[PATCH v2] phy: phy-imx8mq-usb: add vbus regulator support
Add support for enabling and disabling vbus-supply regulator found on several imx8mp boards in the usb3_phy0 and usb3_phy1 nodes.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Adam Ford aford173@gmail.com --- v2: - protect ret with __maybe_unused in case CONFIG_CLK and CONFIG_DM_REGULATOR not defined - add error prints on failures - add Adam's rb tag --- drivers/phy/phy-imx8mq-usb.c | 32 ++++++++++++++++++++++++++++++-- 1 file changed, 30 insertions(+), 2 deletions(-)
diff --git a/drivers/phy/phy-imx8mq-usb.c b/drivers/phy/phy-imx8mq-usb.c index 69f01de55538..53099436b04b 100644 --- a/drivers/phy/phy-imx8mq-usb.c +++ b/drivers/phy/phy-imx8mq-usb.c @@ -14,6 +14,7 @@ #include <linux/delay.h> #include <linux/err.h> #include <clk.h> +#include <power/regulator.h>
#define PHY_CTRL0 0x0 #define PHY_CTRL0_REF_SSP_EN BIT(2) @@ -81,6 +82,7 @@ struct imx8mq_usb_phy { #endif void __iomem *base; enum imx8mpq_phy_type type; + struct udevice *vbus_supply; };
static const struct udevice_id imx8mq_usb_phy_of_match[] = { @@ -172,10 +174,10 @@ static int imx8mq_usb_phy_power_on(struct phy *usb_phy) { struct udevice *dev = usb_phy->dev; struct imx8mq_usb_phy *imx_phy = dev_get_priv(dev); + __maybe_unused int ret; u32 value;
#if CONFIG_IS_ENABLED(CLK) - int ret; ret = clk_enable(&imx_phy->phy_clk); if (ret) { printf("Failed to enable usb phy clock\n"); @@ -183,6 +185,14 @@ static int imx8mq_usb_phy_power_on(struct phy *usb_phy) } #endif
+ if (CONFIG_IS_ENABLED(DM_REGULATOR) && imx_phy->vbus_supply) { + ret = regulator_set_enable(imx_phy->vbus_supply, true); + if (ret) { + pr_err("Failed to enable VBUS regulator: %d\n", ret); + return ret; + } + } + /* Disable rx term override */ value = readl(imx_phy->base + PHY_CTRL6); value &= ~PHY_CTRL6_RXTERM_OVERRIDE_SEL; @@ -195,6 +205,7 @@ static int imx8mq_usb_phy_power_off(struct phy *usb_phy) { struct udevice *dev = usb_phy->dev; struct imx8mq_usb_phy *imx_phy = dev_get_priv(dev); + __maybe_unused int ret; u32 value;
/* Override rx term to be 0 */ @@ -206,6 +217,14 @@ static int imx8mq_usb_phy_power_off(struct phy *usb_phy) clk_disable(&imx_phy->phy_clk); #endif
+ if (CONFIG_IS_ENABLED(DM_REGULATOR) && imx_phy->vbus_supply) { + ret = regulator_set_enable(imx_phy->vbus_supply, false); + if (ret) { + pr_err("Failed to disable VBUS regulator: %d\n", ret); + return ret; + } + } + return 0; }
@@ -224,6 +243,7 @@ struct phy_ops imx8mq_usb_phy_ops = { int imx8mq_usb_phy_probe(struct udevice *dev) { struct imx8mq_usb_phy *priv = dev_get_priv(dev); + __maybe_unused int ret;
priv->type = dev_get_driver_data(dev); priv->base = dev_read_addr_ptr(dev); @@ -232,7 +252,6 @@ int imx8mq_usb_phy_probe(struct udevice *dev) return -EINVAL;
/* Assigned clock already set clock */ ret = clk_get_by_name(dev, "phy", &priv->phy_clk); @@ -242,6 +261,15 @@ int imx8mq_usb_phy_probe(struct udevice *dev) } #endif
+ if (CONFIG_IS_ENABLED(DM_REGULATOR)) { + ret = device_get_supply_regulator(dev, "vbus-supply", + &priv->vbus_supply); + if (ret && ret != -ENOENT) { + pr_err("Failed to get VBUS regulator: %d\n", ret); + return ret; + } + } + return 0; }
v2:
- add Adam's rb tag
Shouldn't this be in #if CONFIG_IS_ENABLED(DM_REGULATOR) ?
- if (CONFIG_IS_ENABLED(DM_REGULATOR) && imx_phy->vbus_supply) {
if (ret) {
You do need to disable clock enabled above. This likely needs a fail path with "err: ... return ret;"
return ret;
- /* Disable rx term override */ value = readl(imx_phy->base + PHY_CTRL6); value &= ~PHY_CTRL6_RXTERM_OVERRIDE_SEL;
if (ret) {
btw with DM, these can be dev_err() .
return ret;
- return 0; }
v2:
- add Adam's rb tag
Hi Marek,
No, the usage of it is within an 'if (CONFIG_IS_ENABLED(DM_REGULATOR) && imx_phy->vbus_supply)' statement
if (ret) {
it does get disabled in imx8mq_usb_phy_power_off()
there are no further conditional return paths in this function.
return ret;
__maybe_unused int ret; u32 value; /* Override rx term to be 0 */
if (ret) {
Ok, I will send a v3 with that.
Tim
return ret;
}return 0;
v2:
- add Adam's rb tag
Hi Marek,
Except if this is not ifdef'd out, the structure is larger for no good reason if DM_REGULATOR is DISABLED.
if (ret) {
If that called if power_on returns -ERRNO ?
I suspect there should be.
return ret;
if (ret) {
Thanks !
v2:
- add Adam's rb tag
Hi Marek,
ok, I see your point.
if (ret) {
sorry, I don't quite understand.
Are you asking me to add a regulator disable in a remove function to make sure it's disabled if removed or are you saying that I shouldn't return the error from regulator_set_enable from imx8mq_usb_phy_power_on?
again, I don't understand. The only thing remaining in this function is disable rx term override below so I don't see the point in adding a goto around that if that is what you are suggesting.
I don't really know what 'rx term override' is either... perhaps the regulator_set_enable should go after that?
best regards,
Tim
return ret;
if (ret) {
Thanks !
Hi Marek,
}; static const struct udevice_id imx8mq_usb_phy_of_match[] = {
if (ret) {
Actually, neither. There is clk_enable() a bit higher up in this power_on function. You need to stop the clock if this regulator_set_enable() return -ERRNO.
Its only a matter of disabling the clock if the regulator enable fails and we bail out, that's all. Does it make sense now ?
Hi Marek,
if (ret) {
Yes - that makes sense. Thanks for explaining... not sure how I misunderstood that. You said 'clock' and I kept reading 'regulator' :)
Thanks,
Tim
Add support for enabling and disabling vbus-supply regulator found on several imx8mp boards in the usb3_phy0 and usb3_phy1 nodes. Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Adam Ford aford173@gmail.com
Best regards, Stefano Babic
Hi Tim,
I had applied V4, but after talking with Marek and seen V5, I have drop it from u-boot-imx.
Regards, Stefano
sbabic@denx.de
Stefano Babic
Tim Harvey
