[U-Boot] [PATCH v5 00/10] spi: Add Atmel QuadSPI driver
Backport the driver from linux v5.1-rc5 and adapt it for u-boot. Tested on sama5d2_xplained Rev B with mx25l25635e spi-nor flash, and on sama5d27_som1_ek with sst26vf064b spi-nor flash.
V5: drop struct platform_device *pdev; linux leftover, add 2 new blank lines
v4: Update Kconfig description
v3: fix following config warnings reported by travis: ./tools/genboardscfg.py WARNING: no status info for 'sama5d2_xplained_qspiflash' WARNING: no maintainers for 'sama5d2_xplained_qspiflash' WARNING: no status info for 'sama5d27_som1_ek_qspiflash' WARNING: no maintainers for 'sama5d27_som1_ek_qspiflash'
v2: update/add configs and update sama5d2_xplained dts
Cyrille Pitchen (2): ARM: dts: at91: sama5d2_xplained: fix QSPI0 node ARM: at91: sama5: add common environment for QSPI
Eugen Hristev (1): configs: sama5d2_xplained: add support QSPI flash boot
Tudor Ambarus (7): dt-bindings: spi: add bindings for Atmel QSPI driver spi: Add Atmel QuadSPI driver configs: sama5d2_xplained: enable qspi controller and flashes configs: sama5d27_som1_ek: enable qspi controller and flashes configs: sama5d2_xplained: add qspiflash_defconfig configs: sama5d27_som1_ek: add qspiflash_defconfig configs: sama5d27_som1_ek: qspi: use common memory layout
arch/arm/dts/at91-sama5d2_xplained.dts | 36 +- board/atmel/sama5d27_som1_ek/MAINTAINERS | 1 + board/atmel/sama5d2_xplained/MAINTAINERS | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 2 + configs/sama5d27_som1_ek_mmc_defconfig | 2 + configs/sama5d27_som1_ek_qspiflash_defconfig | 101 +++++ configs/sama5d2_xplained_emmc_defconfig | 5 + configs/sama5d2_xplained_mmc_defconfig | 5 + configs/sama5d2_xplained_qspiflash_defconfig | 101 +++++ configs/sama5d2_xplained_spiflash_defconfig | 5 + doc/device-tree-bindings/spi/atmel-quadspi.txt | 37 ++ drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/atmel-quadspi.c | 536 +++++++++++++++++++++++++ include/configs/at91-sama5_common.h | 8 + include/configs/sama5d27_som1_ek.h | 7 - include/configs/sama5d2_xplained.h | 11 + 17 files changed, 841 insertions(+), 26 deletions(-) create mode 100644 configs/sama5d27_som1_ek_qspiflash_defconfig create mode 100644 configs/sama5d2_xplained_qspiflash_defconfig create mode 100644 doc/device-tree-bindings/spi/atmel-quadspi.txt create mode 100644 drivers/spi/atmel-quadspi.c
Describe the DT bindings for the driver of the Atmel QSPI controller. Taken form linux v5.1-rc5.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v5: no change v4: no change v3: no change v2: no change
doc/device-tree-bindings/spi/atmel-quadspi.txt | 37 ++++++++++++++++++++++++++ 1 file changed, 37 insertions(+) create mode 100644 doc/device-tree-bindings/spi/atmel-quadspi.txt
diff --git a/doc/device-tree-bindings/spi/atmel-quadspi.txt b/doc/device-tree-bindings/spi/atmel-quadspi.txt new file mode 100644 index 000000000000..7c40ea694352 --- /dev/null +++ b/doc/device-tree-bindings/spi/atmel-quadspi.txt @@ -0,0 +1,37 @@ +* Atmel Quad Serial Peripheral Interface (QSPI) + +Required properties: +- compatible: Should be one of the following: + - "atmel,sama5d2-qspi" + - "microchip,sam9x60-qspi" +- reg: Should contain the locations and lengths of the base registers + and the mapped memory. +- reg-names: Should contain the resource reg names: + - qspi_base: configuration register address space + - qspi_mmap: memory mapped address space +- interrupts: Should contain the interrupt for the device. +- clocks: Should reference the peripheral clock and the QSPI system + clock if available. +- clock-names: Should contain "pclk" for the peripheral clock and "qspick" + for the system clock when available. +- #address-cells: Should be <1>. +- #size-cells: Should be <0>. + +Example: + +spi@f0020000 { + compatible = "atmel,sama5d2-qspi"; + reg = <0xf0020000 0x100>, <0xd0000000 0x8000000>; + reg-names = "qspi_base", "qspi_mmap"; + interrupts = <52 IRQ_TYPE_LEVEL_HIGH 7>; + clocks = <&pmc PMC_TYPE_PERIPHERAL 52>; + clock-names = "pclk"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi0_default>; + + m25p80@0 { + ... + }; +};
We are no particular about bindings, atleast I don't based on my experience since the driver bindings remain the same like Linux. So I would recommend this to keep drop from the series or may be pick it up if we have any conclusive evidence for the usage.
