[U-Boot] [PATCH v3 1/6] drivers: Add OSD uclass
Some devices offer a text-based OSD (on-screen display) that can be programmatically controlled (i.e. text displayed on).
Add a uclass to support such devices.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Mario Six mario.six@gdsys.cc
v2 -> v3: None
v1 -> v2: * Use singular case for UCLASS_VIDEO_OSD description * Expanded description of video_osd_set_mem with example * Replaced all left-over mentions of pixels with text * Renamed x and y parameters to col and row * Expaneded description of color parameter * Added general description of the OSD uclass * Expanded description of video_osd_info
--- drivers/video/Kconfig | 8 ++ drivers/video/Makefile | 2 +- drivers/video/video_osd-uclass.c | 45 +++++++++ include/dm/uclass-id.h | 1 + include/video_osd.h | 192 +++++++++++++++++++++++++++++++++++++++ 5 files changed, 247 insertions(+), 1 deletion(-) create mode 100644 drivers/video/video_osd-uclass.c create mode 100644 include/video_osd.h
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 5ee9032dc9..dfd7b87add 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -667,4 +667,12 @@ config VIDEO_DT_SIMPLEFB The video output is initialized by U-Boot, and kept by the kernel.
+config OSD + bool "Enable OSD support" + depends on DM + default n + help + This supports drivers that provide a OSD (on-screen display), which + is a (usually text-oriented) graphics buffer to show information on + a display. endmenu diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 7c89c67dce..f1523fda7b 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -24,7 +24,7 @@ obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o obj-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o obj-$(CONFIG_CFB_CONSOLE) += cfb_console.o obj-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o -obj-$(CONFIG_VIDEO_FSL_DCU_FB) += fsl_dcu_fb.o videomodes.o +obj-$(CONFIG_OSD) += video_osd-uclass.o obj-$(CONFIG_PXA_LCD) += pxa_lcd.o obj-$(CONFIG_SCF0403_LCD) += scf0403_lcd.o obj-$(CONFIG_S6E8AX0) += s6e8ax0.o diff --git a/drivers/video/video_osd-uclass.c b/drivers/video/video_osd-uclass.c new file mode 100644 index 0000000000..82136a292b --- /dev/null +++ b/drivers/video/video_osd-uclass.c @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2017 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + */ + +#include <common.h> +#include <dm.h> +#include <video_osd.h> + +int video_osd_get_info(struct udevice *dev, struct video_osd_info *info) +{ + struct video_osd_ops *ops = video_osd_get_ops(dev); + + return ops->get_info(dev, info); +} + +int video_osd_set_mem(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count) +{ + struct video_osd_ops *ops = video_osd_get_ops(dev); + + return ops->set_mem(dev, col, row, buf, buflen, count); +} + +int video_osd_set_size(struct udevice *dev, uint col, uint row) +{ + struct video_osd_ops *ops = video_osd_get_ops(dev); + + return ops->set_size(dev, col, row); +} + +int video_osd_print(struct udevice *dev, uint col, uint row, ulong color, + char *text) +{ + struct video_osd_ops *ops = video_osd_get_ops(dev); + + return ops->print(dev, col, row, color, text); +} + +UCLASS_DRIVER(video_osd) = { + .id = UCLASS_VIDEO_OSD, + .name = "video_osd", + .flags = DM_UC_FLAG_SEQ_ALIAS, +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index d7f9df3583..e42f8481bf 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -89,6 +89,7 @@ enum uclass_id { UCLASS_VIDEO, /* Video or LCD device */ UCLASS_VIDEO_BRIDGE, /* Video bridge, e.g. DisplayPort to LVDS */ UCLASS_VIDEO_CONSOLE, /* Text console driver for video device */ + UCLASS_VIDEO_OSD, /* On-screen display */ UCLASS_WDT, /* Watchdot Timer driver */
UCLASS_COUNT, diff --git a/include/video_osd.h b/include/video_osd.h new file mode 100644 index 0000000000..01ac94b425 --- /dev/null +++ b/include/video_osd.h @@ -0,0 +1,192 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2017 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + */ + +#ifndef _VIDEO_OSD_H_ +#define _VIDEO_OSD_H_ + +struct video_osd_info { + /* The width of the OSD display in columns */ + uint width; + /* The height of the OSD display in rows */ + uint height; + /* The major version of the OSD device */ + uint major_version; + /* The minor version of the OSD device */ + uint minor_version; +}; + +/** + * struct video_osd_ops - driver operations for OSD uclass + * + * The OSD uclass implements support for text-oriented on-screen displays, + * which are taken to be devices that independently display a graphical + * text-based overlay over the video output of an associated display. + * + * The functions defined by the uclass support writing text to the display in + * either a generic form (by specifying a string, a driver-specific color value + * for the text, and screen coordinates in rows and columns) or a + * driver-specific form (by specifying "raw" driver-specific data to display at + * a given coordinate). + * + * Functions to read device information and set the size of the virtual OSD + * screen (in rows and columns) are also supported. + * + * Drivers should support these operations unless otherwise noted. These + * operations are intended to be used by uclass code, not directly from + * other code. + */ +struct video_osd_ops { + /** + * get_info() - Get information about a OSD instance + * + * A OSD instance may keep some internal data about itself. This + * function can be used to access this data. + * + * @dev: OSD instance to query. + * @info: Pointer to a structure that takes the information read + * from the OSD instance. + * @return 0 if OK, -ve on error. + */ + int (*get_info)(struct udevice *dev, struct video_osd_info *info); + + /** + * set_mem() - Write driver-specific text data to OSD screen + * + * The passed data are device-specific, and it's up to the driver how + * to interpret them. How the count parameter is interpreted is also + * driver-specific; most likely the given data will be written to the + * OSD count times back-to-back, which is e.g. convenient for filling + * areas of the OSD with a single character. + * + * For example a invocation of + * + * video_osd_set_mem(dev, 0, 0, "A", 1, 10); + * + * will write the device-specific text data "A" to the positions (0, 0) + * to (9, 0) on the OSD. + * + * Device-specific text data may, e.g. be a special encoding of glyphs + * to display and color values in binary format. + * + * @dev: OSD instance to write to. + * @col: Horizontal character coordinate to write to. + * @row Vertical character coordinate to write to. + * @buf: Array containing device-specific data to write to the + * specified coordinate on the OSD screen. + * @buflen: Length of the data in the passed buffer (in byte). + * @count: Write count many repetitions of the given text data + * @return 0 if OK, -ve on error. + */ + int (*set_mem)(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count); + + /** + * set_size() - Set the position and dimension of the OSD's + * writeable window + * + * @dev: OSD instance to write to. + * @col The number of characters in the window's columns + * @row The number of characters in the window's rows + * @return 0 if OK, -ve on error. + */ + int (*set_size)(struct udevice *dev, uint col, uint row); + + /** + * print() - Print a string in a given color to specified coordinates + * on the OSD + * + * @dev: OSD instance to write to. + * @col The x-coordinate of the position the string should be + * written to + * @row The y-coordinate of the position the string should be + * written to + * @color: The color in which the specified string should be + * printed; the interpretation of the value is + * driver-specific, and possible values should be defined + * e.g. in a driver include file. + * @text: The string data that should be printed on the OSD + * @return 0 if OK, -ve on error. + */ + int (*print)(struct udevice *dev, uint col, uint row, ulong color, + char *text); +}; + +#define video_osd_get_ops(dev) ((struct video_osd_ops *)(dev)->driver->ops) + +/** + * video_osd_get_info() - Get information about a OSD instance + * + * A OSD instance may keep some internal data about itself. This function can + * be used to access this data. + * + * @dev: OSD instance to query. + * @info: Pointer to a structure that takes the information read from the + * OSD instance. + * @return 0 if OK, -ve on error. + */ +int video_osd_get_info(struct udevice *dev, struct video_osd_info *info); + +/** + * video_osd_set_mem() - Write text data to OSD memory + * + * The passed data are device-specific, and it's up to the driver how to + * interpret them. How the count parameter is interpreted is also + * driver-specific; most likely the given data will be written to the OSD count + * times back-to-back, which is e.g. convenient for filling areas of the OSD + * with a single character. + * + * For example a invocation of + * + * video_osd_set_mem(dev, 0, 0, "A", 1, 10); + * + * will write the device-specific text data "A" to the positions (0, 0) to (9, + * 0) on the OSD. + * + * Device-specific text data may, e.g. be a special encoding of glyphs to + * display and color values in binary format. + * + * @dev: OSD instance to write to. + * @col: Horizontal character coordinate to write to. + * @row Vertical character coordinate to write to. + * @buf: Array containing device-specific data to write to the specified + * coordinate on the OSD screen. + * @buflen: Length of the data in the passed buffer (in byte). + * @count: Write count many repetitions of the given text data + * @return 0 if OK, -ve on error. + */ +int video_osd_set_mem(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count); + +/** + * video_osd_set_size() - Set the position and dimension of the OSD's + * writeable window + * + * @dev: OSD instance to write to. + * @col The number of characters in the window's columns + * @row The number of characters in the window's rows + * @return 0 if OK, -ve on error. + */ +int video_osd_set_size(struct udevice *dev, uint col, uint row); + +/** + * video_osd_print() - Print a string in a given color to specified coordinates + * on the OSD + * + * @dev: OSD instance to write to. + * @col The x-coordinate of the position the string should be written + * to + * @row The y-coordinate of the position the string should be written + * to + * @color: The color in which the specified string should be printed; the + * interpretation of the value is driver-specific, and possible + * values should be defined e.g. in a driver include file. + * @text: The string data that should be printed on the OSD + * @return 0 if OK, -ve on error. + */ +int video_osd_print(struct udevice *dev, uint col, uint row, ulong color, + char *text); + +#endif /* !_VIDEO_OSD_H_ */ -- 2.11.0
Add a driver for IHS OSDs on IHS FPGAs.
