[U-Boot] [PATCH CFI flash]: Workaround for Numonyx Axcell P33/P30 256-Mbit 65nm bug
Hello Wolfgang & list,
I have "ported" U-boot to a in house made board with Numonyx Axcell P33/P30 256-Mbit 65nm flash chips.
After some time :( searching for bugs in our board or soft, we have discovered that those chips have a small but annoying bug, documented in "Numonyx Axcell P33/P30 256-Mbit Specification Update"
It states : When customer uses [...] block unlock, the block lock status might be altered inadvertently. Lock status might be set to either 01h or 03h unexpectedly (00h as expected data), which leads to program/erase failure on certain blocks.
A working workaround is given, which I have applied and tested with success.
Signed-off-by: Philippe De Muyter phdm@macqel.be
--- drivers/mtd/cfi_flash.c | 27 ++++++++++++++++++++------- 1 files changed, 20 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 3267c5d..0931137 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1347,16 +1347,29 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_STANDARD: - case CFI_CMDSET_INTEL_EXTENDED: - flash_write_cmd (info, sector, 0, - FLASH_CMD_CLEAR_STATUS); - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT); + case CFI_CMDSET_INTEL_EXTENDED: { + unsigned short cmd; + if (prot) - flash_write_cmd (info, sector, 0, - FLASH_CMD_PROTECT_SET); + cmd = FLASH_CMD_PROTECT_SET; else + cmd = FLASH_CMD_PROTECT_CLEAR; + /* see errata + "Numonyx Axcell P33/P30 Specification Update" :) */ + flash_write_cmd (info, sector, 0, FLASH_CMD_READ_ID); + if (!flash_isequal (info, sector, FLASH_OFFSET_PROTECT, + prot)) { + /* cmd must come before 20us after FLASH_CMD_PROTECT */ + /* Disable interrupts which might cause a timeout here */ + int flag = disable_interrupts (); flash_write_cmd (info, sector, 0, - FLASH_CMD_PROTECT_CLEAR); + FLASH_CMD_PROTECT); + flash_write_cmd (info, sector, 0, cmd); + /* re-enable interrupts if necessary */ + if (flag) + enable_interrupts (); + } + } break; case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD:
Dear Philippe De Muyter,
You might want to put the CFI custodian on Cc:
Heh ;-)
unsigned short cmd;
if (prot)
/* see errata
Incorrect multiline comment style.
prot)) {
And please move the declaration above the comment.
FLASH_CMD_PROTECT);
if (flag)
Incorrect indentation.
This is a revised patch, with comments and indentation fixed, I hope.
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 3267c5d..4bf0807 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1347,17 +1347,34 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) switch (info->vendor) { case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_STANDARD: - case CFI_CMDSET_INTEL_EXTENDED: - flash_write_cmd (info, sector, 0, - FLASH_CMD_CLEAR_STATUS); - flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT); + case CFI_CMDSET_INTEL_EXTENDED: { + unsigned short cmd; + if (prot) - flash_write_cmd (info, sector, 0, - FLASH_CMD_PROTECT_SET); + cmd = FLASH_CMD_PROTECT_SET; else + cmd = FLASH_CMD_PROTECT_CLEAR; + /* + * see errata called + * "Numonyx Axcell P33/P30 Specification Update" :) + */ + flash_write_cmd (info, sector, 0, FLASH_CMD_READ_ID); + if (!flash_isequal (info, sector, FLASH_OFFSET_PROTECT, + prot)) { + int flag = disable_interrupts (); + /* + * cmd must come before FLASH_CMD_PROTECT + 20us + * Disable interrupts which might cause a timeout here. + */ flash_write_cmd (info, sector, 0, - FLASH_CMD_PROTECT_CLEAR); + FLASH_CMD_PROTECT); + flash_write_cmd (info, sector, 0, cmd); + /* re-enable interrupts if necessary */ + if (flag) + enable_interrupts (); + } break; + } case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD: /* U-Boot only checks the first byte */
Dear Stefan,
I didn't see comments from you?
Dear Stefan,
Doesn't the Linux kernel need the same fix? Would be great if you(Philippe) could provide one. I too have such chips but I have never seen this problem so I guess I have been lucky so far :)
Jocke
Hello Joakim,
On Mon, Aug 09, 2010 at 10:32:25AM +0200, Joakim Tjernlund wrote:
Dear Stefan,
Jocke
I use linux on those boards, of course, so I also thought that I'd need to fix linux, but I didn't have to. On the boards I had, the bug was easily repeatable with u-boot or the bdm-tools's bdm-based flash programmer I used. The same blocks always gave the same error, while other blocks always worked perfectly. From linux, I tested with eraseall from mtd-utils also on the bad blocks and I never had any problem, so linux probably already does the erase sequence the way numonyx testers do it. The key point is that the CFI unlock command sequence must come just before the CFI erase command sequence, not long before.
Philippe
On Mon, Aug 09, 2010 at 02:57:27PM +0200, Philippe De Muyter wrote:
Hello Joakim,
Dear Stefan,
Jocke
Sorry, bad memory :( The unlock command must be preceded by a read lock command, with no more than 20 us between.
