[U-Boot] [PATCH V8 0/5] Add disk support to orion5x and edminiv2
Patchset history:
V1: Initial 4-patch set -- not cleanly submitted (does not appear on gmane for instance) and contained some unrelated changes.
V2: Slimmed down to 3 patches and removed unrelated changes.
V3: Back to 4 patches (cmd_ide improvement, driver addition, cmd_ide support for orion, edminiv2 support for sata); made initialization code reuseable as a block driver ; moved to C structures; commented some constants.
V4: Reordered objects alphabetically in drivers/block/Makefile. Shortened mv_sata to mvsata. Removed volatile qualifier in mvsata port structure. Moved port pointer definition from SoC to board code. Removed unrelated changes.
V5: Fixed typo in mvsata_ide driver (IMP, should have been IPM).
V6: Fixed case in ide register struct. Fixed warning in deminiv2.c Put IDE configuration under condition.
V7: Reworked the initialization logic to poll status register. Moved initialization from board code to driver code. Removed driver header file and moved its content to driver code. Moved CONFIG_IDE_PREINIT from SoC to board config file.
V8: Separated V7's patch 2 in two independant patches. Fixed typo in struct names within ide_preinit().
The V8 patches have been run through checkpatch.pl --no-tree with no errors or warnings, and have been tested on an ED Mini V2.
Albert Aribaud (5): ide: add configuration CONFIG_IDE_SWAP_IO ide: reorder object files alphabetically ide: add mvsata_ide driver cmd_ide: add support for orion5x edminiv2: add mvsata_ide and cmd_ide support
arch/arm/include/asm/arch-orion5x/orion5x.h | 3 + arch/powerpc/include/asm/config.h | 3 + common/cmd_ide.c | 23 +++-- doc/README.PXA_CF | 8 ++ drivers/block/Makefile | 7 +- drivers/block/mvsata_ide.c | 140 +++++++++++++++++++++++++++ include/configs/ap325rxa.h | 1 + include/configs/edminiv2.h | 34 ++++++- include/configs/ms7720se.h | 1 + include/configs/r2dplus.h | 1 + include/configs/r7780mp.h | 1 + 11 files changed, 209 insertions(+), 13 deletions(-) create mode 100644 drivers/block/mvsata_ide.c
This configuration option replaces a complex conditional in cmd_ide.c with an explicit define to be added to SoC or board configs.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- arch/powerpc/include/asm/config.h | 3 +++ common/cmd_ide.c | 18 +++++++++--------- doc/README.PXA_CF | 8 ++++++++ include/configs/ap325rxa.h | 1 + include/configs/ms7720se.h | 1 + include/configs/r2dplus.h | 1 + include/configs/r7780mp.h | 1 + 7 files changed, 24 insertions(+), 9 deletions(-)
diff --git a/arch/powerpc/include/asm/config.h b/arch/powerpc/include/asm/config.h index f70699d..d098657 100644 --- a/arch/powerpc/include/asm/config.h +++ b/arch/powerpc/include/asm/config.h @@ -95,4 +95,7 @@ #define CONFIG_FSL_LBC #endif
+/* All PPC boards must swap IDE bytes */ +#define CONFIG_IDE_SWAP_IO + #endif /* _ASM_CONFIG_H_ */ diff --git a/common/cmd_ide.c b/common/cmd_ide.c index c0fb88d..d423e53 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -847,7 +847,7 @@ input_swap_data(int dev, ulong *sect_buf, int words) #endif /* __LITTLE_ENDIAN || CONFIG_AU1X00 */
-#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) || defined(CONFIG_SH) +#if defined(CONFIG_IDE_SWAP_IO) static void output_data(int dev, ulong *sect_buf, int words) { @@ -891,15 +891,15 @@ output_data(int dev, ulong *sect_buf, int words) } #endif } -#else /* ! __PPC__ */ +#else /* ! CONFIG_IDE_SWAP_IO */ static void output_data(int dev, ulong *sect_buf, int words) { outsw(ATA_CURR_BASE(dev)+ATA_DATA_REG, sect_buf, words<<1); } -#endif /* __PPC__ */ +#endif /* CONFIG_IDE_SWAP_IO */
