[PATCH v2 0/2] EFI: Reset system after capsule-on-disk
Here is the 3rd version of the reset after capsule-on-disk. This version updates the patch description and use do_reset() and halt or reset_cpu() if available, according to Takahiro and Sughosh's comment.
The reset after completing the capsule-on-disk is stated in the UEFI specification 2.9, section 8.5.5 "Delivery of Capsules via file on Mass Storage device" as below,
In all cases that a capsule is identified for processing the system is restarted after capsule processing is completed.
Thank you,
Masami Hiramatsu (2): efi_loader: use efi_update_capsule_firmware() for capsule on disk efi_loader: Reset system after CapsuleUpdate on disk
lib/efi_loader/efi_capsule.c | 24 +++++++++++++++++++++--- 1 file changed, 21 insertions(+), 3 deletions(-)
-- Masami Hiramatsu masami.hiramatsu@linaro.org
Since the efi_update_capsule() represents the UpdateCapsule() runtime service, it has to handle the capsule flags and update ESRT. However, the capsule-on-disk doesn't need to care about such things. Thus, the capsule-on-disk should use the efi_capsule_update_firmware() directly instead of calling efi_update_capsule(). This means the roles of the efi_update_capsule() and capsule-on-disk are different. We have to keep the efi_update_capsule() for providing runtime service at boot time.
Suggested-by: AKASHI Takahiro takahiro.akashi@linaro.org Signed-off-by: Masami Hiramatsu masami.hiramatsu@linaro.org --- Changes in v3: - Update patch description. Changes in v2: - Fix to pass correct pointer to efi_capsule_update_firmware - Remove ESRT generation, because this part anyway will be removed next patch. --- lib/efi_loader/efi_capsule.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index 4463ae00fd..1ec7ea29ff 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -1118,7 +1118,7 @@ efi_status_t efi_launch_capsules(void) index = 0; ret = efi_capsule_read_file(files[i], &capsule); if (ret == EFI_SUCCESS) { - ret = EFI_CALL(efi_update_capsule(&capsule, 1, 0)); + ret = efi_capsule_update_firmware(capsule); if (ret != EFI_SUCCESS) log_err("Applying capsule %ls failed\n", files[i]);
Add a config option to reset system soon after processing capsule update on disk. This is required in UEFI specification 2.9 Section 8.5.5 "Delivery of Capsules via file on Mass Storage device" as;
This also reports the result of each capsule update so that the user can notice that the capsule update has been succeeded or not from console log.
Signed-off-by: Masami Hiramatsu masami.hiramatsu@linaro.org --- Changes in v3: - Log succeeded capsule update in info level. - Use sysreset if possible. - Use do_reset() and hang() instead of panic(). Changes in v2: - Remove kconfig option to disable this feature. - Use panic() instead of do_reset() so that if the reset fails, the machine halt. - Log the result of each capsule update always. --- lib/efi_loader/efi_capsule.c | 22 ++++++++++++++++++++-- 1 file changed, 20 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index 1ec7ea29ff..ade9155042 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -14,9 +14,11 @@ #include <env.h> #include <fdtdec.h> #include <fs.h> +#include <hang.h> #include <malloc.h> #include <mapmem.h> #include <sort.h> +#include <sysreset.h> #include <asm/global_data.h>
#include <crypto/pkcs7.h> @@ -1120,8 +1122,11 @@ efi_status_t efi_launch_capsules(void) if (ret == EFI_SUCCESS) { ret = efi_capsule_update_firmware(capsule); if (ret != EFI_SUCCESS) - log_err("Applying capsule %ls failed\n", + log_err("Applying capsule %ls failed.\n", files[i]); + else + log_info("Applying capsule %ls succeeded.\n", + files[i]);
/* create CapsuleXXXX */ set_capsule_result(index, capsule, ret); @@ -1142,6 +1147,19 @@ efi_status_t efi_launch_capsules(void) free(files[i]); free(files);
- return ret; + /* + * UEFI spec requires to reset system after complete processing capsule + * update on the storage. + */ + puts("Reboot after firmware update"); + if (CONFIG_IS_ENABLED(SYSRESET)) { + reset_cpu(); + } else { + do_reset(NULL, 0, 0, NULL); + hang(); + } + /* not reach here */ + + return 0; } #endif /* CONFIG_EFI_CAPSULE_ON_DISK */
We no longer have a new config option :)
Changes in v3:
Changes in v2:
else
files[i]); /* create CapsuleXXXX */ set_capsule_result(index, capsule, ret);
- return ret;
- puts("Reboot after firmware update");
- if (CONFIG_IS_ENABLED(SYSRESET)) {
reset_cpu();
- } else {
hang();
- /* not reach here */
Despite the code that I proposed, I have a few concerns: 1) warm or cold reset Now that we are updating firmware, we may have to initiate a cold reset in some cases. (That's why I used 'sysreset(WARM)' to raise a question.)
From the viewpoint of UEFI specification,
* A type of reset can be determined per capsule by calling QueryCapsuleCapabilities API. (The spec said, "Returns if the capsule can be supported via UpdateCapsule()" and Capsule-on-disk might be out of scope?) * There exists ResetSystem API and it takes a *reset type* as a parameter.
2) ResetSystem at boot time So we may want to internally make use of efi_reset_system() following capsule-on-disk processing. The current implementation, however, does not utilize SYSRESET drivers, but call do_reset(). This should be changed (as I suggested above?).
-Takahiro Akashi
Hi Takahiro,
2022年2月3日(木) 10:24 AKASHI Takahiro takahiro.akashi@linaro.org:
Oops, that's my fault.
Changes in v3:
Changes in v2:
else
return ret;
reset_cpu();
} else {
hang();
- warm or cold reset
Indeed. Hm, as far as I can see the EDK2, it also uses cold reset. (HandleCapsules@ArmPkg/Library/PlatformBootManagerLib/PlatformBM.c) Since do_reset() calls sysreset_walk_halt(), I think do_reset() is enough.
- A type of reset can be determined per capsule by calling QueryCapsuleCapabilities API. (The spec said, "Returns if the capsule can be supported via UpdateCapsule()" and Capsule-on-disk might be out of scope?)
I think that is only for UpdateCapsule(), as far as I can read the EDK2 code.
- There exists ResetSystem API and it takes a *reset type* as a parameter.
This API is independent from UpdateCapsule(). But while executing the UpdateCapsule() this API is prohibited. (See Table 8-1)
- ResetSystem at boot time
As I said above, I think it should always be a cold reset and not need to use efi_reset_system(). For the UpdateCapsule(), there is a reason to use warm reset, because the capsule images which will be applied after reset, will be on the memory. In this case the system must be reboot without resetting the memory. But after capsule-on-disk process, all capsule images are applied and the firmware image on the storage is updated. So it is better to reset the system with cold reset so that the new firmware image can start with cleaned memory and devices.
Thank you,
-Takahiro Akashi
Hi Takahiro,
We forgot a simple fact. The warm reset doesn't load the new firmware from media.
If this reset is for reloading the new firmware, we anyway need the cold reset :-) (and I can't think of any reason other than this)
Thank you,
2022年2月3日(木) 13:34 Masami Hiramatsu masami.hiramatsu@linaro.org:
Hi Takahiro,
Changes in v3:
Changes in v2:
else
return ret;
reset_cpu();
} else {
hang();
Thank you,
-Takahiro Akashi
-- Masami Hiramatsu
AKASHI Takahiro
Masami Hiramatsu
