[U-Boot] [PATCH v2 0/7] Add support for NVIDIA Tegra30 SoC
This patch series adds basic (boot to cmd prompt) support for Tegra30. This is based on the Tegra20 SPL, which initializes the AVP (ARM7TDMI) boot proc) first, then control is transferred to the CPU (A9 quad cluster). It is based on current u-boot-tegra/next. Some Tegra20 files were changed or moved to enable use of common code/headers.
Future patches will add support/drivers for MMC, USB, I2C, SPI, NAND and other peripherals. The Cardhu T30 boards is supported initially.
Tom Warren (7): Tegra30: Add arch-tegra30 include files Tegra30: Add AVP (arm720t) files Tegra30: Add CPU (armv7) files Tegra30: Add common CPU (shared) files Tegra30: Cardhu: Add DT files Tegra30: Add generic Tegra30 build support Tegra30: Add/enable Cardhu build (T30 reference board)
Makefile | 6 +- arch/arm/cpu/arm720t/tegra-common/Makefile | 1 + arch/arm/cpu/arm720t/tegra-common/cpu.c | 342 +++++++ arch/arm/cpu/arm720t/tegra-common/cpu.h | 64 +- arch/arm/cpu/arm720t/tegra-common/spl.c | 3 +- arch/arm/cpu/arm720t/tegra20/cpu.c | 216 +---- arch/arm/cpu/arm720t/tegra30/Makefile | 41 + arch/arm/cpu/arm720t/tegra30/config.mk | 19 + arch/arm/cpu/arm720t/tegra30/cpu.c | 176 ++++ arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/start.S | 4 +- arch/arm/cpu/armv7/tegra30/Makefile | 40 + arch/arm/cpu/armv7/tegra30/config.mk | 19 + arch/arm/cpu/tegra-common/ap.c | 22 +- arch/arm/cpu/tegra-common/board.c | 41 +- arch/arm/cpu/tegra-common/sys_info.c | 5 +- arch/arm/cpu/tegra20-common/warmboot.c | 2 +- arch/arm/cpu/tegra30-common/Makefile | 44 + arch/arm/cpu/tegra30-common/clock.c | 1092 ++++++++++++++++++++++ arch/arm/cpu/tegra30-common/funcmux.c | 57 ++ arch/arm/cpu/tegra30-common/pinmux.c | 506 ++++++++++ arch/arm/dts/tegra30.dtsi | 6 + arch/arm/include/asm/arch-tegra/ap.h | 50 +- arch/arm/include/asm/arch-tegra/clk_rst.h | 148 +++- arch/arm/include/asm/arch-tegra/clock.h | 8 +- arch/arm/include/asm/arch-tegra/funcmux.h | 39 + arch/arm/include/asm/arch-tegra/gp_padctrl.h | 39 + arch/arm/include/asm/arch-tegra/tegra.h | 13 +- arch/arm/include/asm/arch-tegra20/funcmux.h | 26 +- arch/arm/include/asm/arch-tegra20/gp_padctrl.h | 17 +- arch/arm/include/asm/arch-tegra30/clock-tables.h | 378 ++++++++ arch/arm/include/asm/arch-tegra30/clock.h | 24 + arch/arm/include/asm/arch-tegra30/flow.h | 35 + arch/arm/include/asm/arch-tegra30/funcmux.h | 31 + arch/arm/include/asm/arch-tegra30/gp_padctrl.h | 59 ++ arch/arm/include/asm/arch-tegra30/gpio.h | 304 ++++++ arch/arm/include/asm/arch-tegra30/hardware.h | 22 + arch/arm/include/asm/arch-tegra30/pinmux.h | 604 ++++++++++++ arch/arm/include/asm/arch-tegra30/pmu.h | 23 + arch/arm/include/asm/arch-tegra30/spl.h | 28 + arch/arm/include/asm/arch-tegra30/tegra.h | 26 + board/nvidia/cardhu/Makefile | 44 + board/nvidia/cardhu/cardhu.c | 39 + board/nvidia/cardhu/pinmux-config-cardhu.h | 339 +++++++ board/nvidia/common/board.c | 17 +- board/nvidia/dts/tegra30-cardhu.dts | 14 + boards.cfg | 1 + include/configs/cardhu.h | 52 + include/configs/tegra-common.h | 163 ++++ include/configs/tegra20-common.h | 171 +--- include/configs/tegra30-common.h | 54 ++ include/serial.h | 2 +- spl/Makefile | 2 +- 53 files changed, 4973 insertions(+), 507 deletions(-) create mode 100644 arch/arm/cpu/arm720t/tegra-common/cpu.c create mode 100644 arch/arm/cpu/arm720t/tegra30/Makefile create mode 100644 arch/arm/cpu/arm720t/tegra30/config.mk create mode 100644 arch/arm/cpu/arm720t/tegra30/cpu.c create mode 100644 arch/arm/cpu/armv7/tegra30/Makefile create mode 100644 arch/arm/cpu/armv7/tegra30/config.mk create mode 100644 arch/arm/cpu/tegra30-common/Makefile create mode 100644 arch/arm/cpu/tegra30-common/clock.c create mode 100644 arch/arm/cpu/tegra30-common/funcmux.c create mode 100644 arch/arm/cpu/tegra30-common/pinmux.c create mode 100644 arch/arm/dts/tegra30.dtsi create mode 100644 arch/arm/include/asm/arch-tegra/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra30/clock-tables.h create mode 100644 arch/arm/include/asm/arch-tegra30/clock.h create mode 100644 arch/arm/include/asm/arch-tegra30/flow.h create mode 100644 arch/arm/include/asm/arch-tegra30/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra30/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra30/gpio.h create mode 100644 arch/arm/include/asm/arch-tegra30/hardware.h create mode 100644 arch/arm/include/asm/arch-tegra30/pinmux.h create mode 100644 arch/arm/include/asm/arch-tegra30/pmu.h create mode 100644 arch/arm/include/asm/arch-tegra30/spl.h create mode 100644 arch/arm/include/asm/arch-tegra30/tegra.h create mode 100644 board/nvidia/cardhu/Makefile create mode 100644 board/nvidia/cardhu/cardhu.c create mode 100644 board/nvidia/cardhu/pinmux-config-cardhu.h create mode 100644 board/nvidia/dts/tegra30-cardhu.dts create mode 100644 include/configs/cardhu.h create mode 100644 include/configs/tegra-common.h create mode 100644 include/configs/tegra30-common.h
Sorry - hit send too soon. A couple of minor edits and I'll resend.
-----Original Message----- From: Tom Warren [mailto:twarren.nvidia@gmail.com] Sent: Monday, December 03, 2012 3:18 PM To: u-boot@lists.denx.de Cc: twarren.nvidia@gmail.com; sjg@chromium.org; Stephen Warren; albert.u.boot@aribaud.net; wd@denx.de; Tom Warren Subject: [PATCH v2 0/7] Add support for NVIDIA Tegra30 SoC
Makefile | 6 +- arch/arm/cpu/arm720t/tegra-common/Makefile | 1 + arch/arm/cpu/arm720t/tegra-common/cpu.c | 342 +++++++ arch/arm/cpu/arm720t/tegra-common/cpu.h | 64 +- arch/arm/cpu/arm720t/tegra-common/spl.c | 3 +- arch/arm/cpu/arm720t/tegra20/cpu.c | 216 +---- arch/arm/cpu/arm720t/tegra30/Makefile | 41 + arch/arm/cpu/arm720t/tegra30/config.mk | 19 + arch/arm/cpu/arm720t/tegra30/cpu.c | 176 ++++ arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/start.S | 4 +- arch/arm/cpu/armv7/tegra30/Makefile | 40 + arch/arm/cpu/armv7/tegra30/config.mk | 19 + arch/arm/cpu/tegra-common/ap.c | 22 +- arch/arm/cpu/tegra-common/board.c | 41 +- arch/arm/cpu/tegra-common/sys_info.c | 5 +- arch/arm/cpu/tegra20-common/warmboot.c | 2 +- arch/arm/cpu/tegra30-common/Makefile | 44 + arch/arm/cpu/tegra30-common/clock.c | 1092 ++++++++++++++++++++++ arch/arm/cpu/tegra30-common/funcmux.c | 57 ++ arch/arm/cpu/tegra30-common/pinmux.c | 506 ++++++++++ arch/arm/dts/tegra30.dtsi | 6 + arch/arm/include/asm/arch-tegra/ap.h | 50 +- arch/arm/include/asm/arch-tegra/clk_rst.h | 148 +++- arch/arm/include/asm/arch-tegra/clock.h | 8 +- arch/arm/include/asm/arch-tegra/funcmux.h | 39 + arch/arm/include/asm/arch-tegra/gp_padctrl.h | 39 + arch/arm/include/asm/arch-tegra/tegra.h | 13 +- arch/arm/include/asm/arch-tegra20/funcmux.h | 26 +- arch/arm/include/asm/arch-tegra20/gp_padctrl.h | 17 +- arch/arm/include/asm/arch-tegra30/clock-tables.h | 378 ++++++++ arch/arm/include/asm/arch-tegra30/clock.h | 24 + arch/arm/include/asm/arch-tegra30/flow.h | 35 + arch/arm/include/asm/arch-tegra30/funcmux.h | 31 + arch/arm/include/asm/arch-tegra30/gp_padctrl.h | 59 ++ arch/arm/include/asm/arch-tegra30/gpio.h | 304 ++++++ arch/arm/include/asm/arch-tegra30/hardware.h | 22 + arch/arm/include/asm/arch-tegra30/pinmux.h | 604 ++++++++++++ arch/arm/include/asm/arch-tegra30/pmu.h | 23 + arch/arm/include/asm/arch-tegra30/spl.h | 28 + arch/arm/include/asm/arch-tegra30/tegra.h | 26 + board/nvidia/cardhu/Makefile | 44 + board/nvidia/cardhu/cardhu.c | 39 + board/nvidia/cardhu/pinmux-config-cardhu.h | 339 +++++++ board/nvidia/common/board.c | 17 +- board/nvidia/dts/tegra30-cardhu.dts | 14 + boards.cfg | 1 + include/configs/cardhu.h | 52 + include/configs/tegra-common.h | 163 ++++ include/configs/tegra20-common.h | 171 +--- include/configs/tegra30-common.h | 54 ++ include/serial.h | 2 +- spl/Makefile | 2 +- 53 files changed, 4973 insertions(+), 507 deletions(-) create mode 100644 arch/arm/cpu/arm720t/tegra-common/cpu.c create mode 100644 arch/arm/cpu/arm720t/tegra30/Makefile create mode 100644 arch/arm/cpu/arm720t/tegra30/config.mk create mode 100644 arch/arm/cpu/arm720t/tegra30/cpu.c create mode 100644 arch/arm/cpu/armv7/tegra30/Makefile create mode 100644 arch/arm/cpu/armv7/tegra30/config.mk create mode 100644 arch/arm/cpu/tegra30-common/Makefile create mode 100644 arch/arm/cpu/tegra30-common/clock.c create mode 100644 arch/arm/cpu/tegra30-common/funcmux.c create mode 100644 arch/arm/cpu/tegra30-common/pinmux.c create mode 100644 arch/arm/dts/tegra30.dtsi create mode 100644 arch/arm/include/asm/arch-tegra/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra30/clock-tables.h create mode 100644 arch/arm/include/asm/arch-tegra30/clock.h create mode 100644 arch/arm/include/asm/arch-tegra30/flow.h create mode 100644 arch/arm/include/asm/arch-tegra30/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra30/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra30/gpio.h create mode 100644 arch/arm/include/asm/arch-tegra30/hardware.h create mode 100644 arch/arm/include/asm/arch-tegra30/pinmux.h create mode 100644 arch/arm/include/asm/arch-tegra30/pmu.h create mode 100644 arch/arm/include/asm/arch-tegra30/spl.h create mode 100644 arch/arm/include/asm/arch-tegra30/tegra.h create mode 100644 board/nvidia/cardhu/Makefile create mode 100644 board/nvidia/cardhu/cardhu.c create mode 100644 board/nvidia/cardhu/pinmux- config-cardhu.h create mode 100644 board/nvidia/dts/tegra30-cardhu.dts create mode 100644 include/configs/cardhu.h create mode 100644 include/configs/tegra-common.h create mode 100644 include/configs/tegra30- common.h
-- nvpublic
Tom Warren
Tom Warren