v2 -> v3: * Replace dev_read_prop with dev_read_string * Fixed binding file * Improved error handling and reporting * Use static const variables instead of #defines * Use named constant for some magic values * Improved documentation
v1 -> v2: * Renamed x and y parameters to col and row * Removed duplicate IHS_VIDEO_OUT definition * Switched error return code of ihs_video_out_set_mem to E2BIG * Dropped blank lines between dev_read_u32_default calls * Documented members of ihs_video_out_priv * Turned printfs into debugs * Don't display OSD until something has been written to it * Made the code a bit more readable * Added binding file * Expanded documentation and help * Switched to display_enable * Switched to regmap usage (instead of fpgamap uclass) * Renamed 'dp_tx' property to 'video_tx'
--- .../video/osd/gdsys,ihs_video_out.txt | 23 ++ drivers/video/Kconfig | 9 + drivers/video/Makefile | 1 + drivers/video/ihs_video_out.c | 341 +++++++++++++++++++++ 4 files changed, 374 insertions(+) create mode 100644 doc/device-tree-bindings/video/osd/gdsys,ihs_video_out.txt create mode 100644 drivers/video/ihs_video_out.c
diff --git a/doc/device-tree-bindings/video/osd/gdsys,ihs_video_out.txt b/doc/device-tree-bindings/video/osd/gdsys,ihs_video_out.txt new file mode 100644 index 0000000000..d7aacc827e --- /dev/null +++ b/doc/device-tree-bindings/video/osd/gdsys,ihs_video_out.txt @@ -0,0 +1,23 @@ +* Guntermann & Drunck Integrated Hardware Systems OSD + +Required properties: +- compatible: "gdsys,ihs_video_out" +- reg: A combination of three register spaces: + - Register base for the video registers + - Register base for the OSD registers + - Address of the OSD video memory +- mode: The initial resolution and frequency: "1024_768_60", "720_400_70", or + "640_480_70" +- clk_gen: phandle to the pixel clock generator +- dp_tx: phandle to the display associated with the OSD + +Example: + +fpga0_video0 { + compatible = "gdsys,ihs_video_out"; + reg = <0x100 0x40 + 0x180 0x20 + 0x1000 0x1000>; + dp_tx = <&fpga0_dp_video0>; + clk_gen = <&fpga0_video0_clkgen>; +}; diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index dfd7b87add..82abde79ca 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -675,4 +675,13 @@ config OSD This supports drivers that provide a OSD (on-screen display), which is a (usually text-oriented) graphics buffer to show information on a display. + +config IHS_VIDEO_OUT + bool "Enable IHS video out driver" + depends on OSD + help + Enable support for the gdsys Integrated Hardware Systems (IHS) video + out On-screen Display (OSD) used on gdsys FPGAs to control dynamic + textual overlays of the display outputs. + endmenu diff --git a/drivers/video/Makefile b/drivers/video/Makefile index f1523fda7b..a780efcffb 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -24,6 +24,7 @@ obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o obj-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o obj-$(CONFIG_CFB_CONSOLE) += cfb_console.o obj-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o +obj-$(CONFIG_IHS_VIDEO_OUT) += ihs_video_out.o obj-$(CONFIG_OSD) += video_osd-uclass.o obj-$(CONFIG_PXA_LCD) += pxa_lcd.o obj-$(CONFIG_SCF0403_LCD) += scf0403_lcd.o diff --git a/drivers/video/ihs_video_out.c b/drivers/video/ihs_video_out.c new file mode 100644 index 0000000000..5cdf17aec1 --- /dev/null +++ b/drivers/video/ihs_video_out.c @@ -0,0 +1,341 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2017 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + * + * based on the gdsys osd driver, which is + * + * (C) Copyright 2010 + * Dirk Eibach, Guntermann & Drunck GmbH, dirk.eibach@gdsys.de + */ + +#include <common.h> +#include <display.h> +#include <dm.h> +#include <regmap.h> +#include <video_osd.h> +#include <asm/gpio.h> + +static const uint MAX_X_CHARS = 53; +static const uint MAX_Y_CHARS = 26; +static const uint MAX_VIDEOMEM_WIDTH = 64; +static const uint MAX_VIDEOMEM_HEIGHT = 32; +static const uint CHAR_WIDTH = 12; +static const uint CHAR_HEIGHT = 18; + +static const u16 BASE_WIDTH_MASK = 0x3f00; +static const uint BASE_WIDTH_SHIFT = 8; +static const u16 BASE_HEIGTH_MASK = 0x001f; +static const uint BASE_HEIGTH_SHIFT; + +struct ihs_video_out_regs { + /* Device version register */ + u16 versions; + /* Device feature register */ + u16 features; + /* Device control register */ + u16 control; + /* Register controlling screen size */ + u16 xy_size; + /* Register controlling screen scaling */ + u16 xy_scale; + /* Register controlling screen x position */ + u16 x_pos; + /* Register controlling screen y position */ + u16 y_pos; +}; + +#define ihs_video_out_set(map, member, val) \ + regmap_range_set(map, 1, struct ihs_video_out_regs, member, val) + +#define ihs_video_out_get(map, member, valp) \ + regmap_range_get(map, 1, struct ihs_video_out_regs, member, valp) + +enum { + CONTROL_FILTER_BLACK = (0 << 0), + CONTROL_FILTER_ORIGINAL = (1 << 0), + CONTROL_FILTER_DARKER = (2 << 0), + CONTROL_FILTER_GRAY = (3 << 0), + + CONTROL_MODE_PASSTHROUGH = (0 << 3), + CONTROL_MODE_OSD = (1 << 3), + CONTROL_MODE_AUTO = (2 << 3), + CONTROL_MODE_OFF = (3 << 3), + + CONTROL_ENABLE_OFF = (0 << 6), + CONTROL_ENABLE_ON = (1 << 6), +}; + +struct ihs_video_out_priv { + /* Register map for OSD device */ + struct regmap *map; + /* Pointer to video memory */ + u16 *vidmem; + /* Display width in text columns */ + uint base_width; + /* Display height in text rows */ + uint base_height; + /* x-resolution of the display in pixels */ + uint res_x; + /* y-resolution of the display in pixels */ + uint res_y; + /* OSD's sync mode (resolution + frequency) */ + int sync_src; + /* The display port output for this OSD */ + struct udevice *video_tx; + /* The pixel clock generator for the display */ + struct udevice *clk_gen; +}; + +static const struct udevice_id ihs_video_out_ids[] = { + { .compatible = "gdsys,ihs_video_out" }, + { } +}; + +/** + * set_control() - Set the control register to a given value + * + * The current value of sync_src is