-#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) || defined(CONFIG_SH) +#if defined(CONFIG_IDE_SWAP_IO) static void input_data(int dev, ulong *sect_buf, int words) { @@ -949,14 +949,14 @@ input_data(int dev, ulong *sect_buf, int words) } #endif } -#else /* ! __PPC__ */ +#else /* ! CONFIG_IDE_SWAP_IO */ static void input_data(int dev, ulong *sect_buf, int words) { insw(ATA_CURR_BASE(dev)+ATA_DATA_REG, sect_buf, words << 1); }
/* ------------------------------------------------------------------------- */ @@ -1573,7 +1573,7 @@ int ide_device_present(int dev) * ATAPI Support */
-#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) +#if defined(CONFIG_IDE_SWAP_IO) /* since ATAPI may use commands with not 4 bytes alligned length * we have our own transfer functions, 2 bytes alligned */ static void @@ -1640,7 +1640,7 @@ input_data_shorts(int dev, ushort *sect_buf, int shorts) #endif }
-#else /* ! __PPC__ */ +#else /* ! CONFIG_IDE_SWAP_IO */ static void output_data_shorts(int dev, ushort *sect_buf, int shorts) { @@ -1653,7 +1653,7 @@ input_data_shorts(int dev, ushort *sect_buf, int shorts) insw(ATA_CURR_BASE(dev)+ATA_DATA_REG, sect_buf, shorts); }
/* * Wait until (Status & mask) == res, or timeout (in ms) diff --git a/doc/README.PXA_CF b/doc/README.PXA_CF index 6a0f236..1d76b32 100644 --- a/doc/README.PXA_CF +++ b/doc/README.PXA_CF @@ -6,6 +6,14 @@ follow the connections of the standard lubbock. Anyway just the block marked memory configuration should be touched since the other parameters are imposed by the PXA architecture.
+EDIT 2010-07-01: in common/cmd_ide.c, having CONFIG_PXA_PCMCIA defined +would cause looping on inw()/outw() rather than using insw()/outsw(), +thus making sure IDE / ATA bytes are properly swapped. This behaviour +is now controlled by CONFIG_IDE_SWAP_IO, therefore PXA boards with +PCMCIA should #define CONFIG_IDE_SWAP_IO. + +#define CONFIG_IDE_SWAP_IO + #define CONFIG_PXA_PCMCIA 1 #define CONFIG_PXA_IDE 1
diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 70dd47e..80a5797 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -138,6 +138,7 @@ #define CONFIG_SYS_ATA_DATA_OFFSET 0x200 /* data reg offset */ #define CONFIG_SYS_ATA_REG_OFFSET 0x200 /* reg offset */ #define CONFIG_SYS_ATA_ALT_OFFSET 0x210 /* alternate register offset */ +#define CONFIG_IDE_SWAP_IO
/* if you use all NOR Flash , you change dip-switch. Please see Manual. */ #define CONFIG_SYS_MAX_FLASH_BANKS 1 diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index ba0a3f8..0ea3527 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -122,5 +122,6 @@ #define CONFIG_SYS_ATA_DATA_OFFSET 0 /* data reg offset */ #define CONFIG_SYS_ATA_REG_OFFSET 0 /* reg offset */ #define CONFIG_SYS_ATA_ALT_OFFSET 0x200 /* alternate register offset */ +#define CONFIG_IDE_SWAP_IO
#endif /* __MS7720SE_H */ diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 8931b97..955f3ff 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -96,6 +96,7 @@ #define CONFIG_SYS_ATA_DATA_OFFSET 0x1000 /* data reg offset */ #define CONFIG_SYS_ATA_REG_OFFSET 0x1000 /* reg offset */ #define CONFIG_SYS_ATA_ALT_OFFSET 0x800 /* alternate register offset */ +#define CONFIG_IDE_SWAP_IO
/* * SuperH PCI Bridge Configration diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index 71c570e..3afe93a 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -171,6 +171,7 @@ #define CONFIG_SYS_ATA_DATA_OFFSET 0x1000 /* data reg offset */ #define CONFIG_SYS_ATA_REG_OFFSET 0x1000 /* reg offset */ #define CONFIG_SYS_ATA_ALT_OFFSET 0x800 /* alternate register offset */ +#define CONFIG_IDE_SWAP_IO #endif /* CONFIG_CMD_IDE */
