[U-Boot] [PATCH 0/2] configs: Minor fixes
Hei hei,
two small patches. One is some missing piece in a defconfig for Microchip SAMA5D27-SOM1-EK1 board. The other one is something I stumbled over by accident.
Greets Alex
Alexander Dahl (2): configs: Remove version control leftovers configs: sama5d27_som1_ek: Activate misc init for uSD variant
configs/kylin-rk3036_defconfig.rej | 10 ---------- configs/puma-rk3399_defconfig.rej | 10 ---------- configs/sama5d27_som1_ek_mmc1_defconfig | 1 + 3 files changed, 1 insertion(+), 20 deletions(-) delete mode 100644 configs/kylin-rk3036_defconfig.rej delete mode 100644 configs/puma-rk3399_defconfig.rej
I assume those should not have been committed in the first place?
Fixes: 2ec3d25f8faab51c2334174a582a96ad28d96344 Signed-off-by: Alexander Dahl ada@thorsis.com --- configs/kylin-rk3036_defconfig.rej | 10 ---------- configs/puma-rk3399_defconfig.rej | 10 ---------- 2 files changed, 20 deletions(-) delete mode 100644 configs/kylin-rk3036_defconfig.rej delete mode 100644 configs/puma-rk3399_defconfig.rej
diff --git a/configs/kylin-rk3036_defconfig.rej b/configs/kylin-rk3036_defconfig.rej deleted file mode 100644 index 5478e65f1a..0000000000 --- a/configs/kylin-rk3036_defconfig.rej +++ /dev/null @@ -1,10 +0,0 @@ ---- configs/kylin-rk3036_defconfig -+++ configs/kylin-rk3036_defconfig -@@ -8,6 +8,7 @@ CONFIG_ROCKCHIP_RK3036=y - CONFIG_TARGET_KYLIN_RK3036=y - CONFIG_SPL_STACK_R_ADDR=0x80000 - CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" -+CONFIG_DEBUG_UART=y - CONFIG_SPL_SYS_MALLOC_F_LEN=0x0 - # CONFIG_ANDROID_BOOT_IMAGE is not set - # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/puma-rk3399_defconfig.rej b/configs/puma-rk3399_defconfig.rej deleted file mode 100644 index 78a1819b5f..0000000000 --- a/configs/puma-rk3399_defconfig.rej +++ /dev/null @@ -1,10 +0,0 @@ ---- configs/puma-rk3399_defconfig -+++ configs/puma-rk3399_defconfig -@@ -74,7 +74,6 @@ CONFIG_ETH_DESIGNWARE=y - CONFIG_GMAC_ROCKCHIP=y - CONFIG_PINCTRL=y - CONFIG_SPL_PINCTRL=y --CONFIG_PINCTRL_ROCKCHIP_RK3399=y - CONFIG_DM_PMIC=y - CONFIG_DM_PMIC_FAN53555=y - CONFIG_PMIC_RK8XX=y
Alexander,
there’s a PR for this open already: https://patchwork.ozlabs.org/patch/1036561/
Sorry for the inconvenience. Philipp.
- CONFIG_PINCTRL=y
- CONFIG_DM_PMIC=y
-- 2.11.0
This was already set for 'sama5d27_som1_ek_mmc_defconfig' (first SD card, full size). Without this option set, the MAC address is not read from the I²C EEPROM at boot, and remains unset:
U-Boot 2019.01 (Jan 01 2019 - 00:00:00 +0000)
CPU: SAMA5D27 1G bits DDR2 SDRAM Crystal frequency: 24 MHz CPU clock : 492 MHz Master clock : 164 MHz DRAM: 128 MiB MMC: sdio-host@a0000000: 0, sdio-host@b0000000: 1 Loading Environment from FAT... OK In: serial Out: serial Err: serial Net: Error: ethernet@f8008000 address not set. eth-1: ethernet@f8008000 Hit any key to stop autoboot: 0
Signed-off-by: Alexander Dahl ada@thorsis.com --- configs/sama5d27_som1_ek_mmc1_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 5f4abe8605..9ba8d79e31 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -23,6 +23,7 @@ CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk root=/dev/mmcblk1p2 rw rootwait" +CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL_SEPARATE_BSS=y CONFIG_HUSH_PARSER=y
U-Boot 2019.01 (Jan 01 2019 - 00:00:00 +0000) CPU: SAMA5D27 1G bits DDR2 SDRAM Crystal frequency: 24 MHz CPU clock : 492 MHz Master clock : 164 MHz DRAM: 128 MiB MMC: sdio-host@a0000000: 0, sdio-host@b0000000: 1 Loading Environment from FAT... OK In: serial Out: serial Err: serial Net: Error: ethernet@f8008000 address not set. eth-1: ethernet@f8008000 Hit any key to stop autoboot: 0
Applied to u-boot-atmel/master Thanks !
Alexander Dahl
Eugen.Hristev@microchip.com
Philipp Tomsich