Backport the driver from linux v5.1-rc5 and adapt it for u-boot. Tested on sama5d2_xplained Rev B with mx25l25635e spi-nor flash.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v5: drop struct platform_device *pdev; linux leftover, 2 new blank lines v4: update Kconfig description v3: no change v2: no change
drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/atmel-quadspi.c | 536 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 545 insertions(+) create mode 100644 drivers/spi/atmel-quadspi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 04ddb32a8f31..a9c080c4fe9c 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -49,6 +49,14 @@ config ATH79_SPI uses driver model and requires a device tree binding to operate. please refer to doc/device-tree-bindings/spi/spi-ath79.txt.
+config ATMEL_QSPI + bool "Atmel Quad SPI Controller" + depends on ARCH_AT91 + help + Enable the Atmel Quad SPI controller in master mode. This driver + does not support generic SPI. The implementation supports only the + spi-mem interface. + config ATMEL_SPI bool "Atmel SPI driver" default y if ARCH_AT91 diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 3f9f2fab2b9f..64c407e2eddf 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -18,6 +18,7 @@ endif
obj-$(CONFIG_ALTERA_SPI) += altera_spi.o obj-$(CONFIG_ATH79_SPI) += ath79_spi.o +obj-$(CONFIG_ATMEL_QSPI) += atmel-quadspi.o obj-$(CONFIG_ATMEL_SPI) += atmel_spi.o obj-$(CONFIG_BCM63XX_HSSPI) += bcm63xx_hsspi.o obj-$(CONFIG_BCM63XX_SPI) += bcm63xx_spi.o diff --git a/drivers/spi/atmel-quadspi.c b/drivers/spi/atmel-quadspi.c new file mode 100644 index 000000000000..7d9a54011dda --- /dev/null +++ b/drivers/spi/atmel-quadspi.c @@ -0,0 +1,536 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Driver for Atmel QSPI Controller + * + * Copyright (C) 2015 Atmel Corporation + * Copyright (C) 2018 Cryptera A/S + * + * Author: Cyrille Pitchen cyrille.pitchen@atmel.com + * Author: Piotr Bugalski bugalski.piotr@gmail.com + */ + +#include <asm/io.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <fdtdec.h> +#include <linux/io.h> +#include <linux/iopoll.h> +#include <linux/ioport.h> +#include <mach/clk.h> +#include <spi.h> +#include <spi-mem.h> + +/* QSPI register offsets */ +#define QSPI_CR 0x0000 /* Control Register */ +#define QSPI_MR 0x0004 /* Mode Register */ +#define QSPI_RD 0x0008 /* Receive Data Register */ +#define QSPI_TD 0x000c /* Transmit Data Register */ +#define QSPI_SR 0x0010 /* Status Register */ +#define QSPI_IER 0x0014 /* Interrupt Enable Register */ +#define QSPI_IDR 0x0018 /* Interrupt Disable Register */ +#define QSPI_IMR 0x001c /* Interrupt Mask Register */ +#define QSPI_SCR 0x0020 /* Serial Clock Register */ + +#define QSPI_IAR 0x0030 /* Instruction Address Register */ +#define QSPI_ICR 0x0034 /* Instruction Code Register */ +#define QSPI_WICR 0x0034 /* Write Instruction Code Register */ +#define QSPI_IFR 0x0038 /* Instruction Frame Register */ +#define QSPI_RICR 0x003C /* Read Instruction Code Register */ + +#define QSPI_SMR 0x0040 /* Scrambling Mode Register */ +#define QSPI_SKR 0x0044 /* Scrambling Key Register */ + +#define QSPI_WPMR 0x00E4 /* Write Protection Mode Register */ +#define QSPI_WPSR 0x00E8 /* Write Protection Status Register */ + +#define QSPI_VERSION 0x00FC /* Version Register */ + +/* Bitfields in QSPI_CR (Control Register) */ +#define QSPI_CR_QSPIEN BIT(0) +#define QSPI_CR_QSPIDIS BIT(1) +#define QSPI_CR_SWRST BIT(7) +#define QSPI_CR_LASTXFER BIT(24) + +/* Bitfields in QSPI_MR (Mode Register) */ +#define QSPI_MR_SMM BIT(0) +#define QSPI_MR_LLB BIT(1) +#define QSPI_MR_WDRBT BIT(2) +#define QSPI_MR_SMRM BIT(3) +#define QSPI_MR_CSMODE_MASK GENMASK(5, 4) +#define QSPI_MR_CSMODE_NOT_RELOADED (0 << 4) +#define QSPI_MR_CSMODE_LASTXFER (1 << 4) +#define QSPI_MR_CSMODE_SYSTEMATICALLY (2 << 4) +#define QSPI_MR_NBBITS_MASK GENMASK(11, 8) +#define QSPI_MR_NBBITS(n) ((((n) - 8) << 8) & QSPI_MR_NBBITS_MASK) +#define QSPI_MR_DLYBCT_MASK GENMASK(23, 16) +#define QSPI_MR_DLYBCT(n) (((n) << 16) & QSPI_MR_DLYBCT_MASK) +#define QSPI_MR_DLYCS_MASK GENMASK(31, 24) +#define QSPI_MR_DLYCS(n) (((n) << 