[U-Boot] [PATCH 00/10] 85xx/85xx pci cleanup
This patch series adds the ability to support 64-bit PCI addresses as well as refactors the fsl_pci_init code and cleans up its users.
Finally it adds some help functions that the board code calls to set dma-ranges in device trees.
If the particular maintainers could ack the patches that would be great (Andy, Jon, Jerry).
- k
PCI bus is inherently 64-bit. While not all system require access to the full 64-bit PCI address range some do. This allows those systems to enable the full PCI address width via CONFIG_SYS_PCI_64BIT.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- drivers/pci/pci.c | 37 ++++++++++++++------ drivers/pci/pci_auto.c | 88 ++++++++++++++++++++++++++++------------------- include/pci.h | 40 +++++++++++++--------- 3 files changed, 102 insertions(+), 63 deletions(-)
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 41780db..e2b05d8 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -218,12 +218,12 @@ pci_dev_t pci_find_device(unsigned int vendor, unsigned int device, int index) * */
-unsigned long pci_hose_phys_to_bus (struct pci_controller *hose, +pci_addr_t pci_hose_phys_to_bus (struct pci_controller *hose, phys_addr_t phys_addr, unsigned long flags) { struct pci_region *res; - unsigned long bus_addr; + pci_addr_t bus_addr; int i;
if (!hose) { @@ -252,7 +252,7 @@ Done: }
phys_addr_t pci_hose_bus_to_phys(struct pci_controller* hose, - unsigned long bus_addr, + pci_addr_t bus_addr, unsigned long flags) { struct pci_region *res; @@ -288,15 +288,17 @@ Done: int pci_hose_config_device(struct pci_controller *hose, pci_dev_t dev, unsigned long io, - unsigned long mem, + pci_addr_t mem, unsigned long command) { - unsigned int bar_response, bar_size, bar_value, old_command; + unsigned int bar_response, old_command; + pci_addr_t bar_value; + pci_size_t bar_size; unsigned char pin; int bar, found_mem64;
- debug ("PCI Config: I/O=0x%lx, Memory=0x%lx, Command=0x%lx\n", - io, mem, command); + debug ("PCI Config: I/O=0x%lx, Memory=0x%llx, Command=0x%lx\n", + io, (u64)mem, command);
pci_hose_write_config_dword (hose, dev, PCI_COMMAND, 0);
@@ -319,10 +321,19 @@ int pci_hose_config_device(struct pci_controller *hose, io = io + bar_size; } else { if ((bar_response & PCI_BASE_ADDRESS_MEM_TYPE_MASK) == - PCI_BASE_ADDRESS_MEM_TYPE_64) - found_mem64 = 1; + PCI_BASE_ADDRESS_MEM_TYPE_64) { + u32 bar_response_upper; + u64 bar64; + pci_hose_write_config_dword(hose, dev, bar+4, 0xffffffff); + pci_hose_read_config_dword(hose, dev, bar+4, &bar_response_upper);
- bar_size = ~(bar_response & PCI_BASE_ADDRESS_MEM_MASK) + 1; + bar64 = ((u64)bar_response_upper << 32) | bar_response; + + bar_size = ~(bar64 & PCI_BASE_ADDRESS_MEM_MASK) + 1; + found_mem64 = 1; + } else { + bar_size = (u32)(~(bar_response & PCI_BASE_ADDRESS_MEM_MASK) + 1); + }
/* round up region base address to multiple of size */ mem = ((mem - 1) | (bar_size - 1)) + 1; @@ -332,11 +343,15 @@ int pci_hose_config_device(struct pci_controller *hose, }
/* Write it out and update our limit */ - pci_hose_write_config_dword (hose, dev, bar, bar_value); + pci_hose_write_config_dword (hose, dev, bar, (u32)bar_value);
if (found_mem64) { bar += 4; +#ifdef CONFIG_SYS_PCI_64BIT + pci_hose_write_config_dword(hose, dev, bar, (u32)(bar_value>>32)); +#else pci_hose_write_config_dword (hose, dev, bar, 0x00000000); +#endif } }
diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index 3844359..c20b981 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -45,14 +45,14 @@ void pciauto_region_init(struct pci_region* res) res->bus_lower = res->bus_start ? res->bus_start : 0x1000; }
-void pciauto_region_align(struct pci_region *res, unsigned long size) +void pciauto_region_align(struct pci_region *res, pci_size_t size) { res->bus_lower = ((res->bus_lower - 1) | (size - 1)) + 1; }
-int pciauto_region_allocate(struct pci_region* res, unsigned int size, unsigned int *bar) +int pciauto_region_allocate(struct pci_region* res, pci_size_t size, pci_addr_t *bar) { - unsigned long addr; + pci_addr_t addr;
if (!res) { DEBUGF("No resource"); @@ -68,13 +68,13 @@ int pciauto_region_allocate(struct pci_region* res, unsigned int size, unsigned
res->bus_lower = addr + size;
- DEBUGF("address=0x%lx bus_lower=%x", addr, res->bus_lower); + DEBUGF("address=0x%llx bus_lower=0x%llx", (u64)addr, (u64)res->bus_lower);
*bar = addr; return 0;
error: - *bar = 0xffffffff; + *bar = (pci_addr_t)-1; return -1; }
@@ -88,7 +88,9 @@ void pciauto_setup_device(struct pci_controller *hose, struct pci_region *prefetch, struct pci_region *io) { - unsigned int bar_value, bar_response, bar_size; + unsigned int bar_response; + pci_addr_t bar_value; + pci_size_t bar_size; unsigned int cmdstat = 0; struct pci_region *bar_res; int bar, bar_nr = 0; @@ -114,33 +116,46 @@ void pciauto_setup_device(struct pci_controller *hose, & 0xffff) + 1; bar_res = io;
- DEBUGF("PCI Autoconfig: BAR %d, I/O, size=0x%x, ", bar_nr, bar_size); + DEBUGF("PCI Autoconfig: BAR %d, I/O, size=0x%llx, ", bar_nr, (u64)bar_size); } else { if ( (bar_response & PCI_BASE_ADDRESS_MEM_TYPE_MASK) == - PCI_BASE_ADDRESS_MEM_TYPE_64) - found_mem64 = 1; + PCI_BASE_ADDRESS_MEM_TYPE_64) { + u32 bar_response_upper; + u64 bar64; + pci_hose_write_config_dword(hose, dev, bar+4, 0xffffffff); + pci_hose_read_config_dword(hose, dev, bar+4, &bar_response_upper); + + bar64 = ((u64)bar_response_upper << 32) | bar_response;
- bar_size = ~(bar_response & PCI_BASE_ADDRESS_MEM_MASK) + 1; + bar_size = ~(bar64 & PCI_BASE_ADDRESS_MEM_MASK) + 1; + found_mem64 = 1; + } else { + bar_size = (u32)(~(bar_response & PCI_BASE_ADDRESS_MEM_MASK) + 1); + } if (prefetch && (bar_response & PCI_BASE_ADDRESS_MEM_PREFETCH)) bar_res = prefetch; else bar_res = mem;
- DEBUGF("PCI Autoconfig: BAR %d, Mem, size=0x%x, ", bar_nr, bar_size); + DEBUGF("PCI Autoconfig: BAR %d, Mem, size=0x%llx, ", bar_nr, (u64)bar_size); }
if (pciauto_region_allocate(bar_res, bar_size, &bar_value) == 0) { /* Write it out and update our limit */ - pci_hose_write_config_dword(hose, dev, bar, bar_value); + pci_hose_write_config_dword(hose, dev, bar, (u32)bar_value);
- /* - * If we are a 64-bit decoder then increment to the - * upper 32 bits of the bar and force it to locate - * in the lower 4GB of memory. - */ if (found_mem64) { bar += 4; +#ifdef CONFIG_SYS_PCI_64BIT + pci_hose_write_config_dword(hose, dev, bar, (u32)(bar_value>>32)); +#else + /* + * If we are a 64-bit decoder then increment to the + * upper 32 bits of the bar and force it to locate + * in the lower 4GB of memory. + */ pci_hose_write_config_dword(hose, dev, bar, 0x00000000); +#endif }
cmdstat |= (bar_response & PCI_BASE_ADDRESS_SPACE) ? @@ -289,35 +304,36 @@ void pciauto_config_init(struct pci_controller *hose) if (hose->pci_mem) { pciauto_region_init(hose->pci_mem);
- DEBUGF("PCI Autoconfig: Bus Memory region: [%lx-%lx],\n" - "\t\tPhysical Memory [%x-%x]\n", - hose->pci_mem->bus_start, - hose->pci_mem->bus_start + hose->pci_mem->size - 1, - hose->pci_mem->phys_start, - hose->pci_mem->phys_start + hose->pci_mem->size - 1); + DEBUGF("PCI Autoconfig: Bus Memory region: [0x%llx-0x%llx],\n" + "\t\tPhysical Memory [%llx-%llxx]\n", + (u64)hose->pci_mem->bus_start, + (u64)(hose->pci_mem->bus_start + hose->pci_mem->size - 1), + (u64)hose->pci_mem->phys_start, + (u64)(hose->pci_mem->phys_start + hose->pci_mem->size - 1)); }
if (hose->pci_prefetch) { pciauto_region_init(hose->pci_prefetch);
- DEBUGF("PCI Autoconfig: Bus Prefetchable Mem: [%lx-%lx],\n" - "\t\tPhysical Memory [%x-%x]\n", - hose->pci_prefetch->bus_start, - hose->pci_prefetch->bus_start + hose->pci_prefetch->size - 1, - hose->pci_prefetch->phys_start, - hose->pci_prefetch->phys_start + - hose->pci_prefetch->size - 1); + DEBUGF("PCI Autoconfig: Bus Prefetchable Mem: [0x%llx-0x%llx],\n" + "\t\tPhysical Memory [%llx-%llx]\n", + (u64)hose->pci_prefetch->bus_start, + (u64)(hose->pci_prefetch->bus_start + + hose->pci_prefetch->size - 1), + (u64)hose->pci_prefetch->phys_start, + (u64)(hose->pci_prefetch->phys_start + + hose->pci_prefetch->size - 1)); }
if (hose->pci_io) { pciauto_region_init(hose->pci_io);
- DEBUGF("PCI Autoconfig: Bus I/O region: [%lx-%lx],\n" - "\t\tPhysical Memory: [%x-%x]\n", - hose->pci_io->bus_start, - hose->pci_io->bus_start + hose->pci_io->size - 1, - hose->pci_io->phys_start, - hose->pci_io->phys_start + hose->pci_io->size - 1); + DEBUGF("PCI Autoconfig: Bus I/O region: [0x%llx-0x%llx],\n" + "\t\tPhysical Memory: [%llx-%llx]\n", + (u64)hose->pci_io->bus_start, + (u64)(hose->pci_io->bus_start + hose->pci_io->size - 1), + (u64)hose->pci_io->phys_start, + (u64)(hose->pci_io->phys_start + hose->pci_io->size - 1));