preserved by the function automatically. + * + * @dev: the OSD device whose control register to set + * @value: the 16-bit value to write to the control register + * Return: 0 + */ +static int set_control(struct udevice *dev, u16 value) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + + if (priv->sync_src) + value |= ((priv->sync_src & 0x7) << 8); + + ihs_video_out_set(priv->map, control, value); + + return 0; +} + +int ihs_video_out_get_info(struct udevice *dev, struct video_osd_info *info) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + u16 versions; + + ihs_video_out_get(priv->map, versions, &versions); + + info->width = priv->base_width; + info->height = priv->base_height; + info->major_version = versions / 100; + info->minor_version = versions % 100; + + return 0; +} + +int ihs_video_out_set_mem(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + int res; + uint offset; + uint k, rep; + u16 data; + + /* Repetitions (controlled via count parmeter) */ + for (rep = 0; rep < count; ++rep) { + offset = row * priv->base_width + col + rep * (buflen / 2); + + /* Write a single buffer copy */ + for (k = 0; k < buflen / 2; ++k) { + uint max_size = priv->base_width * priv->base_height; + + if (offset + k >= max_size) { + debug("%s: Write would be out of OSD bounds\n", + dev->name); + return -E2BIG; + } + + data = buf[2 * k + 1] + 256 * buf[2 * k]; + out_le16(priv->vidmem + offset + k, data); + } + } + + res = set_control(dev, CONTROL_FILTER_ORIGINAL | + CONTROL_MODE_OSD | + CONTROL_ENABLE_ON); + if (res) { + debug("%s: Could not set control register\n", dev->name); + return res; + } + + return 0; +} + +/** + * div2_u16() - Approximately divide a 16-bit number by 2 + * + * @val: The 16-bit value to divide by two + * Return: The approximate division of val by two + */ +static inline u16 div2_u16(u16 val) +{ + return (32767 * val) / 65535; +} + +int ihs_video_out_set_size(struct udevice *dev, uint col, uint row) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + + if (!col || col > MAX_VIDEOMEM_WIDTH || col > MAX_X_CHARS || + !row || row > MAX_VIDEOMEM_HEIGHT || row > MAX_Y_CHARS) { + debug("%s: Desired OSD size invalid\n", dev->name); + return -EINVAL; + } + + ihs_video_out_set(priv->map, xy_size, ((col - 1) << 8) | (row - 1)); + /* Center OSD on screen */ + ihs_video_out_set(priv->map, x_pos, + div2_u16(priv->res_x - CHAR_WIDTH * col)); + ihs_video_out_set(priv->map, y_pos, + div2_u16(priv->res_y - CHAR_HEIGHT * row)); + + return 0; +} + +int ihs_video_out_print(struct udevice *dev, uint col, uint row, ulong color, + char *text) +{ + int res; + u8 buffer[2 * MAX_VIDEOMEM_WIDTH]; + uint k; + uint charcount = strlen(text); + uint len = min(charcount, 2 * MAX_VIDEOMEM_WIDTH); + + for (k = 0; k < len; ++k) { + buffer[2 * k] = text[k]; + buffer[2 * k + 1] = color; + } + + res = ihs_video_out_set_mem(dev, col, row, buffer, 2 * len, 1); + if (res < 0) { + debug("%s: Could not write to video memory\n", dev->name); + return res; + } + + return 0; +} + +static const struct video_osd_ops ihs_video_out_ops = { + .get_info = ihs_video_out_get_info, + .set_mem = ihs_video_out_set_mem, + .set_size = ihs_video_out_set_size, + .print = ihs_video_out_print, +}; + +int ihs_video_out_probe(struct udevice *dev) +{ + struct ihs_video_out_priv *priv = dev_get_priv(dev); + struct ofnode_phandle_args phandle_args; + const char *mode; + u16 features; + struct display_timing timing; + int res; + + res = regmap_init_mem(dev_ofnode(dev), &priv->map); + if (!res) { + debug("%s: Could initialize regmap (err = %d)\n", dev->name, + res); + return res; + } + + /* Range with index 2 is video memory */ + priv->vidmem = regmap_get_range(priv->map, 2); + + mode = dev_read_string(dev, "mode"); + if (!mode) { + debug("%s: Could not read mode property\n", dev->name); + return -EINVAL; + } + + if (!strcmp(mode, "1024_768_60")) { + priv->sync_src = 2; + priv->res_x = 1024; + priv->res_y = 768; + timing.hactive.typ = 1024; + timing.vactive.typ = 768; + } else if (!strcmp(mode, "720_400_70")) { + priv->sync_src = 1; + priv->res_x = 720; + priv->res_y = 400; + timing.hactive.typ = 720; + timing.vactive.typ = 400; + } else { + priv->sync_src = 0; + priv->res_x = 640; + priv->res_y = 480; + timing.hactive.typ = 640; + timing.vactive.typ = 480; + } + + ihs_video_out_get(priv->map, features, &features); + + res = set_control(dev, CONTROL_FILTER_ORIGINAL | + CONTROL_MODE_OSD | + CONTROL_ENABLE_OFF); + if (res) { + debug("%s: Could not set control register (err = %d)\n", + dev->name, res); + return res; + } + + priv->base_width = ((features & BASE_WIDTH_MASK) + >> BASE_WIDTH_SHIFT) + 1; + priv->base_height = ((features & BASE_HEIGTH_MASK) + >> BASE_HEIGTH_SHIFT) + 1; + + res = dev_read_phandle_with_args(dev, "clk_gen", NULL, 0, 0, + &phandle_args); + if (res) { + debug("%s: Could not get clk_gen node (err = %d)\n", + dev->name, res); + return -EINVAL; + } + + res = uclass_get_device_by_ofnode(UCLASS_CLK, phandle_args.node, + &priv->clk_gen); + if (res) { + debug("%s: Could not get clk_gen dev (err = %d)\n", + dev->name, res); + return -EINVAL; + } + + res = dev_read_phandle_with_args(dev, "video_tx", NULL, 0, 0, + &phandle_args); + if (res) { + debug("%s: Could not get video_tx (err = %d)\n", + dev->name, res); + return -EINVAL; + } + + res = uclass_get_device_by_ofnode(UCLASS_DISPLAY, phandle_args.node, + &priv->video_tx); + if (res) { + debug("%s: Could not get video_tx dev (err = %d)\n", + dev->name, res); + return -EINVAL; + } + + res = display_enable(priv->video_tx, 8, &timing); + if (res) { + debug("%s: Could not enable the display (err = %d)\n", + dev->name, res); + return res; + } + + return 0; +} + +U_BOOT_DRIVER(ihs_video_out_drv) = { + .name = "ihs_video_out_drv", + .id = UCLASS_VIDEO_OSD, + .ops = &ihs_video_out_ops, + .of_match = ihs_video_out_ids, + .probe = ihs_video_out_probe, + .priv_auto_alloc_size = sizeof(struct ihs_video_out_priv), +}; -- 2.11.0
On Tue, 26 Jun 2018 13:28:50 +0200 Mario Six mario.six@gdsys.cc wrote: ...
