fdt_fixup_dr_usb(void *blob, bd_t *bd) -{ - static const char * const modes[] = { "host", "peripheral", "otg" }; - static const char * const phys[] = { "ulpi", "utmi", "utmi_dual" }; - int usb_erratum_a006261_off = -1; - int usb_erratum_a007075_off = -1; - int usb_erratum_a007792_off = -1; - int usb_erratum_a005697_off = -1; - int usb_mode_off = -1; - int usb_phy_off = -1; - char str[5]; - int i, j; - - for (i = 1; i <= CONFIG_USB_MAX_CONTROLLER_COUNT; i++) { - const char *dr_mode_type = NULL; - const char *dr_phy_type = NULL; - int mode_idx = -1, phy_idx = -1; - - snprintf(str, 5, "%s%d", "usb", i); - if (hwconfig(str)) { - for (j = 0; j < ARRAY_SIZE(modes); j++) { - if (hwconfig_subarg_cmp(str, "dr_mode", - modes[j])) { - mode_idx = j; - break; - } - } - - for (j = 0; j < ARRAY_SIZE(phys); j++) { - if (hwconfig_subarg_cmp(str, "phy_type", - phys[j])) { - phy_idx = j; - break; - } - } - - if (mode_idx < 0 && phy_idx < 0) { - printf("WARNING: invalid phy or mode\n"); - return; - } - - if (mode_idx > -1) - dr_mode_type = modes[mode_idx]; - - if (phy_idx > -1) - dr_phy_type = phys[phy_idx]; - } - - if (has_dual_phy()) - dr_phy_type = phys[2]; - - usb_mode_off = fdt_fixup_usb_mode_phy_type(blob, - dr_mode_type, NULL, - usb_mode_off); - - if (usb_mode_off < 0) - return; - - usb_phy_off = fdt_fixup_usb_mode_phy_type(blob, - NULL, dr_phy_type, - usb_phy_off); - - if (usb_phy_off < 0) - return; - - if (has_erratum_a006261()) { - usb_erratum_a006261_off = fdt_fixup_usb_erratum - (blob, - "fsl,usb-erratum-a006261", - usb_erratum_a006261_off); - if (usb_erratum_a006261_off < 0) - return; - } - - if (has_erratum_a007075()) { - usb_erratum_a007075_off = fdt_fixup_usb_erratum - (blob, - "fsl,usb-erratum-a007075", - usb_erratum_a007075_off); - if (usb_erratum_a007075_off < 0) - return; - } - - if (has_erratum_a007792()) { - usb_erratum_a007792_off = fdt_fixup_usb_erratum - (blob, - "fsl,usb-erratum-a007792", - usb_erratum_a007792_off); - if (usb_erratum_a007792_off < 0) - return; - } - if (has_erratum_a005697()) { - usb_erratum_a005697_off = fdt_fixup_usb_erratum - (blob, - "fsl,usb-erratum-a005697", - usb_erratum_a005697_off); - if (usb_erratum_a005697_off < 0) - return; - } - } -} -#endif
Where is the changelog ?
- (C) Copyright 2009, 2011 Freescale Semiconductor, Inc.
- (C) Copyright 2008, Excito Elektronik i Sk=E5ne AB
- Author: Tor Krill tor@excito.com
- (C) Copyright 2016 Freescale Semiconductor, Inc.
What's with this copyright change here ?
-#include "ehci.h"
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Wednesday, March 02, 2016 3:43 AM To: Sriram Dash sriram.dash@nxp.com; u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; Ramneek Mehresh ramneek.mehresh@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Tom Rini trini@konsulko.com Subject: Re: [PATCH v3 1/3] board:freescale:common: Move device-tree fixup framework to common file
Will include changelog for v2 and v3 in v4.
It is a new file named common/usb.c. Shall I include the complete ehci-fsl.c copyright information in the new file?
-#include "ehci.h"
-- Best regards, Marek Vasut
Best Regards, Sriram
There is already a file named common/usb.c , you surely mean board/freescale/common/usb.c , yes ?
According to git, it's not a new file:
so yes, it should retain all copyright info.
And now that I am looking at it, I would much rather see the fixup bits in drivers/usb/host/ than some board-specific file. You can very well put those into fsl-dt-fixup.c or whatever there.
-#include "ehci.h"
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, March 03, 2016 3:26 PM To: Sriram Dash sriram.dash@nxp.com; u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; Ramneek Mehresh ramneek.mehresh@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Tom Rini trini@konsulko.com Subject: Re: [PATCH v3 1/3] board:freescale:common: Move device-tree fixup framework to common file
Yes
Ok, We will retain copyright info in v4.
drivers/usb/host/ was a good option, but we want to make it independent of host and gadget. So, whenever there is a specific requirement for freescale boards, it will use the same from board: freescale: common: usb
Else, another option is to have drivers/usb/common/fsl-dt-fixup.c. What do you say?