} } diff --git a/include/pci.h b/include/pci.h index 1c8e216..eebe8a8 100644 --- a/include/pci.h +++ b/include/pci.h @@ -101,8 +101,8 @@ #define PCI_BASE_ADDRESS_MEM_TYPE_1M 0x02 /* Below 1M [obsolete] */ #define PCI_BASE_ADDRESS_MEM_TYPE_64 0x04 /* 64 bit address */ #define PCI_BASE_ADDRESS_MEM_PREFETCH 0x08 /* prefetchable? */ -#define PCI_BASE_ADDRESS_MEM_MASK (~0x0fUL) -#define PCI_BASE_ADDRESS_IO_MASK (~0x03UL) +#define PCI_BASE_ADDRESS_MEM_MASK (~0x0fULL) +#define PCI_BASE_ADDRESS_IO_MASK (~0x03ULL) /* bit 1 is reserved if address_space = 1 */
/* Header type 0 (normal devices) */ @@ -111,7 +111,7 @@ #define PCI_SUBSYSTEM_ID 0x2e #define PCI_ROM_ADDRESS 0x30 /* Bits 31..11 are address, 10..1 reserved */ #define PCI_ROM_ADDRESS_ENABLE 0x01 -#define PCI_ROM_ADDRESS_MASK (~0x7ffUL) +#define PCI_ROM_ADDRESS_MASK (~0x7ffULL)
#define PCI_CAPABILITY_LIST 0x34 /* Offset of first capability list entry */
@@ -312,13 +312,21 @@
#include <pci_ids.h>
+#ifdef CONFIG_SYS_PCI_64BIT +typedef u64 pci_addr_t; +typedef u64 pci_size_t; +#else +typedef u32 pci_addr_t; +typedef u32 pci_size_t; +#endif + struct pci_region { - unsigned long bus_start; /* Start on the bus */ - phys_addr_t phys_start; /* Start in physical address space */ - unsigned long size; /* Size */ - unsigned long flags; /* Resource flags */ + pci_addr_t bus_start; /* Start on the bus */ + phys_addr_t phys_start; /* Start in physical address space */ + pci_size_t size; /* Size */ + unsigned long flags; /* Resource flags */
- unsigned long bus_lower; + pci_addr_t bus_lower; };
#define PCI_REGION_MEM 0x00000000 /* PCI memory space */ @@ -330,9 +338,9 @@ struct pci_region { #define PCI_REGION_RO 0x00000200 /* Read-only memory */
extern __inline__ void pci_set_region(struct pci_region *reg, - unsigned long bus_start, + pci_addr_t bus_start, phys_addr_t phys_start, - unsigned long size, + pci_size_t size, unsigned long flags) { reg->bus_start = bus_start; reg->phys_start = phys_start; @@ -433,9 +441,9 @@ extern __inline__ void pci_set_ops(struct pci_controller *hose, extern void pci_setup_indirect(struct pci_controller* hose, u32 cfg_addr, u32 cfg_data);
extern phys_addr_t pci_hose_bus_to_phys(struct pci_controller* hose, - unsigned long addr, unsigned long flags); -extern unsigned long pci_hose_phys_to_bus(struct pci_controller* hose, - phys_addr_t addr, unsigned long flags); + pci_addr_t addr, unsigned long flags); +extern pci_addr_t pci_hose_phys_to_bus(struct pci_controller* hose, + phys_addr_t addr, unsigned long flags);
#define pci_phys_to_bus(dev, addr, flags) \ pci_hose_phys_to_bus(pci_bus_to_hose(PCI_BUS(dev)), (addr), (flags)) @@ -483,8 +491,8 @@ extern int pci_hose_scan(struct pci_controller *hose); extern int pci_hose_scan_bus(struct pci_controller *hose, int bus);
extern void pciauto_region_init(struct pci_region* res); -extern void pciauto_region_align(struct pci_region *res, unsigned long size); -extern int pciauto_region_allocate(struct pci_region* res, unsigned int size, unsigned int *bar); +extern void pciauto_region_align(struct pci_region *res, pci_size_t size); +extern int pciauto_region_allocate(struct pci_region* res, pci_size_t size, pci_addr_t *bar); extern void pciauto_setup_device(struct pci_controller *hose, pci_dev_t dev, int bars_num, struct pci_region *mem, @@ -500,7 +508,7 @@ extern pci_dev_t pci_find_class(int wanted_class, int wanted_sub_code, extern int pci_hose_config_device(struct pci_controller *hose, pci_dev_t dev, unsigned long io, - unsigned long mem, + pci_addr_t mem, unsigned long command);
#ifdef CONFIG_MPC824X
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/MPC8536DS.h | 1 + include/configs/MPC8540ADS.h | 1 + include/configs/MPC8541CDS.h | 1 + include/configs/MPC8544DS.h | 1 + include/configs/MPC8548CDS.h | 1 + include/configs/MPC8555CDS.h | 1 + include/configs/MPC8560ADS.h | 1 + include/configs/MPC8568MDS.h | 1 + include/configs/MPC8572DS.h | 1 + 9 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 38be10d..d990f11 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -41,6 +41,7 @@ #define CONFIG_PCIE3 1 /* PCIE controler 3 (ULI bridge) */ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */
#define CONFIG_FSL_LAW 1 /* Use common FSL init code */
diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 5a14969..79a52d9 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -46,6 +46,7 @@ #endif
#define CONFIG_PCI +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_FSL_LAW 1 /* Use common FSL init code */ diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index eede26a..7ada8a2 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -38,6 +38,7 @@ #define CONFIG_MPC8541CDS 1 /* MPC8541CDS board specific */
diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 0987448..c47374a 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -41,6 +41,7 @@ #define CONFIG_PCIE3 1 /* PCIE controler 3 (ULI bridge) */ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */
diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 892c52e..b67de56 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -43,6 +43,7 @@ #undef CONFIG_PCI2 #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */
#define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 41870f1..f9419cc 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -38,6 +38,7 @@ #define CONFIG_MPC8555CDS 1 /* MPC8555CDS board specific */
#define CONFIG_PCI +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_FSL_LAW 1 /* Use common FSL init code */ diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 0d3a500..f67d489 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -43,6 +43,7 @@ #define CONFIG_MPC8560 1
#define CONFIG_PCI +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #undef CONFIG_ETHER_ON_FCC /* cpm FCC ethernet support */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index ba2f152..c4d4374 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -38,6 +38,7 @@ #define CONFIG_PCIE1 1 /* PCIE controller */ #define CONFIG_FSL_PCI_INIT 1 /* use common fsl pci init code */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ #define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_QE /* Enable QE */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 5688589..06696f0 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -42,6 +42,7 @@ #define CONFIG_PCIE3 1 /* PCIE controler 3 (ULI bridge) */ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/MPC8610HPCD.h | 1 + include/configs/MPC8641HPCN.h | 1 + 2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 678e1e1..0492274 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -41,6 +41,7 @@ #define CONFIG_PCIE1 1 /* PCIe 1 connected to ULI bridge */ #define CONFIG_PCIE2 1 /* PCIe 2 connected to slot */ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ #define CONFIG_FSL_LAW 1 /* Use common FSL init code */
#define CONFIG_ENV_OVERWRITE diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index e5710c0..ceb2c69 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -49,6 +49,7 @@ #define CONFIG_PCI1 1 /* PCIE controler 1 (ULI bridge) */ #define CONFIG_PCI2 1 /* PCIE controler 2 (slot) */ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ #define CONFIG_FSL_LAW 1 /* Use common FSL law init code */
Add helper functions to return top level #size-cell and #address-cell info
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/fdt_support.h | 18 ++++++++++++++++++ 1 files changed, 18 insertions(+), 0 deletions(-)
diff --git a/include/fdt_support.h b/include/fdt_support.h index ceaadc2..aa9d86b 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -28,6 +28,24 @@
#include <fdt.h>
+static inline int fdt_addrcell(void *blob) { + const u32 *addrcell = fdt_getprop(blob, 0, "#address-cells", NULL); + + if (addrcell) + return *addrcell; + else + return 1; +} + +static inline int fdt_sizecell(void *blob) { + const u32 *sizecell = fdt_getprop(blob, 0, "#size-cells", NULL); + + if (sizecell) + return *sizecell; + else + return 1; +} + int fdt_chosen(void *fdt, int force); int fdt_initrd(void *fdt, ulong initrd_start, ulong initrd_end, int force); void do_fixup_by_path(void *fdt, const char *path, const char *prop,
Added fdt_pci_dma_ranges() that parses the pci_region info from the struct pci_controller and populates the dma-ranges based on it.