Applied to u-boot-video/master, rebased Makefile changes. Thanks!
-- Anatolij
Add sandbox driver and tests for the new OSD uclass.
v2 -> v3: * Fixed style violations * Removed sandbox_osd_get_mem from the uclass and moved it into the driver
v1 -> v2: New in v2
--- arch/sandbox/dts/test.dts | 5 + arch/sandbox/include/asm/test.h | 8 ++ configs/sandbox64_defconfig | 3 + configs/sandbox_defconfig | 3 + configs/sandbox_flattree_defconfig | 3 + configs/sandbox_noblk_defconfig | 3 + configs/sandbox_spl_defconfig | 3 + drivers/video/Kconfig | 6 ++ drivers/video/Makefile | 1 + drivers/video/sandbox_osd.c | 161 ++++++++++++++++++++++++++++ drivers/video/sandbox_osd.h | 13 +++ test/dm/Makefile | 1 + test/dm/osd.c | 210 +++++++++++++++++++++++++++++++++++++ 13 files changed, 420 insertions(+) create mode 100644 drivers/video/sandbox_osd.c create mode 100644 drivers/video/sandbox_osd.h create mode 100644 test/dm/osd.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 5752bf547e..ed5fcea00f 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -34,6 +34,7 @@ usb0 = &usb_0; usb1 = &usb_1; usb2 = &usb_2; + video_osd0 = "/osd"; };
a-test { @@ -563,6 +564,10 @@ }; }; }; + + osd { + compatible = "sandbox,sandbox_osd"; + }; };
#include "sandbox_pmic.dtsi" diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index 08863bf3a9..278d58ca7c 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -78,4 +78,12 @@ long sandbox_i2c_rtc_get_set_base_time(struct udevice *dev, long base_time);
int sandbox_usb_keyb_add_string(struct udevice *dev, const char *str);
+/** + * sandbox_osd_get_mem() - get the internal memory of a sandbox OSD + * + * @dev: OSD device for which to access the internal memory for + * @buf: pointer to buffer to receive the OSD memory data + * @buflen: length of buffer in bytes + */ +int sandbox_osd_get_mem(struct udevice *dev, u8 *buf, size_t buflen); #endif diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 20a2ab3ffb..7464a3ca3a 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_READ=y CONFIG_CMD_REMOTEPROC=y @@ -185,6 +186,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_WDT=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 2fc84a16c9..f7925dfe6f 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_GPT_RENAME=y CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_READ=y CONFIG_CMD_REMOTEPROC=y @@ -186,6 +187,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_WDT=y CONFIG_WDT_SANDBOX=y CONFIG_FS_CBFS=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index e922c4b38f..126b9c07c5 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_DEMO=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SF=y @@ -167,6 +168,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_CMD_DHRYSTONE=y CONFIG_TPM=y CONFIG_LZ4=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index 8bdd4edcda..243234b6c7 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SF=y @@ -166,6 +167,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_FS_CBFS=y CONFIG_FS_CRAMFS=y CONFIG_CMD_DHRYSTONE=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index fb6bb4baa2..771d0f05a4 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y CONFIG_CMD_PCI=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_SF=y @@ -185,6 +186,8 @@ CONFIG_CONSOLE_ROTATION=y CONFIG_CONSOLE_TRUETYPE=y CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y CONFIG_FS_CBFS=y CONFIG_FS_CRAMFS=y CONFIG_CMD_DHRYSTONE=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 82abde79ca..65756ce2a4 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -676,6 +676,12 @@ config OSD is a (usually text-oriented) graphics buffer to show information on a display.
+config SANDBOX_OSD + bool "Enable sandbox OSD" + depends on OSD + help + Enable support for sandbox OSD device used for testing purposes. + config IHS_VIDEO_OUT bool "Enable IHS video out driver" depends on OSD diff --git a/drivers/video/Makefile b/drivers/video/Makefile index a780efcffb..dfe46fb21a 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -27,6 +27,7 @@ obj-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o obj-$(CONFIG_IHS_VIDEO_OUT) += ihs_video_out.o obj-$(CONFIG_OSD) += video_osd-uclass.o obj-$(CONFIG_PXA_LCD) += pxa_lcd.o +obj-$(CONFIG_SANDBOX_OSD) += sandbox_osd.o obj-$(CONFIG_SCF0403_LCD) += scf0403_lcd.o obj-$(CONFIG_S6E8AX0) += s6e8ax0.o obj-$(CONFIG_LD9040) += ld9040.o diff --git a/drivers/video/sandbox_osd.c b/drivers/video/sandbox_osd.c new file mode 100644 index 0000000000..dd84489add --- /dev/null +++ b/drivers/video/sandbox_osd.c @@ -0,0 +1,161 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + */ +#include <common.h> +#include <display.h> +#include <dm.h> +#include <video_osd.h> + +#include "sandbox_osd.h" + +struct sandbox_osd_priv { + uint width; + uint height; + u16 *buf; +}; + +static const struct udevice_id sandbox_osd_ids[] = { + { .compatible = "sandbox,sandbox_osd" }, + { } +}; + +inline u16 make_memval(u8 chr, u8 color) +{ + return chr * 0x100 + color; +} + +int sandbox_osd_get_info(struct udevice *dev, struct video_osd_info *info) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + + info->width = priv->width; + info->height = priv->height; + info->major_version = 1; + info->minor_version = 0; + + return 0; +} + +int sandbox_osd_set_mem(struct udevice *dev, uint col, uint row, u8 *buf, + size_t buflen, uint count) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + int pos; + u8 *mem = (u8 *)priv->buf; + int i; + + pos = 2 * (row * priv->width + col); + + if (pos >= 2 * (priv->width * priv->height)) + return -EINVAL; + + for (i = 0; i < count; i++) + memcpy(mem + pos + (i * buflen), buf, buflen); + + return 0; +} + +int _sandbox_osd_set_size(struct udevice *dev, uint col, uint row) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + int i; + uint size; + + priv->width = col; + priv->height = row; + size = priv->width * priv->height; + if (!priv->buf) + priv->buf = calloc(size, sizeof(u16)); + else + priv->buf = realloc(priv->buf, size * sizeof(u16)); + + if (!priv->buf) + return -ENOMEM; + + /* Fill OSD with black spaces */ + for (i = 0; i < size; i++) + priv->buf[i] = make_memval(' ', 'k'); + + return 0; +} + +int sandbox_osd_set_size(struct udevice *dev, uint col, uint row) +{ + return _sandbox_osd_set_size(dev, col, row); +} + +int sandbox_osd_print(struct udevice *dev, uint col, uint row, ulong color, + char *text) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + char cval; + char *p; + int pos; + + if (col >= priv->width || row >= priv->height) + return -EINVAL; + + switch (color) { + case COLOR_BLACK: + cval = 'k'; + break; + case COLOR_WHITE: + cval = 'w'; + break; + case COLOR_RED: + cval = 'r'; + break; + case COLOR_GREEN: + cval = 'g'; + break; + case COLOR_BLUE: + cval = 'b'; + break; + default: + return -EINVAL; + } + + p = text; + pos = row * priv->width + col; + + while (*p) + priv->buf[pos++] = make_memval(*(p++), cval); + + return 0; +} + +int sandbox_osd_get_mem(struct udevice *dev, u8 *buf, size_t buflen) +{ + struct sandbox_osd_priv *priv = dev_get_priv(dev); + uint memsize = 2 * (priv->width * priv->height); + + if (buflen < memsize) + return -EINVAL; + + memcpy(buf, priv->buf, memsize); + + return 0; +} + +static const struct video_osd_ops sandbox_osd_ops = { + .get_info = sandbox_osd_get_info, + .set_mem = sandbox_osd_set_mem, + .set_size = sandbox_osd_set_size, + .print = sandbox_osd_print, +}; + +int sandbox_osd_probe(struct udevice *dev) +{ + return _sandbox_osd_set_size(dev, 10, 10); +} + +U_BOOT_DRIVER(sandbox_osd_drv) = { + .name = "sandbox_osd_drv", + .id = UCLASS_VIDEO_OSD, + .ops = &sandbox_osd_ops, + .of_match = sandbox_osd_ids, + .probe = sandbox_osd_probe, + .priv_auto_alloc_size = sizeof(struct sandbox_osd_priv), +}; diff --git a/drivers/video/sandbox_osd.h b/drivers/video/sandbox_osd.h new file mode 100644 index 0000000000..15a2c91c52 --- /dev/null +++ b/drivers/video/sandbox_osd.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2018 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + */ + +enum { + COLOR_BLACK, + COLOR_WHITE, + COLOR_RED, + COLOR_GREEN, + COLOR_BLUE, +}; diff --git a/test/dm/Makefile b/test/dm/Makefile index 5511a85700..7b390e1d2a 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -22,6 +22,7 @@ obj-$(CONFIG_LED) += led.o obj-$(CONFIG_DM_MAILBOX) += mailbox.o obj-$(CONFIG_DM_MMC) += mmc.o obj-y += ofnode.o +obj-$(CONFIG_OSD) += osd.o obj-$(CONFIG_DM_PCI) += pci.o obj-$(CONFIG_PHY) += phy.o obj-$(CONFIG_POWER_DOMAIN) += power-domain.o diff --git a/test/dm/osd.c b/test/dm/osd.c new file mode 100644 index 0000000000..6910690b3a --- /dev/null +++ b/test/dm/osd.c @@ -0,0 +1,210 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + */ + +#include <common.h> +#include <display_options.h> +#include <dm.h> +#include <dm/test.h> +#include <test/ut.h> +#include <video_osd.h> +#include <asm/test.h> + +#include "../../drivers/video/sandbox_osd.h" + +const uint memsize = 2 * 10 * 10; + +static void split(u8 *mem, uint size, u8 *text, u8 *colors) +{ + int i; + u16 *p = (u16 *)mem; + + for (i = 0; i < size; i++) { + colors[i] = p[i] % 0x100; + text[i] = p[i] / 0x100; + } +} + +static void print_mem(u8 *mem, uint width, uint height) +{ + const uint memsize = 2 * 10 * 10; + u8 colors[memsize / 2]; + u8 text[memsize / 2]; + int i; + + split(mem, memsize / 2, text, colors); + + for (i = 0; i < width * height; i++) { + printf("%c", text[i]); + if (i > 0 && ((i + 1) % width) == 0) + printf("\n"); + } + + printf("\n"); + + for (i = 0; i < width * height; i++) { + printf("%c", colors[i]); + if (i > 0 && ((i + 1) % width) == 0) + printf("\n"); + } +} + +static int dm_test_osd_basics(struct unit_test_state *uts) +{ + struct udevice *dev; + u8 mem[memsize + 1]; + u8 colors[memsize / 2]; + u8 text[memsize / 2]; + struct video_osd_info info; + + ut_assertok(uclass_first_device_err(UCLASS_VIDEO_OSD, &dev)); + + video_osd_get_info(dev, &info); + + ut_asserteq(10, info.width); + ut_asserteq(10, info.height); + ut_asserteq(1, info.major_version); + ut_asserteq(0, info.minor_version); + + ut_assertok(sandbox_osd_get_mem(dev, mem, memsize)); + split(mem, memsize / 2, text, colors); + + ut_assertok(memcmp(text, " " + " " + " " + " " + " " + " " + " " + " " + " " + " ", memsize / 2)); + + ut_assertok(memcmp(colors, "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk", memsize / 2)); + + print_mem(mem, 10, 10); + + ut_assertok(video_osd_print(dev, 1, 1, COLOR_RED, "Blah")); + + ut_assertok(sandbox_osd_get_mem(dev, mem, memsize)); + split(mem, memsize / 2, text, colors); + + ut_assertok(memcmp(text, " " + " Blah " + " " + " " + " " + " " + " " + " " + " " + " ", memsize / 2)); + + ut_assertok(memcmp(colors, "kkkkkkkkkk" + "krrrrkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk" + "kkkkkkkkkk", memsize / 2)); + + print_mem(mem, 10, 10); + + return 0; +} + +DM_TEST(dm_test_osd_basics, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +static int dm_test_osd_extended(struct unit_test_state *uts) +{ + struct udevice *dev; + u8 mem[memsize + 1]; + u8 colors[memsize / 2]; + u8 text[memsize / 2]; + struct video_osd_info info; + u16 val; + + ut_assertok(uclass_first_device_err(UCLASS_VIDEO_OSD, &dev)); + + ut_assertok(video_osd_set_size(dev, 20, 5)); + + video_osd_get_info(dev, &info); + + ut_asserteq(20, info.width); + ut_asserteq(5, info.height); + ut_asserteq(1, info.major_version); + ut_asserteq(0, info.minor_version); + + ut_assertok(sandbox_osd_get_mem(dev, mem, memsize)); + split(mem, memsize / 2, text, colors); + + ut_assertok(memcmp(text, " " + " " + " " + " " + " ", memsize / 2)); + + ut_assertok(memcmp(colors, "kkkkkkkkkkkkkkkkkkkk" + "kkkkkkkkkkkkkkkkkkkk" + "kkkkkkkkkkkkkkkkkkkk" + "kkkkkkkkkkkkkkkkkkkk" + "kkkkkkkkkkkkkkkkkkkk", memsize / 2)); + + print_mem(mem, 20, 5); + + /* Draw green border */ + val = '-' * 0x100 + 'g'; + ut_assertok(video_osd_set_mem(dev, 1, 0, (u8 *)&val, 2, 18)); + ut_assertok(video_osd_set_mem(dev, 1, 4, (u8 *)&val, 2, 18)); + ut_assertok(video_osd_print(dev, 0, 1, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 0, 2, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 0, 3, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 19, 1, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 19, 2, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 19, 3, COLOR_GREEN, "|")); + ut_assertok(video_osd_print(dev, 0, 0, COLOR_GREEN, "+")); + ut_assertok(video_osd_print(dev, 19, 0, COLOR_GREEN, "+")); + ut_assertok(video_osd_print(dev, 19, 4, COLOR_GREEN, "+")); + ut_assertok(video_osd_print(dev, 0, 4, COLOR_GREEN, "+")); + + /* Add menu caption and entries */ + ut_assertok(video_osd_print(dev, 5, 0, COLOR_GREEN, " OSD menu ")); + ut_assertok(video_osd_print(dev, 2, 1, COLOR_BLUE, " * Entry 1")); + ut_assertok(video_osd_print(dev, 2, 2, COLOR_BLUE, "(*) Entry 2")); + ut_assertok(video_osd_print(dev, 2, 3, COLOR_BLUE, " * Entry 3")); + + ut_assertok(sandbox_osd_get_mem(dev, mem, memsize)); + split(mem, memsize / 2, text, colors); + + print_mem(mem, 20, 5); + + ut_assertok(memcmp(text, "+---- OSD menu ----+" + "| * Entry 1 |" + "| (*) Entry 2 |" + "| * Entry 3 |" + "+------------------+", memsize / 2)); + + ut_assertok(memcmp(colors, "gggggggggggggggggggg" + "gkbbbbbbbbbbbkkkkkkg" + "gkbbbbbbbbbbbkkkkkkg" + "gkbbbbbbbbbbbkkkkkkg" + "gggggggggggggggggggg", memsize / 2)); + + return 0; +} + +DM_TEST(dm_test_osd_extended, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); -- 2.11.0
v2 -> v3:
- Fixed style violations
- Removed sandbox_osd_get_mem from the uclass and moved it into the driver
v1 -> v2: New in v2
Add a unit test assert-method, which compares two given memory areas for byte-wise equality.
