[U-Boot] [PATCH v3] nand/denali: Adding Denali NAND driver support
To add the Denali NAND driver support into U-Boot. It required information such as register base address from configuration header file within include/configs folder.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Artem Bityutskiy artem.bityutskiy@linux.intel.com Cc: David Woodhouse David.Woodhouse@intel.com Cc: Brian Norris computersforpeace@gmail.com Cc: Scott Wood scottwood@freescale.com --- Changes for v3 - Fixed coding style Changes for v2 - Enable this driver support for SOCFPGA --- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/denali_nand.c | 1201 ++++++++++++++++++++++++++++++++++++++++ drivers/mtd/nand/denali_nand.h | 501 +++++++++++++++++ 3 files changed, 1703 insertions(+) create mode 100644 drivers/mtd/nand/denali_nand.c create mode 100644 drivers/mtd/nand/denali_nand.h
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 02b149c..24e8218 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -39,6 +39,7 @@ obj-$(CONFIG_NAND_ECC_BCH) += nand_bch.o obj-$(CONFIG_NAND_ATMEL) += atmel_nand.o obj-$(CONFIG_DRIVER_NAND_BFIN) += bfin_nand.o obj-$(CONFIG_NAND_DAVINCI) += davinci_nand.o +obj-$(CONFIG_NAND_DENALI) += denali_nand.o obj-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o obj-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_nand.o obj-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o diff --git a/drivers/mtd/nand/denali_nand.c b/drivers/mtd/nand/denali_nand.c new file mode 100644 index 0000000..e9db390 --- /dev/null +++ b/drivers/mtd/nand/denali_nand.c @@ -0,0 +1,1201 @@ +/* + * Copyright (C) 2013-2014 Altera Corporation <www.altera.com> + * Copyright (C) 2009-2010, Intel Corporation and its suppliers. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <nand.h> +#include <asm/errno.h> +#include <asm/io.h> + +#include "denali_nand.h" + +/* + * We define a module parameter that allows the user to override + * the hardware and decide what timing mode should be used. + */ +#define NAND_DEFAULT_TIMINGS -1 + +static struct denali_nand_info denali; +static int onfi_timing_mode = NAND_DEFAULT_TIMINGS; + +/* + * We define a macro here that combines all interrupts this driver uses into + * a single constant value, for convenience. + */ +#define DENALI_IRQ_ALL (INTR_STATUS__DMA_CMD_COMP | \ + INTR_STATUS__ECC_TRANSACTION_DONE | \ + INTR_STATUS__ECC_ERR | \ + INTR_STATUS__PROGRAM_FAIL | \ + INTR_STATUS__LOAD_COMP | \ + INTR_STATUS__PROGRAM_COMP | \ + INTR_STATUS__TIME_OUT | \ + INTR_STATUS__ERASE_FAIL | \ + INTR_STATUS__RST_COMP | \ + INTR_STATUS__ERASE_COMP | \ + INTR_STATUS__ECC_UNCOR_ERR | \ + INTR_STATUS__INT_ACT | \ + INTR_STATUS__LOCKED_BLK) + +/* + * indicates whether or not the internal value for the flash bank is + * valid or not + */ +#define CHIP_SELECT_INVALID -1 + +#define SUPPORT_8BITECC 1 + +/* + * This macro divides two integers and rounds fractional values up + * to the nearest integer value. + */ +#define CEIL_DIV(X, Y) (((X)%(Y)) ? ((X)/(Y)+1) : ((X)/(Y))) + +/* + * These constants are defined by the driver to enable common driver + * configuration options. + */ +#define SPARE_ACCESS 0x41 +#define MAIN_ACCESS 0x42 +#define MAIN_SPARE_ACCESS 0x43 + +#define DENALI_UNLOCK_START 0x10 +#define DENALI_UNLOCK_END 0x11 +#define DENALI_LOCK 0x21 +#define DENALI_LOCK_TIGHT 0x31 +#define DENALI_BUFFER_LOAD 0x60 +#define DENALI_BUFFER_WRITE 0x62 + +#define DENALI_READ 0 +#define DENALI_WRITE 0x100 + +/* types of device accesses. We can issue commands and get status */ +#define COMMAND_CYCLE 0 +#define ADDR_CYCLE 1 +#define STATUS_CYCLE 2 + +/* + * this is a helper macro that allows us to + * format the bank into the proper bits for the controller + */ +#define BANK(x) ((x) << 24) + +/* Interrupts are cleared by writing a 1 to the appropriate status bit */ +static inline void clear_interrupt(uint32_t irq_mask) +{ + uint32_t intr_status_reg = 0; + intr_status_reg = INTR_STATUS(denali.flash_bank); + __raw_writel(irq_mask, denali.flash_reg + intr_status_reg); +} + +static uint32_t read_interrupt_status(void) +{ + uint32_t intr_status_reg = 0; + intr_status_reg = INTR_STATUS(denali.flash_bank); + return __raw_readl(denali.flash_reg + intr_status_reg); +} + +static void clear_interrupts(void) +{ + uint32_t status = 0; + status = read_interrupt_status(); + clear_interrupt(status); + denali.irq_status = 0; +} + +static void denali_irq_enable(uint32_t int_mask) +{ + int i; + for (i = 0; i < denali.max_banks; ++i) + __raw_writel(int_mask, denali.flash_reg + INTR_EN(i)); +} + +static uint32_t wait_for_irq(uint32_t irq_mask) +{ + unsigned long comp_res = 1000; + uint32_t intr_status; + + do { + intr_status = read_interrupt_status() & DENALI_IRQ_ALL; + if (intr_status & irq_mask) { + denali.irq_status &= ~irq_mask; + /* our interrupt was detected */ + break; + } + udelay(1); + comp_res--; + } while (comp_res != 0); + + if (comp_res == 0) { + /* timeout */ + printf("Denali timeout with interrupt status %08x\n", + read_interrupt_status()); + intr_status = 0; + } + return intr_status; +} + +/* + * Certain operations for the denali NAND controller use an indexed mode to + * read/write data. The operation is performed by writing the address value + * of the command to the device memory followed by the data. This function + * abstracts this common operation. +*/ +static void index_addr(uint32_t address, uint32_t data) +{ + __raw_writel(address, denali.flash_mem); + __raw_writel(data, denali.flash_mem + 0x10); +} + +/* Perform an indexed read of the device */ +static void index_addr_read_data(uint32_t address, uint32_t *pdata) +{ + __raw_writel(address, denali.flash_mem); + *pdata = __raw_readl(denali.flash_mem + 0x10); +} + +/* + * We need to buffer some data for some of the NAND core routines. + * The operations manage buffering that data. + */ +static void reset_buf(void) +{ + denali.buf.head = 0; + denali.buf.tail = 0; +} + +static void write_byte_to_buf(uint8_t byte) +{ + BUG_ON(denali.buf.tail >= sizeof(denali.buf.buf)); + denali.buf.buf[denali.buf.tail++] = byte; +} + +/* resets a specific device connected to the core */ +static void reset_bank(void) +{ + uint32_t irq_status; + uint32_t irq_mask = INTR_STATUS__RST_COMP | + INTR_STATUS__TIME_OUT; + + clear_interrupts(); + + __raw_writel(1 << denali.flash_bank, denali.flash_reg + DEVICE_RESET); + + irq_status = wait_for_irq(irq_mask); + if (irq_status & INTR_STATUS__TIME_OUT) + debug(KERN_ERR "reset bank failed.