The max # of windws/dma-ranges we support is 3 since on embedded PowerPC based systems this is the max number of windows.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- common/fdt_support.c | 69 +++++++++++++++++++++++++++++++++++++++++++++++++ include/fdt_support.h | 5 +++ 2 files changed, 74 insertions(+), 0 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 8ceeb0f..9f1cc3d 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -593,3 +593,72 @@ int fdt_resize(void *blob)
return actualsize; } + +#ifdef CONFIG_PCI +#define CONFIG_SYS_PCI_NR_INBOUND_WIN 3 + +#define FDT_PCI_PREFETCH (0x40000000) +#define FDT_PCI_MEM32 (0x02000000) +#define FDT_PCI_IO (0x01000000) +#define FDT_PCI_MEM64 (0x03000000) + +int fdt_pci_dma_ranges(void *blob, int phb_off, struct pci_controller *hose) { + + int addrcell, sizecell, len, r; + u32 *dma_range; + /* sized based on pci addr cells, size-cells, & address-cells */ + u32 dma_ranges[(3 + 2 + 2) * CONFIG_SYS_PCI_NR_INBOUND_WIN]; + + addrcell = fdt_addrcell(blob); + sizecell = fdt_sizecell(blob); + + dma_range = &dma_ranges[0]; + for (r = 0; r < hose->region_count; r++) { + u64 bus_start, phys_start, size; + + /* skip if !PCI_REGION_MEMORY */ + if (!(hose->regions[r].flags & PCI_REGION_MEMORY)) + continue; + + bus_start = (u64)hose->regions[r].bus_start; + phys_start = (u64)hose->regions[r].phys_start; + size = (u64)hose->regions[r].size; + + dma_range[0] = 0; + if (size > 0x100000000ull) + dma_range[0] |= FDT_PCI_MEM64; + else + dma_range[0] |= FDT_PCI_MEM32; + if (hose->regions[r].flags & PCI_REGION_PREFETCH) + dma_range[0] |= FDT_PCI_PREFETCH; +#ifdef CONFIG_SYS_PCI_64BIT + dma_range[1] = bus_start >> 32; +#else + dma_range[1] = 0; +#endif + dma_range[2] = bus_start & 0xffffffff; + + if (addrcell == 2) { + dma_range[3] = phys_start >> 32; + dma_range[4] = phys_start & 0xffffffff; + } else { + dma_range[3] = phys_start & 0xffffffff; + } + + if (sizecell == 2) { + dma_range[3 + addrcell + 0] = size >> 32; + dma_range[3 + addrcell + 1] = size & 0xffffffff; + } else { + dma_range[3 + addrcell + 0] = size & 0xffffffff; + } + + dma_range += (3 + addrcell + sizecell); + } + + len = dma_range - &dma_ranges[0]; + if (len) + fdt_setprop(blob, phb_off, "dma-ranges", &dma_ranges[0], len*4); + + return 0; +} +#endif diff --git a/include/fdt_support.h b/include/fdt_support.h index aa9d86b..5c932de 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -81,6 +81,11 @@ void fdt_fixup_crypto_node(void *blob, int sec_rev); static inline void fdt_fixup_crypto_node(void *blob, int sec_rev) {} #endif
+#ifdef CONFIG_PCI +#include <pci.h> +int fdt_pci_dma_ranges(void *blob, int phb_off, struct pci_controller *hose); +#endif + #ifdef CONFIG_OF_BOARD_SETUP void ft_board_setup(void *blob, bd_t *bd); void ft_cpu_setup(void *blob, bd_t *bd);
* PCI Inbound window was setup incorrectly. The PCI address and system address were swapped. The PCI address should be setting piwar/piwbear and the system address should be setting pitar.
* Removed masking of addresses to allow for system address to support system address & PCI address >32-bits
* Set PIWBEAR & POTEAR to allow for full 64-bit PCI addresses
* Respect the PCI_REGION_PREFETCH for inbound windows
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- drivers/pci/fsl_pci_init.c | 38 ++++++++++++++++++++++++-------------- 1 files changed, 24 insertions(+), 14 deletions(-)
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 38a16e5..f41c8aa 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -39,10 +39,9 @@ void pciauto_prescan_setup_bridge(struct pci_controller *hose, pci_dev_t dev, int sub_bus); void pciauto_postscan_setup_bridge(struct pci_controller *hose, pci_dev_t dev, int sub_bus); - void pciauto_config_init(struct pci_controller *hose); -void -fsl_pci_init(struct pci_controller *hose) + +void fsl_pci_init(struct pci_controller *hose) { u16 temp16; u32 temp32; @@ -65,25 +64,36 @@ fsl_pci_init(struct pci_controller *hose) #endif
for (r=0; r<hose->region_count; r++) { + u32 sz = (__ilog2_u64((u64)hose->regions[r].size) - 1); if (hose->regions[r].flags & PCI_REGION_MEMORY) { /* inbound */ - pi->pitar = (hose->regions[r].bus_start >> 12) & 0x000fffff; - pi->piwbar = (hose->regions[r].phys_start >> 12) & 0x000fffff; + u32 flag = PIWAR_EN | PIWAR_LOCAL | \ + PIWAR_READ_SNOOP | PIWAR_WRITE_SNOOP; + pi->pitar = (hose->regions[r].phys_start >> 12); + pi->piwbar = (hose->regions[r].bus_start >> 12); +#ifdef CONFIG_SYS_PCI_64BIT + pi->piwbear = (hose->regions[r].bus_start >> 44); +#else pi->piwbear = 0; - pi->piwar = PIWAR_EN | PIWAR_PF | PIWAR_LOCAL | - PIWAR_READ_SNOOP | PIWAR_WRITE_SNOOP | - (__ilog2(hose->regions[r].size) - 1); +#endif + if (hose->regions[r].flags & PCI_REGION_PREFETCH) + flag |= PIWAR_PF; + pi->piwar = flag | sz; pi++; inbound = hose->regions[r].size > 0; } else { /* Outbound */ - po->powbar = (hose->regions[r].phys_start >> 12) & 0x000fffff; - po->potar = (hose->regions[r].bus_start >> 12) & 0x000fffff; + po->powbar = (hose->regions[r].phys_start >> 12); + po->potar = (hose->regions[r].bus_start >> 12); +#ifdef CONFIG_SYS_PCI_64BIT + po->potear = (hose->regions[r].bus_start >> 44); +#else po->potear = 0; +#endif if (hose->regions[r].flags & PCI_REGION_IO) - po->powar = POWAR_EN | POWAR_IO_READ | POWAR_IO_WRITE | - (__ilog2(hose->regions[r].size) - 1); + po->powar = POWAR_EN | sz | \ + POWAR_IO_READ | POWAR_IO_WRITE; else - po->powar = POWAR_EN | POWAR_MEM_READ | POWAR_MEM_WRITE | - (__ilog2(hose->regions[r].size) - 1); + po->powar = POWAR_EN | sz | \ + POWAR_MEM_READ | POWAR_MEM_WRITE; po++; } }
Add a common setup function that determines the pci_region(s) based on how much memory we have in the system.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- drivers/pci/fsl_pci_init.c | 81 ++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 81 insertions(+), 0 deletions(-)
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index f41c8aa..564459c 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -18,6 +18,8 @@
#include <common.h>
+DECLARE_GLOBAL_DATA_PTR; + /* * PCI/PCIE Controller initialization for mpc85xx/mpc86xx soc's * @@ -41,6 +43,85 @@ void pciauto_postscan_setup_bridge(struct pci_controller *hose, pci_dev_t dev, int sub_bus); void pciauto_config_init(struct pci_controller *hose);
+#ifndef CONFIG_SYS_PCI_MEMORY_BUS +#define CONFIG_SYS_PCI_MEMORY_BUS 0 +#endif + +#ifndef CONFIG_SYS_PCI_MEMORY_PHYS +#define CONFIG_SYS_PCI_MEMORY_PHYS 0 +#endif + +#if defined(CONFIG_SYS_PCI_64BIT) && !defined(CONFIG_SYS_PCI64_MEMORY_BUS) +#define CONFIG_SYS_PCI64_MEMORY_BUS (64ull*1024*1024*1024) +#endif + +int fsl_pci_setup_inbound_windows(struct pci_region *r) +{ + struct pci_region *rgn_base = r; + u64 sz = min((u64)gd->ram_size, 1ull << 32); + + phys_addr_t phys_start = CONFIG_SYS_PCI_MEMORY_PHYS; + pci_addr_t bus_start = CONFIG_SYS_PCI_MEMORY_BUS; + pci_size_t pci_sz = 1ull << __ilog2_u64(sz); + + debug ("R0 bus_start: %llx phys_start: %llx size: %llx\n", + (u64)bus_start, (u64)phys_start, (u64)pci_sz); + pci_set_region(r++, bus_start, phys_start, pci_sz, + PCI_REGION_MEM | PCI_REGION_MEMORY | \ + PCI_REGION_PREFETCH); + + sz -= pci_sz; + bus_start += pci_sz; + phys_start += pci_sz; + + pci_sz = 1ull << __ilog2_u64(sz); + if (sz) { + debug ("R1 bus_start: %llx phys_start: %llx size: %llx\n", + (u64)bus_start, (u64)phys_start, (u64)pci_sz); + pci_set_region(r++, bus_start, phys_start, pci_sz, + PCI_REGION_MEM | PCI_REGION_MEMORY | \ + PCI_REGION_PREFETCH); + sz -= pci_sz; + bus_start += pci_sz; + phys_start += pci_sz; + } + +#if defined(CONFIG_PHYS_64BIT) && defined(CONFIG_SYS_PCI_64BIT) + pci_sz = 1ull << __ilog2_u64(gd->ram_size); + /* round up to the next largest power of two */ + if (gd->ram_size > pci_sz) + sz = 1ull << (__ilog2_u64(gd->ram_size) + 1); + debug ("R64 bus_start: %llx phys_start: %llx size: %llx\n", + (u64)CONFIG_SYS_PCI_MEMORY_BUS, + (u64)CONFIG_SYS_PCI_MEMORY_PHYS, + (u64)pci_sz); + pci_set_region(r++, + CONFIG_SYS_PCI_MEMORY_BUS, + CONFIG_SYS_PCI_MEMORY_PHYS, + pci_sz, + PCI_REGION_MEM | PCI_REGION_MEMORY | \ + PCI_REGION_PREFETCH); +#else + pci_sz = 1ull << __ilog2_u64(sz); + if (sz) { + debug ("R2 bus_start: %llx phys_start: %llx size: %llx\n", + (u64)bus_start, (u64)phys_start, (u64)pci_sz); + pci_set_region(r++, bus_start, phys_start, pci_sz, + PCI_REGION_MEM | PCI_REGION_MEMORY | \ + PCI_REGION_PREFETCH); + sz -= pci_sz; + bus_start += pci_sz; + phys_start += pci_sz; + } +#endif + + if (sz && (((u64)gd->ram_size) < (1ull << 32))) + printf("Was not able to map all of memory via " + "inbound windows -- %lld remaining\n", sz); + + return r - rgn_base; +} + void fsl_pci_init(struct pci_controller *hose) { u16 temp16;
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- drivers/pci/fsl_pci_init.c | 20 ++++++++++++++++++++ 1 files changed, 20 insertions(+), 0 deletions(-)
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 564459c..b5d868f 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -299,3 +299,23 @@ void fsl_pci_init(struct pci_controller *hose) pci_hose_write_config_word(hose, dev, PCI_SEC_STATUS, 0xffff); } } + +#ifdef CONFIG_OF_BOARD_SETUP +#include <libfdt.h> +#include <fdt_support.h> + +void ft_fsl_pci_setup(void *blob, const char *pci_alias, + struct pci_controller *hose) +{ + int off = fdt_path_offset(blob, pci_alias); + + if (off >= 0) { + u32 bus_range[2]; + + bus_range[0] = 0; + bus_range[1] = hose->last_busno - hose->first_busno; + fdt_setprop(blob, off, "bus-range", &bus_range[0], 2*4); + fdt_pci_dma_ranges(blob, off, hose); + } +} +#endif
Converted ATUM8548, MPC8536DS, MPC8544DS, MPC8548CDS, MPC8568MDS, MPC8572DS, TQM85xx, and SBC8548 to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup().