v2 -> v3: New in v3
--- include/test/ut.h | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/include/test/ut.h b/include/test/ut.h index 59b23a25a4..11d1b2d089 100644 --- a/include/test/ut.h +++ b/include/test/ut.h @@ -78,6 +78,24 @@ void ut_failf(struct unit_test_state *uts, const char *fname, int line, } \ }
+/* Assert that two memory areas are equal */ +#define ut_asserteq_mem(expr1, expr2, len) { \ + const u8 *val1 = (u8 *)(expr1), *val2 = (u8 *)(expr2); \ + const uint __len = len; \ + \ + if (memcmp(val1, val2, __len)) { \ + char __buf1[64 + 1] = "\0"; \ + char __buf2[64 + 1] = "\0"; \ + bin2hex(__buf1, val1, min(__len, (uint)32)); \ + bin2hex(__buf2, val2, min(__len, (uint)32)); \ + ut_failf(uts, __FILE__, __LINE__, __func__, \ + #expr1 " = " #expr2, \ + "Expected "%s", got "%s"", \ + __buf1, __buf2); \ + return CMD_RET_FAILURE; \ + } \ +} + /* Assert that two pointers are equal */ #define ut_asserteq_ptr(expr1, expr2) { \ const void *val1 = (expr1), *val2 = (expr2); \ -- 2.11.0
v2 -> v3: New in v3
Add tests for the hex2bin, bin2hex, and hex_to_bin functions, which were recently added to U-Boot.
v2 -> v3: New in v3
--- test/Makefile | 1 + test/lib/Makefile | 5 +++ test/lib/hexdump.c | 95 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 101 insertions(+) create mode 100644 test/lib/Makefile create mode 100644 test/lib/hexdump.c
diff --git a/test/Makefile b/test/Makefile index 1092011fdb..1468ca1baa 100644 --- a/test/Makefile +++ b/test/Makefile @@ -9,3 +9,4 @@ obj-$(CONFIG_SANDBOX) += compression.o obj-$(CONFIG_SANDBOX) += print_ut.o obj-$(CONFIG_UT_TIME) += time_ut.o obj-$(CONFIG_$(SPL_)LOG) += log/ +obj-$(CONFIG_UNIT_TEST) += lib/ diff --git a/test/lib/Makefile b/test/lib/Makefile new file mode 100644 index 0000000000..ea68fae566 --- /dev/null +++ b/test/lib/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2018 +# Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc +obj-y += hexdump.o diff --git a/test/lib/hexdump.c b/test/lib/hexdump.c new file mode 100644 index 0000000000..e8b3e566e0 --- /dev/null +++ b/test/lib/hexdump.c @@ -0,0 +1,95 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + */ + +#include <common.h> +#include <hexdump.h> +#include <dm/test.h> +#include <test/ut.h> + +static int lib_test_hex_to_bin(struct unit_test_state *uts) +{ + return 0; + + ut_asserteq(0x0, hex_to_bin('0')); + ut_asserteq(0x1, hex_to_bin('1')); + ut_asserteq(0x2, hex_to_bin('2')); + ut_asserteq(0x3, hex_to_bin('3')); + ut_asserteq(0x4, hex_to_bin('4')); + ut_asserteq(0x5, hex_to_bin('5')); + ut_asserteq(0x6, hex_to_bin('6')); + ut_asserteq(0x7, hex_to_bin('7')); + ut_asserteq(0x8, hex_to_bin('8')); + ut_asserteq(0x9, hex_to_bin('9')); + ut_asserteq(0xa, hex_to_bin('a')); + ut_asserteq(0xb, hex_to_bin('b')); + ut_asserteq(0xc, hex_to_bin('c')); + ut_asserteq(0xd, hex_to_bin('d')); + ut_asserteq(0xe, hex_to_bin('e')); + ut_asserteq(0xf, hex_to_bin('f')); + ut_asserteq(-1, hex_to_bin('g')); +} + +DM_TEST(lib_test_hex_to_bin, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +static int lib_test_hex2bin(struct unit_test_state *uts) +{ + u8 dst[4]; + + hex2bin(dst, "649421de", 4); + ut_asserteq_mem("\x64\x94\x21\xde", dst, 4); + hex2bin(dst, "aa2e7545", 4); + ut_asserteq_mem("\xaa\x2e\x75\x45", dst, 4); + hex2bin(dst, "75453bc5", 4); + ut_asserteq_mem("\x75\x45\x3b\xc5", dst, 4); + hex2bin(dst, "a16884c3", 4); + ut_asserteq_mem("\xa1\x68\x84\xc3", dst, 4); + hex2bin(dst, "156b2e5e", 4); + ut_asserteq_mem("\x15\x6b\x2e\x5e", dst, 4); + hex2bin(dst, "2e035fff", 4); + ut_asserteq_mem("\x2e\x03\x5f\xff", dst, 4); + hex2bin(dst, "0ffce99f", 4); + ut_asserteq_mem("\x0f\xfc\xe9\x9f", dst, 4); + hex2bin(dst, "d3999443", 4); + ut_asserteq_mem("\xd3\x99\x94\x43", dst, 4); + hex2bin(dst, "91dd87bc", 4); + ut_asserteq_mem("\x91\xdd\x87\xbc", dst, 4); + hex2bin(dst, "7fec8963", 4); + ut_asserteq_mem("\x7f\xec\x89\x63", dst, 4); + + return 0; +} + +DM_TEST(lib_test_hex2bin, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +static int lib_test_bin2hex(struct unit_test_state *uts) +{ + char dst[8 + 1] = "\0"; + + bin2hex(dst, "\x64\x94\x21\xde", 4); + ut_asserteq_str("649421de", dst); + bin2hex(dst, "\xaa\x2e\x75\x45", 4); + ut_asserteq_str("aa2e7545", dst); + bin2hex(dst, "\x75\x45\x3b\xc5", 4); + ut_asserteq_str("75453bc5", dst); + bin2hex(dst, "\xa1\x68\x84\xc3", 4); + ut_asserteq_str("a16884c3", dst); + bin2hex(dst, "\x15\x6b\x2e\x5e", 4); + ut_asserteq_str("156b2e5e", dst); + bin2hex(dst, "\x2e\x03\x5f\xff", 4); + ut_asserteq_str("2e035fff", dst); + bin2hex(dst, "\x0f\xfc\xe9\x9f", 4); + ut_asserteq_str("0ffce99f", dst); + bin2hex(dst, "\xd3\x99\x94\x43", 4); + ut_asserteq_str("d3999443", dst); + bin2hex(dst, "\x91\xdd\x87\xbc", 4); + ut_asserteq_str("91dd87bc", dst); + bin2hex(dst, "\x7f\xec\x89\x63", 4); + ut_asserteq_str("7fec8963", dst); + + return 0; +} + +DM_TEST(lib_test_bin2hex, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); -- 2.11.0
v2 -> v3: New in v3
Add command to query information from and write text to on-screen display (OSD) devices.
