[U-Boot] [PATCH] PMIC: MAX77686: fix invalid bus check
Since p->bus is unsigned checking for negative values is optimized away. Since bus is already used as an argument use tmp. While at it, don't declare variables in the middle of a function.
cc: Rajeshwari Shinde rajeshwari.s@samsung.com Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- drivers/power/pmic/pmic_max77686.c | 13 ++++++++----- 1 file changed, 8 insertions(+), 5 deletions(-)
diff --git a/drivers/power/pmic/pmic_max77686.c b/drivers/power/pmic/pmic_max77686.c index d4c430e..df1fd91 100644 --- a/drivers/power/pmic/pmic_max77686.c +++ b/drivers/power/pmic/pmic_max77686.c @@ -210,6 +210,10 @@ int pmic_init(unsigned char bus) { static const char name[] = "MAX77686_PMIC"; struct pmic *p = pmic_alloc(); +#ifdef CONFIG_OF_CONTROL + const void *blob = gd->fdt_blob; + int node, parent, tmp; +#endif
if (!p) { printf("%s: POWER allocation error!\n", __func__); @@ -217,9 +221,6 @@ int pmic_init(unsigned char bus) }
#ifdef CONFIG_OF_CONTROL - const void *blob = gd->fdt_blob; - int node, parent; - node = fdtdec_next_compatible(blob, 0, COMPAT_MAXIM_MAX77686_PMIC); if (node < 0) { debug("PMIC: No node for PMIC Chip in device tree\n"); @@ -233,11 +234,13 @@ int pmic_init(unsigned char bus) return -1; }
- p->bus = i2c_get_bus_num_fdt(parent); - if (p->bus < 0) { + /* tmp since p->bus is unsigned */ + tmp = i2c_get_bus_num_fdt(parent); + if (tmp < 0) { debug("%s: Cannot find I2C bus\n", __func__); return -1; } + p->bus = tmp; p->hw.i2c.addr = fdtdec_get_int(blob, node, "reg", 9); #else p->bus = bus;
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Jeroen Hofstee
Minkyu Kang