24) & QSPI_MR_DLYCS_MASK) + +/* Bitfields in QSPI_SR/QSPI_IER/QSPI_IDR/QSPI_IMR */ +#define QSPI_SR_RDRF BIT(0) +#define QSPI_SR_TDRE BIT(1) +#define QSPI_SR_TXEMPTY BIT(2) +#define QSPI_SR_OVRES BIT(3) +#define QSPI_SR_CSR BIT(8) +#define QSPI_SR_CSS BIT(9) +#define QSPI_SR_INSTRE BIT(10) +#define QSPI_SR_QSPIENS BIT(24) + +#define QSPI_SR_CMD_COMPLETED (QSPI_SR_INSTRE | QSPI_SR_CSR) + +/* Bitfields in QSPI_SCR (Serial Clock Register) */ +#define QSPI_SCR_CPOL BIT(0) +#define QSPI_SCR_CPHA BIT(1) +#define QSPI_SCR_SCBR_MASK GENMASK(15, 8) +#define QSPI_SCR_SCBR(n) (((n) << 8) & QSPI_SCR_SCBR_MASK) +#define QSPI_SCR_DLYBS_MASK GENMASK(23, 16) +#define QSPI_SCR_DLYBS(n) (((n) << 16) & QSPI_SCR_DLYBS_MASK) + +/* Bitfields in QSPI_ICR (Read/Write Instruction Code Register) */ +#define QSPI_ICR_INST_MASK GENMASK(7, 0) +#define QSPI_ICR_INST(inst) (((inst) << 0) & QSPI_ICR_INST_MASK) +#define QSPI_ICR_OPT_MASK GENMASK(23, 16) +#define QSPI_ICR_OPT(opt) (((opt) << 16) & QSPI_ICR_OPT_MASK) + +/* Bitfields in QSPI_IFR (Instruction Frame Register) */ +#define QSPI_IFR_WIDTH_MASK GENMASK(2, 0) +#define QSPI_IFR_WIDTH_SINGLE_BIT_SPI (0 << 0) +#define QSPI_IFR_WIDTH_DUAL_OUTPUT (1 << 0) +#define QSPI_IFR_WIDTH_QUAD_OUTPUT (2 << 0) +#define QSPI_IFR_WIDTH_DUAL_IO (3 << 0) +#define QSPI_IFR_WIDTH_QUAD_IO (4 << 0) +#define QSPI_IFR_WIDTH_DUAL_CMD (5 << 0) +#define QSPI_IFR_WIDTH_QUAD_CMD (6 << 0) +#define QSPI_IFR_INSTEN BIT(4) +#define QSPI_IFR_ADDREN BIT(5) +#define QSPI_IFR_OPTEN BIT(6) +#define QSPI_IFR_DATAEN BIT(7) +#define QSPI_IFR_OPTL_MASK GENMASK(9, 8) +#define QSPI_IFR_OPTL_1BIT (0 << 8) +#define QSPI_IFR_OPTL_2BIT (1 << 8) +#define QSPI_IFR_OPTL_4BIT (2 << 8) +#define QSPI_IFR_OPTL_8BIT (3 << 8) +#define QSPI_IFR_ADDRL BIT(10) +#define QSPI_IFR_TFRTYP_MEM BIT(12) +#define QSPI_IFR_SAMA5D2_WRITE_TRSFR BIT(13) +#define QSPI_IFR_CRM BIT(14) +#define QSPI_IFR_NBDUM_MASK GENMASK(20, 16) +#define QSPI_IFR_NBDUM(n) (((n) << 16) & QSPI_IFR_NBDUM_MASK) +#define QSPI_IFR_APBTFRTYP_READ BIT(24) /* Defined in SAM9X60 */ + +/* Bitfields in QSPI_SMR (Scrambling Mode Register) */ +#define QSPI_SMR_SCREN BIT(0) +#define QSPI_SMR_RVDIS BIT(1) + +/* Bitfields in QSPI_WPMR (Write Protection Mode Register) */ +#define QSPI_WPMR_WPEN BIT(0) +#define QSPI_WPMR_WPKEY_MASK GENMASK(31, 8) +#define QSPI_WPMR_WPKEY(wpkey) (((wpkey) << 8) & QSPI_WPMR_WPKEY_MASK) + +/* Bitfields in QSPI_WPSR (Write Protection Status Register) */ +#define QSPI_WPSR_WPVS BIT(0) +#define QSPI_WPSR_WPVSRC_MASK GENMASK(15, 8) +#define QSPI_WPSR_WPVSRC(src) (((src) << 8) & QSPI_WPSR_WPVSRC) + +struct atmel_qspi_caps { + bool has_qspick; + bool has_ricr; +}; + +struct atmel_qspi { + void __iomem *regs; + void __iomem *mem; + const struct atmel_qspi_caps *caps; + ulong bus_clk_rate; + u32 mr; +}; + +struct atmel_qspi_mode { + u8 cmd_buswidth; + u8 addr_buswidth; + u8 data_buswidth; + u32 config; +}; + +static const struct atmel_qspi_mode atmel_qspi_modes[] = { + { 1, 1, 1, QSPI_IFR_WIDTH_SINGLE_BIT_SPI }, + { 1, 1, 2, QSPI_IFR_WIDTH_DUAL_OUTPUT }, + { 1, 1, 4, QSPI_IFR_WIDTH_QUAD_OUTPUT }, + { 1, 2, 2, QSPI_IFR_WIDTH_DUAL_IO }, + { 1, 4, 4, QSPI_IFR_WIDTH_QUAD_IO }, + { 2, 2, 2, QSPI_IFR_WIDTH_DUAL_CMD }, + { 4, 4, 4, QSPI_IFR_WIDTH_QUAD_CMD }, +}; + +static inline bool atmel_qspi_is_compatible(const struct spi_mem_op *op, + const struct atmel_qspi_mode *mode) +{ + if (op->cmd.buswidth != mode->cmd_buswidth) + return false; + + if (op->addr.nbytes && op->addr.buswidth != mode->addr_buswidth) + return false; + + if (op->data.nbytes && op->data.buswidth != mode->data_buswidth) + return false; + + return true; +} + +static int atmel_qspi_find_mode(const struct spi_mem_op *op) +{ + u32 i; + + for (i = 0; i < ARRAY_SIZE(atmel_qspi_modes); i++) + if (atmel_qspi_is_compatible(op, &atmel_qspi_modes[i])) + return i; + + return -ENOTSUPP; +} + +static bool atmel_qspi_supports_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + if (atmel_qspi_find_mode(op) < 0) + return false; + + /* special case not supported by hardware */ + if (op->addr.nbytes == 2 && op->cmd.buswidth != op->addr.buswidth && + op->dummy.nbytes == 0) + return false; + + return true; +} + +static int atmel_qspi_set_cfg(struct atmel_qspi *aq, + const struct spi_mem_op *op, u32 *offset) +{ + u32 iar, icr, ifr; + u32 dummy_cycles = 0; + int mode; + + iar = 0; + icr = QSPI_ICR_INST(op->cmd.opcode); + ifr = QSPI_IFR_INSTEN; + + mode = atmel_qspi_find_mode(op); + if (mode < 0) + return mode; + ifr |= atmel_qspi_modes[mode].config; + + if (op->dummy.buswidth && op->dummy.nbytes) + dummy_cycles = op->dummy.nbytes * 8 / op->dummy.buswidth; + + /* + * The controller allows 24 and 32-bit addressing while NAND-flash + * requires 16-bit long. Handling 8-bit long addresses is done using + * the option field. For the 16-bit addresses, the workaround depends + * of the number of requested dummy bits. If there are 8 or more dummy + * cycles, the address is shifted and sent with the first dummy byte. + * Otherwise opcode is disabled and the first byte of the address + * contains the command opcode (works only if the opcode and address + * use the same buswidth). The limitation is when the 16-bit address is + * used without enough dummy cycles and the opcode is using a different + * buswidth than the address. + */ + if (op->addr.buswidth) { + switch (op->addr.nbytes) { + case 0: + break; + case 1: + ifr |= QSPI_IFR_OPTEN | QSPI_IFR_OPTL_8BIT; + icr |= QSPI_ICR_OPT(op->addr.val & 0xff); + break; + case 2: + if (dummy_cycles < 8 / op->addr.buswidth) { + ifr &= ~QSPI_IFR_INSTEN; + ifr |= QSPI_IFR_ADDREN; + iar = (op->cmd.opcode << 16) | + (op->addr.val & 0xffff); + } else { + ifr |= QSPI_IFR_ADDREN; + iar = (op->addr.val << 8) & 0xffffff; + dummy_cycles -= 8 / op->addr.buswidth; + } + break; + case 3: + ifr |= QSPI_IFR_ADDREN; + iar = op->addr.val & 0xffffff; + break; + case 4: + ifr |= QSPI_IFR_ADDREN | QSPI_IFR_ADDRL; + iar = op->addr.val & 0x7ffffff; + break; + default: + return -ENOTSUPP; + } + } + + /* offset of the data access in the QSPI memory space */ + *offset = iar; + + /* Set number of dummy cycles */ + if (dummy_cycles) + ifr |= QSPI_IFR_NBDUM(dummy_cycles); + + /* Set data enable */ + if (op->data.nbytes) + ifr |= QSPI_IFR_DATAEN; + + /* + * If the QSPI controller is set in regular SPI mode, set it in + * Serial Memory Mode (SMM). + */ + if (aq->mr != QSPI_MR_SMM) { + writel(QSPI_MR_SMM, aq->regs + QSPI_MR); + aq->mr = QSPI_MR_SMM; + } + + /* Clear pending interrupts */ + (void)readl(aq->regs + QSPI_SR); + + if (aq->caps->has_ricr) { + if (!op->addr.nbytes && op->data.dir == SPI_MEM_DATA_IN) + ifr |= QSPI_IFR_APBTFRTYP_READ; + + /* Set QSPI Instruction Frame registers */ + writel(iar, aq->regs + QSPI_IAR); + if (op->data.dir == SPI_MEM_DATA_IN) + writel(icr, aq->regs + QSPI_RICR); + else + writel(icr, aq->regs + QSPI_WICR); + writel(ifr, aq->regs + QSPI_IFR); + } else { + if (op->data.dir == SPI_MEM_DATA_OUT) + ifr |= QSPI_IFR_SAMA5D2_WRITE_TRSFR; + + /* Set QSPI Instruction Frame registers */ + writel(iar, aq->regs + QSPI_IAR); + writel(icr, aq->regs + QSPI_ICR); + writel(ifr, aq->regs + QSPI_IFR); + } + + return 0; +} + +static int atmel_qspi_exec_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + struct atmel_qspi *aq = dev_get_priv(slave->dev->parent); + u32 sr, imr, offset; + int err; + + err = atmel_qspi_set_cfg(aq, op, &offset); + if (err) + return err; + + /* Skip to the final steps if there is no data */ + if (op->data.nbytes) { + /* Dummy read of QSPI_IFR to synchronize APB and AHB accesses */ + (void)readl(aq->regs + QSPI_IFR); + + /* Send/Receive data */ + if (op->data.dir == SPI_MEM_DATA_IN) + memcpy_fromio(op->data.buf.in, aq->mem + offset, + op->data.nbytes); + else + memcpy_toio(aq->mem + offset, op->data.buf.out, + op->data.nbytes); + + /* Release the chip-select */ + writel(QSPI_CR_LASTXFER, aq->regs + QSPI_CR); + } + + /* Poll INSTruction End and Chip Select Rise flags. */ + imr = QSPI_SR_INSTRE | QSPI_SR_CSR; + return readl_poll_timeout(aq->regs + QSPI_SR, sr, (sr & imr) == imr, + 1000000); +} + +static int atmel_qspi_set_speed(struct udevice *bus, uint hz) +{ + struct atmel_qspi *aq = dev_get_priv(bus); + u32 scr, scbr, mask, new_value; + + /* Compute the QSPI baudrate */ + scbr = DIV_ROUND_UP(aq->bus_clk_rate, hz); + if (scbr > 0) + scbr--; + + new_value = QSPI_SCR_SCBR(scbr); + mask = QSPI_SCR_SCBR_MASK; + + scr = readl(aq->regs + QSPI_SCR); + if ((scr & mask) == new_value) + return 0; + + scr = (scr & ~mask) | new_value; + writel(scr, aq->regs + QSPI_SCR); + + return 0; +} + +static int atmel_qspi_set_mode(struct udevice *bus, uint mode) +{ + struct atmel_qspi *aq = dev_get_priv(bus); + u32 scr, mask, new_value = 0; + + if (mode & SPI_CPOL) + new_value = QSPI_SCR_CPOL; + if (mode & SPI_CPHA) + new_value = QSPI_SCR_CPHA; + + mask = QSPI_SCR_CPOL | QSPI_SCR_CPHA; + + scr = readl(aq->regs + QSPI_SCR); + if ((scr & mask) == new_value) + return 0; + + scr = (scr & ~mask) | new_value; + writel(scr, aq->regs + QSPI_SCR); + + return 0; +} + +static int atmel_qspi_enable_clk(struct udevice *dev) +{ + struct atmel_qspi *aq = dev_get_priv(dev); + struct clk pclk, qspick; + int ret; + + ret = clk_get_by_name(dev, "pclk", &pclk); + if (ret) + ret = clk_get_by_index(dev, 0, &pclk); + + if (ret) { + dev_err(dev, "Missing QSPI peripheral clock\n"); + return ret; + } + + ret = clk_enable(&pclk); + if (ret) { + dev_err(dev, "Failed to enable QSPI peripheral clock\n"); + goto free_pclk; + } + + if (aq->caps->has_qspick) { + /* Get the QSPI system clock */ + ret = clk_get_by_name(dev, "qspick", &qspick); + if (ret) { + dev_err(dev, "Missing QSPI peripheral clock\n"); + goto free_pclk; + } + + ret = clk_enable(&qspick); + if (ret) + dev_err(dev, "Failed to enable QSPI system clock\n"); + clk_free(&qspick); + } + + aq->bus_clk_rate = clk_get_rate(&pclk); + if (!aq->bus_clk_rate) + ret = -EINVAL; + +free_pclk: + clk_free(&pclk); + + return ret; +} + +static void atmel_qspi_init(struct atmel_qspi *aq) +{ + /* Reset the QSPI controller */ + writel(QSPI_CR_SWRST, aq->regs + QSPI_CR); + + /* Set the QSPI controller by default in Serial Memory Mode */ + writel(QSPI_MR_SMM, aq->regs + QSPI_MR); + aq->mr = QSPI_MR_SMM; + + /* Enable the QSPI controller */ + writel(QSPI_CR_QSPIEN, aq->regs + QSPI_CR); +} + +static int atmel_qspi_probe(struct udevice *dev) +{ + struct atmel_qspi *aq = dev_get_priv(dev); + struct resource res; + int ret; + + aq->caps = (struct atmel_qspi_caps *)dev_get_driver_data(dev); + if (!aq->caps) { + dev_err(dev, "Could not retrieve QSPI caps\n"); + return -EINVAL; + }; + + /* Map the registers */ + ret = dev_read_resource_byname(dev, "qspi_base", &res); + if (ret) { + dev_err(dev, "missing registers\n"); + return ret; + } + + aq->regs = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(aq->regs)) + return PTR_ERR(aq->regs); + + /* Map the AHB memory */ + ret = dev_read_resource_byname(dev, "qspi_mmap", &res); + if (ret) { + dev_err(dev, "missing AHB memory\n"); + return ret; + } + + aq->mem = devm_ioremap(dev, res.start, resource_size(&res)); + if (IS_ERR(aq->mem)) + return PTR_ERR(aq->mem); + + ret = atmel_qspi_enable_clk(dev); + if (ret) + return ret; + + atmel_qspi_init(aq); + + return 0; +} + +static const struct spi_controller_mem_ops atmel_qspi_mem_ops = { + .supports_op = atmel_qspi_supports_op, + .exec_op = atmel_qspi_exec_op, +}; + +static const struct dm_spi_ops atmel_qspi_ops = { + .set_speed = atmel_qspi_set_speed, + .set_mode = atmel_qspi_set_mode, + .mem_ops = &atmel_qspi_mem_ops, +}; + +static const struct atmel_qspi_caps atmel_sama5d2_qspi_caps = {}; + +static const struct atmel_qspi_caps atmel_sam9x60_qspi_caps = { + .has_qspick = true, + .has_ricr = true, +}; + +static const struct udevice_id atmel_qspi_ids[] = { + { + .compatible = "atmel,sama5d2-qspi", + .data = (ulong)&atmel_sama5d2_qspi_caps, + }, + { + .compatible = "microchip,sam9x60-qspi", + .data = (ulong)&atmel_sam9x60_qspi_caps, + }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(atmel_qspi) = { + .name = "atmel_qspi", + .id = UCLASS_SPI, + .of_match = atmel_qspi_ids, + .ops = &atmel_qspi_ops, + .priv_auto_alloc_size = sizeof(struct atmel_qspi), + .probe = atmel_qspi_probe, +};
Reviewed-by: Jagan Teki jagan@amarulasolutions.com
