[PATCH 0/2] add a trailing space to prompt for visionfive2 board
Adds a trailing space to SYS_PROMPT to make it easier to distinguish between commands and the prompt.
Chanho Park (2): configs: visionfive2: add a trailing space to prompt doc: visionfive2: apply a trailing space to the prompt
configs/starfive_visionfive2_defconfig | 2 +- doc/board/starfive/visionfive2.rst | 18 +++++++++--------- 2 files changed, 10 insertions(+), 10 deletions(-)
Signed-off-by: Chanho Park chanho61.park@samsung.com --- configs/starfive_visionfive2_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/starfive_visionfive2_defconfig b/configs/starfive_visionfive2_defconfig index 570a1f53a19b..75b727472da4 100644 --- a/configs/starfive_visionfive2_defconfig +++ b/configs/starfive_visionfive2_defconfig @@ -9,7 +9,7 @@ CONFIG_SF_DEFAULT_SPEED=100000000 CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="jh7110-starfive-visionfive-2" CONFIG_SPL_TEXT_BASE=0x8000000 -CONFIG_SYS_PROMPT="StarFive #" +CONFIG_SYS_PROMPT="StarFive # " CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_SPL_MMC=y
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Apply the trailing space changes in the guide document.
Signed-off-by: Chanho Park chanho61.park@samsung.com --- doc/board/starfive/visionfive2.rst | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/doc/board/starfive/visionfive2.rst b/doc/board/starfive/visionfive2.rst index 951e0d80fb9d..941899a0a4e9 100644 --- a/doc/board/starfive/visionfive2.rst +++ b/doc/board/starfive/visionfive2.rst @@ -206,16 +206,16 @@ Sample boot log from StarFive VisionFive2 board Working FDT set to ff74a340 Hit any key to stop autoboot: 0 StarFive # - StarFive #version + StarFive # version U-Boot 2023.04-rc2-00055-gfc43b9c51a-dirty (Mar 02 2023 - 10:51:39 +0800)
riscv64-buildroot-linux-gnu-gcc.br_real (Buildroot VF2_515_v1.0.0_rc4) 10.3.0 GNU ld (GNU Binutils) 2.36.1 StarFive # - StarFive #mmc dev 1 + StarFive # mmc dev 1 switch to partitions #0, OK mmc1 is current device - StarFive #mmc info + StarFive # mmc info Device: mmc@16020000 Manufacturer ID: 9f OEM: 5449 @@ -229,7 +229,7 @@ Sample boot log from StarFive VisionFive2 board Bus Width: 4-bit Erase Group Size: 512 Bytes StarFive # - StarFive #mmc part + StarFive # mmc part
Partition Map for MMC device 1 -- Partition Type: EFI
@@ -253,7 +253,7 @@ Sample boot log from StarFive VisionFive2 board (data) guid: 539a6df9-4655-4953-8541-733ca36eb1db StarFive # - StarFive #fatls mmc 1:3 + StarFive # fatls mmc 1:3 6429424 Image.gz 717705 u-boot.itb 125437 u-boot-spl.bin.normal.out @@ -262,13 +262,13 @@ Sample boot log from StarFive VisionFive2 board
5 file(s), 0 dir(s)
- StarFive #fatload mmc 1:3 ${kernel_addr_r} Image.gz + StarFive # fatload mmc 1:3 ${kernel_addr_r} Image.gz 6429424 bytes read in 394 ms (15.6 MiB/s) - StarFive #fatload mmc 1:3 ${fdt_addr_r} jh7110-starfive-visionfive-2.dtb + StarFive # fatload mmc 1:3 ${fdt_addr_r} jh7110-starfive-visionfive-2.dtb 11285 bytes read in 5 ms (2.2 MiB/s) - StarFive #fatload mmc 1:3 ${ramdisk_addr_r} initramfs.cpio.gz + StarFive # fatload mmc 1:3 ${ramdisk_addr_r} initramfs.cpio.gz 152848495 bytes read in 9271 ms (15.7 MiB/s) - StarFive #booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} + StarFive # booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} Uncompressing Kernel Image ## Flattened Device Tree blob at 46000000 Booting using the fdt blob at 0x46000000
Chanho Park
Leo Liang