v2 -> v3: * Fixed style violations * Moved gdsys legacy OSD cmds to their own file * Made sure allocated buffer is always freed * Improved error handling * Improved documentation
v1 -> v2: * Added explanation for what a OSD is * Added explanation of the color parameter * Moved GDSYS_LEGACY_OSD_CMDS to gdsys Kconfig
--- board/gdsys/common/Makefile | 2 + board/gdsys/common/osd_cmd.c | 146 ++++++++++++++++++++++ board/gdsys/mpc8308/Kconfig | 11 ++ cmd/Kconfig | 8 ++ cmd/Makefile | 1 + cmd/osd.c | 291 +++++++++++++++++++++++++++++++++++++++++++ 6 files changed, 459 insertions(+) create mode 100644 board/gdsys/common/osd_cmd.c create mode 100644 cmd/osd.c
diff --git a/board/gdsys/common/Makefile b/board/gdsys/common/Makefile index 698ea3b02b..61a137a504 100644 --- a/board/gdsys/common/Makefile +++ b/board/gdsys/common/Makefile @@ -15,3 +15,5 @@ obj-$(CONFIG_STRIDER) += mclink.o dp501.o phy.o ioep-fpga.o adv7611.o ch7301.o obj-$(CONFIG_STRIDER) += fanctrl.o obj-$(CONFIG_STRIDER_CON) += osd.o obj-$(CONFIG_STRIDER_CON_DP) += osd.o + +obj-$(CONFIG_GDSYS_LEGACY_OSD_CMDS) += osd_cmd.o diff --git a/board/gdsys/common/osd_cmd.c b/board/gdsys/common/osd_cmd.c new file mode 100644 index 0000000000..53179b9811 --- /dev/null +++ b/board/gdsys/common/osd_cmd.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2017 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + * + * based on the gdsys osd driver, which is + * + * (C) Copyright 2010 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + */ + +#include <common.h> +#include <dm.h> +#include <hexdump.h> +#include <video_osd.h> +#include <malloc.h> + +static int do_osd_write(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + struct udevice *dev; + uint x, y; + uint count; + char *hexstr; + u8 *buffer; + size_t buflen; + int res; + + if (argc < 4 || (strlen(argv[3])) % 2) + return CMD_RET_USAGE; + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + hexstr = argv[3]; + count = (argc > 4) ? simple_strtoul(argv[4], NULL, 16) : 1; + + buflen = strlen(hexstr) / 2; + + buffer = malloc(buflen); + if (!buffer) { + puts("Memory allocation failure\n"); + return CMD_RET_FAILURE; + } + + res = hex2bin(buffer, hexstr, buflen); + if (res) { + free(buffer); + puts("Hexadecimal input contained invalid characters\n"); + return CMD_RET_FAILURE; + } + + for (uclass_first_device(UCLASS_VIDEO_OSD, &dev); + dev; + uclass_next_device(&dev)) { + int res; + + res = video_osd_set_mem(dev, x, y, buffer, buflen, count); + if (res) { + free(buffer); + printf("Could not write to video mem on osd %s\n", + dev->name); + return CMD_RET_FAILURE; + } + } + + free(buffer); + + return CMD_RET_SUCCESS; +} + +static int do_osd_print(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + struct udevice *dev; + uint x, y; + u8 color; + char *text; + + if (argc < 5) + return CMD_RET_USAGE; + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + color = simple_strtoul(argv[3], NULL, 16); + text = argv[4]; + + for (uclass_first_device(UCLASS_VIDEO_OSD, &dev); + dev; + uclass_next_device(&dev)) { + int res; + + res = video_osd_print(dev, x, y, color, text); + if (res) { + printf("Could not print string to osd %s\n", dev->name); + return CMD_RET_FAILURE; + } + } + + return CMD_RET_SUCCESS; +} + +static int do_osd_size(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + struct udevice *dev; + uint x, y; + + if (argc < 3) + return CMD_RET_USAGE; + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + + for (uclass_first_device(UCLASS_VIDEO_OSD, &dev); + dev; + uclass_next_device(&dev)) { + int res; + + res = video_osd_set_size(dev, x, y); + + if (res) { + printf("Could not set size on osd %s\n", dev->name); + return CMD_RET_FAILURE; + } + } + + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD( + osdw, 5, 0, do_osd_write, + "write 16-bit hex encoded buffer to osd memory", + "osdw [pos_x] [pos_y] [buffer] [count] - write 8-bit hex encoded buffer to osd memory\n" +); + +U_BOOT_CMD( + osdp, 5, 0, do_osd_print, + "write ASCII buffer to osd memory", + "osdp [pos_x] [pos_y] [color] [text] - write ASCII buffer to osd memory\n" +); + +U_BOOT_CMD( + osdsize, 3, 0, do_osd_size, + "set OSD XY size in characters", + "osdsize [size_x] [size_y] - set OSD XY size in characters\n" +); diff --git a/board/gdsys/mpc8308/Kconfig b/board/gdsys/mpc8308/Kconfig index cb29c25c65..9d99f68692 100644 --- a/board/gdsys/mpc8308/Kconfig +++ b/board/gdsys/mpc8308/Kconfig @@ -1,3 +1,9 @@ +config GDSYS_LEGACY_OSD_CMDS + bool + help + Use the 'osdw', 'osdp', and 'osdsize' legacy commands required by + gdsys devices. + if TARGET_HRCON
config SYS_BOARD @@ -9,6 +15,9 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "hrcon"
+config GDSYS_LEGACY_OSD_CMDS + default y + endif
if TARGET_STRIDER @@ -22,6 +31,8 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "strider"
+config GDSYS_LEGACY_OSD_CMDS + default y endif
config CMD_IOLOOP diff --git a/cmd/Kconfig b/cmd/Kconfig index 45c83359ad..3f6bfdc556 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -897,6 +897,14 @@ config CMD_ONENAND and erasing blocks. It allso provides a way to show and change bad blocks, and test the device.