We have a macronix spi-nor flash on sama5d2_xplained RevB and a sst spi-nor flash on RevC. Select the rest for testing purposes.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v5: no change v4: no change v3: no change v2: new patch
configs/sama5d2_xplained_emmc_defconfig | 5 +++++ configs/sama5d2_xplained_mmc_defconfig | 5 +++++ configs/sama5d2_xplained_spiflash_defconfig | 5 +++++ 3 files changed, 15 insertions(+)
diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index f643b5a62f39..f244777121b1 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -65,6 +65,10 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y @@ -76,6 +80,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index c25d67bfebb1..633f6c5ad00c 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -67,6 +67,10 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y @@ -78,6 +82,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index ac5ae5133c3d..39da86530429 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -64,6 +64,10 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y CONFIG_MACB=y CONFIG_PINCTRL=y @@ -75,6 +79,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y
We use a sst spi-nor flash memory on sama5d27_som1_ek. Select the others for testing purposes.
configs/sama5d27_som1_ek_mmc1_defconfig | 2 ++ configs/sama5d27_som1_ek_mmc_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 205a4399410f..9b2b78110357 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -67,6 +67,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=66000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y @@ -80,6 +81,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 0a0780066cd8..e5c551e205d0 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -67,6 +67,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=66000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_DM_ETH=y @@ -80,6 +81,7 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y
From: Cyrille Pitchen cyrille.pitchen@microchip.com
Fix the following: - use "jedec,spi-nor" binding, we use jedec compatible flashes - set bus width to 4, we use quad capable flashes - differentiate bewteen data and clk and cs pins - drop partions as we don't use them in u-boot.
Signed-off-by: Cyrille Pitchen cyrille.pitchen@microchip.com [tudor.ambarus@microchip.com: use "jedec,spi-nor", edit commit message] Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v5: no change v4: no change v3: no change v2: new patch
arch/arm/dts/at91-sama5d2_xplained.dts | 36 ++++++++++++++++------------------ 1 file changed, 17 insertions(+), 19 deletions(-)
diff --git a/arch/arm/dts/at91-sama5d2_xplained.dts b/arch/arm/dts/at91-sama5d2_xplained.dts index c0708feeb7b2..7f0d1696ba3e 100644 --- a/arch/arm/dts/at91-sama5d2_xplained.dts +++ b/arch/arm/dts/at91-sama5d2_xplained.dts @@ -79,26 +79,18 @@ };
qspi0: spi@f0020000 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi0_sck_cs_default &pinctrl_qspi0_dat_default>; status = "okay"; + u-boot,dm-pre-reloc;
flash@0 { - compatible = "atmel,sama5d2-qspi-flash"; + compatible = "jedec,spi-nor"; reg = <0>; - #address-cells = <1>; - #size-cells = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_qspi0_default>; spi-max-frequency = <83000000>; - - partition@00000000 { - label = "boot"; - reg = <0x00000000 0x00c00000>; - }; - - partition@00c00000 { - label = "rootfs"; - reg = <0x00c00000 0x00000000>; - }; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <4>; + u-boot,dm-pre-reloc; }; };
@@ -208,14 +200,20 @@ bias-disable; };
- pinctrl_qspi0_default: qspi0_default { + pinctrl_qspi0_sck_cs_default: qspi0_sck_cs_default { pinmux = <PIN_PA22__QSPI0_SCK>, - <PIN_PA23__QSPI0_CS>, - <PIN_PA24__QSPI0_IO0>, + <PIN_PA23__QSPI0_CS>; + bias-disable; + u-boot,dm-pre-reloc; + }; + + pinctrl_qspi0_dat_default: qspi0_dat_default { + pinmux = <PIN_PA24__QSPI0_IO0>, <PIN_PA25__QSPI0_IO1>, <PIN_PA26__QSPI0_IO2>, <PIN_PA27__QSPI0_IO3>; - bias-disable; + bias-pull-up; + u-boot,dm-pre-reloc; };
pinctrl_sdmmc0_cmd_dat_default: sdmmc0_cmd_dat_default {
Fix the following:
I always believe, keeping period sync of DTS changes from linux rather than minimal or required changes when it needed. it is up to Eugen to make decision here.
