[U-Boot] [PATCH] mmc: Add an mmcsilent option
When using MMC commands for dfu there is considerable noise. Suppress mmc messages when mmcsilent is set.
Signed-off-by: Pantelis Antoniou panto@antoniou-consulting.com --- common/cmd_mmc.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index 4c19df7..73383f3 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -278,8 +278,9 @@ static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
- printf("\nMMC %s: dev # %d, block # %d, count %d ... ", - argv[1], curr_device, blk, cnt); + if (getenv("mmcsilent") == NULL) + printf("\nMMC %s: dev # %d, block # %d, count %d ... ", + argv[1], curr_device, blk, cnt);
mmc_init(mmc);
@@ -301,8 +302,9 @@ static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) BUG(); }
- printf("%d blocks %s: %s\n", - n, argv[1], (n == cnt) ? "OK" : "ERROR"); + if (getenv("mmcsilent") == NULL) + printf("%d blocks %s: %s\n", + n, argv[1], (n == cnt) ? "OK" : "ERROR"); return (n == cnt) ? 0 : 1; }
Dear Pantelis Antoniou,
In message 1354174469-5625-1-git-send-email-panto@antoniou-consulting.com you wrote:
mmc_init(mmc);
return (n == cnt) ? 0 : 1;n, argv[1], (n == cnt) ? "OK" : "ERROR");
Do we need these messages at all? Or should we not just turn these printf() into debug() ?
If not, the "mmcsilent" variable needs to be documented.
On Thu, Nov 29, 2012 at 1:34 AM, Pantelis Antoniou < panto@antoniou-consulting.com> wrote:
I'm not familiar with DFU mode, but is there a reason it's invoking the command line call, rather than accessing the card programmatically? The reason that printf is there is because it's a user-facing interface, rather than a software-facing interface.
Andy
Hi Andy,
On Nov 28, 2012, at 6:49 PM, Andy Fleming wrote:
On Thu, Nov 29, 2012 at 1:34 AM, Pantelis Antoniou panto@antoniou-consulting.com wrote: When using MMC commands for dfu there is considerable noise. Suppress mmc messages when mmcsilent is set.
No there is not. It's just what was there and the messages were irritating. I would prefer a software interface TBH.
Andy
Regards
-- Pantelis
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 11/28/12 11:50, Pantelis Antoniou wrote:
Hi Andy,
I'm trying to recall. Part of the issue was that, I believe, there wasn't an easy software interface to all of the MMC commands that we needed to use here. It might however have boiled down to as a future clean-up, abstract things so that cmd_mmc and cmd_dfu could make use of the same lower level code.
- -- Tom
Andy Fleming
Pantelis Antoniou
