[U-Boot] [PATCH] unit-test: make "test -e" test independent of $CWD
The unit-test for hush's "test -e" currently relies upon being run in the U-Boot build directory, because it tests for the existence of a file that exists in that directory.
Fix this by explicitly creating the file we use for the existence test, and deleting it afterwards so that multiple successive unit-test invocations succeed. This required adding an os.c function to erase files.
Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- arch/sandbox/cpu/os.c | 5 +++++ include/os.h | 8 ++++++++ test/command_ut.c | 14 +++++++++----- 3 files changed, 22 insertions(+), 5 deletions(-)
diff --git a/arch/sandbox/cpu/os.c b/arch/sandbox/cpu/os.c index 2e2fc58..98f565e 100644 --- a/arch/sandbox/cpu/os.c +++ b/arch/sandbox/cpu/os.c @@ -92,6 +92,11 @@ int os_close(int fd) return close(fd); }
+int os_unlink(const char *pathname) +{ + return unlink(pathname); +} + void os_exit(int exit_code) { exit(exit_code); diff --git a/include/os.h b/include/os.h index d6d6e57..fa4e39f 100644 --- a/include/os.h +++ b/include/os.h @@ -84,6 +84,14 @@ int os_open(const char *pathname, int flags); int os_close(int fd);
/** + * Access to the OS unlink() system call + * + * \param pathname Path of file to delete + * \return 0 for success, other for error + */ +int os_unlink(const char *pathname); + +/** * Access to the OS exit() system call * * This exits with the supplied return code, which should be 0 to indicate diff --git a/test/command_ut.c b/test/command_ut.c index b6b6976..aaa1ee2 100644 --- a/test/command_ut.c +++ b/test/command_ut.c @@ -7,6 +7,9 @@ #define DEBUG
#include <common.h> +#ifdef CONFIG_SANDBOX +#include <os.h> +#endif
static const char test_cmd[] = "setenv list 1\n setenv list ${list}2; " "setenv list ${list}3\0" @@ -156,11 +159,12 @@ static int do_ut_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) setenv("ut_var_test", NULL);
#ifdef CONFIG_SANDBOX - /* - * File existence - * This assume U-Boot sandbox is run from the U-Boot build directory - */ - HUSH_TEST(e, "-e host - u-boot", y); + /* File existence */ + HUSH_TEST(e, "-e host - creating_this_file_breaks_uboot_unit_test", n); + run_command("sb save host - creating_this_file_breaks_uboot_unit_test 0 1", 0); + HUSH_TEST(e, "-e host - creating_this_file_breaks_uboot_unit_test", y); + /* Perhaps this could be replaced by an "rm" shell command one day */ + assert(!os_unlink("creating_this_file_breaks_uboot_unit_test")); HUSH_TEST(e, "-e host - creating_this_file_breaks_uboot_unit_test", n); #endif #endif
Stephen Warren
