[PULL] u-boot-sh/master
This is long overdue PR for current release with a few clean ups for the RZG2
The following changes since commit a1c01b17c59ec03c678073e145fbd094c7606dc8:
Merge tag 'efi-2022-01-rc4-2' of https://source.denx.de/u-boot/custodians/u-boot-efi (2021-12-10 07:58:43 -0500)
git://source.denx.de/u-boot-sh.git master
for you to fetch changes up to d5f1beb058a48fb057d3a62dc751a19c1a3db279:
configs: beacon-rzg2m: Config to address new aliases (2021-12-13 00:37:28 +0100)
---------------------------------------------------------------- Adam Ford (5): net: ravb: Support multiple clocks arm: dts: beacon-rzg2: Resync device trees with Linux 5.16-rc3 arm: dts: Create common rz-g2-beacon-u-boot file ARM: rmobile: Fix rzg2_beacon_defconfig to address new aliases configs: beacon-rzg2m: Config to address new aliases
arch/arm/dts/beacon-renesom-baseboard.dtsi | 16 ++++++++++++---- arch/arm/dts/beacon-renesom-som.dtsi | 45 +++++++++++---------------------------------- arch/arm/dts/r8a774a1-beacon-rzg2m-kit-u-boot.dtsi | 32 ++------------------------------ arch/arm/dts/r8a774a1-beacon-rzg2m-kit.dts | 3 +++ arch/arm/dts/r8a774b1-beacon-rzg2n-kit-u-boot.dtsi | 32 ++------------------------------ arch/arm/dts/r8a774b1-beacon-rzg2n-kit.dts | 3 +++ arch/arm/dts/r8a774e1-beacon-rzg2h-kit-u-boot.dtsi | 42 ++---------------------------------------- arch/arm/dts/r8a774e1-beacon-rzg2h-kit.dts | 3 +++ arch/arm/dts/rz-g2-beacon-u-boot.dtsi | 75 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/beacon/beacon-rzg2m/MAINTAINERS | 10 ++++++++++ configs/rzg2_beacon_defconfig | 1 - drivers/net/ravb.c | 10 +++++----- include/configs/beacon-rzg2m.h | 2 +- 13 files changed, 129 insertions(+), 145 deletions(-) create mode 100644 arch/arm/dts/rz-g2-beacon-u-boot.dtsi
