[PATCH] stm32mp: fix compilation issue with DEBUG_UART
Fix the compilation issue when CONFIG_DEBUG_UART is activated
drivers/serial/serial_stm32.o: in function `debug_uart_init': drivers/serial/serial_stm32.c:291: undefined reference to \ `board_debug_uart_init'
The board_debug_uart_init is needed for SPL boot, called in cpu.c::mach_cpu_init(); it is defined in board/st/stm32mp1/spl.c.
But with the removal #ifdefs patch, the function debug_uart_init() is always compiled even if not present in the final U-Boot image.
This patch adds a file to provided this function when DEBUG_UART and SPL are activated.
Fixes: c8b2eef52b6c ("stm32mp15: tidy up #ifdefs in cpu.c") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/mach-stm32mp/Kconfig.15x | 2 +- board/engicam/stm32mp1/Makefile | 2 ++ board/engicam/stm32mp1/spl.c | 25 ------------------------- board/st/stm32mp1/Makefile | 2 ++ board/st/stm32mp1/debug_uart.c | 29 +++++++++++++++++++++++++++++ board/st/stm32mp1/spl.c | 28 ---------------------------- 6 files changed, 34 insertions(+), 54 deletions(-) create mode 100644 board/st/stm32mp1/debug_uart.c
diff --git a/arch/arm/mach-stm32mp/Kconfig.15x b/arch/arm/mach-stm32mp/Kconfig.15x index d516270292a..5bd9b53a5d8 100644 --- a/arch/arm/mach-stm32mp/Kconfig.15x +++ b/arch/arm/mach-stm32mp/Kconfig.15x @@ -117,7 +117,7 @@ endif if DEBUG_UART
config DEBUG_UART_BOARD_INIT - default y + default y if SPL
# debug on UART4 by default config DEBUG_UART_BASE diff --git a/board/engicam/stm32mp1/Makefile b/board/engicam/stm32mp1/Makefile index 65560df2900..155d33f9eec 100644 --- a/board/engicam/stm32mp1/Makefile +++ b/board/engicam/stm32mp1/Makefile @@ -8,3 +8,5 @@ obj-y += spl.o else obj-y += stm32mp1.o endif + +obj-$(CONFIG_DEBUG_UART_BOARD_INIT) += ../../st/stm32mp1/debug_uart.o diff --git a/board/engicam/stm32mp1/spl.c b/board/engicam/stm32mp1/spl.c index 3aa738b3faa..2b7779cc01d 100644 --- a/board/engicam/stm32mp1/spl.c +++ b/board/engicam/stm32mp1/spl.c @@ -6,7 +6,6 @@ */
#include <common.h> -#include <asm/io.h>
/* board early initialisation in board_f: need to use global variable */ static u32 opp_voltage_mv __section(".data"); @@ -22,27 +21,3 @@ int board_early_init_f(void) return 0; }
-#ifdef CONFIG_DEBUG_UART_BOARD_INIT -void board_debug_uart_init(void) -{ -#if (CONFIG_DEBUG_UART_BASE == STM32_UART4_BASE) - -#define RCC_MP_APB1ENSETR (STM32_RCC_BASE + 0x0A00) -#define RCC_MP_AHB4ENSETR (STM32_RCC_BASE + 0x0A28) - - /* UART4 clock enable */ - setbits_le32(RCC_MP_APB1ENSETR, BIT(16)); - -#define GPIOG_BASE 0x50008000 - /* GPIOG clock enable */ - writel(BIT(6), RCC_MP_AHB4ENSETR); - /* GPIO configuration for ST boards: Uart4 TX = G11 */ - writel(0xffbfffff, GPIOG_BASE + 0x00); - writel(0x00006000, GPIOG_BASE + 0x24); -#else - -#error("CONFIG_DEBUG_UART_BASE: not supported value") - -#endif -} -#endif diff --git a/board/st/stm32mp1/Makefile b/board/st/stm32mp1/Makefile index 65560df2900..f2d720b67b3 100644 --- a/board/st/stm32mp1/Makefile +++ b/board/st/stm32mp1/Makefile @@ -8,3 +8,5 @@ obj-y += spl.o else obj-y += stm32mp1.o endif + +obj-$(CONFIG_DEBUG_UART_BOARD_INIT) += debug_uart.o diff --git a/board/st/stm32mp1/debug_uart.c b/board/st/stm32mp1/debug_uart.c new file mode 100644 index 00000000000..24e3f9f2201 --- /dev/null +++ b/board/st/stm32mp1/debug_uart.c @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR BSD-3-Clause +/* + * Copyright (C) 2022, STMicroelectronics - All Rights Reserved + */ + +#include <config.h> +#include <debug_uart.h> +#include <asm/io.h> +#include <asm/arch/stm32.h> +#include <linux/bitops.h> + +#define RCC_MP_APB1ENSETR (STM32_RCC_BASE + 0x0A00) +#define RCC_MP_AHB4ENSETR (STM32_RCC_BASE + 0x0A28) + +#define GPIOG_BASE 0x50008000 + +void board_debug_uart_init(void) +{ + if (CONFIG_DEBUG_UART_BASE == STM32_UART4_BASE) { + /* UART4 clock enable */ + setbits_le32(RCC_MP_APB1ENSETR, BIT(16)); + + /* GPIOG clock enable */ + writel(BIT(6), RCC_MP_AHB4ENSETR); + /* GPIO configuration for ST boards: Uart4 TX = G11 */ + writel(0xffbfffff, GPIOG_BASE + 0x00); + writel(0x00006000, GPIOG_BASE + 0x24); + } +} diff --git a/board/st/stm32mp1/spl.c b/board/st/stm32mp1/spl.c index 8e4549a1b35..747ec7e445a 100644 --- a/board/st/stm32mp1/spl.c +++ b/board/st/stm32mp1/spl.c @@ -5,11 +5,7 @@
#include <config.h> #include <common.h> -#include <init.h> -#include <asm/io.h> #include <asm/arch/sys_proto.h> -#include <linux/bitops.h> -#include <linux/delay.h> #include "../common/stpmic1.h"
/* board early initialisation in board_f: need to use global variable */ @@ -29,27 +25,3 @@ int board_early_init_f(void) return 0; }
- default y
- default y if SPL
-#else
- Copyright (C) 2022, STMicroelectronics - All Rights Reserved
- if (CONFIG_DEBUG_UART_BASE == STM32_UART4_BASE) {
-#else
-#endif -} -#endif
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
- default y
- default y if SPL
-#else
-#else
-#endif -} -#endif
Applied on u-boot-stm32/master
Thanks Patrice
Patrice CHOTARD
Patrick Delaunay