\n"); +} + +/* Reset the flash controller */ +static uint16_t denali_nand_reset(void) +{ + uint32_t i; + + for (i = 0; i < denali.max_banks; i++) + __raw_writel(INTR_STATUS__RST_COMP | INTR_STATUS__TIME_OUT, + denali.flash_reg + INTR_STATUS(i)); + + for (i = 0; i < denali.max_banks; i++) { + __raw_writel(1 << i, denali.flash_reg + DEVICE_RESET); + while (!(__raw_readl(denali.flash_reg + INTR_STATUS(i)) & + (INTR_STATUS__RST_COMP | INTR_STATUS__TIME_OUT))) + if (__raw_readl(denali.flash_reg + INTR_STATUS(i)) & + INTR_STATUS__TIME_OUT) + debug(KERN_DEBUG "NAND Reset operation " + "timed out on bank %d\n", i); + } + + for (i = 0; i < denali.max_banks; i++) + __raw_writel(INTR_STATUS__RST_COMP | INTR_STATUS__TIME_OUT, + denali.flash_reg + INTR_STATUS(i)); + + return PASS; +} + +/* + * this routine calculates the ONFI timing values for a given mode and + * programs the clocking register accordingly. The mode is determined by + * the get_onfi_nand_para routine. + */ +static void nand_onfi_timing_set(uint16_t mode) +{ + uint16_t trea[6] = {40, 30, 25, 20, 20, 16}; + uint16_t trp[6] = {50, 25, 17, 15, 12, 10}; + uint16_t treh[6] = {30, 15, 15, 10, 10, 7}; + uint16_t trc[6] = {100, 50, 35, 30, 25, 20}; + uint16_t trhoh[6] = {0, 15, 15, 15, 15, 15}; + uint16_t trloh[6] = {0, 0, 0, 0, 5, 5}; + uint16_t tcea[6] = {100, 45, 30, 25, 25, 25}; + uint16_t tadl[6] = {200, 100, 100, 100, 70, 70}; + uint16_t trhw[6] = {200, 100, 100, 100, 100, 100}; + uint16_t trhz[6] = {200, 100, 100, 100, 100, 100}; + uint16_t twhr[6] = {120, 80, 80, 60, 60, 60}; + uint16_t tcs[6] = {70, 35, 25, 25, 20, 15}; + + uint16_t tclsrising = 1; + uint16_t data_invalid_rhoh, data_invalid_rloh, data_invalid; + uint16_t dv_window = 0; + uint16_t en_lo, en_hi; + uint16_t acc_clks; + uint16_t addr_2_data, re_2_we, re_2_re, we_2_re, cs_cnt; + + en_lo = CEIL_DIV(trp[mode], CLK_X); + en_hi = CEIL_DIV(treh[mode], CLK_X); +#if ONFI_BLOOM_TIME + if ((en_hi * CLK_X) < (treh[mode] + 2)) + en_hi++; +#endif + + if ((en_lo + en_hi) * CLK_X < trc[mode]) + en_lo += CEIL_DIV((trc[mode] - (en_lo + en_hi) * CLK_X), CLK_X); + + if ((en_lo + en_hi) < CLK_MULTI) + en_lo += CLK_MULTI - en_lo - en_hi; + + while (dv_window < 8) { + data_invalid_rhoh = en_lo * CLK_X + trhoh[mode]; + + data_invalid_rloh = (en_lo + en_hi) * CLK_X + trloh[mode]; + + data_invalid = + data_invalid_rhoh < + data_invalid_rloh ? data_invalid_rhoh : data_invalid_rloh; + + dv_window = data_invalid - trea[mode]; + + if (dv_window < 8) + en_lo++; + } + + acc_clks = CEIL_DIV(trea[mode], CLK_X); + + while (((acc_clks * CLK_X) - trea[mode]) < 3) + acc_clks++; + + if ((data_invalid - acc_clks * CLK_X) < 2) + debug(KERN_WARNING "%s, Line %d: Warning!\n", + __FILE__, __LINE__); + + addr_2_data = CEIL_DIV(tadl[mode], CLK_X); + re_2_we = CEIL_DIV(trhw[mode], CLK_X); + re_2_re = CEIL_DIV(trhz[mode], CLK_X); + we_2_re = CEIL_DIV(twhr[mode], CLK_X); + cs_cnt = CEIL_DIV((tcs[mode] - trp[mode]), CLK_X); + if (!tclsrising) + cs_cnt = CEIL_DIV(tcs[mode], CLK_X); + if (cs_cnt == 0) + cs_cnt = 1; + + if (tcea[mode]) { + while (((cs_cnt * CLK_X) + trea[mode]) < tcea[mode]) + cs_cnt++; + } + +#if MODE5_WORKAROUND + if (mode == 5) + acc_clks = 5; +#endif + + /* Sighting 3462430: Temporary hack for MT29F128G08CJABAWP:B */ + if ((__raw_readl(denali.flash_reg + MANUFACTURER_ID) == 0) && + (__raw_readl(denali.flash_reg + DEVICE_ID) == 0x88)) + acc_clks = 6; + + __raw_writel(acc_clks, denali.flash_reg + ACC_CLKS); + __raw_writel(re_2_we, denali.flash_reg + RE_2_WE); + __raw_writel(re_2_re, denali.flash_reg + RE_2_RE); + __raw_writel(we_2_re, denali.flash_reg + WE_2_RE); + __raw_writel(addr_2_data, denali.flash_reg + ADDR_2_DATA); + __raw_writel(en_lo, denali.flash_reg + RDWR_EN_LO_CNT); + __raw_writel(en_hi, denali.flash_reg + RDWR_EN_HI_CNT); + __raw_writel(cs_cnt, denali.flash_reg + CS_SETUP_CNT); +} + +/* queries the NAND device to see what ONFI modes it supports. */ +static uint16_t get_onfi_nand_para(void) +{ + int i; + /* we needn't to do a reset here because driver has already + * reset all the banks before + * */ + if (!(__raw_readl(denali.flash_reg + ONFI_TIMING_MODE) & + ONFI_TIMING_MODE__VALUE)) + return FAIL; + + for (i = 5; i > 0; i--) { + if (__raw_readl(denali.flash_reg + ONFI_TIMING_MODE) & + (0x01 << i)) + break; + } + + nand_onfi_timing_set(i); + + /* + * By now, all the ONFI devices we know support the page cache + * rw feature. So here we enable the pipeline_rw_ahead feature + */ + + return PASS; +} + +static void get_samsung_nand_para(uint8_t device_id) +{ + if (device_id == 0xd3) { /* Samsung K9WAG08U1A */ + /* Set timing register values according to datasheet */ + __raw_writel(5, denali.flash_reg + ACC_CLKS); + __raw_writel(20, denali.flash_reg + RE_2_WE); + __raw_writel(12, denali.flash_reg + WE_2_RE); + __raw_writel(14, denali.flash_reg + ADDR_2_DATA); + __raw_writel(3, denali.flash_reg + RDWR_EN_LO_CNT); + __raw_writel(2, denali.flash_reg + RDWR_EN_HI_CNT); + __raw_writel(2, denali.flash_reg + CS_SETUP_CNT); + } +} + +static void get_toshiba_nand_para(void) +{ + uint32_t tmp; + + /* + * Workaround to fix a controller bug which reports a wrong + * spare area size for some kind of Toshiba NAND device + */ + if ((__raw_readl(denali.flash_reg + DEVICE_MAIN_AREA_SIZE) == 4096) && + (__raw_readl(denali.flash_reg + DEVICE_SPARE_AREA_SIZE) + == 64)){ + __raw_writel(216, denali.flash_reg + DEVICE_SPARE_AREA_SIZE); + tmp = __raw_readl(denali.flash_reg + DEVICES_CONNECTED) * + __raw_readl(denali.flash_reg + DEVICE_SPARE_AREA_SIZE); + __raw_writel(tmp, denali.flash_reg + LOGICAL_PAGE_SPARE_SIZE); +#if SUPPORT_15BITECC + __raw_writel(15, denali.flash_reg + ECC_CORRECTION); +#elif SUPPORT_8BITECC + __raw_writel(8, denali.flash_reg + ECC_CORRECTION); +#endif + } +} + +static void get_hynix_nand_para(uint8_t device_id) +{ + uint32_t main_size, spare_size; + + switch (device_id) { + case 0xD5: /* Hynix H27UAG8T2A, H27UBG8U5A or H27UCG8VFA */ + case 0xD7: /* Hynix H27UDG8VEM, H27UCG8UDM or H27UCG8V5A */ + __raw_writel(128, denali.flash_reg + PAGES_PER_BLOCK); + __raw_writel(4096, denali.flash_reg + DEVICE_MAIN_AREA_SIZE); + __raw_writel(224, denali.flash_reg + DEVICE_SPARE_AREA_SIZE); + main_size = 4096 * + __raw_readl(denali.flash_reg + DEVICES_CONNECTED); + spare_size = 224 * + __raw_readl(denali.flash_reg + DEVICES_CONNECTED); + __raw_writel(main_size, + denali.flash_reg + LOGICAL_PAGE_DATA_SIZE); + __raw_writel(spare_size, + denali.flash_reg + LOGICAL_PAGE_SPARE_SIZE); + __raw_writel(0, denali.flash_reg + DEVICE_WIDTH); +#if SUPPORT_15BITECC + __raw_writel(15, denali.flash_reg + ECC_CORRECTION); +#elif SUPPORT_8BITECC + __raw_writel(8, denali.flash_reg + ECC_CORRECTION); +#endif + break; + default: + debug(KERN_WARNING + "Spectra: Unknown Hynix NAND (Device ID: 0x%x)." + "Will use default parameter values instead.