[U-Boot] [PATCH] powerpc/t4240: fix per pci endpoint liodn offsets
Update the code that builds the pci endpoint liodn offset list so that it doesn't overlap with other liodns and doesn't generate negative offsets like:
fsl,liodn-offset-list = <0 0xffffffcd 0xffffffcf 0xffffffd1 0xffffffd3 0xffffffd5 0xffffffd7 0xffffffd9 0xffffffdb>;
The update consists in adding a parameter to the function that builds the list to specify the base liodn. On PCI v2.4 use the old base = 256 and, on PCI 3.0 where some of the PCIE liodns are larger than 256, use a base = 1024. The version check is based on the PCI controller's version register.
Signed-off-by: Laurentiu Tudor Laurentiu.Tudor@freescale.com Cc: Scott Wood scottwood@freescale.com Cc: York Sun yorksun@freescale.com --- Based on: git://git.denx.de/u-boot-mpc85xx.git master
arch/powerpc/cpu/mpc85xx/liodn.c | 25 +++++++++++++++++++++---- arch/powerpc/include/asm/immap_85xx.h | 4 +++- 2 files changed, 24 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/liodn.c b/arch/powerpc/cpu/mpc85xx/liodn.c index 4b00da9..19e130e 100644 --- a/arch/powerpc/cpu/mpc85xx/liodn.c +++ b/arch/powerpc/cpu/mpc85xx/liodn.c @@ -239,9 +239,9 @@ static void fdt_fixup_srio_liodn(void *blob, struct srio_liodn_id_table *tbl) #endif
#define CONFIG_SYS_MAX_PCI_EPS 8 -#define CONFIG_SYS_PCI_EP_LIODN_START 256
-static void fdt_fixup_pci_liodn_offsets(void *fdt, const char *compat) +static void fdt_fixup_pci_liodn_offsets(void *fdt, const char *compat, + int ep_liodn_start) { int off, pci_idx = 0, pci_cnt = 0, i, rc; const uint32_t *base_liodn; @@ -271,7 +271,7 @@ static void fdt_fixup_pci_liodn_offsets(void *fdt, const char *compat) continue; } for (i = 0; i < CONFIG_SYS_MAX_PCI_EPS; i++) - liodn_offs[i + 1] = CONFIG_SYS_PCI_EP_LIODN_START + + liodn_offs[i + 1] = ep_liodn_start + i * pci_cnt + pci_idx - *base_liodn; rc = fdt_setprop(fdt, off, "fsl,liodn-offset-list", liodn_offs, sizeof(liodn_offs)); @@ -338,5 +338,22 @@ void fdt_fixup_liodn(void *blob) fdt_fixup_liodn_tbl(blob, rman_liodn_tbl, rman_liodn_tbl_sz); #endif
- fdt_fixup_pci_liodn_offsets(blob, "fsl,qoriq-pcie-v2.4"); + ccsr_pcix_t *pcix = (ccsr_pcix_t *)CONFIG_SYS_PCIE1_ADDR; + int pci_ver = pcix->ipver1 & 0xffff, liodn_base = 0; + + if (pci_ver >= 0x0204) { + if (pci_ver >= 0x0300) + liodn_base = 1024; + else + liodn_base = 256; + } + + if (liodn_base) { + char compat[32]; + + sprintf(compat, "fsl,qoriq-pcie-v%d.%d", + (pci_ver & 0xff00) >> 8, pci_ver & 0xff); + fdt_fixup_pci_liodn_offsets(blob, compat, liodn_base); + fdt_fixup_pci_liodn_offsets(blob, "fsl,qoriq-pcie", liodn_base); + } } diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index e516e07..a087b8c 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -282,7 +282,9 @@ typedef struct ccsr_pcix { u32 int_ack; /* PCIX IRQ Acknowledge */ u8 res000c[52]; u32 liodn_base; /* PCIX LIODN base register */ - u8 res0044[3004]; + u8 res0044[2996]; + u32 ipver1; /* PCIX IP block revision register 1 */ + u32 ipver2; /* PCIX IP block revision register 2 */ u32 potar0; /* PCIX Outbound Transaction Addr 0 */ u32 potear0; /* PCIX Outbound Translation Extended Addr 0 */ u32 powbar0; /* PCIX Outbound Window Base Addr 0 */
Applied to u-boot-mpc85xx/master.
York
Laurentiu Tudor
york sun