+config CMD_OSD + bool "osd" + help + Enable the 'osd' command which allows to query information from and + write text data to a on-screen display (OSD) device; a virtual device + associated with a display capable of displaying a text overlay on the + display it's associated with.. + config CMD_PART bool "part" select PARTITION_UUIDS diff --git a/cmd/Makefile b/cmd/Makefile index 13cf7bf6c2..8796a5b88a 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -63,6 +63,7 @@ obj-$(CONFIG_CMD_FUSE) += fuse.o obj-$(CONFIG_CMD_GETTIME) += gettime.o obj-$(CONFIG_CMD_GPIO) += gpio.o obj-$(CONFIG_CMD_HVC) += smccc.o +obj-$(CONFIG_CMD_OSD) += osd.o obj-$(CONFIG_CMD_I2C) += i2c.o obj-$(CONFIG_CMD_IOTRACE) += iotrace.o obj-$(CONFIG_CMD_HASH) += hash.o diff --git a/cmd/osd.c b/cmd/osd.c new file mode 100644 index 0000000000..0b1fa49936 --- /dev/null +++ b/cmd/osd.c @@ -0,0 +1,291 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2017 + * Mario Six, Guntermann & Drunck GmbH, mario.six@gdsys.cc + * + * based on the gdsys osd driver, which is + * + * (C) Copyright 2010 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + */ + +#include <common.h> +#include <dm.h> +#include <hexdump.h> +#include <video_osd.h> +#include <malloc.h> + +/* Container for selected OSD device */ +static struct udevice *osd_cur; + +/** + * cmd_osd_set_osd_num() - Set the OSD selected for operation + * + * Set the OSD device, which will be used by all subsequent OSD commands. + * + * Devices are identified by their uclass sequence number (as listed by 'osd + * show'). + * + * @osdnum: The OSD device to be selected, identified by its sequence number. + * Return: 0 if OK, -ve on error + */ +static int cmd_osd_set_osd_num(unsigned int osdnum) +{ + struct udevice *osd; + int res; + + res = uclass_get_device_by_seq(UCLASS_VIDEO_OSD, osdnum, &osd); + if (res) { + printf("%s: No OSD %u (err = %d)\n", __func__, osdnum, res); + return res; + } + osd_cur = osd; + + return 0; +} + +/** + * osd_get_osd_cur() - Get the selected OSD device + * + * Get the OSD device that is used by all OSD commands. + * + * @osdp: Pointer to structure that will receive the currently selected OSD + * device. + * Return: 0 if OK, -ve on error + */ +static int osd_get_osd_cur(struct udevice **osdp) +{ + if (!osd_cur) { + puts("No osd selected\n"); + return -ENODEV; + } + *osdp = osd_cur; + + return 0; +} + +/** + * show_osd() - Display information about a OSD device + * + * Display a device's ID (sequence number), and whether it is active (i.e. + * probed) or not. + * + * @osd: OSD device to print information for + */ +static void show_osd(struct udevice *osd) +{ + printf("OSD %d:\t%s", osd->req_seq, osd->name); + if (device_active(osd)) + printf(" (active %d)", osd->seq); + printf("\n"); +} + +static int do_osd_write(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + uint x, y; + uint count; + char *hexstr; + u8 *buffer; + size_t buflen; + int res; + + if (argc < 4 || (strlen(argv[3]) % 2)) + return CMD_RET_USAGE; + + if (!osd_cur) { + puts("No osd selected\n"); + return CMD_RET_FAILURE; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + hexstr = argv[3]; + count = (argc > 4) ? simple_strtoul(argv[4], NULL, 16) : 1; + + buflen = strlen(hexstr) / 2; + + buffer = malloc(buflen); + if (!buffer) { + puts("Memory allocation failure\n"); + return CMD_RET_FAILURE; + } + + res = hex2bin(buffer, hexstr, buflen); + if (res) { + free(buffer); + puts("Hexadecimal input contained invalid characters\n"); + return CMD_RET_FAILURE; + } + + res = video_osd_set_mem(osd_cur, x, y, buffer, buflen, count); + if (res) { + free(buffer); + printf("%s: Could not write to video mem\n", + osd_cur->name); + return CMD_RET_FAILURE; + } + + free(buffer); + + return CMD_RET_SUCCESS; +} + +static int do_osd_print(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + uint x, y; + u8 color; + char *text; + int res; + + if (argc < 5) + return CMD_RET_USAGE; + + if (!osd_cur) { + puts("No osd selected\n"); + return CMD_RET_FAILURE; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + color = simple_strtoul(argv[3], NULL, 16); + text = argv[4]; + + res = video_osd_print(osd_cur, x, y, color, text); + if (res) { + printf("Could not print string to osd %s\n", osd_cur->name); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static int do_osd_size(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + uint x, y; + int res; + + if (argc < 3) + return CMD_RET_USAGE; + + if (!osd_cur) { + puts("No osd selected\n"); + return CMD_RET_FAILURE; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + + res = video_osd_set_size(osd_cur, x, y); + if (res) { + printf("Could not set size on osd %s\n", osd_cur->name); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static int do_show_osd(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + struct udevice *osd; + + if (argc == 1) { + /* show all OSDs */ + struct uclass *uc; + int res; + + res = uclass_get(UCLASS_VIDEO_OSD, &uc); + if (res) { + printf("Error while getting OSD uclass (err=%d)\n", + res); + return CMD_RET_FAILURE; + } + + uclass_foreach_dev(osd, uc) + show_osd(osd); + } else { + int i, res; + + /* show specific OSD */ + i = simple_strtoul(argv[1], NULL, 10); + + res = uclass_get_device_by_seq(UCLASS_VIDEO_OSD, i, &osd); + if (res) { + printf("Invalid osd %d: err=%d\n", i, res); + return CMD_RET_FAILURE; + } + show_osd(osd); + } + + return CMD_RET_SUCCESS; +} + +static int do_osd_num(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + int osd_no; + int res = 0; + + if (argc == 1) { + /* querying current setting */ + struct udevice *osd; + + if (!osd_get_osd_cur(&osd)) + osd_no = osd->seq; + else + osd_no = -1; + printf("Current osd is %d\n", osd_no); + } else { + osd_no = simple_strtoul(argv[1], NULL, 10); + printf("Setting osd to %d\n", osd_no); + + res = cmd_osd_set_osd_num(osd_no); + if (res) + printf("Failure changing osd number (err = %d)\n", res); + } + + return res ? CMD_RET_FAILURE : CMD_RET_SUCCESS; +} + +static cmd_tbl_t cmd_osd_sub[] = { + U_BOOT_CMD_MKENT(show, 1, 1, do_show_osd, "", ""), + U_BOOT_CMD_MKENT(dev, 1, 1, do_osd_num, "", ""), + U_BOOT_CMD_MKENT(write, 4, 1, do_osd_write, "", ""), + U_BOOT_CMD_MKENT(print, 4, 1, do_osd_print, "", ""), + U_BOOT_CMD_MKENT(size, 2, 1, do_osd_size, "", ""), +}; + +static int do_osd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + cmd_tbl_t *c; + + if (argc < 2) + return CMD_RET_USAGE; + + /* Strip off leading 'osd' command argument */ + argc--; + argv++; + + c = find_cmd_tbl(argv[0], &cmd_osd_sub[0], ARRAY_SIZE(cmd_osd_sub)); + + if (c) + return c->cmd(cmdtp, flag, argc, argv); + else + return CMD_RET_USAGE; +} + +static char osd_help_text[] = + "show - show OSD info\n" + "osd dev [dev] - show or set current OSD\n" + "write [pos_x] [pos_y] [buffer] [count] - write 8-bit hex encoded buffer to osd memory at a given position\n" + "print [pos_x] [pos_y] [color] [text] - write ASCII buffer (given by text data and driver-specific color information) to osd memory\n" + "size [size_x] [size_y] - set OSD XY size in characters\n"; + +U_BOOT_CMD( + osd, 6, 1, do_osd, + "OSD sub-system", + osd_help_text +); -- 2.11.0
v2 -> v3:
- Moved gdsys legacy OSD cmds to their own file
- Made sure allocated buffer is always freed
- Improved error handling
- Improved documentation
v1 -> v2:
- Added explanation for what a OSD is
- Added explanation of the color parameter
- Moved GDSYS_LEGACY_OSD_CMDS to gdsys Kconfig
Hi Mario,
On Tue, 26 Jun 2018 13:28:49 +0200 Mario Six mario.six@gdsys.cc wrote: ...
Applied to u-boot-video/master after fixing Makefile changes.
This line shouldn't be removed. Fixed when applying.
-- Anatolij
Hi Anatolij, On Wed, Aug 1, 2018 at 6:56 PM Anatolij Gustschin agust@denx.de wrote:
Hi Mario,
-- Anatolij
Was there another issue with the series that I missed? It looks like it wasn't applied to u-boot-video/master.
Best regards, Mario
Hi Mario,
On Wed, 26 Sep 2018 15:45:57 +0200 Mario Six mario.six@gdsys.cc wrote: ...
After applying, build-testing didn't work due to some Travis-CI issues, so I stopped the tests and never got to it since then, sorry.
I've applied the rebased series again and fixed osd0 alias, but there are some other build issues [1] (it seems the patch 6/6 is not needed?). Could you please check? Thanks!
[1] https://travis-ci.org/vdsao/u-boot-video/jobs/433775307
-- Anatolij
On Thu, 27 Sep 2018 08:40:58 +0200 Anatolij Gustschin agust@denx.de wrote: ...
The rebased series is here:
http://git.denx.de/?p=u-boot/u-boot-video.git;a=shortlog;h=refs/heads/osd-ne...
-- Anatolij
Hi Anatolij,
Thanks, and I found the issue (I had the legacy commands Kconfig setting logic wrong).
Expect a v4 soon.
-- Anatolij
Best regards, Mario
Anatolij Gustschin
Mario Six