Philippe
Philippe De Muyter phdm@macqel.be wrote on 2010/08/09 14:57:27:
Hello Joakim,
Dear Stefan,
Jocke
hmm, the problem isn't erase(as I understand it). It is the unlock/lock sequence that does. I suspect that the auto unlock procedure in cfi_cmd0001 could suffer from this problem. Do you use auto unlock? There is nothing that protects the timing for unlock, is there?
Jocke
Hi Philippe,
first sorry for the late review (thanks Wolfgang for reminding).
On Saturday 07 August 2010 01:11:02 Wolfgang Denk wrote:
Dear Stefan,
Minor note: Such commentary lines should be moved below the "---" line below. They shouldn't appear in the git history.
<snip>
unsigned short cmd;
if (prot)
Please move this variable declaration of "cmd" and assignment further down (see below). You can remove the "{" "}" of this block then.
* see errata called
prot)) {
Declare and assign "cmd" here please.
Please change and resubmit. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hi Stefan,
On Mon, Aug 09, 2010 at 03:52:03PM +0200, Stefan Roese wrote:
Hi Philippe,
Dear Stefan,
<snip>
unsigned short cmd;
if (prot)
Here is the excerpt from the errata :
Workaround: If the interval between 60h and its subsequent command can be guaranteed within 20μs, Option I is recommended, otherwise Option II (involves hardware) should be selected. Option I: The table below lists the detail command sequences: Command Data bus Address bus Remarks Sequence 1 90h Block Address Read Lock Status 2 Read Block Address + 02h (2)(3) (1) 3 60h Block Address (2)(3) (1) Lock/Unlock/RCR Configuration 4 D0h/01h/03h Block Address Notes: (1) Block Address refers to RCR configuration data only when the 60h command sequence is used to set RCR register combined with 03h subsequent command. (2) For the third and fourth command sequences, the Block Address must be the same. (3) The interval between 60h command and its subsequent D0h/01h/2Fh/03h commands should be less than 20μs.
Because of requirement (3), I choosed to minimize the number of instructions between the `read lock status' and the `unlock' commands, hence the initialisation of `cmd' moved before the `read lock status' (hidden in `flash_isequal').
* see errata called
prot)) {
If you still prefer it changed, speak :)
Best regards
Philippe
Hi Philippe,
From my understanding, "only" the last 2 operations need to be in max. 20µs interval. If this is the case, then I would prefer this code version:
case CFI_CMDSET_INTEL_EXTENDED: /* * see errata called * "Numonyx Axcell P33/P30 Specification Update" :) */ flash_write_cmd (info, sector, 0, FLASH_CMD_READ_ID); if (!flash_isequal (info, sector, FLASH_OFFSET_PROTECT, prot)) { int flag = disable_interrupts (); unsigned short cmd;
if (prot) cmd = FLASH_CMD_PROTECT_SET; else cmd = FLASH_CMD_PROTECT_CLEAR;
/* * cmd must come before FLASH_CMD_PROTECT + 20us * Disable interrupts which might cause a timeout here. */ flash_write_cmd (info, sector, 0, FLASH_CMD_PROTECT); flash_write_cmd (info, sector, 0, cmd); /* re-enable interrupts if necessary */ if (flag) enable_interrupts (); }
* see errata called
Update" :) + */
Yes, please let me know if this patch version also fixes the bug. If this is the case, I would prefer that you change it accordingly.
Thanks.
Cheers, Stefan
Hi Stefan,
On Tue, Aug 10, 2010 at 01:20:42PM +0200, Stefan Roese wrote:
Hi Philippe,
Yes, you're right. I had misread the doc :(
I prefer it too.
case CFI_CMDSET_INTEL_EXTENDED: /* * see errata called * "Numonyx Axcell P33/P30 Specification Update" :) */ flash_write_cmd (info, sector, 0, FLASH_CMD_READ_ID); if (!flash_isequal (info, sector, FLASH_OFFSET_PROTECT, prot)) { int flag = disable_interrupts (); unsigned short cmd; if (prot) cmd = FLASH_CMD_PROTECT_SET; else cmd = FLASH_CMD_PROTECT_CLEAR; /* * cmd must come before FLASH_CMD_PROTECT + 20us * Disable interrupts which might cause a timeout here. */
Should the above comment not stay closer to the disable_interrupts () call ?
* see errata called
Update" :) + */
I surmise it does, but I currently do not have a board to test. I'll get new boards (with the same bug) soon, and I'll let you know then.
Best regards
Philippe
Hi Philippe,
I prefer it too.
Good! :)
Should the above comment not stay closer to the disable_interrupts () call?
Perhaps yes. But a comment before the following 2 instructions would also be good. Because this is the "hot path" that needs to be protected against interrupts.
Thanks.
Cheers, Stefan
Hi Philippe,
one more thing:
Please add this workaround text from the errata to the commit text in your next patch version. This makes things easier - no need to search for the errata.
Thanks.
Cheers, Stefan
On Tue, Aug 10, 2010 at 05:28:59PM +0200, Stefan Roese wrote:
Hi Philippe,
one more thing:
OK
Philippe
Joakim Tjernlund
Philippe De Muyter
Stefan Roese