With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/atum8548/atum8548.c | 77 +++++++--------------- board/freescale/mpc8536ds/mpc8536ds.c | 110 ++++++++++-------------------- board/freescale/mpc8544ds/mpc8544ds.c | 109 ++++++++++-------------------- board/freescale/mpc8548cds/mpc8548cds.c | 57 +++++----------- board/freescale/mpc8568mds/mpc8568mds.c | 56 +++++---------- board/freescale/mpc8572ds/mpc8572ds.c | 72 +++++++------------- board/sbc8548/sbc8548.c | 66 ++++++------------- board/tqc/tqm85xx/tqm85xx.c | 58 ++++++----------- include/configs/ATUM8548.h | 5 -- include/configs/MPC8536DS.h | 5 -- include/configs/MPC8544DS.h | 5 -- include/configs/MPC8548CDS.h | 5 -- include/configs/MPC8568MDS.h | 5 -- include/configs/MPC8572DS.h | 5 -- include/configs/TQM85xx.h | 5 -- include/configs/sbc8548.h | 5 -- 16 files changed, 200 insertions(+), 445 deletions(-)
diff --git a/board/atum8548/atum8548.c b/board/atum8548/atum8548.c index 2ef19ce..7b7a968 100644 --- a/board/atum8548/atum8548.c +++ b/board/atum8548/atum8548.c @@ -182,6 +182,9 @@ static struct pci_controller pcie1_hose;
int first_free_busno=0;
+extern int fsl_pci_setup_inbound_windows(struct pci_region *r); +extern void fsl_pci_init(struct pci_controller *hose); + void pci_init_board(void) { @@ -211,10 +214,10 @@ pci_init_board(void) #ifdef CONFIG_PCIE1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent == 5); int pcie_configured = io_sel & 6; + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("\n PCIE1 connected to slot as %s (base address %x)", @@ -227,36 +230,31 @@ pci_init_board(void) printf ("\n");
/* inbound */ - pci_set_region(hose->regions + 0, - CONFIG_SYS_PCI_MEMORY_BUS, - CONFIG_SYS_PCI_MEMORY_PHYS, - CONFIG_SYS_PCI_MEMORY_SIZE, - PCI_REGION_MEM | PCI_REGION_MEMORY); + r += fsl_pci_setup_inbound_windows(r);
/* outbound memory */ - pci_set_region(hose->regions + 1, + pci_set_region(r++, CONFIG_SYS_PCIE1_MEM_BASE, CONFIG_SYS_PCIE1_MEM_PHYS, CONFIG_SYS_PCIE1_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ - pci_set_region(hose->regions + 2, + pci_set_region(r++, CONFIG_SYS_PCIE1_IO_BASE, CONFIG_SYS_PCIE1_IO_PHYS, CONFIG_SYS_PCIE1_IO_SIZE, PCI_REGION_IO);
- hose->region_count = 3; #ifdef CONFIG_SYS_PCIE1_MEM_BASE2 /* outbound memory */ - pci_set_region(hose->regions + 3, + pci_set_region(r++, CONFIG_SYS_PCIE1_MEM_BASE2, CONFIG_SYS_PCIE1_MEM_PHYS2, CONFIG_SYS_PCIE1_MEM_SIZE2, PCI_REGION_MEM); - hose->region_count++; #endif + hose->region_count = r - hose->regions; hose->first_busno=first_free_busno;
pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -279,8 +277,8 @@ pci_init_board(void) #ifdef CONFIG_PCI1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci1_hose; + struct pci_region *r = hose->regions;
uint pci_agent = (host_agent == 6); uint pci_speed = 33333000; /*get_clock_freq (); PCI PSPEED in [4:5] */ @@ -300,26 +298,22 @@ pci_init_board(void) );
/* outbound memory */ - pci_set_region(hose->regions + 1, + pci_set_region(r++, CONFIG_SYS_PCI1_MEM_BASE, CONFIG_SYS_PCI1_MEM_PHYS, CONFIG_SYS_PCI1_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ - pci_set_region(hose->regions + 2, + pci_set_region(r++, CONFIG_SYS_PCI1_IO_BASE, CONFIG_SYS_PCI1_IO_PHYS, CONFIG_SYS_PCI1_IO_SIZE, PCI_REGION_IO); - hose->region_count = 3; + hose->region_count = r - hose->regions; hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data);
@@ -340,26 +334,23 @@ pci_init_board(void) volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI2_ADDR; extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci2_hose; + struct pci_region *r = hose->regions;
if (!(devdisr & MPC85xx_DEVDISR_PCI2)) { - pci_set_region(hose->regions + 0, - CONFIG_SYS_PCI_MEMORY_BUS, - CONFIG_SYS_PCI_MEMORY_PHYS, - CONFIG_SYS_PCI_MEMORY_SIZE, - PCI_REGION_MEM | PCI_REGION_MEMORY); + r += fsl_pci_setup_inbound_windows(r);
- pci_set_region(hose->regions + 1, + pci_set_region(r++, CONFIG_SYS_PCI2_MEM_BASE, CONFIG_SYS_PCI2_MEM_PHYS, CONFIG_SYS_PCI2_MEM_SIZE, PCI_REGION_MEM);
- pci_set_region(hose->regions + 2, + pci_set_region(r++, CONFIG_SYS_PCI2_IO_BASE, CONFIG_SYS_PCI2_IO_PHYS, CONFIG_SYS_PCI2_IO_SIZE, PCI_REGION_IO); - hose->region_count = 3; + hose->region_count = r - hose->regions; hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data);
@@ -385,39 +376,21 @@ int last_stage_init(void) }
#if defined(CONFIG_OF_BOARD_SETUP) +extern void ft_fsl_pci_setup(void *blob, const char *pci_alias, + struct pci_controller *hose);
-void -ft_board_setup(void *blob, bd_t *bd) +void ft_board_setup(void *blob, bd_t *bd) { - int node, tmp[2]; - const char *path; - ft_cpu_setup(blob, bd);
- node = fdt_path_offset(blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { #ifdef CONFIG_PCI1 - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci0", &pci1_hose); #endif #ifdef CONFIG_PCI2 - path = fdt_getprop(blob, node, "pci1", NULL); - if (path) { - tmp[1] = pci2_hose.last_busno - pci2_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci1", &pci2_hose); #endif #ifdef CONFIG_PCIE1 - path = fdt_getprop(blob, node, "pci2", NULL); - if (path) { - tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci2", &pcie1_hose); #endif - } } #endif diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index f357826..2978b7d 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -155,6 +155,9 @@ static struct pci_controller pcie2_hose; static struct pci_controller pcie3_hose; #endif
+extern int fsl_pci_setup_inbound_windows(struct pci_region *r); +extern void fsl_pci_init(struct pci_controller *hose); + int first_free_busno=0;
void @@ -181,10 +184,10 @@ pci_init_board(void) #ifdef CONFIG_PCIE3 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE3_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie3_hose; int pcie_ep = (host_agent == 1); int pcie_configured = (io_sel == 7); + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("\n PCIE3 connected to Slot3 as %s (base address %x)", @@ -197,27 +200,23 @@ pci_init_board(void) printf ("\n");
/* outbound memory */ - pci_set_region(hose->regions + 1, + pci_set_region(r++, CONFIG_SYS_PCIE3_MEM_BASE, CONFIG_SYS_PCIE3_MEM_PHYS, CONFIG_SYS_PCIE3_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ - pci_set_region(hose->regions + 2, + pci_set_region(r++, CONFIG_SYS_PCIE3_IO_BASE, CONFIG_SYS_PCIE3_IO_PHYS, CONFIG_SYS_PCIE3_IO_SIZE, PCI_REGION_IO);
hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -239,11 +238,11 @@ pci_init_board(void) #ifdef CONFIG_PCIE1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent == 5); int pcie_configured = (io_sel == 2 || io_sel == 3 || io_sel == 5 || io_sel == 7); + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("\n PCIE1 connected to Slot1 as %s (base address %x)", @@ -256,36 +255,31 @@ pci_init_board(void) printf ("\n");
pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -308,10 +302,10 @@ pci_init_board(void) #ifdef CONFIG_PCIE2 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE2_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie2_hose; int pcie_ep = (host_agent == 3); int pcie_configured = (io_sel == 5 || io_sel == 7); + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("\n PCIE2 connected to Slot 2 as %s (base address %x)", @@ -324,36 +318,31 @@ pci_init_board(void) printf ("\n");
/* outbound memory */ - pci_set_region(hose->regions + 1, + pci_set_region(r++, CONFIG_SYS_PCIE2_MEM_BASE, CONFIG_SYS_PCIE2_MEM_PHYS, CONFIG_SYS_PCIE2_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ - pci_set_region(hose->regions + 2, + pci_set_region(r++, CONFIG_SYS_PCIE2_IO_BASE, CONFIG_SYS_PCIE2_IO_PHYS, CONFIG_SYS_PCIE2_IO_SIZE, PCI_REGION_IO);
- hose->region_count = 3; #ifdef CONFIG_SYS_PCIE2_MEM_BASE2 /* outbound memory */ - pci_set_region(hose->regions + 3, + pci_set_region(r++, CONFIG_SYS_PCIE2_MEM_BASE2, CONFIG_SYS_PCIE2_MEM_PHYS2, CONFIG_SYS_PCIE2_MEM_SIZE2, PCI_REGION_MEM); - hose->region_count++; #endif + hose->region_count = r - hose->regions; hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data);
@@ -375,8 +364,8 @@ pci_init_board(void) #ifdef CONFIG_PCI1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci1_hose; + struct pci_region *r = hose->regions;
uint pci_agent = (host_agent == 6); uint pci_speed = 66666000; /*get_clock_freq (); PCI PSPEED in [4:5] */ @@ -397,35 +386,31 @@ pci_init_board(void) );
