[U-Boot-Users] [PATCH 22/30] Update README.* to reference new CONFIG_CMD_* names now.
Signed-off-by: Jon Loeliger jdl@freescale.com --- doc/README.SNTP | 4 ++-- doc/README.bedbug | 7 ------- doc/README.nand | 4 ++-- 3 files changed, 4 insertions(+), 11 deletions(-)
diff --git a/doc/README.SNTP b/doc/README.SNTP index fd6f209..9edc957 100644 --- a/doc/README.SNTP +++ b/doc/README.SNTP @@ -1,5 +1,5 @@ -To use SNTP support, add a define CFG_CMD_SNTP to CONFIG_COMMANDS in -the configuration file of the board. +To use SNTP support, add define CONFIG_CMD_SNTP to the +configuration file of the board.
The "sntp" command gets network time from NTP time server and syncronize RTC of the board. This command needs the command line diff --git a/doc/README.bedbug b/doc/README.bedbug index 6b3fe68..2616acc 100644 --- a/doc/README.bedbug +++ b/doc/README.bedbug @@ -31,9 +31,6 @@ can be easily implemented. if it is an illegal instruction, privileged instruction or a trap. Also added debug trap handler.
-./include/config_WALNUT405.h - Added CFG_CMD_BEDBUG to the CONFIG_COMMANDS for the WALNUT. - ./include/ppc_asm.tmpl Added code to handle critical exceptions
@@ -75,10 +72,6 @@ Changes: cpu/mpc8xx/traps.c Added new routine DebugException()
- include/config_MBX.h - Added CFG_CMD_BEDBUG to CONFIG_COMMANDS define - - New Files:
cpu/mpc8xx/bedbug_860.c diff --git a/doc/README.nand b/doc/README.nand index 5c31845..c5c5ef2 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -93,8 +93,8 @@ Commands:
Configuration Options:
- CFG_CMD_NAND - A good one to add to CONFIG_COMMANDS since it enables NAND support. + CONFIG_CMD_NAND + Enables NAND support and commmands.
CONFIG_MTD_NAND_ECC_JFFS2 Define this if you want the Error Correction Code information in
Jon Loeliger
