[PATCH v3] binman: Get futility by building it
A binary download is not great, since it depends on libraries being present in the system. Build futility from source instead.
Changes in v3: - Drop the branch, just use master instead - Explain why we are using a mirror - Drop mention of upstream patches as they are applied
Changes in v2: - Pull from github instead, to avoid needing to login / gitcookies
tools/binman/bintool.py | 10 +++++++--- tools/binman/btool/futility.py | 17 +++++++++++++---- 2 files changed, 20 insertions(+), 7 deletions(-)
diff --git a/tools/binman/bintool.py b/tools/binman/bintool.py index 032179a99de..a582d9d3446 100644 --- a/tools/binman/bintool.py +++ b/tools/binman/bintool.py @@ -319,7 +319,7 @@ class Bintool: return result.stdout
@classmethod - def build_from_git(cls, git_repo, make_target, bintool_path): + def build_from_git(cls, git_repo, make_target, bintool_path, flags=None): """Build a bintool from a git repo
This clones the repo in a temporary directory, builds it with 'make', @@ -330,6 +330,7 @@ class Bintool: make_target (str): Target to pass to 'make' to build the tool bintool_path (str): Relative path of the tool in the repo, after build is complete + flags (list of str): Flags or variables to pass to make, or None
Returns: tuple: @@ -341,8 +342,11 @@ class Bintool: print(f"- clone git repo '{git_repo}' to '{tmpdir}'") tools.run('git', 'clone', '--depth', '1', git_repo, tmpdir) print(f"- build target '{make_target}'") - tools.run('make', '-C', tmpdir, '-j', f'{multiprocessing.cpu_count()}', - make_target) + cmd = ['make', '-C', tmpdir, '-j', f'{multiprocessing.cpu_count()}', + make_target] + if flags: + cmd += flags + tools.run(*cmd) fname = os.path.join(tmpdir, bintool_path) if not os.path.exists(fname): print(f"- File '{fname}' was not produced") diff --git a/tools/binman/btool/futility.py b/tools/binman/btool/futility.py index 75a05c2ac66..04c9aefe9b4 100644 --- a/tools/binman/btool/futility.py +++ b/tools/binman/btool/futility.py @@ -160,8 +160,17 @@ class Bintoolfutility(bintool.Bintool): Raises: Valuerror: Fetching could not be completed """ - if method != bintool.FETCH_BIN: + if method != bintool.FETCH_BUILD: return None - fname, tmpdir = self.fetch_from_drive( - '1hdsInzsE4aJbmBeJ663kYgjOQyW1I-E0') - return fname, tmpdir + + # The Chromium OS repo is here: + # https://chromium.googlesource.com/chromiumos/platform/vboot_reference/ + # + # Unfortunately this requires logging in and obtaining a line for the + # .gitcookies file. So use a mirror instead. + result = self.build_from_git( + 'https://github.com/sjg20/vboot_reference.git', + 'all', + 'build/futility/futility', + flags=['USE_FLASHROM=0']) + return result
Applied to u-boot-dm, thanks!
Applied to u-boot-dm, thanks! Applied to u-boot-dm, thanks!