-#include "ehci.h"
Yes
That is fine. Moving it to board code would make it problematic to convert to DM afterward, so I want to prevent that.
-#include "ehci.h"
Call fdt_usb_get_node_type() from fdt_fixup_usb_mode_phy_type() to avoid code duplication.
Signed-off-by: Ramneek Mehresh ramneek.mehresh@nxp.com Signed-off-by: Sriram Dash sriram.dash@nxp.com --- board/freescale/common/usb.c | 72 ++++++++++++++++++-------------------------- 1 file changed, 29 insertions(+), 43 deletions(-)
diff --git a/board/freescale/common/usb.c b/board/freescale/common/usb.c index 85cb1bf..d815dc1 100644 --- a/board/freescale/common/usb.c +++ b/board/freescale/common/usb.c @@ -18,33 +18,45 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #endif
-static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, - const char *phy_type, int start_offset) +static const char *fdt_usb_get_node_type(void *blob, int start_offset, + int *node_offset) { const char *compat_dr = "fsl-usb2-dr"; const char *compat_mph = "fsl-usb2-mph"; - const char *prop_mode = "dr_mode"; - const char *prop_type = "phy_type"; const char *node_type = NULL; - int node_offset; - int err;
- node_offset = fdt_node_offset_by_compatible(blob, - start_offset, compat_mph); - if (node_offset < 0) { - node_offset = fdt_node_offset_by_compatible(blob, - start_offset, - compat_dr); - if (node_offset < 0) { - printf("WARNING: could not find compatible node: %s", - fdt_strerror(node_offset)); - return -1; + *node_offset = fdt_node_offset_by_compatible(blob, start_offset, + compat_mph); + if (*node_offset < 0) { + *node_offset = fdt_node_offset_by_compatible(blob, + start_offset, + compat_dr); + if (*node_offset < 0) { + printf("ERROR: could not find compatible node: %s\n", + fdt_strerror(*node_offset)); + } else { + node_type = compat_dr; } - node_type = compat_dr; } else { node_type = compat_mph; }
+ return node_type; +} + +static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, + const char *phy_type, int start_offset) +{ + const char *prop_mode = "dr_mode"; + const char *prop_type = "phy_type"; + const char *node_type = NULL; + int node_offset; + int err; + + node_type = fdt_usb_get_node_type(blob, start_offset, &node_offset); + if (!node_type) + return -1; + if (mode) { err = fdt_setprop(blob, node_offset, prop_mode, mode, strlen(mode) + 1); @@ -64,32 +76,6 @@ static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, return node_offset; }
-static const char *fdt_usb_get_node_type(void *blob, int start_offset, - int *node_offset) -{ - const char *compat_dr = "fsl-usb2-dr"; - const char *compat_mph = "fsl-usb2-mph"; - const char *node_type = NULL; - - *node_offset = fdt_node_offset_by_compatible(blob, start_offset, - compat_mph); - if (*node_offset < 0) { - *node_offset = fdt_node_offset_by_compatible(blob, - start_offset, - compat_dr); - if (*node_offset < 0) { - printf("ERROR: could not find compatible node: %s\n", - fdt_strerror(*node_offset)); - } else { - node_type = compat_dr; - } - } else { - node_type = compat_mph; - } - - return node_type; -} - static int fdt_fixup_usb_erratum(void *blob, const char *prop_erratum, int start_offset) {
int *node_offset)
int node_offset;
int err;
start_offset,
compat_dr);
return -1;
compat_mph);
start_offset,
compat_dr);
} else {
}node_type = compat_dr;
} else { node_type = compat_mph; }node_type = compat_dr;
- return node_type;
The function should be able to return error code. If you need to return some more stuff from the function, return it via reference.
- int node_offset;
- int err;
- if (!node_type)
return -1;
- if (mode) { err = fdt_setprop(blob, node_offset, prop_mode, mode, strlen(mode) + 1);
int *node_offset)
compat_mph);
start_offset,
compat_dr);
} else {
- } else {
- return node_type;
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Wednesday, March 02, 2016 3:57 AM To: Sriram Dash sriram.dash@nxp.com; u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; Ramneek Mehresh ramneek.mehresh@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com Subject: Re: [PATCH v3 2/3] board:freescale:usb: Remove code duplication for fdt_usb_get_node_type
int *node_offset)
int node_offset;
int err;
start_offset,
compat_dr);
return -1;
compat_mph);
start_offset,
compat_dr);
} else {
- return node_type;
This patch is not altering the fdt_usb_get_node_type(). It is only calling the function from fdt_fixup_usb_mode_phy_type(), to avoid code duplication.
