[U-Boot] [PATCH] ls2-2085a: Increase default hugepage count
* Increase default hugepage count to 256 from 16 * Note: default env variables are stored at 0x580200000/0x584200000 of size 0x2000
Signed-off-by: Ashish Kumar Ashish.Kumar@freescale.com --- include/configs/ls2080a_common.h | 2 +- include/configs/ls2080ardb.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 4ae7d11..a503934 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -272,7 +272,7 @@ unsigned long long get_qixis_addr(void); #define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ "earlycon=uart8250,mmio,0x21c0500" \ "ramdisk_size=0x2000000 default_hugepagesz=2m" \ - " hugepagesz=2m hugepages=16" + " hugepagesz=2m hugepages=256" #define CONFIG_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ "$kernel_size && bootm $kernel_load" #define CONFIG_BOOTDELAY 10 diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 116dbcd..356d254 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -333,7 +333,7 @@ unsigned long get_board_sys_clk(void); #define CONFIG_BOOTARGS "console=ttyS1,115200 root=/dev/ram0 " \ "earlycon=uart8250,mmio,0x21c0600" \ "ramdisk_size=0x2000000 default_hugepagesz=2m" \ - " hugepagesz=2m hugepages=16" + " hugepagesz=2m hugepages=256"
/* MAC/PHY configuration */ #ifdef CONFIG_FSL_MC_ENET
Signed-off-by: Ashish Kumar Ashish.Kumar@freescale.com --- arch/arm/dts/fsl-ls2080a-rdb.dts | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/dts/fsl-ls2080a-rdb.dts b/arch/arm/dts/fsl-ls2080a-rdb.dts index 1a1813b..71d1969 100644 --- a/arch/arm/dts/fsl-ls2080a-rdb.dts +++ b/arch/arm/dts/fsl-ls2080a-rdb.dts @@ -11,7 +11,7 @@ #include "fsl-ls2080a.dtsi"
/ { - model = "Freescale Layerscape 2080a RDB Board"; + model = "Freescale Layerscape 2085a RDB Board"; compatible = "fsl,ls2080a-rdb", "fsl,ls2080a";
aliases {
aliases {
Ashish,
Why change this? This product has been renamed to LS2080A.
York
-----Original Message----- From: york sun [mailto:york.sun@nxp.com] Sent: Thursday, January 14, 2016 10:36 PM To: Ashish Kumar Ashish.Kumar@freescale.com; u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar@freescale.com Subject: Re: [PATCH] ls2-2085ardb: Correct the model name of ls2085ardb
rdb.dts
aliases {
Ashish,
LS2085ARDB is a platform/board hosting LS2080A, LS2085A and LS2088A.
This is the reason board name is being updated.
--prabhakar
rdb.dts
aliases {
Ashish,
Prabhakar,
You changed the name from LS2085A to LS2080A not long ago, including the board LS2085ARDB, stating LS2080A is the prime personality. Now you want to change it back? You have to give a good reason.
York
-----Original Message----- From: york sun Sent: Wednesday, January 20, 2016 12:02 AM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Ashish Kumar ashish.kumar@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH] ls2-2085ardb: Correct the model name of ls2085ardb
rdb.dts
aliases {
Ashish,
Prabhakar,
LS2080A and LS2085A name is correct.
Things nail down to platform/board which will host the SoC. LS2085ARDB "board" will host both LS2080A, LS2085A and in future LS2088A. Same name is printed on the board. So to avoid confusion board name has been updated.
looks like v2 of this patch is required, as in board/Freescale/ls2080rdb.c board name is printed as per SoC name with suffix of QDS or RDB.
--prabhakar
- Increase default hugepage count to 256 from 16
- Note: default env variables are stored at 0x580200000/0x584200000 of size 0x2000
Ashish,
What does the default env location have anything to do with this patch?
York
Hello York,
It is like a heads-up, that user needs to erase the environment variable location before flashing a new uboot for the changes to reflect.
Regards Ashish
-----Original Message----- From: york sun [mailto:york.sun@nxp.com] Sent: Monday, February 01, 2016 10:17 PM To: Ashish Kumar Ashish.Kumar@freescale.com; u-boot@lists.denx.de Subject: Re: [PATCH] ls2-2085a: Increase default hugepage count
Ashish,
York
On 02/01/2016 10:09 PM, Ashish Kumar wrote:
Hello York,
You are changing default environmental variables. It is up to the users to set correct variables. I don't believe the note clarifies anything in the context of this patch. You don't need to send an update if you agree. I can drop the note when merging the patch.
York
Regards Ashish
Ashish,
York
Agree, Please drop this while merging.
Regards Ashish
-----Original Message----- From: york sun Sent: Tuesday, February 02, 2016 11:50 AM To: Ashish Kumar ashish.kumar@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH] ls2-2085a: Increase default hugepage count
Hello York,
York
Regards Ashish
Ashish,
York
Dropped the note of default env. Applied to fsl-qoriq master. Awaiting upstream.
York
Ashish Kumar
Ashish Kumar
Prabhakar Kushwaha
york sun
