[PATCH] net: ravb: Add additional refclk
The ethernet requires an external reference clock, and the driver currently assumes the clock is always running. For devices using a programmable clock, this may not be true. Add an optional clock called 'refclk' to open and enable the refclk for hardware running with programmable clocks.
Signed-off-by: Adam Ford aford173@gmail.com --- This was also done in the Linux kernel, see: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/dr...
diff --git a/drivers/net/ravb.c b/drivers/net/ravb.c index 6953b7286a..ced80485de 100644 --- a/drivers/net/ravb.c +++ b/drivers/net/ravb.c @@ -130,6 +130,7 @@ struct ravb_priv { struct mii_dev *bus; void __iomem *iobase; struct clk clk; + struct clk *refclk; struct gpio_desc reset_gpio; };
@@ -489,6 +490,8 @@ static int ravb_probe(struct udevice *dev) if (ret < 0) goto err_mdio_alloc;
+ eth->refclk = devm_clk_get_optional(dev, "refclk"); + ret = dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, &phandle_args); if (!ret) { gpio_request_by_name_nodev(phandle_args.node, "reset-gpios", 0, @@ -522,6 +525,10 @@ static int ravb_probe(struct udevice *dev) if (ret) goto err_mdio_register;
+ ret = clk_enable(eth->refclk); + if (ret) + goto err_disable_clk; + ret = ravb_reset(dev); if (ret) goto err_mdio_reset; @@ -533,6 +540,8 @@ static int ravb_probe(struct udevice *dev) return 0;
err_mdio_reset: + clk_disable(eth->refclk); +err_disable_clk: clk_disable(ð->clk); err_mdio_register: mdio_free(mdiodev); @@ -545,6 +554,7 @@ static int ravb_remove(struct udevice *dev) { struct ravb_priv *eth = dev_get_priv(dev);
+ clk_disable(eth->refclk); clk_disable(ð->clk);
free(eth->phydev);
if (ret)
err_mdio_reset:
clk_disable(eth->refclk); clk_disable(ð->clk); free(eth->phydev);
-- 2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Adam Ford
Ramon Fried
