[U-Boot] [PATCH] arm: ls1021a: Ensure Generic Timer disabled before jumping into the OS
This patch addresses a problem mentioned recently on this mailing list: [1].
In that posting a LS1021 based system was locking up at about 5 minutes after boot,but the problem was mysteriously related to the toolchain used for building u-boot.Debugging the problem reveals a stuck interrupt 29 on the GIC.
It appears Freescale's LS1021 support in u-boot erroneously sets the 64-bit ARM generic PL1 physical time CompareValue register to all-ones with a 32-bit value.This causes the timer compare to fire 344 seconds after u-boot configures it.Depending on how fast u-boot gets the kernel booted,this amounts to about 5-minutes of Linux uptime before locking up.
Apparently the bug is masked by some toolchains. Perhaps this is explained by default compiler options, word sizes, or binutils versions.
To fix the above issue, the generic physical timer is disabled before jumping to the OS.
[1] https://lists.yoctoproject.org/pipermail/meta-freescale/2015-June/014400.htm...
Signed-off-by: Chris Kilgour techie@whiterocker.com Signed-off-by: Alison Wang alison.wang@freescale.com --- arch/arm/cpu/armv7/ls102xa/cpu.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/cpu/armv7/ls102xa/cpu.c b/arch/arm/cpu/armv7/ls102xa/cpu.c index 75f0d8c..298422f 100644 --- a/arch/arm/cpu/armv7/ls102xa/cpu.c +++ b/arch/arm/cpu/armv7/ls102xa/cpu.c @@ -346,3 +346,13 @@ void smp_kick_all_cpus(void) out_be32(&gur->brrl, 0x2); } #endif + +void arch_preboot_os(void) +{ + unsigned long ctrl; + + /* Disable PL1 Physical Timer */ + asm("mrc p15, 0, %0, c14, c2, 1" : "=r" (ctrl)); + ctrl &= ~ARCH_TIMER_CTRL_ENABLE; + asm("mcr p15, 0, %0, c14, c2, 1" : : "r" (ctrl)); +}
- unsigned long ctrl;
- /* Disable PL1 Physical Timer */
- asm("mrc p15, 0, %0, c14, c2, 1" : "=r" (ctrl));
- ctrl &= ~ARCH_TIMER_CTRL_ENABLE;
- asm("mcr p15, 0, %0, c14, c2, 1" : : "r" (ctrl));
Mark,
Can you comment on this patch? I believe this is the follow-up after discussion here http://patchwork.ozlabs.org/patch/495476/.
York
Hello Alison,
This only disables the timer when booting linux. Does the possibly misconfigured timer compare value (only lower 32-bits are set to 0xffffffff) have any side-effects within u-boot? I don't currently know the timer is used there. I would prefer that the inline assembly code in timer_init is fixed to pass an 64-bit variable to mcrr. Maybe someone will take that code snippet as an example and such problems occur again. Opinions?
Best regards, Alexander
Hi, Alexander,
list:
[1].
ones
versions.
June/0144
00.html
- asm("mcr p15, 0, %0, c14, c2, 1" : : "r" (ctrl)); }
[Alison Wang] Thanks for your reply. I agree with you that the misconfigured Timer compare value should be fixed too. So except this patch, the patch on http://patchwork.ozlabs.org/patch/495476/ need to be applied too.
Best Regards, Alison Wang
Hi, Mark and Alexander,
Do you have any comment about this patch? Thanks.
list:
[1].
ones
versions.
June/0144
00.html
list:
[1].
ones
versions.
June/0144
00.html
Same opinion here. Both patches should be applied.
The patch looks good to me. FWIW:
Acked-by: Mark Rutland mark.rutland@arm.com
Mark.
Applied to fsl-qoriq master. Thanks.
York
participants (5)
Alexander Stein
Alison Wang
Huan Wang
Mark Rutland
York Sun