- int node_offset;
- int err;
- if (!node_type)
return -1;
char *mode,
int *node_offset)
compat_mph);
start_offset,
compat_dr);
} else {
- } else {
- return node_type;
int *node_offset)
int node_offset;
int err;
start_offset,
compat_dr);
return -1;
compat_mph);
start_offset,
compat_dr);
} else {
- return node_type;
I am not complaining about that part. I am complaining about the new function, fdt_usb_get_node_type(), which returns pointer as a return value instead of returning proper error code as a return value.
- int node_offset;
- int err;
- if (!node_type)
return -1;
char *mode,
int *node_offset)
compat_mph);
start_offset,
compat_dr);
} else {
- } else {
- return node_type;
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, March 03, 2016 3:29 PM To: Sriram Dash sriram.dash@nxp.com; u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; Ramneek Mehresh ramneek.mehresh@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com Subject: Re: [PATCH v3 2/3] board:freescale:usb: Remove code duplication for fdt_usb_get_node_type
int *node_offset)
int node_offset;
int err;
start_offset,
compat_dr);
return -1;
compat_mph);
start_offset,
compat_dr);
} else {
- return node_type;
duplication.
I think git diff tool is creating confusion here, I have just moved function fdt_usb_get_node_type above fdt_fixup_usb_mode_phy_type which created all the diff and looked as if new function is added.
Please check below created patch where declaration is added to call fdt_usb_get_node_type in fdt_usb_get_mode_phy_type. We will be sending below in V4.
diff --git a/board/freescale/common/usb.c b/board/freescale/common/usb.c index 85cb1bf..5553225 100644 --- a/board/freescale/common/usb.c +++ b/board/freescale/common/usb.c @@ -18,32 +18,21 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #endif
+const char *fdt_usb_get_node_type(void *blob, int start_offset, + int *node_offset); + static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, const char *phy_type, int start_offset) { - const char *compat_dr = "fsl-usb2-dr"; - const char *compat_mph = "fsl-usb2-mph"; const char *prop_mode = "dr_mode"; const char *prop_type = "phy_type"; const char *node_type = NULL; int node_offset; int err;
- node_offset = fdt_node_offset_by_compatible(blob, - start_offset, compat_mph); - if (node_offset < 0) { - node_offset = fdt_node_offset_by_compatible(blob, - start_offset, - compat_dr); - if (node_offset < 0) { - printf("WARNING: could not find compatible node: %s", - fdt_strerror(node_offset)); - return -1; - } - node_type = compat_dr; - } else { - node_type = compat_mph; - } + node_type = fdt_usb_get_node_type(blob, start_offset, &node_offset); + if (!node_type) + return -1;
- int node_offset;
- int err;
- if (!node_type)
return -1;
char *mode,
int *node_offset)
compat_mph);
start_offset,
compat_dr);
} else {
- } else {
- return node_type;
int *node_offset)
int node_offset;
int err;
start_offset,
compat_dr);
return -1;
compat_mph);
start_offset,
compat_dr);
} else {
- return node_type;
duplication.
int *node_offset);
Ah I see, I am wrong, sorry.
btw can you fix the fdt_usb_get_node_type() in another patch to return int ?