Jagan.
Use the same memory layout as we use for the NAND boot on the other boards.
QSPI flashes are present on the following boards: sama5d2_xplained RevB: 32 Mbyte flash (mx25l3273fm2i-08g) sama5d2_xplained RevC: 8 Mbyte flash (sst26vf064b-104i/sn) sama5d27_som1_ek: 8 Mbyte flash (sst26vf064b-104i/sn) sama5d2_ptc_ek: 8 Mbyte flash (sst26vf064b-104i/sn)
The 8 Mbyte limit is enough to cope with the memory layout used in the NAND boot. rootfs exceeds the 8 Mbyte limit and will stay in eMMC in the sama5d2_xplained case. The final scope is to use a single memory layout for all boot medias.
Signed-off-by: Cyrille Pitchen cyrille.pitchen@microchip.com [tudor.ambarus@microchip.com: change memory layout, add commit message] Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v5: no change v4: no change v3: no change v2: new patch
include/configs/at91-sama5_common.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index 30c6cd47cac2..fc46540a10ab 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -72,6 +72,14 @@ "sf read 0x21000000 0x60000 0xc000; " \ "sf read 0x22000000 0x6c000 0x394000; " \ "bootz 0x22000000 - 0x21000000" +#elif CONFIG_QSPI_BOOT +#define CONFIG_ENV_OFFSET 0x140000 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_SECT_SIZE 0x1000 +#define CONFIG_BOOTCOMMAND "sf probe 0; " \ + "sf read 0x21000000 0x180000 0x80000; " \ + "sf read 0x22000000 0x200000 0x600000; " \ + "bootz 0x22000000 - 0x21000000" #endif
#endif
Add the default config file of QSPI media. The config is based on sama5d2_xplained_mmc_defconfig.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v5: no change v4: no change v3: fix the following: ./tools/genboardscfg.py WARNING: no status info for 'sama5d2_xplained_qspiflash' WARNING: no maintainers for 'sama5d2_xplained_qspiflash'
v2: new patch
board/atmel/sama5d2_xplained/MAINTAINERS | 1 + configs/sama5d2_xplained_qspiflash_defconfig | 101 +++++++++++++++++++++++++++ 2 files changed, 102 insertions(+) create mode 100644 configs/sama5d2_xplained_qspiflash_defconfig
diff --git a/board/atmel/sama5d2_xplained/MAINTAINERS b/board/atmel/sama5d2_xplained/MAINTAINERS index 08de5bb6a076..88e327f81cd8 100644 --- a/board/atmel/sama5d2_xplained/MAINTAINERS +++ b/board/atmel/sama5d2_xplained/MAINTAINERS @@ -6,3 +6,4 @@ F: include/configs/sama5d2_xplained.h F: configs/sama5d2_xplained_mmc_defconfig F: configs/sama5d2_xplained_spiflash_defconfig F: configs/sama5d2_xplained_emmc_defconfig +F: configs/sama5d2_xplained_qspiflash_defconfig diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig new file mode 100644 index 000000000000..1bf04936f748 --- /dev/null +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -0,0 +1,101 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_SYS_TEXT_BASE=0x26f00000 +CONFIG_TARGET_SAMA5D2_XPLAINED=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0xf8020000 +CONFIG_DEBUG_UART_CLOCK=83000000 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_DEBUG_UART=y +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p1 rw rootwait" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d2_xplained" +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_DM_GPIO=y +CONFIG_ATMEL_PIO4=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_AT91=y +CONFIG_I2C_EEPROM=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ATMEL_USART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_DM_VIDEO=y +CONFIG_ATMEL_HLCD=y +CONFIG_W1=y +CONFIG_W1_GPIO=y +CONFIG_W1_EEPROM=y +CONFIG_W1_EEPROM_DS24XXX=y +CONFIG_FAT_WRITE=y +CONFIG_OF_LIBFDT_OVERLAY=y
Add the default config file of QSPI media. The config is based on sama5d27_som1_ek_mmc_defconfig.
Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v5: no change v4: no change v3: fix the following: ./tools/genboardscfg.py WARNING: no status info for 'sama5d27_som1_ek_qspiflash' WARNING: no maintainers for 'sama5d27_som1_ek_qspiflash' v2: new patch
board/atmel/sama5d27_som1_ek/MAINTAINERS | 1 + configs/sama5d27_som1_ek_qspiflash_defconfig | 101 +++++++++++++++++++++++++++ 2 files changed, 102 insertions(+) create mode 100644 configs/sama5d27_som1_ek_qspiflash_defconfig
diff --git a/board/atmel/sama5d27_som1_ek/MAINTAINERS b/board/atmel/sama5d27_som1_ek/MAINTAINERS index 74434e93e952..f2d2f49db304 100644 --- a/board/atmel/sama5d27_som1_ek/MAINTAINERS +++ b/board/atmel/sama5d27_som1_ek/MAINTAINERS @@ -5,3 +5,4 @@ F: board/atmel/sama5d27_som1_ek/ F: include/configs/sama5d27_som1_ek.h F: configs/sama5d27_som1_ek_mmc_defconfig F: configs/sama5d27_som1_ek_mmc1_defconfig +F: configs/sama5d27_som1_ek_qspiflash_defconfig diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig new file mode 100644 index 000000000000..128b6645f6d9 --- /dev/null +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -0,0 +1,101 @@ +CONFIG_ARM=y +CONFIG_ARCH_AT91=y +CONFIG_SYS_TEXT_BASE=0x23f00000 +CONFIG_TARGET_SAMA5D27_SOM1_EK=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0xf8020000 +CONFIG_DEBUG_UART_CLOCK=82000000 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_DEBUG_UART=y +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_FIT=y +CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_SPL_TEXT_BASE=0x200000 +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="at91-sama5d27_som1_ek" +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_AT91_H32MX=y +CONFIG_AT91_GENERIC_CLK=y +CONFIG_DM_GPIO=y +CONFIG_ATMEL_PIO4=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_AT91=y +CONFIG_I2C_EEPROM=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ATMEL=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=66000000 +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_AT91PIO4=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ATMEL_USART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_QSPI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_ATMEL_PIT_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_DM_VIDEO=y +CONFIG_ATMEL_HLCD=y +CONFIG_W1=y +CONFIG_W1_GPIO=y +CONFIG_W1_EEPROM=y +CONFIG_W1_EEPROM_DS24XXX=y +CONFIG_FAT_WRITE=y +CONFIG_OF_LIBFDT_OVERLAY=y
Use the qspi memory layout defined in at91-sama5_common - it aligns with the 8 Mbyte flash (sst26vf064b-104i/sn) available in sama5d27_som1_ek.
include/configs/sama5d27_som1_ek.h | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h index 5f6979cd77a5..90846c4bfd44 100644 --- a/include/configs/sama5d27_som1_ek.h +++ b/include/configs/sama5d27_som1_ek.h @@ -43,13 +43,6 @@ #endif
#ifdef CONFIG_QSPI_BOOT -#define CONFIG_ENV_OFFSET 0xb0000 -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_BOOTCOMMAND "sf probe 0; " \ - "sf read 0x21000000 0xc0000 0x20000; " \ - "sf read 0x22000000 0xe0000 0x400000; " \ - "bootz 0x22000000 - 0x21000000" #undef CONFIG_BOOTARGS #define CONFIG_BOOTARGS \ "console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait"
The spi-nor flash resides on spi bus 1. Update the CONFIG_ENV_SPI_CS and CONFIG_BOOTCOMMAND accordingly.
Based on original work by Wenyou Yang.
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com [tudor.ambarus@microchip.com: amend the commit message.] Signed-off-by: Tudor Ambarus tudor.ambarus@microchip.com --- v5: no change v4: no change v3: no change v2: new patch
include/configs/sama5d2_xplained.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index e522740e0c5b..3dea3591275f 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -46,6 +46,17 @@
#endif
+#ifdef CONFIG_QSPI_BOOT +#undef CONFIG_ENV_SPI_BUS +#undef CONFIG_BOOTCOMMAND +#define CONFIG_ENV_SPI_BUS 1 +#define CONFIG_BOOTCOMMAND "sf probe 1:0; " \ + "sf read 0x21000000 0x180000 0x80000; " \ + "sf read 0x22000000 0x200000 0x600000; "\ + "bootz 0x22000000 - 0x21000000" + +#endif + /* SPL */ #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000
Hello Jagan,
I can only take these patches through u-boot-atmel tree if you Ack/Review them. Otherwise you can consider taking them through u-boot-spi ?
Thanks, Eugen
On Tue, Jun 25, 2019 at 5:05 PM Eugen.Hristev@microchip.com wrote:
Hello Jagan,
I would need a look on the new version, once ie fine I can pick via spi tree. if possible please assign me on the patchwork, thanks.
Hi Eugen,
Hello Jagan,
I have marked my comments, you can make the decision accordingly. By the way I assigned them to you as well, thanks.
Jagan.
On 29.06.2019 17:55, Jagan Teki wrote:
Hi Eugen,
Hello Jagan,
Jagan.
Applied patches 2-10 to u-boot-atmel/next Dropped patch 1 (dt-bindings) as advised by Jagan. Will be queued for 2019.10 merge window.
Thanks Tudor and Jagan !
Eugen
Jagan Teki