\n", + device_id); + } +} + +/* + * determines how many NAND chips are connected to the controller. Note for + * Intel CE4100 devices we don't support more than one device. + */ +static void find_valid_banks(void) +{ + uint32_t id[denali.max_banks]; + int i; + + denali.total_used_banks = 1; + for (i = 0; i < denali.max_banks; i++) { + index_addr((uint32_t)(MODE_11 | (i << 24) | 0), 0x90); + index_addr((uint32_t)(MODE_11 | (i << 24) | 1), 0); + index_addr_read_data((uint32_t)(MODE_11 | (i << 24) | 2), + &id[i]); + + if (i == 0) { + if (!(id[i] & 0x0ff)) + break; /* WTF? */ + } else { + if ((id[i] & 0x0ff) == (id[0] & 0x0ff)) + denali.total_used_banks++; + else + break; + } + } +} + +/* + * Use the configuration feature register to determine the maximum number of + * banks that the hardware supports. + */ +static void detect_max_banks(void) +{ + uint32_t features = __raw_readl(denali.flash_reg + FEATURES); + denali.max_banks = 2 << (features & FEATURES__N_BANKS); +} + +static void detect_partition_feature(void) +{ + /* + * For MRST platform, denali.fwblks represent the + * number of blocks firmware is taken, + * FW is in protect partition and MTD driver has no + * permission to access it. So let driver know how many + * blocks it can't touch. + */ + if (__raw_readl(denali.flash_reg + FEATURES) & FEATURES__PARTITION) { + if ((__raw_readl(denali.flash_reg + PERM_SRC_ID(1)) & + PERM_SRC_ID__SRCID) == SPECTRA_PARTITION_ID) { + denali.fwblks = + ((__raw_readl(denali.flash_reg + MIN_MAX_BANK(1)) & + MIN_MAX_BANK__MIN_VALUE) * + denali.blksperchip) + + + (__raw_readl(denali.flash_reg + MIN_BLK_ADDR(1)) & + MIN_BLK_ADDR__VALUE); + } else { + denali.fwblks = SPECTRA_START_BLOCK; + } + } else { + denali.fwblks = SPECTRA_START_BLOCK; + } +} + +static uint16_t denali_nand_timing_set(void) +{ + uint16_t status = PASS; + uint32_t id_bytes[5], addr; + uint8_t i, maf_id, device_id; + + /* + * Use read id method to get device ID and other + * params. For some NAND chips, controller can't + * report the correct device ID by reading from + * DEVICE_ID register + */ + addr = (uint32_t)MODE_11 | BANK(denali.flash_bank); + index_addr((uint32_t)addr | 0, 0x90); + index_addr((uint32_t)addr | 1, 0); + for (i = 0; i < 5; i++) + index_addr_read_data(addr | 2, &id_bytes[i]); + maf_id = id_bytes[0]; + device_id = id_bytes[1]; + + if (__raw_readl(denali.flash_reg + ONFI_DEVICE_NO_OF_LUNS) & + ONFI_DEVICE_NO_OF_LUNS__ONFI_DEVICE) { /* ONFI 1.0 NAND */ + if (FAIL == get_onfi_nand_para()) + return FAIL; + } else if (maf_id == 0xEC) { /* Samsung NAND */ + get_samsung_nand_para(device_id); + } else if (maf_id == 0x98) { /* Toshiba NAND */ + get_toshiba_nand_para(); + } else if (maf_id == 0xAD) { /* Hynix NAND */ + get_hynix_nand_para(device_id); + } + + find_valid_banks(); + + detect_partition_feature(); + + /* + * If the user specified to override the default timings + * with a specific ONFI mode, we apply those changes here. + */ + if (onfi_timing_mode != NAND_DEFAULT_TIMINGS) + nand_onfi_timing_set(onfi_timing_mode); + + return status; +} + +static void denali_set_intr_modes(uint16_t INT_ENABLE) +{ + if (INT_ENABLE) + __raw_writel(1, denali.flash_reg + GLOBAL_INT_ENABLE); + else + __raw_writel(0, denali.flash_reg + GLOBAL_INT_ENABLE); +} + +/* + * Validation function to verify that the controlling software is making + * a valid request + */ +static inline bool is_flash_bank_valid(int flash_bank) +{ + return (flash_bank >= 0 && flash_bank < 4); +} + +static void denali_irq_init(void) +{ + uint32_t int_mask = 0; + int i; + + /* Disable global interrupts */ + denali_set_intr_modes(false); + + int_mask = DENALI_IRQ_ALL; + + /* Clear all status bits */ + for (i = 0; i < denali.max_banks; ++i) + __raw_writel(0xFFFF, denali.flash_reg + INTR_STATUS(i)); + + denali_irq_enable(int_mask); +} + +/* + * This helper function setups the registers for ECC and whether or not + * the spare area will be transferred. + */ +static void setup_ecc_for_xfer(bool ecc_en, bool transfer_spare) +{ + int ecc_en_flag = 0, transfer_spare_flag = 0; + + /* set ECC, transfer spare bits if needed */ + ecc_en_flag = ecc_en ? ECC_ENABLE__FLAG : 0; + transfer_spare_flag = transfer_spare ? TRANSFER_SPARE_REG__FLAG : 0; + + /* Enable spare area/ECC per user's request. */ + __raw_writel(ecc_en_flag, denali.flash_reg + ECC_ENABLE); + /* applicable for MAP01 only */ + __raw_writel(transfer_spare_flag, + denali.flash_reg + TRANSFER_SPARE_REG); +} + +/* + * Sends a pipeline command operation to the controller. See the Denali NAND + * controller's user guide for more information (section 4.2.3.6). + */ +static int denali_send_pipeline_cmd(bool ecc_en, bool transfer_spare, + int access_type, int op) +{ + uint32_t addr = 0x0, cmd = 0x0, irq_status = 0, irq_mask = 0; + uint32_t page_count = 1; /* always read a page */ + + if (op == DENALI_READ) + irq_mask = INTR_STATUS__LOAD_COMP; + else if (op == DENALI_WRITE) + irq_mask = INTR_STATUS__PROGRAM_COMP | + INTR_STATUS__PROGRAM_FAIL; + else + BUG(); + + /* clear interrupts */ + clear_interrupts(); + + /* setup ECC and transfer spare reg */ + setup_ecc_for_xfer(ecc_en, transfer_spare); + + addr = BANK(denali.flash_bank) | denali.page; + + /* setup the acccess type */ + cmd = MODE_10 | addr; + index_addr((uint32_t)cmd, access_type); + + /* setup the pipeline command */ + if (access_type == SPARE_ACCESS && op == DENALI_WRITE) + index_addr((uint32_t)cmd, DENALI_BUFFER_WRITE); + else if (access_type == SPARE_ACCESS && op == DENALI_READ) + index_addr((uint32_t)cmd, DENALI_BUFFER_LOAD); + else + index_addr((uint32_t)cmd, 0x2000 | op | page_count); + + /* wait for command to be accepted */ + irq_status = wait_for_irq(irq_mask); + if ((irq_status & irq_mask) != irq_mask) + return FAIL; + + if (access_type != SPARE_ACCESS) { + cmd = MODE_01 | addr; + __raw_writel(cmd, denali.flash_mem); + } + return PASS; +} + +/* helper function that simply writes a buffer to the flash */ +static int write_data_to_flash_mem(const uint8_t *buf, + int len) +{ + uint32_t i = 0, *buf32; + + /* + * verify that the len is a multiple of 4. see comment in + * read_data_from_flash_mem() + */ + BUG_ON((len % 4) != 0); + + /* write the data to the flash memory */ + buf32 = (uint32_t *)buf; + for (i = 0; i < len / 4; i++) + __raw_writel(*buf32++, denali.flash_mem + 0x10); + return i*4; /* intent is to return the number of bytes read */ +} + +static void denali_mode_main_access(void) +{ + uint32_t addr, cmd; + addr = BANK(denali.flash_bank) | denali.page; + cmd = MODE_10 | addr; + index_addr((uint32_t)cmd, MAIN_ACCESS); +} + +static void denali_mode_main_spare_access(void) +{ + uint32_t addr, cmd; + addr = BANK(denali.flash_bank) | denali.page; + cmd = MODE_10 | addr; + index_addr((uint32_t)cmd, MAIN_SPARE_ACCESS); +} + +/* + * Writes OOB data to the device. + * This code unused under normal U-Boot console as normally page write raw + * to be used for write oob data with main data. + */ +static int write_oob_data(struct mtd_info *mtd, uint8_t *buf, int page) +{ + uint32_t cmd; + + denali.page = page; + debug("* write_oob_data *\n"); + + /* We need to write to buffer first through MAP00 command */ + cmd = MODE_00 | BANK(denali.flash_bank); + __raw_writel(cmd, denali.flash_mem); + + /* send the data into flash buffer */ + write_data_to_flash_mem(buf, mtd->oobsize); + + /* activate the write through MAP10 commands */ + if (denali_send_pipeline_cmd(false, false, SPARE_ACCESS, DENALI_WRITE) + != PASS) + return -EIO; + + return 0; +} + +/* + * This function examines buffers to see if they contain data that + * indicate that the buffer is part of an erased region of flash. + */ +bool is_erased(uint8_t *buf, int len) +{ + int i = 0; + for (i = 0; i < len; i++) + if (buf[i] != 0xFF) + return false; + return true; +} + + +/* programs the controller to either enable/disable DMA transfers */ +static void denali_enable_dma(bool en) +{ + uint32_t reg_val = 0x0; + + if (en) + reg_val = DMA_ENABLE__FLAG; + + __raw_writel(reg_val, denali.flash_reg + DMA_ENABLE); + __raw_readl(denali.flash_reg + DMA_ENABLE); +} + +/* setups the HW to perform the data DMA */ +static void denali_setup_dma_sequence(int op) +{ + const int page_count = 1; + uint32_t mode; + uint32_t addr = (uint32_t)denali.buf.dma_buf; + + mode = MODE_10 | BANK(denali.flash_bank); + + /* DMA is a four step process */ + + /* 1. setup transfer type and # of pages */ + index_addr(mode | denali.page, 0x2000 | op | page_count); + + /* 2. set memory high address bits 23:8 */ + index_addr(mode | ((uint16_t)(addr >> 16) << 8), 0x2200); + + /* 3. set memory low address bits 23:8 */ + index_addr(mode | ((uint16_t)addr << 8), 0x2300); + + /* 4. interrupt when complete, burst len = 64 bytes*/ + index_addr(mode | 0x14000, 0x2400); +} + +/* Common DMA function */ +static uint32_t denali_dma_configuration(uint32_t ops, bool raw_xfer, + uint32_t irq_mask, int oob_required) +{ + uint32_t irq_status = 0; + /* setup_ecc_for_xfer(bool ecc_en, bool transfer_spare) */ + setup_ecc_for_xfer(!raw_xfer, oob_required); + + /* clear any previous interrupt flags */ + clear_interrupts(); + + /* enable the DMA */ + denali_enable_dma(true); + + /* setup the DMA */ + denali_setup_dma_sequence(ops); + + /* wait for operation to complete */ + irq_status = wait_for_irq(irq_mask); + + /* + * If ECC fault happen, seems we need delay before turning off DMA. + * If not, the controller will go into non responsive condition + */ + if (irq_status & INTR_STATUS__ECC_UNCOR_ERR) + udelay(100); + + /* disable the DMA */ + denali_enable_dma(false); + + return irq_status; +} + +static int write_page(struct mtd_info *mtd, struct nand_chip *chip, + const uint8_t *buf, bool raw_xfer, int oob_required) +{ + uint32_t irq_status = 0; + uint32_t irq_mask = INTR_STATUS__DMA_CMD_COMP; + + denali.status = PASS; + + /* copy buffer into DMA buffer */ + memcpy((void *)denali.buf.dma_buf, buf, mtd->writesize); + + /* need extra memcpoy for raw transfer */ + if (raw_xfer) + memcpy((void *)denali.buf.dma_buf + mtd->writesize, + chip->oob_poi, mtd->oobsize); + + /* setting up DMA */ + irq_status = denali_dma_configuration(DENALI_WRITE, raw_xfer, irq_mask, + oob_required); + + /* if timeout happen, error out */ + if (!(irq_status & INTR_STATUS__DMA_CMD_COMP)) { + debug("DMA timeout for denali write_page\n"); + denali.status = NAND_STATUS_FAIL; + return -EIO; + } + + if (irq_status & INTR_STATUS__LOCKED_BLK) { + debug("Failed as write to locked block\n"); + denali.status = NAND_STATUS_FAIL; + return -EIO; + } + return 0; +} + +/* NAND core entry points */ + +/* + * This is the callback that the NAND core calls to write a page. Since + * writing a page with ECC or without is similar, all the work is done + * by write_page above. + */ +static int denali_write_page(struct mtd_info *mtd, struct nand_chip *chip, + const uint8_t *buf, int oob_required) +{ + /* + * for regular page writes, we let HW handle all the ECC + * data written to the device. + */ + debug("denali_write_page at page %08x\n", denali.page); + + if (oob_required) + /* switch to main + spare access */ + denali_mode_main_spare_access(); + else + /* switch to main access only */ + denali_mode_main_access(); + + return write_page(mtd, chip, buf, false, oob_required); +} + +/* + * This is the callback that the NAND core calls to write a page without ECC. + * raw access is similar to ECC page writes, so all the work is done in the + * write_page() function above. + */ +static int denali_write_page_raw(struct mtd_info *mtd, struct nand_chip *chip, + const uint8_t *buf, int oob_required) +{ + /* + * for raw page writes, we want to disable ECC and simply write + * whatever data is in the buffer. + */ + debug("denali_write_page_raw at page %08x\n", denali.page); + + if (oob_required) + /* switch to main + spare access */ + denali_mode_main_spare_access(); + else + /* switch to main access only */ + denali_mode_main_access(); + + return write_page(mtd, chip, buf, true, oob_required); +} + +static int denali_write_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + return write_oob_data(mtd, chip->oob_poi, page); +} + +/* raw include ECC value and all the spare area */ +static int denali_read_page_raw(struct mtd_info *mtd, struct nand_chip *chip, + uint8_t *buf, int oob_required, int page) +{ + uint32_t irq_status, irq_mask = INTR_STATUS__DMA_CMD_COMP; + + debug("denali_read_page_raw at page %08x\n", page); + if (denali.page != page) { + debug("Missing NAND_CMD_READ0 command\n"); + return -EIO; + } + + if (oob_required) + /* switch to main + spare access */ + denali_mode_main_spare_access(); + else + /* switch to main access only */ + denali_mode_main_access(); + + /* setting up the DMA where ecc_enable is false */ + irq_status = denali_dma_configuration(DENALI_READ, true, irq_mask, + oob_required); + + /* if timeout happen, error out */ + if (!(irq_status & INTR_STATUS__DMA_CMD_COMP)) { + debug("DMA timeout for denali_read_page_raw\n"); + return -EIO; + } + + /* splitting the content to destination buffer holder */ + memcpy(chip->oob_poi, (const void *)(denali.buf.dma_buf + + mtd->writesize), mtd->oobsize); + memcpy(buf, (const void *)denali.buf.dma_buf, mtd->writesize); + debug("buf %02x %02x\n", buf[0], buf[1]); + debug("chip->oob_poi %02x %02x\n", chip->oob_poi[0], chip->oob_poi[1]); + return 0; +} + +static int denali_read_page(struct mtd_info *mtd, struct nand_chip *chip, + uint8_t *buf, int oob_required, int page) +{ + uint32_t irq_status, irq_mask = INTR_STATUS__DMA_CMD_COMP; + + debug("denali_read_page at page %08x\n", page); + if (denali.page != page) { + debug("Missing NAND_CMD_READ0 command\n"); + return -EIO; + } + + if (oob_required) + /* switch to main + spare access */ + denali_mode_main_spare_access(); + else + /* switch to main access only */ + denali_mode_main_access(); + + /* setting up the DMA where ecc_enable is true */ + irq_status = denali_dma_configuration(DENALI_READ, false, irq_mask, + oob_required); + + memcpy(buf, (const void *)denali.buf.dma_buf, mtd->writesize); + debug("buf %02x %02x\n", buf[0], buf[1]); + + /* check whether any ECC error */ + if (irq_status & INTR_STATUS__ECC_UNCOR_ERR) { + /* is the ECC cause by erase page, check using read_page_raw */ + debug(" Uncorrected ECC detected\n"); + denali_read_page_raw(mtd, chip, buf, oob_required, denali.page); + + if (is_erased(buf, mtd->writesize) == true && + is_erased(chip->oob_poi, mtd->oobsize) == true) { + debug(" ECC error cause by erased block\n"); + /* false alarm, return the 0xFF */ + } else { + return -EIO; + } + } + memcpy(buf, (const void *)denali.buf.dma_buf, mtd->writesize); + return 0; +} + +static uint8_t denali_read_byte(struct mtd_info *mtd) +{ + uint32_t addr, result; + addr = (uint32_t)MODE_11 | BANK(denali.flash_bank); + index_addr_read_data((uint32_t)addr | 2, &result); + return (uint8_t)result & 0xFF; +} + +static int denali_read_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + debug("denali_read_oob at page %08x\n", page); + denali.page = page; + return denali_read_page_raw(mtd, chip, denali.buf.buf, 1, page); +} + +static void denali_read_buf(struct mtd_info *mtd, uint8_t *buf, int len) +{ + uint32_t i, addr, result; + + /* delay for tR (data transfer from Flash array to data register) */ + udelay(25); + + /* ensure device completed else additional delay and polling */ + wait_for_irq(INTR_STATUS__INT_ACT); + + addr = (uint32_t)MODE_11 | BANK(denali.flash_bank); + for (i = 0; i < len; i++) { + index_addr_read_data((uint32_t)addr | 2, &result); + write_byte_to_buf(result); + } + memcpy(buf, denali.buf.buf, len); +} + +static void denali_select_chip(struct mtd_info *mtd, int chip) +{ + denali.flash_bank = chip; +} + +static int denali_waitfunc(struct mtd_info *mtd, struct nand_chip *chip) +{ + int status = denali.status; + denali.status = 0; + + return status; +} + +static void denali_erase(struct mtd_info *mtd, int page) +{ + uint32_t cmd = 0x0, irq_status = 0; + + debug("denali_erase at page %08x\n", page); + + /* clear interrupts */ + clear_interrupts(); + + /* setup page read request for access type */ + cmd = MODE_10 | BANK(denali.flash_bank) | page; + index_addr((uint32_t)cmd, 0x1); + + /* wait for erase to complete or failure to occur */ + irq_status = wait_for_irq(INTR_STATUS__ERASE_COMP | + INTR_STATUS__ERASE_FAIL); + + if (irq_status & INTR_STATUS__ERASE_FAIL || + irq_status & INTR_STATUS__LOCKED_BLK) + denali.status = NAND_STATUS_FAIL; + else + denali.status = PASS; +} + +static void denali_cmdfunc(struct mtd_info *mtd, unsigned int cmd, int col, + int page) +{ + uint32_t addr; + + switch (cmd) { + case NAND_CMD_PAGEPROG: + break; + case NAND_CMD_STATUS: + addr = (uint32_t)MODE_11 | BANK(denali.flash_bank); + index_addr((uint32_t)addr | 0, cmd); + break; + case NAND_CMD_PARAM: + clear_interrupts(); + case NAND_CMD_READID: + reset_buf(); + /* + * sometimes ManufactureId read from register is not right + * e.g. some of Micron MT29F32G08QAA MLC NAND chips + * So here we send READID cmd to NAND insteand + */ + addr = (uint32_t)MODE_11 | BANK(denali.flash_bank); + index_addr((uint32_t)addr | 0, cmd); + index_addr((uint32_t)addr | 1, col & 0xFF); + break; + case NAND_CMD_READ0: + case NAND_CMD_SEQIN: + denali.page = page; + break; + case NAND_CMD_RESET: + reset_bank(); + break; + case NAND_CMD_READOOB: + /* TODO: Read OOB data */ + break; + case NAND_CMD_ERASE1: + /* + * supporting block erase only, not multiblock erase as + * it will cross plane and software need complex calculation + * to identify the block count for the cross plane + */ + denali_erase(mtd, page); + break; + case NAND_CMD_ERASE2: + /* nothing to do here as it was done during NAND_CMD_ERASE1 */ + break; + case NAND_CMD_UNLOCK1: + addr = (uint32_t)MODE_10 | BANK(denali.flash_bank) | page; + index_addr((uint32_t)addr | 0, DENALI_UNLOCK_START); + break; + case NAND_CMD_UNLOCK2: + addr = (uint32_t)MODE_10 | BANK(denali.flash_bank) | page; + index_addr((uint32_t)addr | 0, DENALI_UNLOCK_END); + break; + case NAND_CMD_LOCK: + addr = (uint32_t)MODE_10 | BANK(denali.flash_bank); + index_addr((uint32_t)addr | 0, DENALI_LOCK); + break; + case NAND_CMD_LOCK_TIGHT: + addr = (uint32_t)MODE_10 | BANK(denali.flash_bank); + index_addr((uint32_t)addr | 0, DENALI_LOCK_TIGHT); + break; + default: + printf(": unsupported command received 0x%x\n", cmd); + break; + } +} + +/* stubs for ECC functions not used by the NAND core */ +static int denali_ecc_calculate(struct mtd_info *mtd, const uint8_t *data, + uint8_t *ecc_code) +{ + debug("Should not be called as ECC handled by hardware\n"); + BUG(); + return -EIO; +} + +static int denali_ecc_correct(struct mtd_info *mtd, uint8_t *data, + uint8_t *read_ecc, uint8_t *calc_ecc) +{ + debug("Should not be called as ECC handled by hardware\n"); + BUG(); + return -EIO; +} + +static void denali_ecc_hwctl(struct mtd_info *mtd, int mode) +{ + debug("Should not be called as ECC handled by hardware\n"); + BUG(); +} +/* end NAND core entry points */ + +/* Initialization code to bring the device up to a known good state */ +static void denali_hw_init(void) +{ + /* + * tell driver how many bit controller will skip before writing + * ECC code in OOB. This is normally used for bad block marker + */ + __raw_writel(CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES, + denali.flash_reg + SPARE_AREA_SKIP_BYTES); + detect_max_banks(); + denali_nand_reset(); + __raw_writel(0x0F, denali.flash_reg + RB_PIN_ENABLED); + __raw_writel(CHIP_EN_DONT_CARE__FLAG, + denali.flash_reg + CHIP_ENABLE_DONT_CARE); + __raw_writel(0xffff, denali.flash_reg + SPARE_AREA_MARKER); + + /* Should set value for these registers when init */ + __raw_writel(0, denali.flash_reg + TWO_ROW_ADDR_CYCLES); + __raw_writel(1, denali.flash_reg + ECC_ENABLE); + denali_nand_timing_set(); + denali_irq_init(); +} + +/* + * Although controller spec said SLC ECC is forceb to be 4bit, but denali + * controller in MRST only support 15bit and 8bit ECC correction + */ +#ifdef CONFIG_SYS_NAND_15BIT_HW_ECC_OOBFIRST +#define ECC_15BITS 26 +static struct nand_ecclayout nand_15bit_oob = { + .eccbytes = ECC_15BITS, +}; +#else +#define ECC_8BITS 14 +static struct nand_ecclayout nand_8bit_oob = { + .eccbytes = ECC_8BITS, +}; +#endif /* CONFIG_SYS_NAND_15BIT_HW_ECC_OOBFIRST */ + +void denali_nand_init(struct nand_chip *nand) +{ + denali.flash_reg = (void __iomem *)CONFIG_SYS_NAND_REGS_BASE; + denali.flash_mem = (void __iomem *)CONFIG_SYS_NAND_DATA_BASE; + + nand->chip_delay = 0; +#ifdef CONFIG_SYS_NAND_USE_FLASH_BBT + /* + * check whether flash got BBT table (located at end of flash). As we + * use NAND_BBT_NO_OOB, the BBT page will start with + * bbt_pattern. We will have mirror pattern too + */ + nand->options |= NAND_BBT_USE_FLASH; + /* + * We are using main + spare with ECC support. As BBT need ECC support, + * we need to ensure BBT code don't write to OOB for the BBT pattern. + * All BBT info will be stored into data area with ECC support. + */ + nand->options |= NAND_BBT_NO_OOB; +#endif + + nand->ecc.mode = NAND_ECC_HW; + nand->ecc.size = CONFIG_NAND_DENALI_ECC_SIZE; + nand->ecc.read_oob = denali_read_oob; + nand->ecc.write_oob = denali_write_oob; + nand->ecc.read_page = denali_read_page; + nand->ecc.read_page_raw = denali_read_page_raw; + nand->ecc.write_page = denali_write_page; + nand->ecc.write_page_raw = denali_write_page_raw; +#ifdef CONFIG_SYS_NAND_15BIT_HW_ECC_OOBFIRST + /* 15bit ECC */ + nand->ecc.bytes = 26; + nand->ecc.layout = &nand_15bit_oob; +#else /* 8bit ECC */ + nand->ecc.bytes = 14; + nand->ecc.layout = &nand_8bit_oob; +#endif + nand->ecc.calculate = denali_ecc_calculate; + nand->ecc.correct = denali_ecc_correct; + nand->ecc.hwctl = denali_ecc_hwctl; + + /* Set address of hardware control function */ + nand->cmdfunc = denali_cmdfunc; + nand->read_byte = denali_read_byte; + nand->read_buf = denali_read_buf; + nand->select_chip = denali_select_chip; + nand->waitfunc = denali_waitfunc; + denali_hw_init(); +} + +int board_nand_init(struct nand_chip *chip) +{ + puts("NAND: Denali NAND controller\n"); + denali_nand_init(chip); + return 0; +} diff --git a/drivers/mtd/nand/denali_nand.h b/drivers/mtd/nand/denali_nand.h new file mode 100644 index 0000000..b573f14 --- /dev/null +++ b/drivers/mtd/nand/denali_nand.h @@ -0,0 +1,501 @@ +/* + * Copyright (C) 2013-2014 Altera Corporation <www.altera.com> + * Copyright (C) 2009-2010, Intel Corporation and its suppliers. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +typedef int irqreturn_t; + +#define IRQ_HANDLED 1 +#define IRQ_NONE 0 + +#define DEVICE_RESET 0x0 +#define DEVICE_RESET__BANK0 0x0001 +#define DEVICE_RESET__BANK1 0x0002 +#define DEVICE_RESET__BANK2 0x0004 +#define DEVICE_RESET__BANK3 0x0008 + +#define TRANSFER_SPARE_REG 0x10 +#define TRANSFER_SPARE_REG__FLAG 0x0001 + +#define LOAD_WAIT_CNT 0x20 +#define LOAD_WAIT_CNT__VALUE 0xffff + +#define PROGRAM_WAIT_CNT 0x30 +#define PROGRAM_WAIT_CNT__VALUE 0xffff + +#define ERASE_WAIT_CNT 0x40 +#define ERASE_WAIT_CNT__VALUE 0xffff + +#define INT_MON_CYCCNT 0x50 +#define INT_MON_CYCCNT__VALUE 0xffff + +#define RB_PIN_ENABLED 0x60 +#define RB_PIN_ENABLED__BANK0 0x0001 +#define RB_PIN_ENABLED__BANK1 0x0002 +#define RB_PIN_ENABLED__BANK2 0x0004 +#define RB_PIN_ENABLED__BANK3 0x0008 + +#define MULTIPLANE_OPERATION 0x70 +#define MULTIPLANE_OPERATION__FLAG 0x0001 + +#define MULTIPLANE_READ_ENABLE 0x80 +#define MULTIPLANE_READ_ENABLE__FLAG 0x0001 + +#define COPYBACK_DISABLE 0x90 +#define COPYBACK_DISABLE__FLAG 0x0001 + +#define CACHE_WRITE_ENABLE 0xa0 +#define CACHE_WRITE_ENABLE__FLAG 0x0001 + +#define CACHE_READ_ENABLE 0xb0 +#define CACHE_READ_ENABLE__FLAG 0x0001 + +#define PREFETCH_MODE 0xc0 +#define PREFETCH_MODE__PREFETCH_EN 0x0001 +#define PREFETCH_MODE__PREFETCH_BURST_LENGTH 0xfff0 + +#define CHIP_ENABLE_DONT_CARE 0xd0 +#define CHIP_EN_DONT_CARE__FLAG 0x01 + +#define ECC_ENABLE 0xe0 +#define ECC_ENABLE__FLAG 0x0001 + +#define GLOBAL_INT_ENABLE 0xf0 +#define GLOBAL_INT_EN_FLAG 0x01 + +#define WE_2_RE 0x100 +#define WE_2_RE__VALUE 0x003f + +#define ADDR_2_DATA 0x110 +#define ADDR_2_DATA__VALUE 0x003f + +#define RE_2_WE 0x120 +#define RE_2_WE__VALUE 0x003f + +#define ACC_CLKS 0x130 +#define ACC_CLKS__VALUE 0x000f + +#define NUMBER_OF_PLANES 0x140 +#define NUMBER_OF_PLANES__VALUE 0x0007 + +#define PAGES_PER_BLOCK 0x150 +#define PAGES_PER_BLOCK__VALUE 0xffff + +#define DEVICE_WIDTH 0x160 +#define DEVICE_WIDTH__VALUE 0x0003 + +#define DEVICE_MAIN_AREA_SIZE 0x170 +#define DEVICE_MAIN_AREA_SIZE__VALUE 0xffff + +#define DEVICE_SPARE_AREA_SIZE 0x180 +#define DEVICE_SPARE_AREA_SIZE__VALUE 0xffff + +#define TWO_ROW_ADDR_CYCLES 0x190 +#define TWO_ROW_ADDR_CYCLES__FLAG 0x0001 + +#define MULTIPLANE_ADDR_RESTRICT 0x1a0 +#define MULTIPLANE_ADDR_RESTRICT__FLAG 0x0001 + +#define ECC_CORRECTION 0x1b0 +#define ECC_CORRECTION__VALUE 0x001f + +#define READ_MODE 0x1c0 +#define READ_MODE__VALUE 0x000f + +#define WRITE_MODE 0x1d0 +#define WRITE_MODE__VALUE 0x000f + +#define COPYBACK_MODE 0x1e0 +#define COPYBACK_MODE__VALUE 0x000f + +#define RDWR_EN_LO_CNT 0x1f0 +#define RDWR_EN_LO_CNT__VALUE 0x001f + +#define RDWR_EN_HI_CNT 0x200 +#define RDWR_EN_HI_CNT__VALUE 0x001f + +#define MAX_RD_DELAY 0x210 +#define MAX_RD_DELAY__VALUE 0x000f + +#define CS_SETUP_CNT 0x220 +#define CS_SETUP_CNT__VALUE 0x001f + +#define SPARE_AREA_SKIP_BYTES 0x230 +#define SPARE_AREA_SKIP_BYTES__VALUE 0x003f + +#define SPARE_AREA_MARKER 0x240 +#define SPARE_AREA_MARKER__VALUE 0xffff + +#define DEVICES_CONNECTED 0x250 +#define DEVICES_CONNECTED__VALUE 0x0007 + +#define DIE_MASK 0x260 +#define DIE_MASK__VALUE 0x00ff + +#define FIRST_BLOCK_OF_NEXT_PLANE 0x270 +#define FIRST_BLOCK_OF_NEXT_PLANE__VALUE 0xffff + +#define WRITE_PROTECT 0x280 +#define WRITE_PROTECT__FLAG 0x0001 + +#define RE_2_RE 0x290 +#define RE_2_RE__VALUE 0x003f + +#define MANUFACTURER_ID 0x300 +#define MANUFACTURER_ID__VALUE 0x00ff + +#define DEVICE_ID 0x310 +#define DEVICE_ID__VALUE 0x00ff + +#define DEVICE_PARAM_0 0x320 +#define DEVICE_PARAM_0__VALUE 0x00ff + +#define DEVICE_PARAM_1 0x330 +#define DEVICE_PARAM_1__VALUE 0x00ff + +#define DEVICE_PARAM_2 0x340 +#define DEVICE_PARAM_2__VALUE 0x00ff + +#define LOGICAL_PAGE_DATA_SIZE 0x350 +#define LOGICAL_PAGE_DATA_SIZE__VALUE 0xffff + +#define LOGICAL_PAGE_SPARE_SIZE 0x360 +#define LOGICAL_PAGE_SPARE_SIZE__VALUE 0xffff + +#define REVISION 0x370 +#define REVISION__VALUE 0xffff + +#define ONFI_DEVICE_FEATURES 0x380 +#define ONFI_DEVICE_FEATURES__VALUE 0x003f + +#define ONFI_OPTIONAL_COMMANDS 0x390 +#define ONFI_OPTIONAL_COMMANDS__VALUE 0x003f + +#define ONFI_TIMING_MODE 0x3a0 +#define ONFI_TIMING_MODE__VALUE 0x003f + +#define ONFI_PGM_CACHE_TIMING_MODE 0x3b0 +#define ONFI_PGM_CACHE_TIMING_MODE__VALUE 0x003f + +#define ONFI_DEVICE_NO_OF_LUNS 0x3c0 +#define ONFI_DEVICE_NO_OF_LUNS__NO_OF_LUNS 0x00ff +#define ONFI_DEVICE_NO_OF_LUNS__ONFI_DEVICE 0x0100 + +#define ONFI_DEVICE_NO_OF_BLOCKS_PER_LUN_L 0x3d0 +#define ONFI_DEVICE_NO_OF_BLOCKS_PER_LUN_L__VALUE 0xffff + +#define ONFI_DEVICE_NO_OF_BLOCKS_PER_LUN_U 0x3e0 +#define ONFI_DEVICE_NO_OF_BLOCKS_PER_LUN_U__VALUE 0xffff + +#define FEATURES 0x3f0 +#define FEATURES__N_BANKS 0x0003 +#define FEATURES__ECC_MAX_ERR 0x003c +#define FEATURES__DMA 0x0040 +#define FEATURES__CMD_DMA 0x0080 +#define FEATURES__PARTITION 0x0100 +#define FEATURES__XDMA_SIDEBAND 0x0200 +#define FEATURES__GPREG 0x0400 +#define FEATURES__INDEX_ADDR 0x0800 + +#define TRANSFER_MODE 0x400 +#define TRANSFER_MODE__VALUE 0x0003 + +#define INTR_STATUS(__bank) (0x410 + ((__bank) * 0x50)) +#define INTR_EN(__bank) (0x420 + ((__bank) * 0x50)) + +/* + * Some versions of the IP have the ECC fixup handled in hardware. In this + * configuration we only get interrupted when the error is uncorrectable. + * Unfortunately this bit replaces INTR_STATUS__ECC_TRANSACTION_DONE from the + * old IP. + */ +#define INTR_STATUS__ECC_UNCOR_ERR 0x0001 +#define INTR_STATUS__ECC_TRANSACTION_DONE 0x0001 +#define INTR_STATUS__ECC_ERR 0x0002 +#define INTR_STATUS__DMA_CMD_COMP 0x0004 +#define INTR_STATUS__TIME_OUT 0x0008 +#define INTR_STATUS__PROGRAM_FAIL 0x0010 +#define INTR_STATUS__ERASE_FAIL 0x0020 +#define INTR_STATUS__LOAD_COMP 0x0040 +#define INTR_STATUS__PROGRAM_COMP 0x0080 +#define INTR_STATUS__ERASE_COMP 0x0100 +#define INTR_STATUS__PIPE_CPYBCK_CMD_COMP 0x0200 +#define INTR_STATUS__LOCKED_BLK 0x0400 +#define INTR_STATUS__UNSUP_CMD 0x0800 +#define INTR_STATUS__INT_ACT 0x1000 +#define INTR_STATUS__RST_COMP 0x2000 +#define INTR_STATUS__PIPE_CMD_ERR 0x4000 +#define INTR_STATUS__PAGE_XFER_INC 0x8000 + +#define INTR_EN__ECC_TRANSACTION_DONE 0x0001 +#define INTR_EN__ECC_ERR 0x0002 +#define INTR_EN__DMA_CMD_COMP 0x0004 +#define INTR_EN__TIME_OUT 0x0008 +#define INTR_EN__PROGRAM_FAIL 0x0010 +#define INTR_EN__ERASE_FAIL 0x0020 +#define INTR_EN__LOAD_COMP 0x0040 +#define INTR_EN__PROGRAM_COMP 0x0080 +#define INTR_EN__ERASE_COMP 0x0100 +#define INTR_EN__PIPE_CPYBCK_CMD_COMP 0x0200 +#define INTR_EN__LOCKED_BLK 0x0400 +#define INTR_EN__UNSUP_CMD 0x0800 +#define INTR_EN__INT_ACT 0x1000 +#define INTR_EN__RST_COMP 0x2000 +#define INTR_EN__PIPE_CMD_ERR 0x4000 +#define INTR_EN__PAGE_XFER_INC 0x8000 + +#define PAGE_CNT(__bank) (0x430 + ((__bank) * 0x50)) +#define ERR_PAGE_ADDR(__bank) (0x440 + ((__bank) * 0x50)) +#define ERR_BLOCK_ADDR(__bank) (0x450 + ((__bank) * 0x50)) + +#define DATA_INTR 0x550 +#define DATA_INTR__WRITE_SPACE_AV 0x0001 +#define DATA_INTR__READ_DATA_AV 0x0002 + +#define DATA_INTR_EN 0x560 +#define DATA_INTR_EN__WRITE_SPACE_AV 0x0001 +#define DATA_INTR_EN__READ_DATA_AV 0x0002 + +#define GPREG_0 0x570 +#define GPREG_0__VALUE 0xffff + +#define GPREG_1 0x580 +#define GPREG_1__VALUE 0xffff + +#define GPREG_2 0x590 +#define GPREG_2__VALUE 0xffff + +#define GPREG_3 0x5a0 +#define GPREG_3__VALUE 0xffff + +#define ECC_THRESHOLD 0x600 +#define ECC_THRESHOLD__VALUE 0x03ff + +#define ECC_ERROR_BLOCK_ADDRESS 0x610 +#define ECC_ERROR_BLOCK_ADDRESS__VALUE 0xffff + +#define ECC_ERROR_PAGE_ADDRESS 0x620 +#define ECC_ERROR_PAGE_ADDRESS__VALUE 0x0fff +#define ECC_ERROR_PAGE_ADDRESS__BANK 0xf000 + +#define ECC_ERROR_ADDRESS 0x630 +#define ECC_ERROR_ADDRESS__OFFSET 0x0fff +#define ECC_ERROR_ADDRESS__SECTOR_NR 0xf000 + +#define ERR_CORRECTION_INFO 0x640 +#define ERR_CORRECTION_INFO__BYTEMASK 0x00ff +#define