/* outbound io */ - pci_set_region(hose->regions + 2, + pci_set_region(r++, CONFIG_SYS_PCI1_IO_BASE, CONFIG_SYS_PCI1_IO_PHYS, CONFIG_SYS_PCI1_IO_SIZE, PCI_REGION_IO); - hose->region_count = 3; + #ifdef CONFIG_SYS_PCI1_MEM_BASE2 /* outbound memory */ - pci_set_region(hose->regions + 3, + pci_set_region(r++, CONFIG_SYS_PCI1_MEM_BASE2, CONFIG_SYS_PCI1_MEM_PHYS2, CONFIG_SYS_PCI1_MEM_SIZE2, PCI_REGION_MEM); - hose->region_count++; #endif + hose->region_count = r - hose->regions; hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data);
@@ -660,45 +645,24 @@ int board_eth_init(bd_t *bis) }
#if defined(CONFIG_OF_BOARD_SETUP) -void -ft_board_setup(void *blob, bd_t *bd) -{ - int node, tmp[2]; - const char *path; +extern void ft_fsl_pci_setup(void *blob, const char *pci_alias, + struct pci_controller *hose);
+void ft_board_setup(void *blob, bd_t *bd) +{ ft_cpu_setup(blob, bd);
- node = fdt_path_offset(blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { #ifdef CONFIG_PCI1 - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci0", &pci1_hose); #endif #ifdef CONFIG_PCIE2 - path = fdt_getprop(blob, node, "pci1", NULL); - if (path) { - tmp[1] = pcie2_hose.last_busno - pcie2_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci1", &pcie2_hose); #endif -#ifdef CONFIG_PCIE1 - path = fdt_getprop(blob, node, "pci2", NULL); - if (path) { - tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } +#ifdef CONFIG_PCIE2 + ft_fsl_pci_setup(blob, "pci2", &pcie1_hose); #endif -#ifdef CONFIG_PCIE3 - path = fdt_getprop(blob, node, "pci3", NULL); - if (path) { - tmp[1] = pcie3_hose.last_busno - pcie3_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } +#ifdef CONFIG_PCIE1 + ft_fsl_pci_setup(blob, "pci3", &pcie3_hose); #endif - } } #endif diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index 826180c..600d606 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -103,6 +103,9 @@ static struct pci_controller pcie2_hose; static struct pci_controller pcie3_hose; #endif
void @@ -126,10 +129,10 @@ pci_init_board(void) #ifdef CONFIG_PCIE3 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE3_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie3_hose; int pcie_ep = (host_agent == 1); int pcie_configured = io_sel >= 1; + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("\n PCIE3 connected to ULI as %s (base address %x)", @@ -142,36 +145,31 @@ pci_init_board(void) printf ("\n");
- hose->region_count = 3; #ifdef CONFIG_SYS_PCIE3_MEM_BASE2 /* outbound memory */ - pci_set_region(hose->regions + 3, + pci_set_region(r++, CONFIG_SYS_PCIE3_MEM_BASE2, CONFIG_SYS_PCIE3_MEM_PHYS2, CONFIG_SYS_PCIE3_MEM_SIZE2, PCI_REGION_MEM); - hose->region_count++; #endif + hose->region_count = r - hose->regions; hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data);
@@ -198,10 +196,10 @@ pci_init_board(void) #ifdef CONFIG_PCIE1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent == 5); int pcie_configured = io_sel & 6; + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("\n PCIE1 connected to Slot2 as %s (base address %x)", @@ -214,36 +212,31 @@ pci_init_board(void) printf ("\n");
pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -266,10 +259,10 @@ pci_init_board(void) #ifdef CONFIG_PCIE2 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE2_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie2_hose; int pcie_ep = (host_agent == 3); int pcie_configured = io_sel & 4; + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("\n PCIE2 connected to Slot 1 as %s (base address %x)", @@ -282,36 +275,31 @@ pci_init_board(void) printf ("\n");
@@ -333,8 +321,8 @@ pci_init_board(void) #ifdef CONFIG_PCI1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci1_hose; + struct pci_region *r = hose->regions;
uint pci_agent = (host_agent == 6); uint pci_speed = 66666000; /*get_clock_freq (); PCI PSPEED in [4:5] */ @@ -355,35 +343,31 @@ pci_init_board(void) );
/* outbound io */ - pci_set_region(hose->regions + 2, + pci_set_region(r++, CONFIG_SYS_PCI1_IO_BASE, CONFIG_SYS_PCI1_IO_PHYS, CONFIG_SYS_PCI1_IO_SIZE, PCI_REGION_IO); - hose->region_count = 3; + #ifdef CONFIG_SYS_PCIE3_MEM_BASE2 /* outbound memory */ - pci_set_region(hose->regions + 3, + pci_set_region(r++, CONFIG_SYS_PCIE3_MEM_BASE2, CONFIG_SYS_PCIE3_MEM_PHYS2, CONFIG_SYS_PCIE3_MEM_SIZE2, PCI_REGION_MEM); - hose->region_count++; #endif + hose->region_count = r - hose->regions; hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data);
@@ -503,46 +487,25 @@ int board_eth_init(bd_t *bis) }
- node = fdt_path_offset(blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { + #ifdef CONFIG_PCI1 - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci0", &pci1_hose); #endif #ifdef CONFIG_PCIE2 - path = fdt_getprop(blob, node, "pci1", NULL); - if (path) { - tmp[1] = pcie2_hose.last_busno - pcie2_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci1", &pcie1_hose); #endif #ifdef CONFIG_PCIE1 - path = fdt_getprop(blob, node, "pci2", NULL); - if (path) { - tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci2", &pcie3_hose); #endif #ifdef CONFIG_PCIE3 - path = fdt_getprop(blob, node, "pci3", NULL); - if (path) { - tmp[1] = pcie3_hose.last_busno - pcie3_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci3", &pcie2_hose); #endif - } } #endif diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index 875628d..6eb62ea 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -285,6 +285,9 @@ static struct pci_controller pci2_hose; static struct pci_controller pcie1_hose; #endif /* CONFIG_PCIE1 */
void @@ -298,9 +301,9 @@ pci_init_board(void) #ifdef CONFIG_PCI1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci1_hose; struct pci_config_table *table; + struct pci_region *r = hose->regions;
uint pci_32 = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; /* PORDEVSR[15] */ uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ @@ -322,27 +325,22 @@ pci_init_board(void)
/* inbound */ - pci_set_region(hose->regions + 0, - CONFIG_SYS_PCI_MEMORY_BUS, - CONFIG_SYS_PCI_MEMORY_PHYS, - CONFIG_SYS_PCI_MEMORY_SIZE, - PCI_REGION_MEM | PCI_REGION_MEMORY); - + r += fsl_pci_setup_inbound_windows(r);
/* relocate config table pointers */ hose->config_table = \ @@ -393,9 +391,9 @@ pci_init_board(void) #ifdef CONFIG_PCIE1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent == 0) || (host_agent == 2 ) || (host_agent == 3); + struct pci_region *r = hose->regions;
@@ -411,27 +409,23 @@ pci_init_board(void) printf ("\n");
hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -484,29 +478,16 @@ int last_stage_init(void)
#if defined(CONFIG_OF_BOARD_SETUP) -void -ft_pci_setup(void *blob, bd_t *bd) -{ - int node, tmp[2]; - const char *path; +extern void ft_fsl_pci_setup(void *blob, const char *pci_alias, + struct pci_controller *hose);
- node = fdt_path_offset(blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { +void ft_pci_setup(void *blob, bd_t *bd) +{ #ifdef CONFIG_PCI1 - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci0", &pci1_hose); #endif #ifdef CONFIG_PCIE1 - path = fdt_getprop(blob, node, "pci1", NULL); - if (path) { - tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci1", &pcie1_hose); #endif - } } #endif diff --git a/board/freescale/mpc8568mds/mpc8568mds.c b/board/freescale/mpc8568mds/mpc8568mds.c index eab1900..28e3892 100644 --- a/board/freescale/mpc8568mds/mpc8568mds.c +++ b/board/freescale/mpc8568mds/mpc8568mds.c @@ -323,6 +323,9 @@ static struct pci_controller pci1_hose = { static struct pci_controller pcie1_hose; #endif /* CONFIG_PCIE1 */
+extern int fsl_pci_setup_inbound_windows(struct pci_region *r); +extern void fsl_pci_init(struct pci_controller *hose); + int first_free_busno = 0;
/* @@ -380,8 +383,8 @@ pci_init_board(void) pib_init();
uint pci_32 = 1; /* PORDEVSR[15] */ uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ @@ -402,27 +405,23 @@ pci_init_board(void) );
hose->first_busno = first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -441,9 +440,9 @@ pci_init_board(void) #ifdef CONFIG_PCIE1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent == 0) || (host_agent == 2 ) || (host_agent == 3); + struct pci_region *r = hose->regions;
@@ -459,27 +458,23 @@ pci_init_board(void) printf ("\n");
hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -500,31 +495,18 @@ pci_init_board(void) #endif /* CONFIG_PCI */