Thanks! Best regards, Marek Vasut
Enables usb device-tree fixup code to incorporate xhci controller
Signed-off-by: Ramneek Mehresh ramneek.mehresh@nxp.com Signed-off-by: Sriram Dash sriram.dash@nxp.com --- board/freescale/common/Makefile | 1 + board/freescale/common/usb.c | 30 +++++++++++++----------------- include/fdt_support.h | 4 ++-- 3 files changed, 16 insertions(+), 19 deletions(-)
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 62de45c..c644896 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -14,6 +14,7 @@ endif endif
obj-$(CONFIG_USB_EHCI_FSL) += usb.o +obj-$(CONFIG_USB_XHCI_FSL) += usb.o
ifdef MINIMAL # necessary to create built-in.o diff --git a/board/freescale/common/usb.c b/board/freescale/common/usb.c index d815dc1..8e423be 100644 --- a/board/freescale/common/usb.c +++ b/board/freescale/common/usb.c @@ -18,29 +18,25 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #endif
+const char compat_usb_fsl[][16] = {"fsl-usb2-mph", + "fsl-usb2-dr", + "snps,dwc3"}; + static const char *fdt_usb_get_node_type(void *blob, int start_offset, int *node_offset) { - const char *compat_dr = "fsl-usb2-dr"; - const char *compat_mph = "fsl-usb2-mph"; const char *node_type = NULL; - - *node_offset = fdt_node_offset_by_compatible(blob, start_offset, - compat_mph); - if (*node_offset < 0) { - *node_offset = fdt_node_offset_by_compatible(blob, - start_offset, - compat_dr); - if (*node_offset < 0) { - printf("ERROR: could not find compatible node: %s\n", - fdt_strerror(*node_offset)); - } else { - node_type = compat_dr; + int size = sizeof(compat_usb_fsl)/sizeof(compat_usb_fsl[0]); + int i; + + for (i = 0; i < size ; i++) { + *node_offset = fdt_node_offset_by_compatible + (blob, start_offset, compat_usb_fsl[i]); + if (*node_offset >= 0) { + node_type = compat_usb_fsl[i]; + break; } - } else { - node_type = compat_mph; } - return node_type; }
diff --git a/include/fdt_support.h b/include/fdt_support.h index 296add0..d34e959 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -113,11 +113,11 @@ void fdt_fixup_qe_firmware(void *fdt); */ int fdt_fixup_display(void *blob, const char *path, const char *display);
-#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) +#if defined(CONFIG_USB_EHCI_FSL) || defined(CONFIG_USB_XHCI_FSL) void fdt_fixup_dr_usb(void *blob, bd_t *bd); #else static inline void fdt_fixup_dr_usb(void *blob, bd_t *bd) {} -#endif /* defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) */ +#endif /* defined(CONFIG_USB_EHCI_FSL) || defined(CONFIG_USB_XHCI_FSL) */
#if defined(CONFIG_SYS_FSL_SEC_COMPAT) void fdt_fixup_crypto_node(void *blob, int sec_rev);
Changelog ?
"fsl-usb2-dr",
"snps,dwc3"};
This is const char *foo[].
compat_mph);
start_offset,
compat_dr);
} else {
- int size = sizeof(compat_usb_fsl)/sizeof(compat_usb_fsl[0]);
Oh the art of counting. Firstly, what you did here is reimplementation of ARRAY_SIZE(), but that's wrong in this context. Each one of the array elements is differently sized, so to avoid problems with this crap, the code hard-codes random constant defining the element size, which is another crap workaround as it will break once a longer element is added. And it wastes space. No, instead, use a terminating entry in the array.
btw use checkpatch before your next submission.
- int i;
- for (i = 0; i < size ; i++) {
}break;
- } else {
}node_type = compat_mph;
- return node_type;
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Wednesday, March 02, 2016 3:55 AM To: Sriram Dash sriram.dash@nxp.com; u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; Ramneek Mehresh ramneek.mehresh@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com Subject: Re: [PATCH v3 3/3] board:freescale:usb: Add device-tree fixup support for xhci controller
Changelog ?
"fsl-usb2-dr",
"snps,dwc3"};
Reference from "char compat[][16] = { "cfi-flash", "jedec-flash" };" I will change to const char *compat_usb_fsl[] in v4.
compat_mph);
start_offset,
compat_dr);
} else {
Will change compat_usb_fsl[][16] into const char *compat_usb_fsl[], and use ARRAY_SIZE(compat_usb_fsl) . What is your opinion?
- int i;
}break;
- } else {
- return node_type;
-#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) +#if defined(CONFIG_USB_EHCI_FSL) || defined(CONFIG_USB_XHCI_FSL) void fdt_fixup_dr_usb(void *blob, bd_t *bd); #else static inline void fdt_fixup_dr_usb(void *blob, bd_t *bd) {} -#endif /* defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) */ +#endif /* defined(CONFIG_USB_EHCI_FSL) || +defined(CONFIG_USB_XHCI_FSL) */
Changelog ?
"fsl-usb2-dr",
"snps,dwc3"};
compat_mph);
start_offset,
compat_dr);
} else {
My opinion is to use a terminating NULL entry and iterate over the array until you reach it.
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, March 03, 2016 3:33 PM To: Sriram Dash sriram.dash@nxp.com; u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; Ramneek Mehresh ramneek.mehresh@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com Subject: Re: [PATCH v3 3/3] board:freescale:usb: Add device-tree fixup support for xhci controller
Changelog ?
"fsl-usb2-dr",
"snps,dwc3"};
compat_mph);
start_offset,
compat_dr);
} else {
element is added.
Accepted. Will do it in v4.
Sriram Dash
