[U-Boot] Samsung patches pending
Hi Minkyu,
I have collected a list of patches from the mailing list related to exynos and tested them on snow. This is not a complete list - there is still the GPIO patches to come, plus 'EXYNOS: Move files from board/samsung to arch/arm' but these will need to be rebased.
I have pushed the patches I collected and tested to u-boot-x86.git in branch snow.
The list (in reverse order) is:
d1c106f (HEAD, x86/snow, snow) EXYNOS: Add API for power reset and exit wakeup a79f0a6 Exynos5: cpufreq: Implement frequency scaling for exynos5 aa90070 pmic: max77686: add pmic_set_voltage api for max77686 cacbe6a EXYNOS4210: Configure GPIO for uart 4e37956 EXYNOS: LDS file move to common e751ab2 EXYNOS: Add API for power reset and shutdown 2900538 EXYNOS: Move includes from setup.h to tzpc_init.c fd0ba0c CONFIG: EXYNOS5: Enable silent console 3337750 S5P: Serial: Add fdt support to driver 9319822 EXYNOS5: FDT: Add serial device node values c0ba798 EXYNOS5: FDT: Add compatible strings for Serial 3700619 exynos: dts: Use 50MHz SPI flash speed on snow 8492823 EXYNOS: SPL: Add a custom spi copy function c89dd42 EXYNOS: SPI: Support word transfers f887dfd EXYNOS: SPI: Minimise access to SPI FIFO level 8f49e3c EXYNOS: SPI: Support a delay after deactivate 4aba9b5 EXYNOS: Export timer_get_us() to get microsecond timer 3f60ae8 EXYNOS: SPI: Support SPI_PREAMBLE mode 65cbaed SPI: Add support for preamble bytes e9c45bb exynos: Enable mmc for snow e9f0d09 COMMON: MMC: Command to support EMMC booting and to resize EMMC boot partition 5de8a42 SMDK5250: Enable EMMC booting e545b7d MMC: APIs to support resize of EMMC boot partition edcf63d SMDK5250: Initialise and Enable DWMMC, support FDT and non-FDT 102ab75 EXYNOS5: DWMMC: Initialise the local variable to avoid unwanted results. 646756e EXYNOS5: DWMMC: Added FDT support for DWMMC 272db65 DWMMC: Initialise dwmci and resolve EMMC read write issues cc32791 EXYNOS5: FDT: Add DWMMC device node data adfd53c FDT: Add compatible string for DWMMC