#endif /* __R7780RP_H */
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- drivers/block/Makefile | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/block/Makefile b/drivers/block/Makefile index 3f6ad5c..3bab1e4 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -25,15 +25,15 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libblock.a
+COBJS-$(CONFIG_SCSI_AHCI) += ahci.o COBJS-$(CONFIG_ATA_PIIX) += ata_piix.o -COBJS-$(CONFIG_CMD_MG_DISK) += mg_disk.o COBJS-$(CONFIG_FSL_SATA) += fsl_sata.o -COBJS-$(CONFIG_IDE_SIL680) += sil680.o COBJS-$(CONFIG_LIBATA) += libata.o +COBJS-$(CONFIG_CMD_MG_DISK) += mg_disk.o COBJS-$(CONFIG_PATA_BFIN) += pata_bfin.o COBJS-$(CONFIG_SATA_DWC) += sata_dwc.o COBJS-$(CONFIG_SATA_SIL3114) += sata_sil3114.o -COBJS-$(CONFIG_SCSI_AHCI) += ahci.o +COBJS-$(CONFIG_IDE_SIL680) += sil680.o COBJS-$(CONFIG_SCSI_SYM53C8XX) += sym53c8xx.o COBJS-$(CONFIG_SYSTEMACE) += systemace.o
This driver only provides initialization code; actual driving is done by cmd_ide.c using the ATA compatibility mode of the Marvell SATAHC controller.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- drivers/block/Makefile | 1 + drivers/block/mvsata_ide.c | 140 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 141 insertions(+), 0 deletions(-) create mode 100644 drivers/block/mvsata_ide.c
diff --git a/drivers/block/Makefile b/drivers/block/Makefile index 3bab1e4..64dcf4e 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -30,6 +30,7 @@ COBJS-$(CONFIG_ATA_PIIX) += ata_piix.o COBJS-$(CONFIG_FSL_SATA) += fsl_sata.o COBJS-$(CONFIG_LIBATA) += libata.o COBJS-$(CONFIG_CMD_MG_DISK) += mg_disk.o +COBJS-$(CONFIG_MVSATA_IDE) += mvsata_ide.o COBJS-$(CONFIG_PATA_BFIN) += pata_bfin.o COBJS-$(CONFIG_SATA_DWC) += sata_dwc.o COBJS-$(CONFIG_SATA_SIL3114) += sata_sil3114.o diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c new file mode 100644 index 0000000..8ac84ea --- /dev/null +++ b/drivers/block/mvsata_ide.c @@ -0,0 +1,140 @@ +/* + * Copyright (C) 2010 Albert ARIBAUD albert.aribaud@free.fr + * + * Written-by: Albert ARIBAUD albert.aribaud@free.fr + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> + +#if defined(CONFIG_ORION5X) +#include <asm/arch/orion5x.h> +#elif defined(CONFIG_KIRKWOOD) +#include <asm/arch/kirkwood.h> +#endif + +/* SATA port registers */ +struct mvsata_port_registers { + u32 reserved1[192]; + /* offset 0x300 : ATA Interface registers */ + u32 sstatus; + u32 serror; + u32 scontrol; + u32 ltmode; + u32 phymode3; + u32 phymode4; + u32 reserved2[5]; + u32 phymode1; + u32 phymode2; + u32 bist_cr; + u32 bist_dw1; + u32 bist_dw2; + u32 serrorintrmask; +}; + +/* + * Sanity checks: + * - to compile at all, we need CONFIG_SYS_ATA_BASE_ADDR. + * - for ide_preinit to make sense, we need at least one of + * CONFIG_SYS_ATA_IDE0_OFFSET or CONFIG_SYS_ATA_IDE0_OFFSET; + * - for inde_preinit to be called, we need CONFIG_IDE_PREINIT. + * Fail with an explanation message if these conditions are not met. + * This is particularly important for CONFIG_IDE_PREINIT, because + * its lack would not cause a build error. + */ + +#if !defined(CONFIG_SYS_ATA_BASE_ADDR) +#error CONFIG_SYS_ATA_BASE_ADDR must be defined +#elif !defined(CONFIG_SYS_ATA_IDE0_OFFSET) \ + && !defined(CONFIG_SYS_ATA_IDE1_OFFSET) +#error CONFIG_SYS_ATA_IDE0_OFFSET or CONFIG_SYS_ATA_IDE1_OFFSET \ + must be defined +#elif !defined(CONFIG_IDE_PREINIT) +#error CONFIG_IDE_PREINIT must be defined +#endif + +/* + * Masks and values for SControl DETection and Interface