[U-Boot] Problem with board bring up with 8308 processor.
HI, I am new to U boot. I am trying to port a custom board with 8308 processor, Uboot code is stored on a NOR flash. I am able to program the NOR flash. I am using a BDI programmer to program the UBOOT. 1) For some reason, the booting stops with COP status 5. 2) I even tried single stepping debug with a BDI, but even that fails. Once I power on the board the booting stops with COP status 5 . I do not get any prints on the console 3) For some reason the Code Warrior tool from Freescale does not support the NOR Flash type used on the board.
I get the following error on single stepping with BDI
Waiting for target stop failed - TARGET: Break at boot vector failed, freeze forced
4) I have checked the HRESET word, it seems to be fine. Ihave also checked BR0, OR0 and local access window settings. 5) mmd of the nor flash properly shows the HRESET settings.
Please help me on this.
Thanks Sharath
Can you send all what you see in the BDI telnet command line from reset up until you program your flash. Include the result of info cmd after your run prog as well.
Where do you start single stepping from ? Does it ever break properly after reset ?
- I have checked the HRESET word, it seems to be fine. Ihave also checked
At which point are you checking those if your BDI never stops ? Are you perhaps referring that your config file includes all the correct settings, if so send that part of your config file as well.
-- sinan
Sharath Kurudi
Sinan Akman
