[U-Boot] [PATCH] arm: mvebu: enable sata support for clearfog
The a38x sata interfaces run in ahci mode and can be accessed via the scsi command.
Signed-off-by: Jon Nettleton jon@solid-run.com [baruch: rebase on current upstream] Signed-off-by: Baruch Siach baruch@tkos.co.il --- configs/clearfog_defconfig | 2 ++ include/configs/clearfog.h | 9 +++++++++ 2 files changed, 11 insertions(+)
diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 5e1733e11ba1..3972c31ef978 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_TIME=y CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y +CONFIG_SCSI_AHCI=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_MV=y @@ -44,6 +45,7 @@ CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_MVNETA=y CONFIG_PCI=y +CONFIG_SCSI=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index f57f9b21aba6..ed6f000db16b 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -62,6 +62,15 @@ #define CONFIG_PCI_SCAN_SHOW #endif
+/* SATA support */ +#ifdef CONFIG_SCSI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) +#endif + /* Keep device tree and initrd in lower memory so the kernel can access them */ #define RELOCATION_LIMITS_ENV_SETTINGS \ "fdt_high=0x10000000\0" \
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Baruch Siach
Stefan Roese