Power Management, + * and for SStatus DETection. + */ + +#define MVSATA_SCONTROL_DET_MASK 0x0000000F +#define MVSATA_SCONTROL_DET_NONE 0x00000000 +#define MVSATA_SCONTROL_DET_INIT 0x00000001 +#define MVSATA_SCONTROL_IPM_MASK 0x00000F00 +#define MVSATA_SCONTROL_IPM_NO_LP_ALLOWED 0x00000300 +#define MVSATA_SCONTROL_MASK \ + (MVSATA_SCONTROL_DET_MASK|MVSATA_SCONTROL_IPM_MASK) +#define MVSATA_PORT_INIT \ + (MVSATA_SCONTROL_DET_INIT|MVSATA_SCONTROL_IPM_NO_LP_ALLOWED) +#define MVSATA_PORT_USE \ + (MVSATA_SCONTROL_DET_NONE|MVSATA_SCONTROL_IPM_NO_LP_ALLOWED) +#define MVSATA_SSTATUS_DET_MASK 0x0000000F +#define MVSATA_SSTATUS_DET_DEVCOMM 0x00000003 + +/* + * Initialize one MVSATAHC port: set SControl's IPM to "always active" + * and DET to "reset", then wait for SStatus's DET to become "device and + * comm ok" (or time out after 50 us if no device), then set SControl's + * DET back to "no action". + */ + +static void mvsata_ide_initialize_port(struct mvsata_port_registers *port) +{ + u32 control; + u32 status; + u32 tout = 50; /* wait at most 50 us for SATA reset to complete */ + + control = readl(&port->scontrol); + control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_INIT; + writel(control, &port->scontrol); + while (--tout) { + status = readl(&port->sstatus) & MVSATA_SSTATUS_DET_MASK; + if (status == MVSATA_SSTATUS_DET_DEVCOMM) + break; + udelay(1); + } + control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_USE; + writel(control, &port->scontrol); +} + +/* + * ide_preinit() will be called by ide_init in cmd_ide.c and will + * reset the MVSTATHC ports needed by the board. + */ + +int ide_preinit(void) +{ + /* Enable ATA port 0 (could be SATA port 0 or 1) if declared */ +#if defined(CONFIG_SYS_ATA_IDE0_OFFSET) + mvsata_ide_initialize_port( + (struct mvsata_port_registers *) + (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_IDE0_OFFSET)); +#endif + /* Enable ATA port 1 (could be SATA port 0 or 1) if declared */ +#if defined(CONFIG_SYS_ATA_IDE1_OFFSET) + mvsata_ide_initialize_port( + (struct mvsata_port_registers *) + (CONFIG_SYS_ATA_BASE_ADDR + CONFIG_SYS_ATA_IDE1_OFFSET)); +#endif + /* return 0 as we always succeed */ + return 0; +}
Add MVSATAHC definitions to orion5x. Add support for orion5x in cmd_ide.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- arch/arm/include/asm/arch-orion5x/orion5x.h | 3 +++ common/cmd_ide.c | 5 +++++ 2 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-orion5x/orion5x.h b/arch/arm/include/asm/arch-orion5x/orion5x.h index d257b66..e3d3f76 100644 --- a/arch/arm/include/asm/arch-orion5x/orion5x.h +++ b/arch/arm/include/asm/arch-orion5x/orion5x.h @@ -55,6 +55,9 @@ #define ORION5X_USB20_PORT0_BASE (ORION5X_REGISTER(0x50000)) #define ORION5X_USB20_PORT1_BASE (ORION5X_REGISTER(0xA0000)) #define ORION5X_EGIGA_BASE (ORION5X_REGISTER(0x72000)) +#define ORION5X_SATA_BASE (ORION5X_REGISTER(0x80000)) +#define ORION5X_SATA_PORT0_OFFSET 0x2000 +#define ORION5X_SATA_PORT1_OFFSET 0x4000
/* Orion5x GbE controller has a single port */ #define MAX_MVGBE_DEVS 1 diff --git a/common/cmd_ide.c b/common/cmd_ide.c index d423e53..b23db3f 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -25,6 +25,7 @@ /* * IDE support */ + #include <common.h> #include <config.h> #include <watchdog.h> @@ -45,6 +46,10 @@ #include <mpc5xxx.h> #endif
+#ifdef CONFIG_ORION5X +#include <asm/arch/orion5x.h> +#endif + #include <ide.h> #include <ata.h>
Add mvsata_ide and cmd_ide configuration in edminiv2 config
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- include/configs/edminiv2.h | 34 +++++++++++++++++++++++++++++++++- 1 files changed, 33 insertions(+), 1 deletions(-)
diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 055931c..57dd165 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -60,7 +60,7 @@
#define ORION5X_MPP0_7 0x00000003 #define ORION5X_MPP8_15 0x55550000 -#define ORION5X_MPP16_23 0x00000000 +#define ORION5X_MPP16_23 0x00005555
/* * Board-specific values for Orion5x GPIO low level init: @@ -131,6 +131,7 @@ * Commands configuration - using default command set for now */ #include <config_cmd_default.h> +#define CONFIG_CMD_IDE
/* * Network @@ -150,6 +151,37 @@ #endif
/* + * IDE + */ +#ifdef CONFIG_CMD_IDE +#define __io +#define CONFIG_IDE_PREINIT +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +/* ED Mini V has an IDE-compatible SATA connector for port 1 */ +#define CONFIG_MVSATA_IDE +#define CONFIG_MVSATA_IDE_USE_PORT1 +/* Needs byte-swapping for ATA data register */ +#define CONFIG_IDE_SWAP_IO +/* Data, registers and alternate blocks are at the same offset */ +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0100) +#define CONFIG_SYS_ATA_REG_OFFSET (0x0100) +#define CONFIG_SYS_ATA_ALT_OFFSET (0x0100) +/* Each 8-bit ATA register is aligned to a 4-bytes address */ +#define CONFIG_SYS_ATA_STRIDE 4 +/* Controller supports 48-bits LBA addressing */ +#define CONFIG_LBA48 +/* A single bus, a single device */ +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 +/* ATA registers base is at SATA controller base */ +#define CONFIG_SYS_ATA_BASE_ADDR ORION5X_SATA_BASE +/* ATA bus 0 is orion5x port 1 on ED Mini V2 */ +#define CONFIG_SYS_ATA_IDE0_OFFSET ORION5X_SATA_PORT1_OFFSET +/* end of IDE defines */ +#endif /* CMD_IDE */ + +/* * Environment variables configurations */ #define CONFIG_ENV_IS_IN_FLASH 1
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Saturday, August 07, 2010 6:22 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V8 5/5] edminiv2: add mvsata_ide and cmd_ide support
Applied to u-boot-marvell.git master branch
Regards.. Prafulla . .
Signed-off-by: Albert Aribaudalbert.aribaud@free.fr
Hi Albert,
I'm trying to get IDE to work with my DNS323, which uses both SATA ports, but am being unsuccessful.
It seems that there may be something incorrectly merged, perhaps:
$ git grep CONFIG_MVSATA_IDE_USE_PORT include/configs/edminiv2.h:#define CONFIG_MVSATA_IDE_USE_PORT1 include/configs/openrd_base.h:#define CONFIG_MVSATA_IDE_USE_PORT1 $
i.e. CONFIG_MVSATA_IDE_USE_PORT1 is defined, but never used for anything.
Regards,
Rogan
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Saturday, August 07, 2010 6:22 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V8 4/5] cmd_ide: add support for orion5x
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Saturday, August 07, 2010 6:22 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V8 3/5] ide: add mvsata_ide driver
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Saturday, August 07, 2010 6:22 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V8 2/5] ide: reorder object files alphabetically
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Saturday, August 07, 2010 6:22 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V8 1/5] ide: add configuration CONFIG_IDE_SWAP_IO
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Saturday, August 07, 2010 6:22 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V8 0/5] Add disk support to orion5x and edminiv2
Patchset history:
Applied this patch series to u-boot-marvell.git master branch
Thanks Prafulla!
Amicalement,
Albert ARIBAUD
Albert Aribaud
Prafulla Wadaskar
Rogan Dawes