- node = fdt_path_offset(blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { #ifdef CONFIG_PCI1 - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci0", &pci1_hose); #endif #ifdef CONFIG_PCIE1 - path = fdt_getprop(blob, node, "pci1", NULL); - if (path) { - tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci1", &pcie1_hose); #endif - } } #endif diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index b2402dc..d1528a7 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -147,6 +147,9 @@ static struct pci_controller pcie2_hose; static struct pci_controller pcie3_hose; #endif
+extern int fsl_pci_setup_inbound_windows(struct pci_region *r); +extern void fsl_pci_init(struct pci_controller *hose); + int first_free_busno=0; #ifdef CONFIG_PCI void pci_init_board(void) @@ -172,11 +175,11 @@ void pci_init_board(void) #ifdef CONFIG_PCIE3 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE3_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie3_hose; int pcie_ep = (host_agent == 0) || (host_agent == 3) || (host_agent == 5) || (host_agent == 6); int pcie_configured = io_sel >= 1; + struct pci_region *r = hose->regions; u32 temp32;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ @@ -190,27 +193,23 @@ void pci_init_board(void) printf ("\n");
@@ -244,11 +243,11 @@ void pci_init_board(void) #ifdef CONFIG_PCIE2 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE2_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie2_hose; int pcie_ep = (host_agent == 2) || (host_agent == 4) || (host_agent == 6) || (host_agent == 0); int pcie_configured = io_sel & 4; + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("\n PCIE2 connected to Slot 1 as %s (base address %x)", @@ -261,27 +260,23 @@ void pci_init_board(void) printf ("\n");
@@ -301,11 +296,11 @@ void pci_init_board(void) #ifdef CONFIG_PCIE1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent <= 1) || (host_agent == 4) || (host_agent == 5); int pcie_configured = io_sel & 6; + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("\n PCIE1 connected to Slot 2 as %s (base address %x)", @@ -318,27 +313,23 @@ void pci_init_board(void) printf ("\n");
pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -568,10 +559,11 @@ int board_eth_init(bd_t *bis) #endif
#if defined(CONFIG_OF_BOARD_SETUP) +extern void ft_fsl_pci_setup(void *blob, const char *pci_alias, + struct pci_controller *hose); + void ft_board_setup(void *blob, bd_t *bd) { - int node, tmp[2]; - const char *path; ulong base, size;
ft_cpu_setup(blob, bd); @@ -581,31 +573,15 @@ void ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_memory(blob, (u64)base, (u64)size);
- node = fdt_path_offset(blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { #ifdef CONFIG_PCIE3 - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - tmp[1] = pcie3_hose.last_busno - pcie3_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci0", &pcie3_hose); #endif #ifdef CONFIG_PCIE2 - path = fdt_getprop(blob, node, "pci1", NULL); - if (path) { - tmp[1] = pcie2_hose.last_busno - pcie2_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci1", &pcie2_hose); #endif #ifdef CONFIG_PCIE1 - path = fdt_getprop(blob, node, "pci2", NULL); - if (path) { - tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci2", &pcie1_hose); #endif - } } #endif
diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index 21f82f2..e27c92d 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -364,6 +364,9 @@ static struct pci_controller pcie1_hose;
+extern int fsl_pci_setup_inbound_windows(struct pci_region *r); +extern void fsl_pci_init(struct pci_controller *hose); + void pci_init_board(void) { @@ -372,9 +375,9 @@ pci_init_board(void) #ifdef CONFIG_PCI1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci1_hose; struct pci_config_table *table; + struct pci_region *r = hose->regions;
uint pci_32 = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; /* PORDEVSR[15] */ uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ @@ -396,27 +399,22 @@ pci_init_board(void)
/* relocate config table pointers */ hose->config_table = \ @@ -467,9 +465,9 @@ pci_init_board(void) #ifdef CONFIG_PCIE1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent == 0) || (host_agent == 2 ) || (host_agent == 3); + struct pci_region *r = hose->regions;
@@ -485,27 +483,27 @@ pci_init_board(void) printf ("\n");
/* inbound */ - pci_set_region(hose->regions + 0, + pci_set_region(r++, CONFIG_SYS_PCI_MEMORY_BUS, CONFIG_SYS_PCI_MEMORY_PHYS, CONFIG_SYS_PCI_MEMORY_SIZE, PCI_REGION_MEM | PCI_REGION_MEMORY);
hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -531,41 +529,17 @@ int last_stage_init(void) }
#if defined(CONFIG_OF_BOARD_SETUP) -void -ft_pci_setup(void *blob, bd_t *bd) -{ - int node, tmp[2]; +extern void ft_fsl_pci_setup(void *blob, const char *pci_alias, + struct pci_controller *hose);
- node = fdt_path_offset(blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); #ifdef CONFIG_PCI1 - const char *path; - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci0", &pci1_hose); #endif #ifdef CONFIG_PCIE1 - const char *path; - path = fdt_getprop(blob, node, "pci1", NULL); - if (path) { - tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } -#endif - } -} -#endif - -#if defined(CONFIG_OF_BOARD_SETUP) -void -ft_board_setup(void *blob, bd_t *bd) -{ - ft_cpu_setup(blob, bd); -#ifdef CONFIG_PCI - ft_pci_setup(blob, bd); + ft_fsl_pci_setup(blob, "pci1", &pcie1_hose); #endif } #endif diff --git a/board/tqc/tqm85xx/tqm85xx.c b/board/tqc/tqm85xx/tqm85xx.c index 1f309bb..97d49ea 100644 --- a/board/tqc/tqm85xx/tqm85xx.c +++ b/board/tqc/tqm85xx/tqm85xx.c @@ -538,6 +538,9 @@ void local_bus_init (void) */ static int first_free_busno;
+extern int fsl_pci_setup_inbound_windows(struct pci_region *r); +extern void fsl_pci_init(struct pci_controller *hose); + #if defined(CONFIG_PCI) || defined(CONFIG_PCI1) static struct pci_controller pci1_hose; #endif /* CONFIG_PCI || CONFIG_PCI1 */ @@ -552,8 +555,8 @@ static inline void init_pci1(void) #if defined(CONFIG_PCI) || defined(CONFIG_PCI1) uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *)CONFIG_SYS_PCI1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci1_hose; + struct pci_region *r = hose->regions;
/* PORDEVSR[15] */ uint pci_32 = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; @@ -578,28 +581,23 @@ static inline void init_pci1(void)
/* inbound */ - pci_set_region (hose->regions + 0, - CONFIG_SYS_PCI_MEMORY_BUS, - CONFIG_SYS_PCI_MEMORY_PHYS, - CONFIG_SYS_PCI_MEMORY_SIZE, - PCI_REGION_MEM | PCI_REGION_MEMORY); - + r += fsl_pci_setup_inbound_windows(r);
/* outbound memory */ - pci_set_region (hose->regions + 1, + pci_set_region (r++, CONFIG_SYS_PCI1_MEM_BASE, CONFIG_SYS_PCI1_MEM_PHYS, CONFIG_SYS_PCI1_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ - pci_set_region (hose->regions + 2, + pci_set_region (r++, CONFIG_SYS_PCI1_IO_BASE, CONFIG_SYS_PCI1_IO_PHYS, CONFIG_SYS_PCI1_IO_SIZE, PCI_REGION_IO);
hose->first_busno = first_free_busno; pci_setup_indirect (hose, (int)&pci->cfg_addr, @@ -641,10 +639,10 @@ static inline void init_pcie1(void) uint io_sel = (gur->pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *)CONFIG_SYS_PCIE1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent == 0) || (host_agent == 2 ) || (host_agent == 3); + struct pci_region *r = hose->regions;
@@ -660,27 +658,23 @@ static inline void init_pcie1(void) puts ("\n");
/* inbound */ - pci_set_region (hose->regions + 0, - CONFIG_SYS_PCI_MEMORY_BUS, - CONFIG_SYS_PCI_MEMORY_PHYS, - CONFIG_SYS_PCI_MEMORY_SIZE, - PCI_REGION_MEM | PCI_REGION_MEMORY); + r += fsl_pci_setup_inbound_windows(r);
/* outbound memory */ - pci_set_region (hose->regions + 1, + pci_set_region (r++, CONFIG_SYS_PCIE1_MEM_BASE, CONFIG_SYS_PCIE1_MEM_PHYS, CONFIG_SYS_PCIE1_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ - pci_set_region (hose->regions + 2, + pci_set_region (r++, CONFIG_SYS_PCIE1_IO_BASE, CONFIG_SYS_PCIE1_IO_PHYS, CONFIG_SYS_PCIE1_IO_SIZE, PCI_REGION_IO);
hose->first_busno = first_free_busno; pci_setup_indirect(hose, (int)&pci->cfg_addr, @@ -707,31 +701,19 @@ void pci_init_board (void) }
#ifdef CONFIG_OF_BOARD_SETUP +extern void ft_fsl_pci_setup(void *blob, const char *pci_alias, + struct pci_controller *hose); + void ft_board_setup (void *blob, bd_t *bd) { - int node, tmp[2]; - const char *path; - ft_cpu_setup (blob, bd);