ERR_CORRECTION_INFO__DEVICE_NR 0x0f00 +#define ERR_CORRECTION_INFO__ERROR_TYPE 0x4000 +#define ERR_CORRECTION_INFO__LAST_ERR_INFO 0x8000 + +#define DMA_ENABLE 0x700 +#define DMA_ENABLE__FLAG 0x0001 + +#define IGNORE_ECC_DONE 0x710 +#define IGNORE_ECC_DONE__FLAG 0x0001 + +#define DMA_INTR 0x720 +#define DMA_INTR__TARGET_ERROR 0x0001 +#define DMA_INTR__DESC_COMP_CHANNEL0 0x0002 +#define DMA_INTR__DESC_COMP_CHANNEL1 0x0004 +#define DMA_INTR__DESC_COMP_CHANNEL2 0x0008 +#define DMA_INTR__DESC_COMP_CHANNEL3 0x0010 +#define DMA_INTR__MEMCOPY_DESC_COMP 0x0020 + +#define DMA_INTR_EN 0x730 +#define DMA_INTR_EN__TARGET_ERROR 0x0001 +#define DMA_INTR_EN__DESC_COMP_CHANNEL0 0x0002 +#define DMA_INTR_EN__DESC_COMP_CHANNEL1 0x0004 +#define DMA_INTR_EN__DESC_COMP_CHANNEL2 0x0008 +#define DMA_INTR_EN__DESC_COMP_CHANNEL3 0x0010 +#define DMA_INTR_EN__MEMCOPY_DESC_COMP 0x0020 + +#define TARGET_ERR_ADDR_LO 0x740 +#define TARGET_ERR_ADDR_LO__VALUE 0xffff + +#define TARGET_ERR_ADDR_HI 0x750 +#define TARGET_ERR_ADDR_HI__VALUE 0xffff + +#define CHNL_ACTIVE 0x760 +#define CHNL_ACTIVE__CHANNEL0 0x0001 +#define CHNL_ACTIVE__CHANNEL1 0x0002 +#define CHNL_ACTIVE__CHANNEL2 0x0004 +#define CHNL_ACTIVE__CHANNEL3 0x0008 + +#define ACTIVE_SRC_ID 0x800 +#define ACTIVE_SRC_ID__VALUE 0x00ff + +#define PTN_INTR 0x810 +#define PTN_INTR__CONFIG_ERROR 0x0001 +#define PTN_INTR__ACCESS_ERROR_BANK0 0x0002 +#define PTN_INTR__ACCESS_ERROR_BANK1 0x0004 +#define PTN_INTR__ACCESS_ERROR_BANK2 0x0008 +#define PTN_INTR__ACCESS_ERROR_BANK3 0x0010 +#define PTN_INTR__REG_ACCESS_ERROR 0x0020 + +#define PTN_INTR_EN 0x820 +#define PTN_INTR_EN__CONFIG_ERROR 0x0001 +#define PTN_INTR_EN__ACCESS_ERROR_BANK0 0x0002 +#define PTN_INTR_EN__ACCESS_ERROR_BANK1 0x0004 +#define PTN_INTR_EN__ACCESS_ERROR_BANK2 0x0008 +#define PTN_INTR_EN__ACCESS_ERROR_BANK3 0x0010 +#define PTN_INTR_EN__REG_ACCESS_ERROR 0x0020 + +#define PERM_SRC_ID(__bank) (0x830 + ((__bank) * 0x40)) +#define PERM_SRC_ID__SRCID 0x00ff +#define PERM_SRC_ID__DIRECT_ACCESS_ACTIVE 0x0800 +#define PERM_SRC_ID__WRITE_ACTIVE 0x2000 +#define PERM_SRC_ID__READ_ACTIVE 0x4000 +#define PERM_SRC_ID__PARTITION_VALID 0x8000 + +#define MIN_BLK_ADDR(__bank) (0x840 + ((__bank) * 0x40)) +#define MIN_BLK_ADDR__VALUE 0xffff + +#define MAX_BLK_ADDR(__bank) (0x850 + ((__bank) * 0x40)) +#define MAX_BLK_ADDR__VALUE 0xffff + +#define MIN_MAX_BANK(__bank) (0x860 + ((__bank) * 0x40)) +#define MIN_MAX_BANK__MIN_VALUE 0x0003 +#define MIN_MAX_BANK__MAX_VALUE 0x000c + + +/* ffsdefs.h */ +#define CLEAR 0 /*use this to clear a field instead of "fail"*/ +#define SET 1 /*use this to set a field instead of "pass"*/ +#define FAIL 1 /*failed flag*/ +#define PASS 0 /*success flag*/ +#define ERR -1 /*error flag*/ + +/* lld.h */ +#define GOOD_BLOCK 0 +#define DEFECTIVE_BLOCK 1 +#define READ_ERROR 2 + +#define CLK_X 5 +#define CLK_MULTI 4 + +/* spectraswconfig.h */ +#define CMD_DMA 0 + +#define SPECTRA_PARTITION_ID 0 +/**** Block Table and Reserved Block Parameters *****/ +#define SPECTRA_START_BLOCK 3 +#define NUM_FREE_BLOCKS_GATE 30 + +/* KBV - Updated to LNW scratch register address */ +#define SCRATCH_REG_ADDR CONFIG_MTD_NAND_DENALI_SCRATCH_REG_ADDR +#define SCRATCH_REG_SIZE 64 + +#define GLOB_HWCTL_DEFAULT_BLKS 2048 + +#define SUPPORT_15BITECC 1 +#define SUPPORT_8BITECC 1 + +#define CUSTOM_CONF_PARAMS 0 + +#define ONFI_BLOOM_TIME 1 +#define MODE5_WORKAROUND 0 + +/* lld_nand.h */ +/* + * NAND Flash Controller Device Driver + * Copyright (c) 2009, Intel Corporation and its suppliers. + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License along with + * this program; if not, write to the Free Software Foundation, Inc., + * 51 Franklin St - Fifth Floor, Boston, MA 02110-1301 USA. + * + */ + +#ifndef _LLD_NAND_ +#define _LLD_NAND_ + +#define MODE_00 0x00000000 +#define MODE_01 0x04000000 +#define MODE_10 0x08000000 +#define MODE_11 0x0C000000 + + +#define DATA_TRANSFER_MODE 0 +#define PROTECTION_PER_BLOCK 1 +#define LOAD_WAIT_COUNT 2 +#define PROGRAM_WAIT_COUNT 3 +#define ERASE_WAIT_COUNT 4 +#define INT_MONITOR_CYCLE_COUNT 5 +#define READ_BUSY_PIN_ENABLED 6 +#define MULTIPLANE_OPERATION_SUPPORT 7 +#define PRE_FETCH_MODE 8 +#define CE_DONT_CARE_SUPPORT 9 +#define COPYBACK_SUPPORT 10 +#define CACHE_WRITE_SUPPORT 11 +#define CACHE_READ_SUPPORT 12 +#define NUM_PAGES_IN_BLOCK 13 +#define ECC_ENABLE_SELECT 14 +#define WRITE_ENABLE_2_READ_ENABLE 15 +#define ADDRESS_2_DATA 16 +#define READ_ENABLE_2_WRITE_ENABLE 17 +#define TWO_ROW_ADDRESS_CYCLES 18 +#define MULTIPLANE_ADDRESS_RESTRICT 19 +#define ACC_CLOCKS 20 +#define READ_WRITE_ENABLE_LOW_COUNT 21 +#define READ_WRITE_ENABLE_HIGH_COUNT 22 + +#define ECC_SECTOR_SIZE 512 + +#define DENALI_BUF_SIZE (NAND_MAX_PAGESIZE + NAND_MAX_OOBSIZE) + +struct nand_buf { + int head; + int tail; + /* seprating dma_buf as buf can be used for status read purpose */ + uint8_t dma_buf[DENALI_BUF_SIZE] __aligned(64); + uint8_t buf[DENALI_BUF_SIZE]; +}; + +#define INTEL_CE4100 1 +#define INTEL_MRST 2 +#define DT 3 + +struct denali_nand_info { + struct mtd_info mtd; + struct nand_chip *nand; + + int flash_bank; /* currently selected chip */ + int status; + int platform; + struct nand_buf buf; + struct device *dev; + int total_used_banks; + uint32_t block; /* stored for future use */ + uint32_t page; + void __iomem *flash_reg; /* Mapped io reg base address */ + void __iomem *flash_mem; /* Mapped io reg base address */ + + /* elements used by ISR */ + /*struct completion complete;*/ + + uint32_t irq_status; + int irq_debug_array[32]; + int idx; + int irq; + + uint32_t devnum; /* represent how many nands connected */ + uint32_t fwblks; /* represent how many blocks FW used */ + uint32_t totalblks; + uint32_t blksperchip; + uint32_t bbtskipbytes; + uint32_t max_banks; +}; + +#endif /*_LLD_NAND_*/
Changes for v3
Changes for v2
Sorry, didn't see this when I replied to v2. Some of those comments still apply, though.
- This macro divides two integers and rounds fractional values up
- to the nearest integer value.
How is this different from DIV_ROUND_UP(), other than being more complicated?
-Scott
Changes for v3
Changes for v2
Yup, fixed
All change to use DIV_ROUND_UP as no need to duplicate
Thanks
Chin Liang
-Scott
Chin Liang See
Scott Wood