- node = fdt_path_offset (blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { #if defined(CONFIG_PCI) || defined(CONFIG_PCI1) - path = fdt_getprop (blob, node, "pci0", NULL); - if (path) { - tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; - do_fixup_by_path (blob, path, "bus-range", &tmp, 8, 1); - } -#endif /* CONFIG_PCI || CONFIG_PCI1 */ + ft_fsl_pci_setup(blob, "pci0", &pci1_hose); +#endif #ifdef CONFIG_PCIE1 - path = fdt_getprop (blob, node, "pci1", NULL); - if (path) { - tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - do_fixup_by_path (blob, path, "bus-range", &tmp, 8, 1); - } -#endif /* CONFIG_PCIE1 */ - } + ft_fsl_pci_setup(blob, "pci1", &pcie1_hose); +#endif } #endif /* CONFIG_OF_BOARD_SETUP */
diff --git a/include/configs/ATUM8548.h b/include/configs/ATUM8548.h index 2450adb..1b74526 100644 --- a/include/configs/ATUM8548.h +++ b/include/configs/ATUM8548.h @@ -287,11 +287,6 @@
#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */
-/* PCI view of System Memory */ -#define CONFIG_SYS_PCI_MEMORY_BUS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_PHYS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_SIZE 0x80000000 - #endif /* CONFIG_PCI */
#if defined(CONFIG_TSEC_ENET) diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index d990f11..bdecfa0 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -315,11 +315,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); * Memory space is mapped 1-1, but I/O space must start from 0. */
-/* PCI view of System Memory */ -#define CONFIG_SYS_PCI_MEMORY_BUS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_PHYS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_SIZE 0x80000000 - #define CONFIG_SYS_PCI1_MEM_BASE 0x80000000 #define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE #define CONFIG_SYS_PCI1_MEM_SIZE 0x10000000 /* 256M */ diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index c47374a..cdbbea6 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -276,11 +276,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_PCI1_IO_PHYS 0xe1000000 #define CONFIG_SYS_PCI1_IO_SIZE 0x00010000 /* 64k */
-/* PCI view of System Memory */ -#define CONFIG_SYS_PCI_MEMORY_BUS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_PHYS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_SIZE 0x80000000 - /* controller 2, Slot 1, tgtid 1, Base address 9000 */ #define CONFIG_SYS_PCIE2_MEM_BASE 0x80000000 #define CONFIG_SYS_PCIE2_MEM_PHYS CONFIG_SYS_PCIE2_MEM_BASE diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index b67de56..083afba 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -420,11 +420,6 @@ extern unsigned long get_clock_freq(void);
diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index c4d4374..ab3e6d6 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -389,11 +389,6 @@ extern unsigned long get_clock_freq(void); #undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1057 /* Motorola */
#ifndef CONFIG_NET_MULTI diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 06696f0..fbb8970 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -336,11 +336,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); * Memory space is mapped 1-1, but I/O space must start from 0. */
-/* PCI view of System Memory */ -#define CONFIG_SYS_PCI_MEMORY_BUS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_PHYS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_SIZE 0x80000000 - /* controller 3, direct to uli, tgtid 3, Base address 8000 */ #define CONFIG_SYS_PCIE3_MEM_BASE 0x80000000 #define CONFIG_SYS_PCIE3_MEM_PHYS CONFIG_SYS_PCIE3_MEM_BASE diff --git a/include/configs/TQM85xx.h b/include/configs/TQM85xx.h index b05f43d..2d4048a 100644 --- a/include/configs/TQM85xx.h +++ b/include/configs/TQM85xx.h @@ -403,11 +403,6 @@ #define CONFIG_SYS_PCI1_IO_PHYS CONFIG_SYS_PCI1_IO_BASE #define CONFIG_SYS_PCI1_IO_SIZE 0x1000000 /* 16M */
-/* PCI view of System Memory */ -#define CONFIG_SYS_PCI_MEMORY_BUS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_PHYS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_SIZE 0x80000000 - #ifdef CONFIG_PCIE1 /* * General PCI express diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 54f3e66..aefd30a 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -387,11 +387,6 @@
Converted MPC8610HCPD, MPC8641HPCN, and SBC8641D to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup().
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 78 +++++++++-------------------- board/freescale/mpc8641hpcn/mpc8641hpcn.c | 53 ++++++------------- board/sbc8641d/sbc8641d.c | 55 +++++++-------------- include/configs/MPC8610HPCD.h | 5 -- include/configs/MPC8641HPCN.h | 5 -- include/configs/sbc8641d.h | 5 -- 6 files changed, 59 insertions(+), 142 deletions(-)
diff --git a/board/freescale/mpc8610hpcd/mpc8610hpcd.c b/board/freescale/mpc8610hpcd/mpc8610hpcd.c index 5faeca1..dacd2a9 100644 --- a/board/freescale/mpc8610hpcd/mpc8610hpcd.c +++ b/board/freescale/mpc8610hpcd/mpc8610hpcd.c @@ -240,6 +240,9 @@ static struct pci_controller pcie2_hose;
+extern int fsl_pci_setup_inbound_windows(struct pci_region *r); +extern void fsl_pci_init(struct pci_controller *hose); + void pci_init_board(void) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; @@ -256,11 +259,11 @@ void pci_init_board(void) #ifdef CONFIG_PCIE1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie1_hose; int pcie_configured = (io_sel == 1) || (io_sel == 4); int pcie_ep = (host_agent == 0) || (host_agent == 2) || (host_agent == 5); + struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIE1)) { printf(" PCIe 1 connected to Uli as %s (base address %x)\n", @@ -270,27 +273,23 @@ void pci_init_board(void) pci->pme_msg_det = 0xffffffff;
hose->first_busno = first_free_busno; pci_setup_indirect(hose, (int)&pci->cfg_addr, @@ -313,8 +312,8 @@ void pci_init_board(void) #ifdef CONFIG_PCIE2 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE2_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pcie2_hose; + struct pci_region *r = hose->regions;
int pcie_configured = (io_sel == 0) || (io_sel == 4); int pcie_ep = (host_agent == 0) || (host_agent == 1) || @@ -329,27 +328,23 @@ void pci_init_board(void) pci->pme_msg_det = 0xffffffff;
hose->first_busno = first_free_busno; pci_setup_indirect(hose, (int)&pci->cfg_addr, @@ -371,9 +366,9 @@ void pci_init_board(void) #ifdef CONFIG_PCI1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci1_hose; int pci_agent = (host_agent >= 4) && (host_agent <= 6); + struct pci_region *r = hose->regions;
if ( !(devdisr & MPC86xx_DEVDISR_PCI1)) { printf(" PCI connected to PCI slots as %s" \ @@ -382,27 +377,23 @@ void pci_init_board(void) (uint)pci);
hose->first_busno = first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, @@ -422,12 +413,12 @@ void pci_init_board(void) }
#if defined(CONFIG_OF_BOARD_SETUP) +extern void ft_fsl_pci_setup(void *blob, const char *pci_alias, + struct pci_controller *hose); + void ft_board_setup(void *blob, bd_t *bd) { - int node, tmp[2]; - const char *path; - do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, "timebase-frequency", bd->bi_busfreq / 4, 1); do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, @@ -442,36 +433,15 @@ ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_memory(blob, bd->bi_memstart, bd->bi_memsize);
- - node = fdt_path_offset(blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { - #ifdef CONFIG_PCI1 - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } - + ft_fsl_pci_setup(blob, "pci0", &pci1_hose); #endif #ifdef CONFIG_PCIE1 - path = fdt_getprop(blob, node, "pci1", NULL); - if (path) { - tmp[1] = pcie1_hose.last_busno - - pcie1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci1", &pcie1_hose); #endif #ifdef CONFIG_PCIE2 - path = fdt_getprop(blob, node, "pci2", NULL); - if (path) { - tmp[1] = pcie2_hose.last_busno - - pcie2_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci2", &pcie2_hose); #endif - } } #endif
diff --git a/board/freescale/mpc8641hpcn/mpc8641hpcn.c b/board/freescale/mpc8641hpcn/mpc8641hpcn.c index fcaaacb..6b4d6ce 100644 --- a/board/freescale/mpc8641hpcn/mpc8641hpcn.c +++ b/board/freescale/mpc8641hpcn/mpc8641hpcn.c @@ -161,6 +161,8 @@ static struct pci_controller pci2_hose;
void pci_init_board(void) { @@ -173,8 +175,9 @@ void pci_init_board(void) #ifdef CONFIG_PCI1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci1_hose; + struct pci_region *r = hose->regions; + #ifdef DEBUG uint host1_agent = (gur->porbmsr & MPC8641_PORBMSR_HA) >> MPC8641_PORBMSR_HA_SHIFT; @@ -193,27 +196,23 @@ void pci_init_board(void) debug("\n");
hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -242,32 +241,27 @@ void pci_init_board(void) #ifdef CONFIG_PCI2 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI2_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci2_hose; - + struct pci_region *r = hose->regions;
/* outbound memory */ - pci_set_region(hose->regions + 1, + pci_set_region(r++, CONFIG_SYS_PCI2_MEM_BASE, CONFIG_SYS_PCI2_MEM_PHYS, CONFIG_SYS_PCI2_MEM_SIZE, PCI_REGION_MEM);
/* outbound io */ - pci_set_region(hose->regions + 2, + pci_set_region(r++, CONFIG_SYS_PCI2_IO_BASE, CONFIG_SYS_PCI2_IO_PHYS, CONFIG_SYS_PCI2_IO_SIZE, PCI_REGION_IO);
hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -286,33 +280,20 @@ void pci_init_board(void)
- node = fdt_path_offset(blob, "/aliases"); - tmp[0] = 0; - if (node >= 0) { #ifdef CONFIG_PCI1 - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci0", &pci1_hose); #endif #ifdef CONFIG_PCI2 - path = fdt_getprop(blob, node, "pci1", NULL); - if (path) { - tmp[1] = pci2_hose.last_busno - pci2_hose.first_busno; - do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); - } + ft_fsl_pci_setup(blob, "pci1", &pci2_hose); #endif - } } #endif
diff --git a/board/sbc8641d/sbc8641d.c b/board/sbc8641d/sbc8641d.c index 06d1d2a..191045a 100644 --- a/board/sbc8641d/sbc8641d.c +++ b/board/sbc8641d/sbc8641d.c @@ -220,6 +220,9 @@ static struct pci_controller pci2_hose;
+extern int fsl_pci_setup_inbound_windows(struct pci_region *r); +extern void fsl_pci_init(struct pci_controller *hose); + void pci_init_board(void) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; @@ -231,8 +234,8 @@ void pci_init_board(void) #ifdef CONFIG_PCI1 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci1_hose; + struct pci_region *r = hose->regions; #ifdef DEBUG uint host1_agent = (gur->porbmsr & MPC8641_PORBMSR_HA) >> MPC8641_PORBMSR_HA_SHIFT; @@ -251,27 +254,23 @@ void pci_init_board(void) debug("\n");
hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -293,32 +292,28 @@ void pci_init_board(void) #ifdef CONFIG_PCI2 { volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI2_ADDR; - extern void fsl_pci_init(struct pci_controller *hose); struct pci_controller *hose = &pci2_hose; + struct pci_region *r = hose->regions;
hose->first_busno=first_free_busno; pci_setup_indirect(hose, (int) &pci->cfg_addr, (int) &pci->cfg_data); @@ -337,33 +332,19 @@ void pci_init_board(void)
-void -ft_board_setup (void *blob, bd_t *bd) +void ft_board_setup (void *blob, bd_t *bd) { - int node, tmp[2]; - const char *path; - ft_cpu_setup(blob, bd);
diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 0492274..fe80e5d 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -279,11 +279,6 @@ #define CONFIG_SYS_PCI1_IO_PHYS 0xe1000000 #define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */
-/* PCI view of System Memory */ -#define CONFIG_SYS_PCI_MEMORY_BUS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_PHYS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_SIZE 0x80000000 - /* For RTL8139 */ #define KSEG1ADDR(x) ({u32 _x = le32_to_cpu(*(u32 *)(x)); (&_x); }) #define _IO_BASE 0x00000000 diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index ceb2c69..80c8bee 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -305,11 +305,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_PCI1_IO_PHYS 0xe2000000 #define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */
-/* PCI view of System Memory */ -#define CONFIG_SYS_PCI_MEMORY_BUS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_PHYS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_SIZE 0x80000000 - /* For RTL8139 */ #define KSEG1ADDR(x) ({u32 _x=le32_to_cpu(*(u32 *)(x)); (&_x);}) #define _IO_BASE 0x00000000 diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 14d1c88..09a9901 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -308,11 +308,6 @@ #define CONFIG_SYS_PCI1_IO_PHYS CONFIG_SYS_PCI1_IO_BASE #define CONFIG_SYS_PCI1_IO_SIZE 0x1000000 /* 16M */
-/* PCI view of System Memory */ -#define CONFIG_SYS_PCI_MEMORY_BUS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_PHYS 0x00000000 -#define CONFIG_SYS_PCI_MEMORY_SIZE 0x80000000 - #define CONFIG_SYS_PCI2_MEM_BASE 0xa0000000 #define CONFIG_SYS_PCI2_MEM_PHYS CONFIG_SYS_PCI2_MEM_BASE #define CONFIG_SYS_PCI2_MEM_SIZE 0x10000000 /* 256M */
ACK.
jdl
#include <fdt.h>
- const u32 *addrcell = fdt_getprop(blob, 0, "#address-cells", NULL);
- if (addrcell)
return *addrcell;
- else
return 1;
- const u32 *sizecell = fdt_getprop(blob, 0, "#size-cells", NULL);
- if (sizecell)
return *sizecell;
- else
return 1;
Hi Kumar,
What about collapsing the two above into a common function?
fdt_addrcell(blob); becomes fdt_get_prop_u32(blob, "/", "#address-cells", 1); and fdt_sizecell(blob); becomes fdt_get_prop_u32(blob, "/", "#size-cells", 1);
WARNING, UNTESTED CODE: /** * fdt_get_prop_u32: Find a node and return it's property or a default * * @fdt: ptr to device tree * @node: path of node * @prop: property name * @defalt: default value if the property isn't found * * Convenience function to find a node and return it's property or a * default value if it doesn't exist. */ u32 fdt_get_prop_u32(void *fdt, const char *node, const char *prop, const u32 default) { const u32 *addrcell = fdt_getprop(fdt, node, prop, NULL);
if (addrcell) return *addrcell; else return default; }
On Oct 23, 2008, at 6:55 AM, Jerry Van Baren wrote:
Kumar Gala wrote:
Add helper functions to return top level #size-cell and #address- cell info Signed-off-by: Kumar Gala galak@kernel.crashing.org
include/fdt_support.h | 18 ++++++++++++++++++ 1 files changed, 18 insertions(+), 0 deletions(-) diff --git a/include/fdt_support.h b/include/fdt_support.h index ceaadc2..aa9d86b 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -28,6 +28,24 @@ #include <fdt.h> +static inline int fdt_addrcell(void *blob) {
- if (addrcell)
return *addrcell;
- else
return 1;
- if (sizecell)
return *sizecell;
- else
return 1;
Hi Kumar,
- fdt_get_prop_u32: Find a node and return it's property or a default
- @fdt: ptr to device tree
- @node: path of node
- @prop: property name
- @defalt: default value if the property isn't found
- Convenience function to find a node and return it's property or a
- default value if it doesn't exist.
I'd prefer we call it fdt_getprop_u32_default(). If you are good with the name I'll change my patchset.
- k
Kumar Gala wrote:
Add helper functions to return top level #size-cell and #address-cell info Signed-off-by: Kumar Gala galak@kernel.crashing.org
- if (addrcell)
return *addrcell;
- else
return 1;
- if (sizecell)
return *sizecell;
- else
return 1;
Hi Kumar,
fdt_addrcell(blob);
- k
That was my second choice. I figured Dennis Richie would call me up and complain the name was too long. ;-)
I'm find with the change.
Acked-by: Gerald Van Baren vanbaren@cideas.com
Thanks, gvb
Hi Kumar,
default
- k
Thanks, gvb
sent two new patches for you to ack.
- k
Dear Kumar Gala,
In message 1224743208-11160-2-git-send-email-galak@kernel.crashing.org you wrote:
PCI bus is inherently 64-bit. While not all system require access to the full 64-bit PCI address range some do. This allows those systems to enable the full PCI address width via CONFIG_SYS_PCI_64BIT.
drivers/pci/pci.c | 37 ++++++++++++++------ drivers/pci/pci_auto.c | 88 ++++++++++++++++++++++++++++------------------- include/pci.h | 40 +++++++++++++--------- 3 files changed, 102 insertions(+), 63 deletions(-)
Acked-by: Wolfgang Denk wd@denx.de
Dear Kumar Gala,
In message 1224743208-11160-1-git-send-email-galak@kernel.crashing.org you wrote:
This patch series adds the ability to support 64-bit PCI addresses as well as refactors the fsl_pci_init code and cleans up its users.
Finally it adds some help functions that the board code calls to set dma-ranges in device trees.
If the particular maintainers could ack the patches that would be great (Andy, Jon, Jerry).
So who is supposed to apply the patches, then? Me?
On Oct 23, 2008, at 3:35 AM, Wolfgang Denk wrote:
Dear Kumar Gala,
In message <1224743208-11160-1-git-send-email-galak@kernel.crashing.org
you wrote: This patch series adds the ability to support 64-bit PCI addresses as well as refactors the fsl_pci_init code and cleans up its users.
yes :)
I practice Andy can apply them to u-boot-85xx if you ack the first patch and Jerry ack's the fdt patches.
- k
participants (5)
Andy Fleming
Jerry Van Baren
Jon Loeliger
Kumar Gala
